The **OFFICIAL** DENON AVR-4520CI thread - Page 256 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #7651 of 13593 Old 04-15-2014, 04:51 PM
jdsmoothie's Avatar
Quoted: 12584 Post(s)
Liked: 5757
Originally Posted by nexusdoan View Post
Hope you guys can help me with this one.
My 4520 intermitently dispays green flicker (via the TV) with the Audio stopped when I connect my ios to it via Airplay.
This only happens with Airplay.
Usually indicative of a bad HDMI cable. Try replacing the cable from the AVR to the TV or swapping to another input on the TV.
jdsmoothie is online now
post #7652 of 13593 Old 04-15-2014, 04:52 PM
howard68's Avatar
Quoted: 151 Post(s)
Does anyone know what type of lawyer
I need to Get, as the only one have spoken to so far are only interested if the amp has injured me!
I am fed up with this and will be contacting BBB now.
howard68 is offline
post #7653 of 13593 Old 04-15-2014, 05:07 PM
jdsmoothie's Avatar
Liked: 5757
Originally Posted by ellisr63 View Post
Accessories4less is an Authorized Dealer... That is where I bought mine. If I would have known that I could get it for almost the same price from AVS... I would have bought it here instead, and got a BNIB one though.
Not to mention the full 3 year warranty. Only a couple of more weeks at reduced MSRP ..... eek.gif
post #7654 of 13593 Old 04-15-2014, 05:23 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 412
A lawyer is going to cost you more than the 4520.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #7655 of 13593 Old 04-15-2014, 05:47 PM
JohnAV's Avatar
Quoted: 312 Post(s)
Liked: 469
What can I say
After months of fighting with Denon
They finally replace my amp
With a faulty refurbished one!!!!
I have bought denon for the last 25 years
I am so upset it is beyond words
If you get a 4520ci that works they are amazing
However pray It will not stop working
Or you have a $2000 paperweight
Very bad business
How is the refurbished 4520 faulty? Just wondering? Is it exhibiting a similar problem to your original issue?
Did this get sent to a authorized service center or one of their super service centers?
Oppo Beta Group
JohnAV is offline
post #7656 of 13593 Old 04-15-2014, 06:30 PM
howard68's Avatar
Quoted: 151 Post(s)
The amp will not output any bass information to left and right speakers
I have done extensive tests
I know what this amp sounds like when it works
I have changed out speakers
Tested them on a different amp to be fine
All previous problems have been solved with this refurbished amp
Only to get new problems
The calibration set up wants to recognise my full range speakers as small
Have turned audussey off completely and done manual settings for crossovers
Nothing makes the speakers give out bass info
It is like it is stuck at 80 hertz
I have spoken to Denon and they now are not returning my calls or email. This refurbished amp has not been serviced since i have had it and noticed these priblems
howard68 is offline
post #7657 of 13593 Old 04-15-2014, 06:45 PM
OzHDHT's Avatar
Quoted: 820 Post(s)
Liked: 440
You do know in an ideal Audyssey set up, you would want to manually set your full range (front) speakers to small right anyway? More importantly though than that is what crossover Audyssey is setting for your Front speakers? If it's way up high like 120-150Hz, then you more than likely have a speaker based issue. I had an issue recently all due to the bass compensation setting in my fronts being set to wrong mode for my room. You probably want to check speaker placements if you haven't already and mic position - which is of course crucial for correct measurement. Lastly, just make sure there isn't anything obviously wrong with your room that could be throwing off the automated measurements.
OzHDHT is offline
post #7658 of 13593 Old 04-15-2014, 06:48 PM
Weary Enthusiast
WHATTHEDILEO's Avatar
Quoted: 56 Post(s)
Liked: 52
I just got my unit repaired - as predicted by some Denon experts here, the board connectors were poorly attached (prior to the repair).
https://www.flickr.com/photos/47274578@N05/13884791983/
WHATTHEDILEO
Some people LOVE MUSIC.
Some people LOVE the SOUND of music.
If you don't know the difference, then you LIKE MUSIC.
My slow-cooking 11.4 channel Theater Room quest
WHATTHEDILEO is offline
post #7659 of 13593 Old 04-15-2014, 07:03 PM
howard68's Avatar
Quoted: 151 Post(s)
I have split the same cd with every processing thing turned off and in pure stereo mode no sub , and played two right tracks one with 4520ci and one with an old denon amp, the woofer did not move on the 4520ci, the other amp and speaker played bass from pink floyd
I have extensive set up in the same room when i had the old 4520ci and the sound is not the same
In manual set up with the crossover set to full range the woofer should move
Have done the same test with a old LP
Same deck same speakers different amp
One plays bass information one will not
howard68 is offline
post #7660 of 13593 Old 04-15-2014, 08:34 PM
Kamikaze_Ice's Avatar
Quoted: 133 Post(s)
Liked: 70
I've tried searching for my answer but had no luck, so I'm just gonna ask here now.
What is the difference between the Listening/Surround Modes (Movie, Music & Game)?
For example, what makes DTS Neo: X in Movie mode different from DTS Neo: X in Game mode?
I understand one is for movies, and the other for games, but exactly is the difference? With the delay in switching modes, I can't trust my ears/brain (not that they were trustworthy to begin with :P)
I can kind of tell the difference between Music and the other two, just slightly on how sound pans/transitions between speakers. But then again it could be a placebo, so I'd like to find out.
Kamikaze_Ice is offline
post #7661 of 13593 Old 04-16-2014, 03:26 AM
jdsmoothie's Avatar
Liked: 5757
Movie mode tends to focus the dialogue more towards the center speaker while Music mode focuses it towards the FL/FR speakers and AFAIK, Game mode is supposed to emphasize the surrounds a little more, but doubt that anyone really uses that mode.
post #7662 of 13593 Old 04-16-2014, 07:42 AM
tknx's Avatar
Quoted: 34 Post(s)
HI everyone,
I have searched through threads and haven't figured out what I am doing wrong. I bought some wireless outdoor speakers for use on my balcony. The speakers and wirelss transmitter work fine if I plug it into my iPhone.
If I plug it into the Zone 2 pre-outs using an RCA to mini cable, I can't get anything to work. I am playing off an analog source and I hit the Zone 2 button to have it say "ZONE 2 ON" but nothing. Is there something basic I am missing?
Denon X4300H | Salk Veracity ST | SVS SB13 Ultra | Neeo Remote (pending)
tknx is offline
post #7663 of 13593 Old 04-16-2014, 07:51 AM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 87
I noticed it can be finicky with source selection for Zone 2. Once in a while I had to switch the source and then switch back.
See My System Here
Processor: Emotiva XMC-1
R/C/L Amps... (3) Emotiva XPR-1's (1750w x 3 = 5250w)
Surround Amps: Emotiva XPA-5 G2 (200 x 4 = 800w) not using 5th
Zone 2: Emotiva Mini-X a-100 driving 2 Boston Acoustics Voyager 70's
10050 watts total power.
mhrischuk is offline
post #7664 of 13593 Old 04-16-2014, 11:39 AM
jdsmoothie's Avatar
Liked: 5757
Originally Posted by tknx View Post
HI everyone,
When trying to troubleshoot a Zone 2 source, the first step is to get it working in the main zone. Once accomplished, and knowing that the source is connected with an analog cable, the issue would not likely be either the source or the AVR.
post #7665 of 13593 Old 04-16-2014, 03:18 PM
avgorder's Avatar
Is there any way I can stream music from my phone to the avr ? I want to stream music from google music.
Denon 4520 CI
JTR 228 x 3
JTR Slanted 8 x 2
PSA XS30 x 2
avgorder is offline
post #7666 of 13593 Old 04-16-2014, 03:30 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6848 Post(s)
Liked: 3812
If it is an iPhone, you can use Airplay.
AustinJerry is online now
post #7667 of 13593 Old 04-16-2014, 03:57 PM
pmcduie's Avatar
Hi All
I am after some help on the best way to connect a new TV to my 4520.
Currently have Panasonic 46" Plasma ( TH-46PZ800A), which I have been using for many years, and now replacing it with one of the last generation of Panasonic Plasma TV's - 60" TH-P60ST60A.
My main question is regarding the use of the HDMI ARC option for Audio using the new TV, is it better than using the current Digital Audio out from my current TV?
Are there any tips or tricks in using the HDMI ARC function with this combination?
Any help appreciated
pmcduie is offline
post #7668 of 13593 Old 04-16-2014, 04:08 PM
jdsmoothie's Avatar
Liked: 5757
Often times the HDMI(ARC) connection is a bigger headache then it's worth as the AVR will always switch to the TV input when powered on, not to mention in some cases can only pass PCM 2.0 vs. DD 5.1 using the optical audio output connection so just depends on the capability of the TV as to which way to go.
post #7669 of 13593 Old 04-16-2014, 04:08 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Best way is to run everything to the avr and a single hdmi cable to the tv
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #7670 of 13593 Old 04-16-2014, 04:17 PM
Liked: 3812
I agree that ARC is a PITA, and I use the optical out for TV audio. However, I seem to only get two-channel audio this way. It's not a big deal for me, since I rarely use the TV tuner. All my TV comes from either a DirecTV DVR, or an Apple TV, both of which deliver 5.1 over HDMI.
post #7671 of 13593 Old 04-16-2014, 04:30 PM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 87
I turn all that auto switching off. When I was listening to my DVD player I would turn off the TV and it would shut off the DVD.
See My System Here
post #7672 of 13593 Old 04-16-2014, 04:33 PM
avgorder's Avatar
Unfortunately mine is an android, Galaxy S4.
Denon 4520 CI
JTR 228 x 3
JTR Slanted 8 x 2
PSA XS30 x 2
avgorder is offline
post #7673 of 13593 Old 04-16-2014, 06:02 PM
pmcduie's Avatar
Thanks for the feedback, looks like I will stick with the existing Optical Audio out, as per current configuration. Free to Air TV here in Australia, has virtually no 5.1 audio anyway, so not missing out on much, mainly trying to eliminate the extra cable.
Once again thanks for the replies, looking forward to the new plasma and trying out some favourite blu-rays.
pmcduie is offline
post #7674 of 13593 Old 04-16-2014, 06:18 PM
wysiwygbg's Avatar
You can buy one of them Android HDMI dongle devices and run some equivallent of AirPlay directly on the TV from the phone.
wysiwygbg is offline
post #7675 of 13593 Old 04-16-2014, 09:02 PM
hansangb's Avatar
BBB is going to net you absolutely nothing. My advice would be to be polite but firm. Keep asking to be escalated w/o getting nasty about it. Keep everything documented. Then if that doesn't work, try social media and hope some for the best. Come up with something witty, hope it goes somewhat viral (not world wide, obviously) but ask all your relatives for help.
Best of luck!
Hansang
hansangb is offline
post #7676 of 13593 Old 04-16-2014, 09:43 PM
OzHDHT's Avatar
Quoted: 820 Post(s)
Liked: 440
So you're saying (btw you"re extremely hard to follow with your odd list like and somewhat abrupt posts), that you've tried A/B testing the preout output into your old amp(feeding into your speakers) and then compared it to the speaker level output on the 4520? That would be an easy way to hear missing frequencies, especially bass. You never said what your configuration is other than you're listening to cd's. It sounds like your using pure 2ch stereo with the 4520, in which case it should be very easy to ensure everything is set up for 2 front full range speakers. Also, if so and you are running surround for anything, then I have to question the use of a 4520 for the purpose of 2ch stereo reproduction. The are far better sounding units out there for that purpose in the same price range and under. BTW, Apols if I've read between the lines in thinking your setup is just 2ch, but you haven't mentioned any other speakers thus far.
OzHDHT is offline
post #7677 of 13593 Old 04-17-2014, 01:05 AM
laulau's Avatar
Quoted: 77 Post(s)
Liked: 112
You can use BubbleUpNP. It will make your Android device appear as a Media Server device (DLNA) on the 4520 where you'll be able to choose which media (located on device, LAN or cloud) to stream. You can try out the main app for free, but it costs $4.69 for the license app to unlock all the features. To get an idea how it would work, you can try out the Cast To UPnP/DLNA for GMusic app...in fact, if you would only ever want to stream GMusic you could just stick to that app (not sure what the cost is). I think the main app gives you a lot more options, especially down the road. There are probably many other apps that do the same thing, but BubbleUpNP is what I've been using (to stream FLAC files to my mobile devices) and I've been pleased with it so far.
You could also go the Chromecast route and just cast it to the receiver, if you're willing to spend a little more for the CC device.
HTH.
Salk STRT / SongCtr-RT / SongSurr I ; Rythmik F12 (x2) (latest ver of setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; CCast; Harmony1; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RPi3&Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i & Meze 99 Classics :: Rpi3&/Digi+ Pro > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 & HD6XX :: FooB2K > Schiit Mimby > Schiit Magni2U > Oppo PM3
laulau is offline
post #7678 of 13593 Old 04-17-2014, 01:59 AM
mercury's Avatar
Liked: 101
sure... you can stream anything thats on your network with this-
skifta... from pictures to mp3.
https://play.google.com/store/apps/details?id=com.skifta.android.app
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
post #7679 of 13593 Old 04-17-2014, 07:57 AM
ril850's Avatar
Quoted: 77 Post(s)
Liked: 30
Originally Posted by pmcduie View Post
Hi All
I was having trouble at first with ARC, using the exact same TV. I finally figured out how to get it to work consistently, I was not having much luck at first. I do get 5.1 Dolby Digital from the Vudu app in the TV. I don't use Netflix, so I can't speak on that.
tomagardner likes this.
Life is what you make it.......
ril850 is online now
post #7680 of 13593 Old 04-17-2014, 11:05 AM
tknx's Avatar
Quoted: 34 Post(s)
Source is working fine in the main zone.
My setup is:
1. Turntable
2. Denon
3a. Zone 2 preamp outs > wireless transmitter > outdoor speakers
3b. Main zone speakers
I have tested the wireless transmitter with other sources and it works fine. But I can't get the turntable sound to appear on the Zone 2 speakers - even when I set it to "All sources". Occasionally when fiddling around with Zone 2 on and off, the main source will decrease in volume which requires a reset of Audyssey to get it back up...
tknx is offline
Denon Avr 4520ci Receiver
