The **OFFICIAL** DENON AVR-4520CI thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
Old 11-09-2012, 02:11 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
Originally Posted by TazExprez View Post
Thank you so much Joe! Can't wait!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Old 11-09-2012, 08:25 AM
jlanzy's Avatar
Quoted: 241 Post(s)
Liked: 65
Originally Posted by streetsmart88 View Post
Chris, I eagerly await your review of the 4520, including if your calibration time with Audyssey Pro doubles (similar to jerry). I still haven't found a good reason to dump my 4311 ...
My sense is that it has a lot of new features (Audyssey LFC, Dialogue Enhancer, PIP, etc), nearly all of which, sadly, are pretty useless for me. So far, the only good reason I've found is that I can still get good value for a trade-in on my 4311 but that argument somehow seems flawed. tongue.gif
Mark
Whenever I upgrade I need to feel that the new product will give me that 'wow' factor that my current source can't because of new technology.  Personally, if my main reason would be getting a better trade in price now, and the new video or audio didn't 'wow' me, probably very shortly after the 'newness' of it wore off I'd be saying gee, this really is hardly any better than what I just sold, what the he--  was I thinking, especially if you have a fine product like the 4311 already.
jlanzy is offline
Old 11-09-2012, 09:39 AM
vikgrao's Avatar
Quoted: 17 Post(s)
Liked: 48
Hi, i have 6 surround speakers. Surround backs and a pair of side surrounds for each of my two rows. Can the Front high or wide channels in the 4520CI be reassigned to be used as a second pair of side surrounds?
Vik
vikgrao is offline
Old 11-09-2012, 10:40 AM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Hi Vik -- Yes, because the 4520 has a "free assign" mode you can do this. You need to set AMP ASSIGN to "Custom" which enables free assignment of all but the C/SL/SR amp channels (see chart on pg 183 of the manual).
Obviously you will leave the "core" 5.1 channels plus the surr.back channel amps as is, and then the 8th/9th amp channels (default assignment is FHL/FHR) you reassign to duplicate SL/SR.
(Note that this will prevent you from being able to run heights or wides without adding additional amplification, because you have used all 9 internal amps for your current 9 speaker layout, even though it's technically still only 7 "channels" of output)
napiermark and vikgrao like this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 11-09-2012, 11:10 AM
flint350's Avatar
Liked: 36
Vik
Custom amp assign can do this.
edit:  nm, I see Batpig dealt with this as I was typing.
Ray
"You cannot reason a person out of a position he did not reason himself into in the first place." -Jonathan Swift
flint350 is online now
Old 11-09-2012, 11:56 AM
vikgrao's Avatar
Quoted: 17 Post(s)
Liked: 48
Thanks so much. you solved a huge dilemma for me. Shawn byrne mentioned that this would do the job yesterday i just wanted to confirm on the official thread also. Btw i wish i had your username and the quote below i absolutely love it!!!
vikgrao is offline
Old 11-09-2012, 11:57 AM
vikgrao's Avatar
Quoted: 17 Post(s)
Liked: 48
Thanks Flint!
vikgrao is offline
Old 11-09-2012, 12:08 PM
vikgrao's Avatar
Quoted: 17 Post(s)
Liked: 48
Oh i forgot to mention My LCR's are Seaton Catalyst 12C powered speakers. So i guess i will still have 3 internal amps left to assign.
vikgrao is offline
Old 11-09-2012, 12:12 PM - Thread Starter
batpig's Avatar
Liked: 3415
actually only two -- if you examine the chart I referenced and read what I wrote, you will note that three amps (SR/SL/C) are non assignable, even in "Custom" amp assign mode.
FYI - here's the chart:
so you could technically still run a 9ch setup I believe, by reassigning the unused FL/FR amps to power the extra SL/SR speakers, and then you would still have the FHL/FHR amps available.
Setup Guide and FAQ
batpig is offline
Old 11-09-2012, 12:29 PM
vikgrao's Avatar
Quoted: 17 Post(s)
Liked: 48
vikgrao is offline
Old 11-09-2012, 01:23 PM
ccotenj's Avatar
Liked: 101
it's here...
first note is that the default volume scale is opposite of what it was on recent models...
the "initial setup" seems to work ok, and should (hopefully) eliminate some of the basic "how do i do this" questions...
menu is ok... it's a menu...
deremote found it and controls it without issue...
more to come...
- chris
ccotenj is offline
Old 11-09-2012, 02:00 PM
Mark1000's Avatar
actually my reading is that it IS possible to achieve 6.1 with the extra 3 amps bi-amping the FR, FL, and C channels.
according to that chart, when in "Custom" free assign mode, the C, SL, and SR channels are "fixed" an non-assignable (although the "-" seems to indicate that they can be deactivated), but the other 6 amps are fully assignable to ANY channel (with the caveat that left is always left, right is always right).
that means you could leave the five main amps at their normal settings (FR, FL, C, SR, SL), reassign the front height amps to also power the FR and FL, and then use whatever SB amp you aren't using to assign to C and bi-amp the center.
Unfortunately, it is not a complete free assign mode, as it turns out. Custom assign is only possible in pairs, so I am not able to use one of the surround back amps to handle my single surround back speaker and the other to bi-amp my center. I could bi-amp both my surround speakers though, without using my surround back speaker if I really wanted that...
Mark1000 is offline
Old 11-09-2012, 02:01 PM
Mark1000's Avatar
Originally Posted by ccotenj View Post
it's here...
more to come...
You can restore the old + or - 0 dB mode through the menu.
Mark1000 is offline
Old 11-09-2012, 02:08 PM
ccotenj's Avatar
Liked: 101
yup, already did... smile.gif it's set up and functional... no errors so far...
initial testing of straight video passthrough looks good... no obvious errors... still need to run some further tests there...
time to go down the aud pro rabbit hole... hope i can find all my stuff... redface.gif
- chris
ccotenj is offline
Old 11-09-2012, 02:51 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6503 Post(s)
Liked: 3611
Chris, I can't recall. When you had the A-100, did you benefit from the post-calibration sub distance tweak? Do you run measurements after a calibration?
Please measure the amount of time it takes to do the data transfer between each set of Audyssey chirps. You are the second 4520 user to run a Pro calibration, and we want to see if my experience with slow USB-to-Serial transfers are duplicated with your AVR.
AustinJerry is online now
Old 11-09-2012, 03:07 PM
ccotenj's Avatar
Liked: 101
yea, i did jerry... yea, i do... unfortunately, i'm not nearly as fastidious as you are about record keeping, so i doubt i have any "pre-tweak" measurements saved... redface.gif
i'll time it, sure, but i don't use a usb-serial cable... i've got an old lappy with a serial port that i use... did a usb-serial cable come with the kit? if so, i'll do a run with it after i get a good calibration done and saved... might as well see if it's reproducible... smile.gif
- chris
ccotenj is offline
Old 11-09-2012, 03:13 PM
sdrucker's Avatar
Quoted: 677 Post(s)
Liked: 453
If Jerry's right, you may have a LOT of time to catch up on your e-reading while you're doing your Pro Cal...biggrin.gif
Congradulations on being the second guinea pig....somebody's got to do it and I"m glad your drive for new toys won out over utilitarian thinking:rolleyes:
I need lots of InstaPreview info to get the cognitive dissonance going...eek.gif
BTW, the Pro Kit (at least mine in the spring) came with a Serial-to-USB cable.
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 subs (4) - 9.4.4
sdrucker is online now
Old 11-09-2012, 04:46 PM
Liked: 3611
Interesting, I have never heard of using a serial cable between the AVR and the laptop. Unfortunately, we won't have an apples-to-apples comparison, although I doubt that a direct serial connection will be any faster. My theory is that the serial interface on the AVR has a lower speed, or the driver on the AVR side is hosed. Either would affect your calibration as well. I'm on the edge of my seat waiting for your report. Of course, I'll be passing the time with a glass of Cabernet... wink.gif
Old 11-09-2012, 06:34 PM
Tobal's Avatar
Hi all. I am very new here and a noob in the world of sound and picture.
I have a problem and would be very happy if some1 help me out
Yesterday I purchased a denon 4520 and it is really amazing.
The problem is when I play a movie using my TV and home network I donot have any sound. I have no idea why.
Theother thing is when I use my iphone to play movies via airplay all it says is `failed`
and also I am not able to control my TV or PS3 by using the denon remote control.
Thx in advance
My TV . Sony KDL46HX920
Speakers . Dali Lektor series. ( 2 front-center-surround)
Subwoofer. Klipsh RT-10D
Kables . HDMI Monster 1200HDex Ultimate High Speed Cable for all connections.
Tobal is offline
Old 11-09-2012, 07:09 PM
Liked: 3611
Thx in advance
Hello Tobal,
Let's start with the first problem. Please answer each of the following:
- how are you trying to "play a movie"? Are you streaming a movie over the Internet? If yes, what device is doing the streaming, the TV?
- How is the audio from the TV connected to the 4520? There should be an audio connection, e.g. Toslink, from the TV to an input on the 4520.
Now for the Airplay issue. When you select a music file to play using Airplay, do you get the Airplay icon with which to select the output device? If you click on the icon, does it show the Denon AVR-4520CI as one of the output destinations? When you open the 4520 menu and go to the network submenu, does the 4520 have a valid IP address on your network?
Old 11-10-2012, 05:45 AM
Tobal's Avatar
Hi and thx for the tips.
To the TV only one HDMI is connected. From the TV to Denon nothing.
For streaming airplay , yes , I can see denon 4520 and I can play music from it but not movies.
I thought HDMI audio return channel is gonna be working as an extra cable for audio.
And yes the movies I play is from my hard disk which is connected to my home network
I play the movies using the TV not denon because the TV supports more formats.
Thx again
Tobal is offline
Old 11-10-2012, 05:50 AM
ccotenj's Avatar
Liked: 101
a) you cannot stream video via airplay to the avr... only audio...
b) what gets sent out via "arc" is dependent upon the display... some of them will not send audio from a connected component, only from internally generated (tuner, apps, etc.) sources...
c) not sure what you mean by the "tv supports more formats" comment? confused.gif can you explain that further?
- chris
ccotenj is offline
Old 11-10-2012, 06:24 AM
Liked: 3611
Thx again
I have an optical (Toslink) cable from the TV to the Denon as well, and I can play audio from the TV. You might want to try this as well.
As Chris says, Airplay supports audio only. If you want to stream video as well, Apple TV is an inexpensive solution that works well if the movies are in iTunes.
Old 11-10-2012, 06:31 AM
FrankTR's Avatar
Maybe not the correct place to ask this but, I had a Onkyo 709 that is in repair and yesterday Onkyo said they were going to replace it with a new Onkyo 717. I plan to sell the 717 and thinking of getting the Onkyo 818 however, is the Denon 4520 worth two and half times the cost of the Onkyo 818?
FrankTR is offline
Old 11-10-2012, 06:34 AM
ccotenj's Avatar
Liked: 101
without going into detail (since this isn't the thread for it), to me it was, yes...
fwiw, it's about twice the price if the 818 if you pick up the phone and call the sponsor of this site... wink.gif
- chris
ccotenj is offline
Old 11-10-2012, 07:02 AM
Tachy's Avatar
The 4311 specs suggest it converts composite to component out. I do not see that mentioned in the 4520 specs? Anyone know if it does? I currently have a TV with component inputs only and at some point plan to upgrade to HDMI.
Tachy is offline
Old 11-10-2012, 07:30 AM
ccotenj's Avatar
Liked: 101
yes it does... see page 7 of the owner's manual...
- chris
ccotenj is offline
Old 11-10-2012, 09:10 AM
bfreedma's Avatar
Liked: 51
That just means he's old been around long enough to remember how to set up a serial port tongue.gif 9600,8,1,n eek.gif
Jerry, I think the serial interface on the AVR is the limiting factor. The timing of the download from my laptop to the A-100 correlated pretty well to a 9600 baud connection. Now that Denon is including Ethernet ports and in the case of the 4520, a hub, it's time they rewrote the interface. That said, given the relatively low number of Pro kits out there, it probably isn't a priority.
bfreedma is offline
Old 11-10-2012, 10:24 AM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
landshark1 is offline
Old 11-10-2012, 10:42 AM
Liked: 3611
What you say may be true, but it doesn't explain why the serial data transfer speed for the 4520 is only half as fast as the 4311. One would not expect a step backwards. BTW, I opened a case with Denon over a month ago, but (as is typical of Denon support) I have not received an answer yet.
Denon Avr 4520ci Receiver
