The **OFFICIAL** DENON AVR-4520CI thread - Page 284 - AVS Forum | Home Theater Discussions And Reviews
 842Likes
Old 06-21-2014, 04:11 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 10238 Post(s)
Liked: 4745
For a single center back surround, you wire the speaker to the SBLeft speaker posts.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Authorized dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, SVS, Oppo
Ask me how to get a FREE HEOS 1 HS2 wireless speaker.
jdsmoothie is offline
Old 06-21-2014, 08:35 AM
Dreamliner's Avatar
Quoted: 333 Post(s)
Liked: 121
Dreamliner is online now
Old 06-21-2014, 10:53 AM
PepperOne's Avatar
Red face
Originally Posted by Dreamliner View Post
It's called 6.1 in case you've never heard of that.
PepperOne is offline
Old 06-21-2014, 10:57 AM
Dreamliner's Avatar
Quoted: 333 Post(s)
Liked: 121
I know, I just thought it was funny.
I went from 5.1 -> 7.1 -> 9.2 -> 11.2. I've had a Denon 887, 888, 3310, 4311 & 4520.
...Still have the 888 & 4520.
Old 06-21-2014, 11:07 AM
jlpowell84's Avatar
Quoted: 1493 Post(s)
Liked: 667
Basically in my case if I were to put two speakers back there they would be like 1.5 to 2 ft apart. And I would need to pick up another pair of little monitors to go with the 4 I have. But I do have the matching center and could put it directly behind mounted up on a light fixture. Still would need to amplify that channel though. Perhaps I could find like a 50 watt a channel stereo amp and bridge it to like 125 or so. Anyway this case all I need is to get the amp and I am ready to go Installing the heights and wides today.
jlpowell84 is offline
Old 06-21-2014, 12:48 PM - Thread Starter
batpig's Avatar
Quoted: 3395 Post(s)
Liked: 3237
Way to miss the joke
batpig is online now
Old 06-21-2014, 01:09 PM
PepperOne's Avatar
A fly ball, and he caught it!
Old 06-21-2014, 03:23 PM
Red Dolittle's Avatar
Is anyone going to make fun of me for having 8.1? Only have room for a rear center channel and no space for wides so I'm running heights. The heights actually improve my front soundstage. Having fun revisiting some movies I haven't seen in a while. World War Z sounds pretty sweet!
Red Dolittle is offline
Old 06-21-2014, 11:16 PM
jlpowell84's Avatar
Liked: 667
WWZ is a very well done soundtrack. I installed wides today and will have heights Monday when mounts arrive. Need an amp to run my one rear channel lol. Anyone know of an inexpensive 2 channel amp that can be bridged to get about 125-150 watts?
Old 06-22-2014, 03:46 AM
Dredd sounds really cool, too! I thought the rear center channel comment was funny since I've been using a Def Tech C1 as my back surround for a while. Have fun with your new setup
You might be better off getting a multi-channel amp in case you want to upgrade to Dolby Atmos! Where can I put those extra speakers
Old 06-22-2014, 07:57 AM
johnny dollar's Avatar
On the 4311 when you select a given input source, like an HDMI video, and assign it to a slot like, say, DVD, it's no longer available for any of the other slots. I'd like to use a video input more than once and use it in two different slots, one as is and another that uses the same HDMI cable but with the analog audio inputs. Does the 4520 allow use of a given source more than once, or is it like the 4311 and does not permit it? Thank you so much.
Is there anyone who can answer this question? Thanks in advance...
yours truly, johnny dollar
johnny dollar is offline
Old 06-22-2014, 10:11 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4745
All D&M models are the same in this respect in that an HDMI input can only be assigned to a single source; however, if you simply want to watch HDMI video will listening to analog audio, then you can plug the source's analog outputs to the 4311's analog inputs labeled DVD and then change the INPUT MODE for the DVD source to "Analog" when you want to switch from HDMI to analog audio. The 4520CI offers the additional feature in that any analog inputs can be used and then "assigned" to the DVD source name just as with the HDMI, optical, and coax digital on the 4311CI.
Old 06-22-2014, 10:21 AM
jlpowell84's Avatar
Liked: 667
Nice! These little Pro Monitor 600's or any of the series really are great little speakers! Look tiny in my room with my mains, subs, and room treatments lol. Stealth status. But they do their job well!
Old 06-22-2014, 10:29 AM
Thank you JDSmoothie. And thanks for the tip about input mode too. I'm going to try that out!
Old 06-22-2014, 05:10 PM
Glock3540's Avatar
Quoted: 22 Post(s)
Hi Guys,
I just purchased a 4520 a month or so ago. My previous receivers were a 4810ci and before that a 4802R. I have it set up in 11.2. My main speakers (and my center speaker) are Infinity P-fr's. My side surrounds are Infinity Overture 1's (soon to be replaced with P-fr's) and my height,wide and rear surrounds are Infinity Overture 1's.
I have a Emotiva XPA-1 powering my center speaker, An XPA-2 powering the mains, An XPA-5 powering the side and rear surrounds. The heights and wides are powered by the 4520. My subs are a pair of CHT 18.2's powered by a MQ-600 pro amp.
I'm in process of switching from Windows to Mac. I purchased a MacBook Pro to play iTunes without all of the glitches I've fought with Windows over the years.
My question is this; I listen to Multi Channel Music and it sounds great in my A/V room but I have run upon an issue I cannot figure out. My MacBook is connected to my router and then my 4520. When plain iTunes (as I am right now) the volume limits itself to appx 75% volume. When turning up the volume on the 4520 it will briefly go up to say 78 or 79 on the volume scale and then it decreases (by itself) back down to 74 or 75 almost instantly. I checked my settings on the 4520 and the scale is set to 0-98, and the Volume Limit is set to "Off". The volume on my MacBook in iTunes is at full volume. Do you have any ideas?
It is quite loud as is (appx 104 or 105 dB in the center of the room but I am used to quite a few more dB than that when having parties. (I know it is not advisable but I like it loud sometimes). I DO NOT LIKE MY EQUIPMENT ACTING AS A NANNY and limiting the volume. I do have Audyssey engaged and have not tried it with it turned off but it does not limit me when watching movies or playing music through my CD player.
Any Help Will Be Greatly Appreciated.
Thanks, Brian
"I'm Your Huckleberry..."
Glock3540 is offline
Old 06-22-2014, 05:34 PM
Glock3540's Avatar
Quoted: 22 Post(s)
I think I just figured out part of the issue I am having. I went into my Mac's Audio Midi Setup and changed some settings there. It now will go up to 93.5 but something is still not quite right....
Old 06-22-2014, 10:52 PM
jlpowell84's Avatar
Liked: 667
So I popped a CD into my new Oppo BD103D to compare the SQ to my ALAC files in iTunes. All the listening presets worked fine until I went to Stereo. The Denon does that clicking noise like it does when you power it off or go into the Audyssey setup. Not sure what was going on...
Old 06-23-2014, 01:48 AM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
Originally Posted by Glock3540 View Post
Hi Guys,
Thanks, Brian
Quite sure you have checked this, but where are your channel volumes?
I believe these can influence where master volume maxes out at.
TorTorden is offline
Old 06-23-2014, 05:22 AM - Thread Starter
batpig's Avatar
Liked: 3237
It's not the receiver, it's iTunes. This is a known issue with Airplay streaming from a computer that's been reported many times. For some reason the volume gets capped at -6 (74 on the absolute scale). I don't know the exact cause or the solution.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
Old 06-23-2014, 05:23 AM - Thread Starter
batpig's Avatar
Liked: 3237
Did something actually go "wrong" or are you just concerned because you heard some clicks? Because there's nothing to be concerned about if it's the latter.
Setup Guide and FAQ
Old 06-23-2014, 11:59 AM
jlpowell84's Avatar
Liked: 667
No I am not concerned that something is wrong. I know the Denon units make clicks like that. Just trying to figure out why all the listening presets work fine then it does that when I go to stereo. And only from my Oppo...
Old 06-23-2014, 08:26 PM
jlpowell84's Avatar
Liked: 667
Ok now I am concerned something is wrong and TBO honest a little irritated I buy a flagship model and it is already having issues. Everything has worked 100% flawless besides the only thing yesterday when I would select "stereo" listening preset with a CD playing music via my Oppo BD103D connected via HDMI (like everything else (PS3, Mac Mini)). The Denon would make that traditional clicking sound when stereo was selected and I would get no audio. Anyway all worked besides that little weirdness when I turned everything off last night. Now I turn on this evening and I can not GET ANYTHING THROUGH ANY HDMI SOURCE. The Oppo, the PS3, the Mac mini, all are inactive through hdmi. HDMI pass through is not working either. I tried different HDMI cables, and even my computer monitor connected to Zone 4 will not get an HDMI signal. Sure hope this is a bonehead move on my part and I don't have to send in a BRAND NEW FLAGSHIP DENON!!!!!
Old 06-23-2014, 08:53 PM
Schwa's Avatar
Quoted: 817 Post(s)
Liked: 914
Before you screw yourself into the ceiling, heed the advice JD includes in his signature (i.e. if all else fails, reset the processor).
Schwa is offline
Old 06-23-2014, 10:35 PM
jlpowell84's Avatar
Liked: 667
Well that worked. First time I have ever had to do that. First time as a Denon owner I have had to do that. Forgive me for those of you who read and sighed at my previous comment. I was just thinking to myself this is the worst time for something to go wrong with heights and wides being setup and guests and such...the thought of having to pack up and send off...ughhghg....
So what exactly causes this? My 3313 never had any issues. Is it basically like a software freeze?
No worries having to rerun Audyssey as I installed heights today before turning everything on. So I have to rerun anyway.
Old 06-23-2014, 11:23 PM
Ahab's Avatar
Am having audio problems with my receiver.
Purchased the 4520 late last year and ran fine until about a month ago when it started shutting off on its own. Took it to an authorized repair service. They had to replace a part. Picked it up today and ran the Audyssey calibration. I only have a 3.1 system so calibration didn't take too long and all seemed to go ok.
I have an Apple TV, Oppo Blu Ray player and Denon DVD play connected via HDMI.
When I tried playing some songs through the Apple TV I could not get any sound at first. Manged to get sound by changing Input Mode from Auto to HDMI.
Had to make the same change to the Input Mode for the Denon and Oppo players and was getting audio fine through all speakers from the sample discs I played.
Watched a movie on the Oppo and all was still working ok. But when I tried playing a disc on the Denon player the only sound I could get was from the SW, even though I had gotten full audio earlier. Went back and tried another movie in the Oppo but had the same result as with the Denon.
Video is fine. But am presently getting no sound through the center and front speakers.
Is a processor reset the only thing left for me to try at this time? Or is there some setting I'm overlooking in the setup menu?
Updated Info: Tried doing a reset this am. Still no sound from speakers. Will switch in my 4310 tonight and see if there is a problem with speakers. Rather doubt it since everything was working fine with the 4310 while the new receiver was being repaired.
Ahab is offline
Old 06-24-2014, 09:56 AM
travis-g's Avatar
Quoted: 96 Post(s)
Liked: 58
I just hooked up my 4520 and I noticed in stereo mode listening to music the bass is almost non existent through my subs. All my speakers are set to small. Any ideas?
travis-g is offline
Old 06-24-2014, 10:41 AM
jlpowell84's Avatar
Liked: 667
Originally Posted by travis-g View Post
i just hooked up my 4520 and i noticed in stereo mode listening to music the bass is almost non existent through my subs. All my speakers are set to small. Any ideas?
just bump the trim up
Old 06-24-2014, 11:11 AM
Quoted: 59 Post(s)
Liked: 6
Hi Guys,
Thanks, Brian
I was just reading this post and had to ask. Why would you buy a 4520 and use all those Emotiva amps. Wouldn't it make more sense to get a x4000 and spend the rest on something else? Is the 4520 a superior processor?
audio.hobby is offline
Old 06-24-2014, 12:01 PM
Glock3540's Avatar
Quoted: 22 Post(s)
Yea, Not sure is the 4520 is any "better" than the x4000. After doing a lot of research, I "felt" like it was better so that is my only excuse. I almost bought a Marantz AV8801 but again, after much research, thought the 4520 was the better deal.
The reason for all of the amps is I push my equipment hard sometimes. My 4810 would go into protection mode after extended sessions before I got the Emo amps. I rewired my A/V room with 5 dedicated 20 amp outlets, 12/2 wire to 5 dedicated 20 amp breakers. Before I did that, the entire top floor of my houses lights would dim on heavy bass material. I know, I'm crazy for listening to music/movies that loud. I just can't help myself sometimes...
I just remembered, I don't think the x4000 does 11.2? I'm not sure about that, but I LOVE My 11.2 set up. On Multi Channel Music it sounds incredible!
Old 06-24-2014, 12:05 PM
Glock3540's Avatar
Quoted: 22 Post(s)
Wow, my new Oppo 103D is being delivered today. This all makes me a little worried....
Denon Avr 4520ci Receiver
