The **OFFICIAL** DENON AVR-4520CI thread - Page 291 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
Old 07-09-2014, 03:05 PM - Thread Starter
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
Originally Posted by Selden Ball View Post
If your room is carefully treated and your speakers (and subs) are highly accurate, then there isn't much left for Audyssey to do. Most people don't have that kind of listening environment, though.
Yup -- most of the time turning off Audyssey and other processing is more about "purity" bias than it is about actual objective data.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 07-09-2014, 04:24 PM
dan webster's Avatar
Quoted: 142 Post(s)
Liked: 99
I was watching a movie last night when suddenly the picture goes crazy and then nothing. I thought i was my brand new jvc projector wit am hdmi problem. After about 3 hours of double checking the hdmi output on the denon is bad. I am sending it in to a local repair shop in Connecticut. The tech i spoke to said he has replaced many of the hdmi boards. I thought only Onkyo had this kind of problem. I was not sure if i should of sent it to the New Jersey location or not. I hope it is not gone too long since i am using an old onkyo 501 in its place.
Dolby Atmos 7.2.4 Marantz AV8002a processor Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 bluray player Jvc 4910 projector Vivitek 1186 projector
Carada 110"BW screen Monster HTS 5100 MK11 power conditioner
Golden Ear Triton 5 L&R &super center XXL triton 7's sides Martin logan motion 12 rears
4 RSL C34 in ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is online now
Old 07-09-2014, 05:22 PM
UHD Addict
aaronwt's Avatar
Quoted: 5220 Post(s)
Liked: 3123
Does anyone know haw many watts the 4520 actually draws? I'm currently using an APC 1300VA UPS with my 3808 and it doesn't come anywhere close to hitting the UPS max of 780 watts. But the 4520 is more powerful so if I need to get an APC 1500VA UPS(which can handle up to 865 watts) I need to put one in place of the 1300VA UPS before my 4520 arrives.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
Old 07-09-2014, 05:38 PM
jdsmoothie's Avatar
Quoted: 12182 Post(s)
Liked: 5549
Likely no more than 100W-110W on average (if that), although perhaps someone with a Kill-O-Watt can chime in.
jdsmoothie is offline
Old 07-09-2014, 05:41 PM
UHD Addict
aaronwt's Avatar
Liked: 3123
OK. Then I should be fine. Thanks.
Old 07-09-2014, 06:21 PM
petetherock's Avatar
Quoted: 1078 Post(s)
Liked: 516
I don't know if it will be more stateside, but down here (230v), I used a Belkin device to measure (it's available off Amazon), and at idle it's about 25W, and in full tilt it's still less than 150W, but I have subs taking the stress off for the lower frequencies.
I once attached my laptop, Oppo BR player, TV, 4520 and stereo amp to the same socket, and the total draw was less than 700W...
petetherock is offline
Old 07-10-2014, 12:47 AM
Dreamliner's Avatar
Quoted: 368 Post(s)
Liked: 125
I have my 4520, 2-channel Onko amp, JVC RS46 projector, PS3, HTPC, router, modem, cooling fans and the rest of my home theater gear (except subs) all running through a 1500 watt APC battery backup without issues. It's usually got 3/5 LED's lit up on the load meter.
I finished the Dexter series finale on battery power one night. (storm...and disappointed in Dexter)
Dreamliner is offline
Old 07-10-2014, 01:08 AM
Benga's Avatar
Originally Posted by jlpowell84 View Post
I would never use direct. I measured it once and it had the bass below 120hz down like 12db.
I came to the conclusion I will do serious music listening in Stereo for now on. Back to stereo and they are fully present. I am sure this is that they are stereo soucres and something happens when the PLII Music preset does it's mixing.
Hmmz -12db on 120 hz?? Wow that's extreme and might explain my problem with the direct modi ... When listening in normal stereo do you prefer with or without audyssey engaged? I always tought that is was my speakers sounding muffled in the direct stand, but the fact you have measured this might point out to a 4520 flaw...
Benga is offline
Old 07-10-2014, 01:44 AM
Yveke's Avatar
Quoted: 12 Post(s)
Liked: 2
What about your experiences with Multi-channel stereo(9.2 in my case) vs "normal" 2.1 Stereo mode?
Multi-CH. Stereo seems a bit too much overdone on mid and bass, but still I like the sound as a base for further tuning. There seems to be a huge difference between Multi-CH Stereo vs the 2.1 Stereo, anyone have a plausible explanation?
Yveke is offline
Old 07-10-2014, 03:58 AM
jdsmoothie's Avatar
Liked: 5549
Multi CH Stereo simply passes the same 2.0 signal going to the FL/FR speakers to each of the other 3 pairs of speakers you are using.
Old 07-10-2014, 04:04 AM
Yveke's Avatar
Quoted: 12 Post(s)
Liked: 2
Well, that seems strange as I can defintely hear a distinct difference in bass output, and it seems more than just the higher volume due to more speakers. With multi channel stereo I need to bring soruce input level down by -10db to be equal to the Stereo mode output. Stereo with FR/FL(KEF IQ90) + my 2 subs seems very thin compared to the 9.2 output with multichannel stereo. Do you all experience the same i.e. A/B listen, not just the theory?
Yveke is offline
Old 07-10-2014, 06:43 AM
UHD Addict
aaronwt's Avatar
Liked: 3123
Thanks. I forgot how little power the receivers draw. My 3808 last night didn't go higher than 170 watts when I was looking at it. ANd that was only when I had a loud section from a BD. I have one 1300VA UPS dedicated to my receiver, one 1500VA UPS dedicated to my subwoofer and then a couple of the 1500VA UPSs, with extended runtime batteries, dedicated to everything else in my main display area.
Old 07-10-2014, 07:56 AM
chi_guy50's Avatar
Quoted: 1261 Post(s)
Liked: 747
Aaron, that sounds about right extrapolating from my experience. I have my AVR-3311CI (driving 7 speakers), an AMP-100 (driving 4 speakers), and a TiVo Premiere Elite all on battery-backup outlets on a CyberPower CP825AVRG (450W). The highest power draw I've been able to measure has been between 130 to 140W, and that's at ear-splitting levels in the main zone; otherwise it seldom goes over about 110W (JD pretty much hit it on the nose). I have the rest of the AV gear in my main zone on a separate CyberPower CP550SLG (330W) with the SW on a surge-only protected outlet. I like CyberPower for their user-friendly PowerPanel UI, which allows me to monitor battery performance via USB to a laptop without having to access the UPS itself, which sits out of view behind my wall unit.
I don't know what your requirements are, but I am jealous of the resources you are devoting to UPS backup. I know you've had a little bad luck lately with water damage and a broken windshield, and it's too bad your UPS's couldn't have helped with those incidents.
BTW, as you know replacement batteries--particularly on the larger UPS's--can be rather expensive. I've had good results buying non-OEM batteries from this eBay seller. If they carry the suitable battery for your 1300/1500VA UPS's, you can probably get replacements for around $20 shipped, which is about one-half what you'd pay at a retail store.
chi_guy50 is offline
Old 07-10-2014, 02:28 PM
jlpowell84's Avatar
Quoted: 1619 Post(s)
Liked: 713
You should check the sub trim levels. Different presets save different sub trim levels. Just a thought...
jlpowell84 is offline
Old 07-10-2014, 02:30 PM
jlpowell84's Avatar
Liked: 713
I have had inconsistencies in REW measurements in the past so even I myself don't feel comfortable accepting it 100% But I don't use direct as I think it sounds terrible! It is something with direct preset why it is that way.
Old 07-10-2014, 03:19 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6606 Post(s)
Liked: 3645
I just ran a quick test and here are the results:
- No difference in volume or bass output when running either Stereo or PLII Music.
- Direct turns off any output to the subs (as expected)
- Multi-channel Stereo seems to be at a volume level approx. +10dB from the Stereo and PLII Music modes.
I see no reason why you would think that bass output in Stereo is "thin", other than the louder output in Multi-channel Stereo.
AustinJerry is online now
Old 07-10-2014, 03:24 PM
Liked: 3645
As mentioned in my previous post, there is no output to the subs in Direct mode, so all bass is coming from the mains. This would account for the lower bass measurements. I always prefer to have Audyssey engaged, regardless of the listening mode. Audyssey corrects for issues in your listening room, so why would you not want to have it engaged? With Audyssey on, you can experiment with DEQ, of course, and choose whether to leave it on.
Old 07-10-2014, 03:35 PM
Yveke's Avatar
Quoted: 12 Post(s)
Liked: 2
Thanks for checking... indeed the +10db is indeed what I figured out and hence the -10DB on the "network streaming" source input level to avoid crazy differences in volume between sources. I would agree on the bass perception due to the +10 db, but when I crank the volume to +10 DB with Stereo mode, it is perceived as lacking vs the multi channel stereo mode. I tested it back and forth for several hours with some music tracks...as -ahum- for example "billy jean - Michael Jackson"... I know I know don't judge me for the music pick, but it has a nice solid bass track to help my bad sound memory for A/B testing.
Must experiment some more with the front speaker placements, settings, etc... but a shame one can only change audessey settings per input and not speaker trim levels for example.
Yveke is offline
Old 07-10-2014, 04:07 PM
Liked: 3645
Leave the speaker trims as Audyssey calculated them, and then forget Multi-channel Stereo. It really is a poor choice if you want to listen to music accurately.
Old 07-10-2014, 05:18 PM
UHD Addict
aaronwt's Avatar
Liked: 3123
Rats!! I missed the FedEx person with my 4520. Now I won't be able to get it until Saturday since i need them to drop it off at FedEx Kinkos so I can pick it up at my leisure. At least this will give me time to prep the area so I can dust and make sure everything is still labeled. Now I need to find my tripod since I will need it for both the audio and video calibration.
Old 07-10-2014, 05:21 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3067 Post(s)
Liked: 2987
At least now you have something fun to do this Sat. - set up your new 4520 - woo hoo !!!
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
Old 07-10-2014, 06:57 PM
jlpowell84's Avatar
Liked: 713
"as expected" Just curious Jerry. Why does direct do that to sub output? I never knew it did officially but my ears have heard it
Old 07-10-2014, 07:06 PM - Thread Starter
batpig's Avatar
Liked: 3420
Direct mode bypasses all processing, including bass management. So no bass will be routed from another channel to the subwoofer.
So if a signal comes in as 2ch stereo, only the front L/R speakers will make noise. (the only exception would be if you enable LFE+MAIN which engages double bass).
If a 5.1 signal is played in direct mode the subwoofer WILL make noise because there is a dedicated LFE signal present in the soundtrack. But the other five speakers will play full range signals.
jlpowell84 likes this.
batpig is offline
Old 07-10-2014, 07:12 PM
Liked: 3645
Exactly as Batpig says. For my test, I had bass set to "LFE", not "LFE+Main", which is why the subs were silent. I was testing with a 2.0 signal, with no LFE content.
Old 07-10-2014, 09:05 PM
jlpowell84's Avatar
Liked: 713
Ok so I am curious what exactly the "Stage width" and Stage Height" for the wides and heights do in the Audio>Audyssey menu section. What do you guys set them on? +the most what does it do? And - the most what does it do?
Old 07-10-2014, 09:15 PM - Thread Starter
batpig's Avatar
Liked: 3420
They are simply level controls for the height / wide speakers when DSX is engaged. I believe the full range corresponds to +/- 3db
batpig is offline
Old 07-10-2014, 11:57 PM
jlpowell84's Avatar
Liked: 713
You mean adjusting the trim/volume/level on those speakers? Just to be sure BP
Old 07-11-2014, 06:10 AM
jdsmoothie's Avatar
Liked: 5549
Correct. Each setting simply simultaneously adjusts both DSX Width or DSX Height speakers up or down in volume. Recommended is the default 0 setting.
Old 07-11-2014, 12:17 PM
reyalP's Avatar
I have the 4520 and a 7.1 setup. I noticed that when watching movies even though they advertise the recodring in 5.1 the reciever still plays it in 7.1. Not all movies but some do this. Is there a way to turn off the surround back left and right when I don't want to hear 7.1?
reyalP is offline
Old 07-11-2014, 12:51 PM
Liked: 3645
If you hold down the Movie button on the remote, you can choose Dolby Digital or Dolby Digital Ex. The former does not use the rear surrounds.
Denon Avr 4520ci Receiver
