The **OFFICIAL** DENON AVR-4520CI thread - Page 297 - AVS Forum | Home Theater Discussions And Reviews
 824Likes
post #8881 of 13381 Old 07-27-2014, 08:34 PM
johnny dollar's Avatar
Please accept my apologies if this is answered somewhere in the thread but after a half hour of searching I'm just more confused than ever.
I just strung an HDMI cable from the 4520 into another room where I connected it to a small tv. It was my thought from what I got out of the manual that Zone 4 would pass thru whatever source I chose to assign to it and send it thru that cable into the 2nd tv when the 4520 was in standby mode. But in standby mode I get nothing.
I finally figured out that I can get a signal when I power ON Zone 4. But then the 4520 is no longer in standby and has to be on like 24 hours a day unless I want to keep running back and forth from one room to another every time I turn a tv on or off.
Is there a way to get a signal out of Zone 4 while the 4520 is in the typical standby mode (no display, red light over power button)? If I have to leave the 4520 on 24 hours a day I don't think that's at all worthwhile for the wear and tear or electricity cost.
Thank you so much for your help on this.
yours truly, johnny dollar
johnny dollar is offline
post #8882 of 13381 Old 07-27-2014, 08:46 PM
JohnAV's Avatar
Quoted: 176 Post(s)
Liked: 196
Originally Posted by Sam S View Post
And I'm pretty sure they can't. Seems like Atmos + Audyssey requires 2X the processors/processing power that the 4520 has onboard.
No big loss, figure you don't want to mess with initial implementations anyway, it always improves with the next model, just look at how HDMI interfaces and DSP usage has evolved with each new model. Does it ever stop.
Oppo Beta Group
JohnAV is offline
post #8883 of 13381 Old 07-27-2014, 09:35 PM - Thread Starter
batpig's Avatar
Quoted: 3203 Post(s)
Liked: 3049
Zone 4 is an active matrix, not a standby pass through. If you want Zone 4 to be on, it has to be on. It's not the passive pass through that you get with the main zone outputs. But in terms of energy use / cost I would bet it's quite minimal, the main zone circuitry and amps don't have to be on.
If you don't need the independent source control you can use the second main zone HDMI output and designate it as the standby option. But you can't actively select the source that is passing through (setting is either one designated source or "last" source) and you basically have to choose between having the main zone on or the second zone pass thru, not both simultaneously.
If you want the flexibility of a full matrix with independent source and power for the two zones, you have to use Zone 4.
All that said.... why do you have to leave it on 24 hrs a day? In terms of running back and forth between rooms to turn power on or off.... Um, you have heard of this thing called the internet right? You do know tour receiver can be controlled by it, right?
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #8884 of 13381 Old 07-28-2014, 06:17 AM
I don't know about that. Do you really think that internet thing is going to catch on?
Finally I understand how zone 4 works. Thank you so much for clearing it up. Plus it's suggested to me another possibility (teach my RF remote the on/off zone 4 commands).
post #8885 of 13381 Old 07-28-2014, 04:44 PM
AVS Club Gold
aaronwt's Avatar
Quoted: 3867 Post(s)
Liked: 2282
I'm thinking about adding front heights to my setup to take advantage of the two extra channels of amplification the 4520 has over the 3808 it replaced. WIth my setup, front heights are all I can add. I don't have the space for front wides.
I currently have a 7.1 setup using an SVS subwoofer from 2003 along with a seven speaker SVS system from 2008. My space is limited for front heights because there is only one spot I can mount them on the wall where the stud is. And one of those spots is above a window. So I was looking at the Axiom M3 bookshelf speaker to use for front heights.
With the MultEQ XT32, will that do a decent job with the Axioms and the SVS speakers in my system?(with just the SVS speakers it sounds superb) Will those Axiom speakers even work well for front height speakers?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #8886 of 13381 Old 07-28-2014, 05:02 PM - Thread Starter
batpig's Avatar
Liked: 3049
I think they will be fine. Axiom speakers should be pretty neutral and close to flat so it shouldn't be hard for XT32 to tweak them to the target curve. And furthermore the height speakers probably don't stick out that much anyway so you'd be unlikely to notice whatever small differences are left.
Side note, but if you are going to put money into improving the setup, what about a second SVS subwoofer instead? You can use the same rationale ("taking advantage" of an unused feature of the 4520, namely SubEQ) and adding a second sub should yield pretty signficant improvements in smoothness of bass response across the listening zone.
Setup Guide and FAQ
batpig is offline
post #8887 of 13381 Old 07-28-2014, 05:07 PM
AVS Club Gold
aaronwt's Avatar
Liked: 2282
I would love to add a second sub but I am in a condo. With just the one sub and the sub-sonic bass it produces, things can really start rattling. Fortunately I don't have to worry too much about the volume since I'm in the basement condo. But if I added a second SVS subwoofer I think that would push it a little too far.
Although next on my list would be to just replace my existing sub with a newer SVS sub.
Thanks for the comment about the Axioms. I wasn't really sure if they would work or not. I was completely resigned to stick with a 7.1 setup until I got the 4520. And with the excellent results I can hear in my current setup I really want to try and take advantage of the two extra channels of amplification. Plus I need to test it out soon anyway since it's a refurb. If there is an issue during the first 30 days, Denon covers shipping both ways to fix it.
aaronwt is offline
post #8888 of 13381 Old 07-28-2014, 08:57 PM
Liked: 0
AVR-4520 together with DNP-720?
Hi,
I purchased the AVR-4520 yesterday together with the DBT-3313. When I told the shop assistent I want to play my 1TB Flac files on the 4520, he told me I would also need to purchase the DNP-720 since that would enhance the quality. Ok, I purchased that too.
When I told that my mate, he said that is rubbish since the 4520 could do the same as the DNP-720. I should better purchase a NAS HDD, load all Flac files there and connect that HDD to the 4520 directly via Ethernet.
Is that correct or what would be the best connection to the 4520? I don't mind having the DNP-720 additionally connected if that produces better quality output.
Can anyone recommend a good (but not too expensive) NAS HDD (if possible connecting wireless to the 4520)?
Thanks a lot for any help.
Cheers
Caesar
-Caesar- is offline
post #8889 of 13381 Old 07-29-2014, 02:50 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 9366 Post(s)
Liked: 4328
You can use the Audyssey LFC setting to tame the lower bass frequencies so as not to disturb the neighbors.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
post #8890 of 13381 Old 07-29-2014, 04:33 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5015
Originally Posted by JohnAV View Post
When one is setting up a home audio system not everything is about movies.
Nor did I say it was. I said Atmos has been designed for movies.
kbarnes701 is offline
post #8891 of 13381 Old 07-29-2014, 04:39 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4328
Originally Posted by -Caesar- View Post
Hi,
Cheers
Caesar
Your mate is correct. Send the DNP-720 back as it is redundant. I'm sure one of the forum members can make a NAS HDD recommendation.
post #8892 of 13381 Old 07-29-2014, 06:45 AM
Liked: 0
Thanks mate.
The DNP is returned and I bought a Buffalo LS210D 3TB HDD.
I hope that's ok?
Cheers
Caesar
-Caesar- is offline
post #8893 of 13381 Old 07-29-2014, 10:23 AM - Thread Starter
batpig's Avatar
Liked: 3049
Here's the thing though -- adding a second sub does NOT make the bass louder. Sure, you would have more headroom if you were inclined to crank it, but remember that once you calibrate the system the sub channel (combined output) will still be calibrated at 75dB just like the other channels. So if you listen at -25dB volume, the calibrated subwoofer channel would be producing the same volume whether you had one, two, or eight subs.
Now, counterintuitively, adding a second sub might make things LESS obtrusive in terms of rattling and neighbor disturbance. Remember that a second sub will smooth out the room response -- you have will fewer big peaks and nulls as you move around the room because the two subs, in different locations, are energizing different room modes. It's possible (likely even) that the smoother, more consistent bass response throughout the room would result in knocking down a nasty peak or two that are exacerbating certain rattles and rumbling.
Plus, of course, as JD notes you can always use the LFC setting for when you really want to cut it out.
aaronwt and jstach500 like this.
Setup Guide and FAQ
batpig is offline
post #8894 of 13381 Old 07-29-2014, 12:41 PM
Selden Ball's Avatar
Quoted: 2363 Post(s)
Liked: 1142
Buffalo's LS210D supports DLNA. See http://www.buffalotech.com/content/f.../LS210D_DS.pdf
Selden
Selden Ball is online now
post #8895 of 13381 Old 07-29-2014, 03:35 PM
laulau's Avatar
Location: "The loveliest fleet of islands that lies anchored
Quoted: 65 Post(s)
Liked: 91
Should be good to go then. Hopefully, the Buffalo's version of Twonky is better than the borked version running on my WDTV LH, it can be "unpredictable" when building its media library database.
Salk SongTowers-RAAL/Salk SongCtr-RAAL/Salk SongSurr ; Rythmik F12 (x2) (my humble setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; Xbox 360; Chromecast; Harmony One; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RaspPi3 w/Digi+ -> AGD DAC19 -> Cavalli LC -> HFM HE-400i ::: CCastAudio -> Schiit Bifrost 4490 -> Schiit Valhalla -> Senn HD600 ::: FooB2K -> Schiit Modi2U -> Schiit Magni2U -> Oppo PM3
laulau is offline
post #8896 of 13381 Old 07-29-2014, 10:21 PM
Liked: 0
Hi,
The Buffalo brand was recommended to me by Denon.
Thanks again everybody and have a wonderful day.
Cheers
Caesar
-Caesar- is offline
post #8897 of 13381 Old 07-31-2014, 09:09 AM
Figarou's Avatar
Quoted: 180 Post(s)
Liked: 78
When the X7200W finally comes out, I was thinking of using the 4520CI as a power amp for the other channels. Batpig told me that was a bad idea in another thread. He said I should get an Emotiva XPA-3. I decided on the XPA-5 after doing some research. It should arrive today. I'd like for it to power the main 5.1 speakers while the 4520CI powers the surround back, wide and height. I noticed in "Custom" mode the FRONT, SURR BACK, and HEIGHT can be changed to any other output. CENTER and SURROUND can't. For the setup I need, I change FRONT to WIDE, correct? This will be my 1st time doing this and I want to make sure I got it right.
Figarou is online now
post #8898 of 13381 Old 07-31-2014, 09:19 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4328
No reason to as there is a dedicated set of Front Wide speaker posts. Just set AMP ASSIGN to "Discrete 11.1CH" and select the "Front" pre-outs.
Figarou likes this.
post #8899 of 13381 Old 07-31-2014, 09:24 AM - Thread Starter
batpig's Avatar
Liked: 3049
There is no need to use the "Custom" amp assign setting at all. That's only needed when there is some non-standard config that you can't achieve through one of the stock amp assign settings.
Just put it in 11ch amp assign mode -- in this mode, all the pre-outs are "hot" so just hook up the amp to the five channels you want to power. The only thing you have to change is the "Main Pre-Amps" sub setting that tells the receiver the FIRST two channels that will be externally amp'd -- in your case just choose "Front" and it will automatically reassign those two amps to the Front Height speakers because it knows your Front L/R are externally amp'd. Then just hook up normally and run Audyssey.
Figarou likes this.
Setup Guide and FAQ
batpig is offline
post #8900 of 13381 Old 07-31-2014, 09:38 AM
Figarou's Avatar
Quoted: 180 Post(s)
Liked: 78
Ok....thanks. I'll try it when the XPA-5 arrives later today.
Once the X7200W is out, I'll do the same.
post #8901 of 13381 Old 07-31-2014, 09:42 AM
Weary Enthusiast
WHATTHEDILEO's Avatar
Quoted: 52 Post(s)
Liked: 46
I'm mapping out my power requirements, and wondering if anyone thinks the 4520 will consume more than 500w if I'm using an EXTERNAL amplifier for the main three channels.
I am powering LEFT/CENTER/RIGHT with an Emotiva XPA-3 Gen2, so I'm quite sure I will never come close to the 780w maximum power consumption spec.
I may hook it up to a Kill-a-Watt to see its instantaneous power consumption.
WHATTHEDILEO
Some people LOVE MUSIC.
Some people LOVE the SOUND of music.
If you don't know the difference, then you LIKE MUSIC.
My slow-cooking 11.4 channel Theater Room quest
WHATTHEDILEO is offline
post #8902 of 13381 Old 07-31-2014, 09:50 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4328
Likely never use > 150W on average even with front 3 powered.
post #8903 of 13381 Old 07-31-2014, 10:25 AM
AVS Club Gold
aaronwt's Avatar
Liked: 2282
In my 7.1 setup my 4520 usually draws around 130 to 140 watts. At least that is what my UPS shows.
WHATTHEDILEO likes this.
aaronwt is offline
post #8904 of 13381 Old 07-31-2014, 10:37 AM
Sam S's Avatar
Quoted: 177 Post(s)
Liked: 61
Yep. What pulls power is extreme bass, i.e. subs, or giant front speakers with full range bass-heavy music. Could never happen with movie soundtracks.
Sam S is offline
post #8905 of 13381 Old 07-31-2014, 05:32 PM
JohnAV's Avatar
Quoted: 176 Post(s)
Liked: 196
On that note, if you are using powered subwoofers, then you no longer using the 4520 CI to reproduce that bass heavy reproduction.
Oppo Beta Group
JohnAV is offline
post #8906 of 13381 Old 07-31-2014, 06:06 PM
bgoering's Avatar
Quoted: 160 Post(s)
Liked: 47
Hi batpig - this caught my attention. I am about to start wiring up my "Multipurpose/Media" room (not really a true HT). I have the 4520 to power a 7.1 system in this room. The room is the bottom floor of a two story pool house with the wife's space on the 2nd floor. To power the 5.1 speakers in her space I have an antique (probably 18-20 years old) Marantz SR5000. The idea at present is to use zone 4 on the 4520 with an adapter that splits the audio off from the HDMI that goes to either optical or coax in on the Marantz, then the Marantz will only be utilized as a power amp. This plan seems to work relatively OK so far in my testing, except she won't have access to the nice airplay, Internet radio, and other network features of the 4520 from zone 4.
I have thus far been under the impression that when the speakers were on in the 4520 the pre-outs were dead, and vice-versa. Are there other modes (like hopefully 7.1 + zone 2) that leaves the pre-outs "hot?" Failing that, can I use that 11ch amp assign mode to do the same thing as 7.1 + zone 2? Also seeing as I only have a single sub in my downstairs setup - will the sub 2 out be able to drive the sub input on the Marantz? I do have 6 channel (5.1) inputs also on the Marantz.
Probably all stupid questions and I should stick to my likely simpler original plan
Thanks - Bill
bgoering is offline
post #8907 of 13381 Old 07-31-2014, 06:27 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4328
The main zone speaker posts and pre-outs are always "hot" if the main zone is powered on. In fact some have placed a mirrored 5.1 setup in another room as a result using both the speaker posts and pre-outs.
post #8908 of 13381 Old 07-31-2014, 06:31 PM - Thread Starter
batpig's Avatar
Liked: 3049
That said if I was in your place I would swap the Marantz for a cheap 5.1 HDMI receiver. You can find something for $150 used without much trouble. Then just run Zone 4 HDMI to an HDMI input on the receiver and call it a day. Eliminate all that extra complexity.
batpig is offline
post #8909 of 13381 Old 07-31-2014, 06:47 PM
bgoering's Avatar
Quoted: 160 Post(s)
Liked: 47
Thanks jd and batpig - food for thought
stef2 likes this.
bgoering is offline
post #8910 of 13381 Old 08-01-2014, 08:44 AM
AVS Club Gold
aaronwt's Avatar
Liked: 2282
The speaker posts and pre-outs are always "hot." In fact some have placed a mirrored 5.1 setup in another room as a result using both the speaker posts and pre-outs.
So even if the zones are off the pre-outs are hot? Why would that be the case? I leave my Zone 2, 3, and 4 off. I would not expect there to be a signal unless I had those zones on.
aaronwt is offline
Denon Avr 4520ci Receiver
