The **OFFICIAL** DENON AVR-4520CI thread - Page 303 - AVS Forum | Home Theater Discussions And Reviews
 877Likes
post #9061 of 13684 Old 08-22-2014, 08:02 AM
UHD Addict
aaronwt's Avatar
Quoted: 5962 Post(s)
Liked: 3669
Originally Posted by harrybnbad View Post
Just wondering why someone needs two additional amps. Oh, unless they are single channel.
I have one, 2 channel amp, and every thing runs great. Now, I have changed it from l/r mains to f/heights and back afew times. I think I like the sound of the denon amps best, so I let it run the mains. I was hoping to be the other way, to try to take some stress of the denon.
What kind of stress will there be? I haven't connected my Front Heights yet but I am running a 7.1 system. My 4520 runs around 130 watts with no audio output and only a few watts higher with audio being output. Even though I'm not using those extra two channels I thought I read that they were powered whether they were used or not.
aaronwt is offline
post #9062 of 13684 Old 08-22-2014, 12:34 PM
RapalloAV's Avatar
Quoted: 1572 Post(s)
Liked: 455
It appears to be a region specific update which does not apply to the USA models.
Do you know how one finds out what the update was for?
I see on the website you have to put your serial number in to get the info, its hard to get that info without pulling out the rack.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #9063 of 13684 Old 08-22-2014, 12:37 PM
RapalloAV's Avatar
Liked: 455
Originally Posted by knoxtn View Post
Are your wides old surround speakers ? They may be wired for bipole???
No they are not. The result is very erratic, you can place the mic in one position and it might show the left wide is out of phase. In another position both are out. In another position the left is out. In another position they are both correct.
Crazy that the mic position changes the result only for the wides. They are wired correctly so I just ignore the result.
Murray Thompson
X Owner RapalloAV
post #9064 of 13684 Old 08-22-2014, 01:38 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7414 Post(s)
Liked: 4121
Originally Posted by RapalloAV View Post
Can you recall a previous Audyssey EQ on the 4520?
I couldn't do that on my pervious Integra 70.4....
Murray, did you try a network save?
AustinJerry is online now
post #9065 of 13684 Old 08-22-2014, 02:14 PM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
I don't believe Onkyo equipment has a network save/restore option at all, unlike D+M.
Selden
Selden Ball is offline
post #9066 of 13684 Old 08-22-2014, 02:28 PM
knoxtn's Avatar
I used to have an Onkyo and I remember something like that as well.. I don't remember which receiver gave me the error.
But now, I moved and don't have room for the wides in the new house.
knoxtn is offline
post #9067 of 13684 Old 08-22-2014, 02:30 PM
Liked: 4121
Perhaps you missed it, Seldom, but Murray recently upgraded to the 4520, which is why you see him frequenting this thread now.
post #9068 of 13684 Old 08-22-2014, 02:44 PM - Thread Starter
batpig's Avatar
Quoted: 3687 Post(s)
Liked: 3530
Didn't you mention previously that your wides are mismatched (i.e. not at all the same speaker family as the other speakers)? What kind of speakers are they?
False positives for the polarity check can occur due to room acoustics and also due to speaker design. For example, some speakers intentionally wire one of the drivers out of phase with the others to improve the response at the crossover freqs. As an example of room acoustics, the back right corner of my living room space opens up to a hallway to the bathroom. When my right surround speaker was on a shelf close to that hallway, I would always get a phase error. I adjusted its position a bit so it was further from the big opening and no longer get the error.
False positives like this are probably why Onkyo dropped the polarity check portion of Audyssey setup a few years ago.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #9069 of 13684 Old 08-22-2014, 03:04 PM
RapalloAV's Avatar
Liked: 455
My wides are the only mismatched in the room, Cambridge Audio Minx Min 21, they are wired correctly.
http://www.amazon.com/Cambridge-Audi.../dp/B008S4IT0S
Murray Thompson
X Owner RapalloAV
post #9070 of 13684 Old 08-22-2014, 03:17 PM
RapalloAV's Avatar
Liked: 455
No Jerry I haven't tried that yet. I only wanted to know if it was possible on this new AVR.
Im currently dealing with a horrible null at 47Hz which seems to be at most seats. Not sure how to tackle that since all my room acoustics and bass traps are done. I don't even know what sounds I might be missing in the region of 47Hz. Even though this null disappoints me the sound is still spectacular and the bass to die for. Just hate something not right though!!!
Murray Thompson
X Owner RapalloAV
post #9071 of 13684 Old 08-22-2014, 03:31 PM
jdsmoothie's Avatar
Quoted: 14365 Post(s)
Liked: 6785
The serial number is required; however, it should also be listed on the box (you did keep the box, right?).
jdsmoothie is offline
post #9072 of 13684 Old 08-22-2014, 03:43 PM
RapalloAV's Avatar
Liked: 455
Yes I did keep the box but that's at work. Saturday here, will need to wait till I return back to work on Monday. Thanks for your help.
Murray Thompson
X Owner RapalloAV
post #9073 of 13684 Old 08-22-2014, 03:44 PM
Liked: 4121
The way to address a null is to place a sub in the center of the null. I don't recall whether you have any flexibility left WRT sub placement. DSP can't really pull a null up.
post #9074 of 13684 Old 08-22-2014, 04:15 PM
UHD Addict
aaronwt's Avatar
Liked: 3669
What good is having no way to save the data? Even my ancient 3808 receiver from 2008 could save over the network. I figured this was a standard feature of receivers by now? I'm very surprised it isn't.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #9075 of 13684 Old 08-22-2014, 04:28 PM
Liked: 4121
Having been a Denon user for quite some time, I can't imagine being without this feature. There have been numerous occasions when being able to restore the configuration has saved me a lot of time and effort. It has become second nature to run a network save immediately after running a new Audyssey calibration.
post #9076 of 13684 Old 08-22-2014, 04:31 PM
jdsmoothie's Avatar
Liked: 6785
Yeh .. that's our Jerry ... also known as Mr. Save & Load.
Craig Peer and RayWK like this.
post #9077 of 13684 Old 08-22-2014, 05:00 PM
RapalloAV's Avatar
Liked: 455
Ive moved the subs everywhere within the front width of the room, I have no other options and I believe its in the length of the room. There are no spaces available in the length.
Do you know what I might be missing sound wise in the region of 47Hz?
What about tuned traps?
Murray Thompson
X Owner RapalloAV
post #9078 of 13684 Old 08-22-2014, 05:36 PM
BB1111's Avatar
Quoted: 82 Post(s)
Liked: 34
Does anyone have a list of what has actually been changed in the firmware updates?
BB1111 is offline
post #9079 of 13684 Old 08-22-2014, 05:42 PM
Liked: 4121
I had an experiment with GIK Scopus tuned traps. If you search the REW thread for the word "Scopus" you will find my write-up. Again, a dip indicates a lack of energy. A trap is an absorber of energy, which is exactly the opposite of what is needed to fix a dip. The 47Hz frequency needs to be excited, which is why I questioned whether you could solve it by moving one or more subs. I appreciate that your placement options are limited, so I am not sure what other solutions might be available.
Take a look at the chart here. This will give you an idea of what is in the 47Hz range. How wide is the dip? You haven't posted any measurements in a while, so we are flying blind here. If the dip is narrow, i.e. disappears when you apply 1/12 or 1/6 smoothing, there is a good chance it is inaudible, in which case you don't need to worry.
Edit: Here is a link to the membrane trap eval: Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
post #9080 of 13684 Old 08-22-2014, 05:54 PM
jdsmoothie's Avatar
Liked: 6785
See post #4 of this thread. Last update was back in Feb.
post #9081 of 13684 Old 08-23-2014, 05:21 AM
kbarnes701's Avatar
Quoted: 6818 Post(s)
Liked: 5247
kbarnes701 is offline
post #9082 of 13684 Old 08-23-2014, 01:50 PM
harrybnbad's Avatar
Quoted: 58 Post(s)
Any word on what the update is
harrybnbad is offline
post #9083 of 13684 Old 08-23-2014, 01:53 PM
jdsmoothie's Avatar
Liked: 6785
post #9084 of 13684 Old 08-26-2014, 01:13 PM
JohnAV's Avatar
Quoted: 361 Post(s)
Liked: 514
AFAIK, there is no update for the USA units.
Would expect some minor network tweaks or network app changes eventually. But yes no updates since 2/19/2014 (3525-8853-5475)
Oppo Beta Group
JohnAV is offline
post #9085 of 13684 Old 08-26-2014, 01:27 PM
jdsmoothie's Avatar
Liked: 6785
post #9086 of 13684 Old 08-26-2014, 01:27 PM
jdsmoothie's Avatar
Liked: 6785
But hey .... for those of you patiently waiting for another UAP price drop on the 4520CI .. that day has come again. Call for pricing.
post #9087 of 13684 Old 08-26-2014, 02:35 PM
UHD Addict
aaronwt's Avatar
Liked: 3669
As usual soon after I get something the price drops like a rock.
aaronwt is offline
post #9088 of 13684 Old 08-26-2014, 08:54 PM
bronxkid's Avatar
Quoted: 62 Post(s)
After weeks of wavering between denon, marantz and yamaha models I decided to jump on the deal for the 4520. I figure at this price range getting the flagship model for a quality receiver is difficult to find. One thing though: I realized it came out in 2012. Am I going to miss out on any features available this year's AV receiver models other than Atmos which I don't care about? I also don't need multiple sub eq
bronxkid is offline
post #9089 of 13684 Old 08-26-2014, 10:53 PM - Thread Starter
batpig's Avatar
Liked: 3530
Well the 4520 already has multiple sub EQ, so no difference with the new models.
Atmos is obviously the biggest change. The other meaningful changes are ancillary features like wifi, Bluetooth, digital audio to zones 2/3. But in most other respects the 4520 actually outclasses the 4100/5200 models, as its true replacement (physical size, amp quality, 32 bit processing architecture) will be the X7200W which will probably retail for around double what you can probably get the 4520 for.
So I guess I endorse your decision if you like "flagship" quality and don't give a hoot about Atmos the a steeply discounted 4520 seems like a sweet buy.
Setup Guide and FAQ
batpig is offline
post #9090 of 13684 Old 08-27-2014, 01:24 AM
Dreamliner's Avatar
Quoted: 714 Post(s)
Liked: 216
I've been through a lot of receivers over the last few years (887/888/3310/4311/4520). I'm kinda glad the next Flagship won't be massively better for the same price.
I have a feeling it may be awhile until there are many Atmos Blu-rays. As it is there isn't a ton of DTS NEO:X. I'll probably pick up the next flagship when it releases...hopefully 2016/17 along with a 4K projector.
The only thing that concerns me is if Atmos takes off, I'm assuming the Blu-rays will be mastered with Atmos and Dolby TrueHD so I'd have only up to 7.1 information. If so, the Dolby processing is considerably older than NEO:X and I'd have to rely on Audyssey to uprez to 11.2, right?
All depends on if/when Atmos replaces DTS on Blu-ray. Since DTS-HD took off, Dolby TrueHD is practically extinct on new release Blu-rays. If a bunch of Atmos Blu's release next year and DTS goes away I might get pissy.
Dreamliner is online now
Denon Avr 4520ci Receiver
