The **OFFICIAL** DENON AVR-4520CI thread - Page 339 - AVS Forum
post #10141 of 10154 Old 10-18-2014, 09:33 AM
AustinJerry's Avatar
Quoted: 741 Post(s)
Liked: 789
Originally Posted by batpig View Post
Just as an alternate suggestion, be aware that the Denon has picture control adjustments which are input specific. So for example what you can do is calibrate your TV for your "reference" input as a baseline (assume that would be your oppo) and disable the additional video processing for that input in the receiver, and then make adjustments relative to that baseline for the uverse input. This would allow you to have different picture calibration settings for the two inputs with one HDMI connection to the TV.
This might be an alternative for some users, but the picture controls on the Denon are nowhere near as comprehensive as those on the display itself.
AustinJerry is online now
post #10142 of 10154 Old 10-18-2014, 01:00 PM
chiptouz's Avatar
Quoted: 24 Post(s)
Liked: 59
Bat pig/AustinJerry,
Thanks for the input, but could you answer the question? If you don't know, no problem. I appreciated that you answered already.
Chip
Argyl Home Theater - Indefinitely Delayed
My Movie Library - and still growing!
Family Room: Sharp LC-80uq17u + Denon 3808ci + Oppo 93, Speakers: C: Polk CSi-A6, F(L+R): Polk Rti-A7, S(R+RS) Polk TC60i, Sub: HSU – VTF3-MK4
chiptouz is offline
post #10143 of 10154 Old 10-18-2014, 01:07 PM
Quoted: 741 Post(s)
Liked: 789
Chip
What question is unanswered? Is the way you are proposing the only way to accomplish your objective? Yes, as far as I know. Are there any differences between Monitor1 and Monitor2? Already answered, no difference that I am aware of.
post #10144 of 10154 Old 10-18-2014, 02:18 PM
Dave_A_Anderson's Avatar
Quoted: 23 Post(s)
Liked: 8
Question concerning monitor out 1 and 2. On my sharp 80uq17u I like to use separate video inputs for uverse and my oppo 93. Is the only way to do this is by using both monitor outputs 1 & 2? Is there any video differences between these two? If anyone wonders why I like to use the different inputs on the tv is because I have different calibrations for tv and for movies. If I just use monitor 1 I would need to change this depending on the feed instead of it being automatic with the tv input.
The manual only mentions that ARC is supported on MONITOR1 but not MONITOR2. I see no other difference.
It does sound like you could select either of those at the TV and get what you want. There is a note on p.190 of the manual indicating that the AVR will try to negotiate a common resolution supported by both devices that are connected. As long as the input at the TV that is NOT selected reports the same capabilities as the one that is in use or deactivates completely it should be fine.
Dave_A_Anderson is online now
post #10145 of 10154 Old 10-18-2014, 04:51 PM
chiptouz's Avatar
Quoted: 24 Post(s)
Liked: 59
Thanks all! I appreciate it.
chiptouz is offline
post #10146 of 10154 Old 10-18-2014, 05:54 PM
Quoted: 23 Post(s)
Liked: 8
Oops, I was looking at the 5200 manual. Details about the two outputs on the 4520 are on p.130 of its manual. Seems like the same applies but you might want to test it at a dealer if possible, or see if you can work something out where you can bring home a floor model to try before you commit.
post #10147 of 10154 Old Yesterday, 06:04 AM
jrhooper1963's Avatar
Quoted: 14 Post(s)
Anyone out there that has went from separate components,to using just the 4520 for amplification? If so, what are your thoughts? Do you feel you are missing out on anything?
THANKS !!
jrhooper1963 is offline
post #10148 of 10154 Old Yesterday, 06:07 AM
gadgtfreek's Avatar
Quoted: 115 Post(s)
Liked: 323
I went from an Outlaw 7125 and X4000 to the 4520.
So far watching a good 15 hours of HDTV, and two movies (cranked to reference 0.0), I have been very happy. My speakers are very efficient though. I'm sure separates matter more for power depending on speaker type and specs.
As far as SQ, I think it sounds great. Also runs cool/warm after a 2 hour movie at high volume.
65" VT50 / BDP-S7200
Denon AVR-4520CI
Klipsch RF82 II and RC62 II / Hsu VTF-15H (2)
Directv HR44-200 / HR24-500
gadgtfreek is online now
post #10149 of 10154 Old Yesterday, 06:10 AM
Quoted: 14 Post(s)
My speakers are 8 ohm, and 87 decibals sensitivity.
post #10150 of 10154 Old Yesterday, 06:18 AM
gadgtfreek's Avatar
Quoted: 115 Post(s)
Liked: 323
I am not familiar with speakers that low. If there is an owner's thread here, you might be able to get better info. Mine like 98db sensitivity, in theory they need very little power to get loud, but I do like the head room. You may be better suited by getting an X4000 on its way out and an emo or outlaw amp.
I am constrained on space, so it was nice going from two large boxes to one
Denon AVR-4520CI
post #10151 of 10154 Old Yesterday, 06:34 AM
Archaea's Avatar
Quoted: 529 Post(s)
Liked: 768
THANKS !!
I went from a Onkyo PR-SC5508 with a Sherborn 7-350 amp to a Denon 4520CI. I don't think I'm missing anything. But I had/have very sensitive PA speakers that get to reference with like 8-16 watts. The speakers I'm using currently are 96dB @ 1 watt, the previous were 98dB @ 1watt.
"Without subs it's just background music - with subs it's the main event!"
Archaea's Theatre Room
2011 KC Sub Shootout
2012 KC Blind Sub Shootout
My Subwoofer Recommendations by Pricepoint
Archaea is online now
post #10152 of 10154 Old Yesterday, 07:06 AM
JaremyP's Avatar
Quoted: 27 Post(s)
Liked: 27
I'm wondering the same thing about the 4520 vs separates. I have Traid silver 6 LCR and silver 4 surrounds. All in wall. The mains are 92 db 2.83v/1m. The surrounds are just 83 db/1w/1m though. All are 4 ohm. It's a 7.2 config.
I'm driving the speakers off emotive xpa3 and xpa5 right now and need a new preamp. I was thinking to just get a X4000 or SR7008 to use as the preamp, but you can get a 4520 now for almost the same at the SR7008.
If the 4520 could negate my amps it would be interesting. Then upgrade again later when the X7200 is on close out. I don't need atmos or 4k now.
JaremyP is online now
post #10153 of 10154 Old Yesterday, 07:24 AM
gadgtfreek's Avatar
Quoted: 115 Post(s)
Liked: 323
I can tell you this, the X4000 is a nice preamp with XT32 and multi sub eq. Real cheap right now too.
I needed the room and my X4000 failed, so it made sense just to grab a 4520 at $1100 in my situation. But some would probably still benefit from separates.
Denon AVR-4520CI
post #10154 of 10154 Old Today, 10:53 AM
rlb
rlb's Avatar
Quoted: 182 Post(s)
Liked: 113
Numerous posts on this thread have mentioned problems with ARC always directing the Denon to the TV input when all components are initially turned on. The "fix" detailed on the following post worked well for my Harmony when correcting the issue with my Samsung: OFFICIAL Samsung 4k HU8550 and HU9000 thread
rlb is online now
Denon Avr 4520ci Receiver
