The **OFFICIAL** DENON AVR-4520CI thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 879Likes
post #991 of 13731 Old 11-19-2012, 06:00 AM
kelseyhorne's Avatar
Sweet thanks for this
kelseyhorne is offline
post #992 of 13731 Old 11-19-2012, 06:52 AM
Irwinroad's Avatar
Quoted: 88 Post(s)
Liked: 44
I added the discreet codes to my URC remote to scroll the input sources. Network comes up but
I do not see "Network" in the menu to hide sources. There is no high speed internet where the
4520 is located.
Is there any way to delete network?
Irwinroad is offline
post #993 of 13731 Old 11-19-2012, 06:57 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7560 Post(s)
Liked: 4224
Originally Posted by Tachy View Post
Curious if anyone has tried the new firmware update that came out today, and if anyone knows what it fixes?
Since I have two cases open with Denon support on the 4520, I called and asked if there are any release notes on this firmware version.  The answer I received:  information on firmware updates are not made available to customers.  I asked if there had been any progress on my two cases.  Answer: no.
JD, do you have any insight regarding the changes in this FW upgrade?
AustinJerry is offline
post #994 of 13731 Old 11-19-2012, 07:15 AM
Oven's Avatar
Longest firmware update I've ever done. 45 min. I'm hoping it clears up the HDMI issues I've been experiencing.
Oven is offline
post #995 of 13731 Old 11-19-2012, 07:50 AM
Oven's Avatar
Nope, didn't fix my issues.
Oven is offline
post #996 of 13731 Old 11-19-2012, 07:55 AM
ccotenj's Avatar
Liked: 101
can you refresh my memory as to your hdmi issues? maybe "we" can help... smile.gif
- chris
ccotenj is offline
post #997 of 13731 Old 11-19-2012, 08:41 AM
Oven's Avatar
I've been on the phone with Denon all morning. Looks like it might be a hardware issue. After 3 days of perfect use, my screen started glitching and having handshake issues. It was turning rainbow colors and pixelated. I've tried different HDMI cables, and even a different TV with a shorter cable (as opposed to the 35' cable I had to my projector). They're ready for me to send it in to repair.
Oven is offline
post #998 of 13731 Old 11-19-2012, 09:54 AM
kamiraa's Avatar
Liked: 31
Anyone know if the Marantz PM8004 would be a good addition for the 2 channels to expand to 11.2 from 9.2?
Problem is it's only rated at 70W (8 ohms), 100W (4 ohms).
I think it says you can run it in straight "power amp" mode. I'm guessing that disables the volume control and preamp features??
I'm asking because a local retail store is clearancing these guys at $400 appiece .. .
http://us.marantz.com/us/Products/Pages/ProductDetails.aspx?CatId=HiFiComponents&SubCatId=0&ProductId=PM8004
kamiraa is offline
post #999 of 13731 Old 11-19-2012, 11:18 AM
Liked: 4224
On the AVR4311, the current firmware component versions could be displayed by pressing and holding the Status and Return buttons when powering on the AVR. Is there similar functionality on the 4520 (other than the Info area in the Menu)?
post #1000 of 13731 Old 11-19-2012, 12:02 PM
Tachy's Avatar
The firmware update did not effect the Pandora or Spotify issues.
Tachy is offline
post #1001 of 13731 Old 11-19-2012, 01:03 PM
Liked: 4224
Firmware Update Warning
I just completed updating the 4520 firmware to version 3325-0792-1424.  As per the update estimate, it indeed took approximately 46 minutes to complete.
While I know from experience that a FW update is not supposed to affect the AVR configuration or its Audyssey calibration, being overly cautious, I checked the settings anyway.  Much to my surprise, the AVR calibration settings (e.g. distances and trims) had reverted to the previous calibration values.  Anyone who upgraded from the AVR-4311, or has followed the 4311 thread, will be familiar with a peculiar behavior in which the 4311 reverts to prior calibration settings after a power interruption.  Evidently, this behavior can happen after a firmware upgrade as well, which could have a bad impact on an unsuspecting owner.
I always save the AVR's configuration after a calibration, so it was a simple process to restore the calibration settings from the most recent save.  My advice to all 4520 owners is to take the following steps when you upgrade the firmware:
- Make sure you have a successful configuration save file (make sure it isn't all zeros). The save process is documented here.
- Jot down (or take a screen shot) of your settings.  Go to \Speakers\Audyssey\Check Results.
- Conduct the FW upgrade.
- Immediately after it has finished, check the settings.
- If they haven't changed, you are OK.  If they have changed, restore the settings from the Save file you created in the first step.
If anyone else observes that settings have reverted to previous values during the FW upgrade, please post a comment in this thread so we can determine if this is an isolated case, or a repeatable bug.
post #1002 of 13731 Old 11-19-2012, 02:03 PM
kamiraa's Avatar
Liked: 31
Will do when I get home Jerry. I'll post later tonight
kamiraa is offline
post #1003 of 13731 Old 11-19-2012, 02:27 PM
jdsmoothie's Avatar
Quoted: 15009 Post(s)
Liked: 7236
Yup. Post #4 updated.
jdsmoothie is online now
post #1004 of 13731 Old 11-19-2012, 03:44 PM
streetsmart88's Avatar
Setup was very simple. Denon has put a major effort to make the 4520 more user-friendly and this is evident with the way it hand-holds you through the setup process. The only problem with the setup was that the audio sounded horrible and sure enough, Audyssey Dynamic Volume had been set on by default and that resulted in a very muffled sound. Somehow, the subwoofer level was at -10 and that extinguished the bass so I pushed that to zero. I'm not sure if Dialog Enhancer was on and I switched that off too. After these adjustments, the sound was good. For video, I only have a pass thru so it was not a problem.
I like the remote and the menu better than the previous models (4311, 4810, 3808). It is friendlier and easier to navigate.
Since the unit is only on loan, I haven't purchase the Audyssey Pro license yet so immediately, you can detect an audio difference, particularly in the target curve. I have a large room so I use the Pro target curve with a steeper high frequency roll-off. Without this, there is a lot more sibilant sounds. There are other audio differences because of Pro but that's not relevant to this thread.
Mark
streetsmart88 is offline
post #1005 of 13731 Old 11-19-2012, 03:47 PM
jdsmoothie's Avatar
Liked: 7236
Before even considering Audyssey Pro, you really should read the Audyssey 101/FAQ guide linked in my sig to ensure you have properly used the Audyssey setup procedure. Dyn Volume was set to ON as you set it that way during the setup process.
post #1006 of 13731 Old 11-19-2012, 04:53 PM
kaphely's Avatar
Well thanks for posting that! I hesitated to do a save prior to do the update but because of your post I decided to save my settings first. Good thing I did because my receiver was also set to previous settings after the update as it did with yours. So I can confirm it is not isolated but reproducible.
I checked the change log in post #4. First, where do you get this info jdsmoothie? Do you work for Denon? Anyway, it is good that a guy like you give us this info!
I expected more from this update though, first I would have thought they would fix the Save issue where you can't save unless your network is set to off in standby. I also reported a couple of Web GUI bugs to Denon that would have been easily fixable, likethe fact that the web GUI reports my sub distance as 1/10 of what the GUI on TV does and the fact that some options are available and should not be like two channel speaker setup when I already use all amps for surround. This is grayed out on the TV GUI. Anyway as a first time Network AVR user, can I expect these to be fixed? Or will Denon ignore what I reported?
So thanks again for saving me a lot of trouble AustinJerry!
Home Theater: Denon AVR-4520CI, BDP-2010CI, Hitachi 62VS69A, Paradigm Monitor 7 v3, CC-370 v4, ADP-190 v6, Mini-Monitor v4, PW-2200 v2
Living Room: Denon AVR-2807, DVD-1930CI, Samsung LN40B540 40" LCD, Apple-TV, Paradigm Titan Monitor v6, PDR W100
Patio: Paradigm Stylus-370 (Zone 2 of living room)
kaphely is offline
post #1007 of 13731 Old 11-19-2012, 04:54 PM
As a clarification, I've had an Audyssey Pro kit for more than 3 years now and I've used it progressively with a Denon 3808, then 4810 and finally a 4311. I've also been following the Audyssey thread daily for the last 6 years so I'm pretty familiar with the FAQ/Setup Guide of Keith and Giomania. smile.gif
The problem is that for each new AVR, you need to buy a license for $150 and if I'm not going to keep the 4520, I'm not spending that money.
I'm not fully certain but I really don't think that Dynamic Volume is set on or off during the setup process. It's the default setting after the setup.
Mark
post #1008 of 13731 Old 11-19-2012, 05:32 PM
turnne1's Avatar
Quoted: 1943 Post(s)
Liked: 479
I would say send it in
or better yet....get a replacement unit from the dealer you bought it from
Somehow....in my experience these issues dont get better and can be very frustrating
A few years ago I had a 4308...Spent all kinds of crazy time on the phone with Denon support
Their attitude was that it was something I was doing incorrectly...??
Anyway...finally I sent it in for repair to Panurgy
Got it back 3 weeks later..and the problem was still there
After a "lovely" conversation with their tech support... Denon decided they could figure out a way for me to give them the unit back for a 100% refund
Warren
Rm 1 Samsung 65KS9800 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon 4520 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 55KS8000 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is offline
post #1009 of 13731 Old 11-19-2012, 05:34 PM
joerod's Avatar
Quoted: 719 Post(s)
Liked: 653
I did a little "write up" on the 4520...
http://hstrial-jrodriguez996.homestead.com/DENON-AVR-4520CI-RECEIVER-REVIEW.html?_=1353372722253
napiermark and tkroeker like this.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is online now
post #1010 of 13731 Old 11-19-2012, 05:46 PM
Woof Woof's Avatar
Quoted: 242 Post(s)
Liked: 120
Tks joe. Reading now!
Woof Woof is online now
post #1011 of 13731 Old 11-19-2012, 07:18 PM
Liked: 4224
When I was using a 4311, I was used to being to establish custom settings for 2-channel playback.  On the 4520, when I go into Speakers\Manual Setup, the 2ch Playback option is grayed out.  When does this option become configurable?
post #1012 of 13731 Old 11-20-2012, 02:14 AM
jdsmoothie's Avatar
Liked: 7236
AFAIK, the "2CH Playback" settings (p. 145 OM) should always be available. Try setting AMP ASSIGN to "9.1CH/2CH Front".
post #1013 of 13731 Old 11-20-2012, 02:17 AM
jdsmoothie's Avatar
Liked: 7236
Mark
My point was that you say you "pushed the 'sub' volume to zero" which I took to mean you adjusted the level with the remote rather than reducing the gain on the sub and running Audyssey again.
post #1014 of 13731 Old 11-20-2012, 06:35 AM
Liked: 4224
I'll be glad to try this temporarily, but I have a 11.1 setup. IIRC, on the 4311, the custom 2CH settings were invoked anytime I selected stereo output, regardless of the amp assign configuration.
post #1015 of 13731 Old 11-20-2012, 07:09 AM
Vyrolan's Avatar
Don't know if I am one whom you trust wink.gif, but I am using the Darblet with the 4520. I recommend it highly. Maybe you need a Thanksgiving Day present?
I was using the Darblet too and it is indeed nice. I had to send it back though since it was causing me some HDCP issues. =( While noticeable, I wouldn't say it was earth-shattering in my setup so not a huge loss.
who out there is using zone 4 out? if anyone, what kind of behaviour are you getting if you try to send the same source to zone 1 and 4 and the sinks differ in capabilities? does it merely send lowest common denominator (hoped for), or not work at all?
I FINALLY have my 4520...and I'll probably be using the Zone 4. I'm going to try a few crazy ideas with it and see how it goes.
Vyrolan is offline
post #1016 of 13731 Old 11-20-2012, 07:15 AM
joerod's Avatar
Quoted: 719 Post(s)
Liked: 653
post #1017 of 13731 Old 11-20-2012, 07:22 AM
Liked: 4224
Originally Posted by joerod View Post
Joe, I want to make sure your situation was similar to mine. Had you actually done more than one calibration on the 4520? If no, then there wouldn't be a previous calibration to revert to. If yes, were the differences between the two calibration settings such that it would be obvious that the settings reverted? For example, the distance setting for my mains with the previous calibration was 9.9', and the current calibration has the distance as 10.0', so I immediately noticed a difference. Just checking...
post #1018 of 13731 Old 11-20-2012, 08:21 AM
joerod's Avatar
Quoted: 719 Post(s)
Liked: 653
Makes perfect sense. I only did one calibration. I was worried I might lose settings but even if I did I would just pull out the mic again. smile.gif
post #1019 of 13731 Old 11-20-2012, 09:39 AM
nismo604's Avatar
Joe, I've read your review and you mentioned that the Onkyo and Denon sound different, but didn't elaborate in what way. Can you please expand on how they differ sonically? Also what makes the XT32 better on the Denon?
nismo604 is offline
post #1020 of 13731 Old 11-20-2012, 09:42 AM
RSTide's Avatar
I have a 7.2 setup and the 2ch options are grayed out for me as well.
I think they must not be configurable unless you set up the amp assignment for 2ch audio.
OTOH, if you don't have dedicated separate fronts for 2 channel, why would you need separate 2ch settings?
RSTide is offline
Denon Avr 4520ci Receiver
