The **OFFICIAL** DENON AVR-4520CI thread - Page 343 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #10261 of 13588 Old 10-30-2014, 08:34 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6840 Post(s)
Liked: 3809
Originally Posted by gadgtfreek View Post
I had an audyssey pro cal from chad b, before and after graphs were very helpful in that, just like a display cal.
Just to be clear, the Audyssey's Pro "Certificate", which shows before and after graphs, can be a bit misleading. The after graph is an interpolation of the expected response after applying the Audyssey filters, not an actual room measurement. In my experience using actual REW measurements after a calibration, the certificate graphs are revealed to not always be accurate. Besides, the certificates are presented with 1/3 smoothing, which masks most of the room response issues anyway.
AustinJerry is offline
post #10262 of 13588 Old 10-30-2014, 10:52 AM - Thread Starter
batpig's Avatar
Quoted: 3597 Post(s)
Liked: 3440
Originally Posted by mnc View Post
I don't doubt the benefits of measuring room response to improve sound quality, that wasn't my point. I was simply saying that today's Audyssey equipped receivers already contain the necessary software and hardware to do exactly that. I am just wondering why they don't make the option of a "before Audyssey correction" graph on-screen. It should be very simple to have that capability, especially on the higher-end models that use XT32 such as the 4520.
Originally Posted by AustinJerry View Post
Let's make sure you understand the "EQ" charts you are referencing, located in the Audyssey setup area in the menu, sub-section "View Results". These charts provide a rough approximation of the correction being applied by the Audyssey filters. They do NOT represent "after" measurements and, IMO, are marginally useful.
It is worth pointing out that the Audyssey EQ graphs in the "Results Check" section of the GUI are in a way a "before correction" graph. What they literally show is the correction being applied, so (assuming you are looking at the EQ graphs for the "Flat" curve) the "before correction" response should essentially be the inverse of the correction graph.
That said, as Jerry implies these graphs should be taken with caution. For one, the resolution is pretty low. Second, it tends to display wonky things below the crossover freq that seem implausible. That said, above the approximate crossover frequency they are a pretty reasonable approximation of the (upside down) before response.
mnc likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10263 of 13588 Old 10-31-2014, 06:36 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Playing around more last night.
After running audessey the other day everything sounded great. So the person I am that messes with everything and loves bass decided to play.
My sub setup is:
2 Martycubes up front in each corner with inuke 3000dsp
2 Infinity BU 120 (12 inch)
While playing music and movie clips it sounded like I was getting some frequencies cancelation. So for fun I changed the phase on the rear 2 infinity's (they are stacked right behind MLP) to 180 and holy crap. It was like night and day, I measured and picked up about 10-15 db more. I had to set the channel levels down way more.
Before audessey I did not need to set out of phase so why would it need it now? Do you think by the distanced and delays added by audessey?
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #10264 of 13588 Old 10-31-2014, 06:37 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Double post.
bluer101 is offline
post #10265 of 13588 Old 10-31-2014, 06:48 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5079
My sub setup is:
Changing the sub distances (delays) has the same effect as changing the phase knob on the sub. Audyssey does not always (usually?) get the phase relationship between the subs and the mains right. This is not surprising because Audyssey never measures the mains and subs playing together, so the delays set for the subs are calculated, not measured.
If you have measuring equipment and software like REW, you may care to take a look at the Sub Distance Tweak Guide linked in my sig.
kbarnes701 is offline
post #10266 of 13588 Old 10-31-2014, 07:08 AM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Thank you for the link. After reading that it makes sense.
Before audessey I was using out of box settings which distances are set at 12 ft for everything.
I run the 2 Martycubes as sub 1 and the 2 12's as sub 2. After audessey it set them almost perfect. Sub 1 at around 11 ft and sub 2 around 3 ft.
So if I'm right it has changed the phase by distance which is one third the distance before audessey.
I need to get a mic and rew.
bluer101 is offline
post #10267 of 13588 Old 10-31-2014, 07:17 AM
kbarnes701's Avatar
Liked: 5079
Yes - your findings seem logical to me. The main thing is that you have adjusted the phase on one pair of subs and now, it seems, you have all the subs in phase with each other. Your listening tests and SPL readings seem to confirm this.
A suitable mic for REW is about $100 and the software is free. If you decide to go that route, check out AustinJerry's terrific guide to getting set up with REW and how to interpret the results of the measurements. It is the 'bible' for anyone using REW and is a masterly work in itself. It is linked in his sig IIRC.
post #10268 of 13588 Old 10-31-2014, 07:17 AM
Floran's Avatar
A Few Questions re 4520 Operation
I have a few questions on a few issues I noticed on how the 4520 operates; I'm thinking that I hopefully missed some setup parameters (or maybe it's just the way it operates):
1. When I turn it on using the red power button on the remote, it seems like all 4 zones are switched on. When I turn it off the front display stays dimly lit reading "Main zone off"; to turn it off completely so that the front display goes dark I need to cycle through the remaining zones and turn them off. Am I doing something wrong?
2. When everything is turned off in my HT (all HDMI connections) setup and I turn on the cable box and the TV using the Comcast remote the receiver turns on too but does now switch to the SAT/CABLE input, so I need to do that too as an extra step. With the 4310 this was working just fine, no switching from whatever HDMI input (or HD/Internet Radio) was previously used to sat/cable was necessary. I have the HDMI CEC turned on (except for power off command).
3. Is the 4520 missing the HDCD decoder (4310 has it, and I think 4311 has it too)?
4. Sometimes it seems like using the TV's remote to send commands like Play, Stop, FF, REW to the DVD/BR player does not work, or it take a few minutes to start working. Did you experience this? (again, the 4310 did not have this problem)
Thanks, F.
Floran is offline
post #10269 of 13588 Old 10-31-2014, 09:35 AM
Floran's Avatar
Originally Posted by EMSone View Post
Just upgraded from the 4310ci to the 4520ci, and boy what an adventure it was. First thing I noticed was the weight, they nearly weighed the same, after removing the 4310ic and installing the 4520ci and running the audyssey calibration I was VERY disappointed by what I was hearing. Here is where the adventure began, because I know that this unit should sound better than my old one. My setup: 7.2 Mirage Speakers with 2 Prestige s10 subs, what the 4520ci MultEQ XT 32 did to my subwoofer levels was laughable, -9 -10?! I knew something was odd when during the setup it asked to level EACH sub at 75db, solution, I used the y adapter and manually leveled both subs to 75db and switched back and forth from the y adapter to the dual outputs until each sub calibrated out to the same level witch ended up being -5/-5. After all of that I was still highly disappointed with the sound, the 4520ci MultEQ XT 32 calibration's midrange response was VERY thin! It was like I was using 7 satellite speakers and the bass was still too low.
Now I am very upset, and started thinking how can I get this receiver to sound like my old one, then I had an epiphany, use the 4310ci as a baseline for the 4520ci. The most important variable in the calibration was the microphones, the old mic (DM-A409) proved to be more sensitive, by about 2db. After recalibrating with the old mic, voilà, pristine sound, oh then I adjusted each sub by the +2db difference then added 1 more db for effect (-2db each sub) and I was in heaven! The accuracy is unparalleled, I have to towers on the floor and my center is 5ft off the ground and the L-C-R sweeping effect is seamless, actually all channels are! Be sure to adjust your crossovers to your liking and use LFE+Main if your fronts don't produce enough bass for you.
Interestingly, it looks like I think I'm going through a similar experience.
I first calibrated the 4520 with its own mike, and although at first I liked the tight bass, after more auditioning the sound felt too bright with not enough bass.
Then I tried calibrating using the 4310 mike, and the sound it's much more like I was used from the 4310, except for the tighter bass.
Which makes me actually wonder in the end whether the calibration microphones that come with the 4310 and 4520 are really interchangeable or is one of them faulty (at this point I would suspect the 4520's one).
Did you guys have similar experiences?
Thanks again, F.
Floran is offline
post #10270 of 13588 Old 11-01-2014, 09:35 AM
Weary Enthusiast
WHATTHEDILEO's Avatar
Quoted: 56 Post(s)
Liked: 52
I just watched Transformers - Age of Extinction on my PS3/4520 setup in 9.1 configuration. The Front-Wides sounded quite unnatural, to the point of real distraction (imagine an artificial surround mode like 'Concert Hall', with terrible simulated echo, with the channel volume boosted higher than the other channels). This only happened when someone was speaking off-camera to the LEFT or RIGHT (i.e. the Wide channel was correct to be coming alive, but did not blend).
I have never experienced this type of response from the Wide channels - they have always performed very nicely. I have watched only ~16 movies with this setup (some of those were Stereo - expanded to 9.1) but this is a unique case. This disc has Dolby Atmos, with a TrueHD bed for older setups without Atmos. I wonder if this has anything to do with my experience?
WHATTHEDILEO
Some people LOVE MUSIC.
Some people LOVE the SOUND of music.
If you don't know the difference, then you LIKE MUSIC.
My slow-cooking 11.4 channel Theater Room quest
WHATTHEDILEO is offline
post #10271 of 13588 Old 11-01-2014, 09:45 AM
Liked: 3809
I have DSX (wides and heights) engaged for all non-music sources, all of the time. As a general rule, the wides are never over-exaggerated. Occasionally, usually on a satellite broadcast, DSX adds a bit more reverberation than I like, so I just switch it off.
What I am saying is that I don't think there is an issue with DSX itself, and when DSX sounds bad, it is usually the content being watched. This assumes, of course, that you have a good calibration. The only way to test that out would be to re-run the calibration and watch the same source material again.
post #10272 of 13588 Old 11-01-2014, 04:04 PM
audio4life's Avatar
Liked: 300
I recently ordered the 4520 from AC4L, got the A stock clearance price. I'm coming from an Onkyo 906 and really looking forward to this! I've loved the Onkyo, but the 8-10 second HDMI handshake, loud relay clicks and heat management issues(also a slowly moving remote volume compared with Denon) had me ready to make the switch. This is quite a thread, I've got some reading to do.
audio4life is offline
post #10273 of 13588 Old 11-01-2014, 04:37 PM
jrhooper1963's Avatar
Quoted: 73 Post(s)
Liked: 36
I would love to hear your thoughts on the 4520, after you get it set up and dialed in to your liking.
jrhooper1963 is online now
post #10274 of 13588 Old 11-01-2014, 07:12 PM
mnc
mnc's Avatar
Quoted: 578 Post(s)
Liked: 488
When I look at my Results Check, I can't find the Subwoofer graph?
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #10275 of 13588 Old 11-01-2014, 07:14 PM
herbg's Avatar
Why would Audyssey set the F/R speakers to "LARGE" after I manually set them to "SMALL"?
Since I'm running Subwoofers, the Subwoofer Mode is set to "LFE" with the BASS Crossover Frequency set to 120Hz.
What went wrong with Audyssey?
herbg is offline
post #10276 of 13588 Old 11-01-2014, 07:19 PM
Liked: 3809
Nothing went wrong. Audyssey ignores any settings prior to calibrating. When the calibration completes, simply reset the speakers to small, set a crossover value, e.g. 80Hz, and you are good to go.
post #10277 of 13588 Old 11-01-2014, 07:27 PM
herbg's Avatar
Great! I did exactly that - set them back to SMALL.
I set the LPF for LFE to 120Hz. I noticed you suggested 80Hz?
herbg is offline
post #10278 of 13588 Old 11-01-2014, 07:57 PM
laulau's Avatar
Quoted: 77 Post(s)
Liked: 112
The subwoofer crossover setting (Speakers->Manual Setting->Crossovers->Individual->Subwoofer) that AustinJerry was referring to is different from the LPF of LFE setting. To start off with, the subwoofer crossover should be set to 80Hz and the LPF of LFE should be set to 120Hz.
Salk STRT / SongCtr-RT / SongSurr I ; Rythmik F12 (x2) (latest ver of setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; CCast; Harmony1; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RPi3&Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i & Meze 99 Classics :: Rpi3&/Digi+ Pro > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 & HD6XX :: FooB2K > Schiit Mimby > Schiit Magni2U > Oppo PM3
laulau is offline
post #10279 of 13588 Old 11-01-2014, 08:35 PM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Just got thru watching this in 3D. I'm running 7.4 with wides right now. I noticed only a few areas where the dialog was to far apart but nothing bad. The whole movie sounded great. This was our first full movie with the 4520ci. The LFE soundtrack is very heavy with this film but great. I keep playing with the subs trim to get a happy medium with 4 subs.
bluer101 is offline
post #10280 of 13588 Old 11-01-2014, 11:36 PM
RapalloAV's Avatar
Quoted: 1321 Post(s)
Liked: 293
I can never use DSX with my WIDES as I find it unnatural. Its a shocker if you ever play any older films that say were shot in 70MM or early CinemascopE, the dialog is played outside of the screen, sooo wrong.....
I will only use NeoX with Denon or THX with Onkyo/Integra, playing this way the WIDES never have any dialog in them. This way they are much more subtle than when played in DSX and that's the way I prefer. I believe Keith (big ears) also prefers not using DSX, for what reasons I'm not sure.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #10281 of 13588 Old 11-02-2014, 04:58 AM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
It's useful to see what Audyssey actually had to contend with.
Hence why I own a minidsp UMIK-1 for REW.
It gives you this and so much more.
TorTorden is online now
post #10282 of 13588 Old 11-02-2014, 06:36 AM
UHD Addict
aaronwt's Avatar
Quoted: 5338 Post(s)
Liked: 3211
I need to switch to PLIIz for tracks like that. With A-DSX that is one thing I don't like with it putting the voices in the heights. I use heights and not wides. Although with BDs and games I can typically run A-DSX without issues. It's TV content that I need to use PLIIz otherwise with A-DSX it can be pretty bad with voices coming from the Heights.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #10283 of 13588 Old 11-02-2014, 07:46 AM - Thread Starter
batpig's Avatar
Liked: 3440
If he has the 4520 he can also try Neo:X. PLIIz would keep the wides silent.
He didn't even indicate what surround mode he was using, although given his discription it's safe to say it was DSX as it's the only one that would create that "echo" effect in the wides with dialogue off screen to the left/right.
Setup Guide and FAQ
batpig is offline
post #10284 of 13588 Old 11-02-2014, 10:26 AM
EMSone's Avatar
Glad to know it wasn't just me.
UPDATE:
The mic provided with the 4310ci (DM-A409) does in fact produce a more accurate calculation. After 2 weeks of tweaking and re-calibrating the mic provided with the 4520ci (ACM1HB) registers a 3db to 4db spike in treble frequencies in the 10khz to 20khz range which would explain the lack of mid-range response I was getting, it also actually had lower mid-range results in the 200hz range. It took a "perfect calibration" to achieve my desired results. I used the mic placement diagram and instructions provided on the Audyssey website http://www.audyssey.com/technologies/multeq/how-to, not the one that is displayed on the 4520ci's initial setup menu. I then used 2 thin wooden planks with holes drilled in them to screw the mic in at the recommended 2ft from the center on both sides, leveled on an ironing board behind the couch. The planks resembled a crucifix where the horizontal plank can be unscrewed and remounted 2ft forward and 1ft back as instructed. After all this was setup, that initial mic position is what determines the speaker distances, figuring that this is basically a numerical calculation, I adjusted the mic slightly until I achieved a TRUE numerical center, L/R fronts (exact same number), L/R surrounds (exact same number), surround backs (exact same number). Now you have to know that this was my intent when mounting my speakers initially, most people choose random spots or have odd shaped rooms.
Another important note was I made sure it was DEAD SILENT, I'm talking about turning the HVAC off, ceiling fan, directv receiver, any eletronic device that was audible. This was also done in the AM hours of the morning where there were no natural or people noises either. I couldn't hear anything but the natural high pitch feedback from my own eardrums. And lastly made sure that both subs reported the same db level. After calibrating the 4520ci this time, I was hearing sounds and effects in movies that I have never heard before, it was very well balanced. I always adjust the bass settings and crossovers to get that big screen effect for movies by enabling LFE+mains and re-adjusting the front and center crossovers to about 80hz. Last thing was increasing the sub level a little and I can't see how I can get it to sound any better. Some movies do have high squealing treble, for those movies i enable the cinema eq in the audio menu. The only occasional adjustment I make is when listening to music, I increase the center channel crossover a little to get a more natural thump from the bass drum (almost any Michael Jackson song excels in this, Man in the Mirror), 100hz usually does the trick.
In conclusion, I feel it took way too much effort to get the sound I was looking for, I had already started an ebay listing to sell this thing, but i think I'm going to stick with it for a while. While I give the sound about a 8.5 out of 10, the features are it's saving grace. Later i'm going to re-calibrate my 4310ci with the 4520ci's mic and hear what that sounds like, because although the bass on the 4520ci is more accurate, the 4310ci still has that classic boom in the bass/subs.
ellisr63 likes this.
EMSone is offline
post #10285 of 13588 Old 11-02-2014, 12:54 PM
herbg's Avatar
Hmmm ... when I go to (Speakers->Manual Setting->Crossovers->Individual), I only see Front @ 40Hz, Center @ 60Hz, Surround @ 40Hz, and Front Height @ 150Hz. No listing for Subwoofer.
When I check (Speakers->Manual Setting->Speaker Config.), I see Front@Small, Center@Small, Subwoofer@1spkr, Surround@Small, Front Height@Small.
Why no crossover setting for the Subwoofer?
herbg is offline
post #10286 of 13588 Old 11-02-2014, 01:35 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
everything crosses TO the subwoofer. I think maybe the LPF (low pass filter) for LFE limits the high frequencies that can go to to the subwoofer, but the LFE channel doesn't generally contain content that would have to crossover to the other speakers.
bgoering is offline
post #10287 of 13588 Old 11-02-2014, 01:36 PM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
Subwoofer mode and the LPF for LFE setting is separate from the normal crossover settings for speakers, and in its own sub menu labeled bass.
It is in:
Menu-> speakers -> manual -> bass
post #10288 of 13588 Old 11-02-2014, 02:01 PM
Liked: 3809
It is in:
TorTorden, you are only confusing things. The LPF for LFE is a low pass filter that affects only the LFE channel, and restricts what frequencies that are in the LFE channel from being passed to the sub.
In addition to LFE signals, the subs receive re-directed bass from all channels set to "small". The frequency at which this re-direction occurs is the crossover identified in the AVR as Front, Center, Surround, etc. IOW, a Front crossover of 80Hz is a crossover between the Front speakers and the sub. That is why you don't see a crossover for the sub, because what nonsense would a sub to sub crossover be?
The AVR manufacturers have done their customers a huge injustice by including the LPF for LFE setting, because it is the most misunderstood setting.
herbg likes this.
post #10289 of 13588 Old 11-02-2014, 02:28 PM
herbg's Avatar
OK ... now that we've established that there is no Subwoofer Crossover setting, should the Individual Speaker Selection Crossovers remain at the current settings? Or, should I switch to "ALL" and select the 80Hz setting.
BTW, I lowered the LPF for LFE to 100Hz (there seems to be some merit in seeking something between 120Hz and 80Hz).
herbg is offline
post #10290 of 13588 Old 11-02-2014, 03:07 PM
UHD Addict
aaronwt's Avatar
Liked: 3211
I use a 60Hz crossover for my SVS mains and then use an 80 Hz crossover for my SVS center and SVS four surround speakers as well as with my Axiom Front Heights.
I'm still toying with the idea of getting a second SVS sub to compliment my ancient SVS sub from 2003. But the calibration with the 4520 has done a superb job with the one sub woofer so I'm not sure when I will get another SVS sub.
cchunter and herbg like this.
Denon Avr 4520ci Receiver
