The **OFFICIAL** DENON AVR-4520CI thread - Page 344 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #10291 of 13580 Old 11-02-2014, 04:25 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6497 Post(s)
Liked: 3608
Originally Posted by herbg View Post
OK ... now that we've established that there is no Subwoofer Crossover setting, should the Individual Speaker Selection Crossovers remain at the current settings? Or, should I switch to "ALL" and select the 80Hz setting.
BTW, I lowered the LPF for LFE to 100Hz (there seems to be some merit in seeking something between 120Hz and 80Hz).
You may establish whatever crossover you want between the individual speakers and the sub. A typical selection would be 80Hz for all the speakers (unless Audyssey sets a higher crossover value, in which case you should not lower the crossover). Depending on the capabilities of your main speakers, you might select a lower value, say 60Hz, but you should experiment and select the value you feel provides the best sound. Remember, your sub is designed to for handling the low frequencies, in most cases better than your mains, so let them do their job.
Lowering the LPF for LFE to 100 Hz is likely not going to have any audible improvement whatsoever. I would leave it at the default, and recommended, value of 120Hz. If you can cite a source that recommends a lower LPF, then please do so. There have been several discussions that lowering the LPF to 80Hz filters out some unwanted signals in the LFE channel on some poorly-engineering music sources, but as a general rule this doesn't apply for movie content.
herbg likes this.
AustinJerry is offline
post #10292 of 13580 Old 11-02-2014, 05:18 PM
herbg's Avatar
All good points. Set LPF for LFE back to 120Hz. I also bumped up the Crossovers for the Fronts from 40Hz to 60Hz. Left the Center @ 60Hz and bumped the Surrounds to 60Hz.
I have a 2nd ML BalancedForce 210 arriving this week so I will be doing another Audyssey calibration soon.
herbg is offline
post #10293 of 13580 Old 11-02-2014, 07:34 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2969
I run my mains and center on small and 80hz, and the LPF on 120 hz.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #10294 of 13580 Old 11-03-2014, 06:27 AM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
Me to I run everything at 80hz and lpf at 120.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #10295 of 13580 Old 11-03-2014, 06:33 AM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
I have not had anymore green screens with the audio issues. I stopped using the denon app and been only using the supplied remote. So maybe the 4520 gets confused through ip control. I do notice on the app that there are functions that do not relate to the 4520 too. I will keep an eye on it.
bluer101 is offline
post #10296 of 13580 Old 11-03-2014, 07:06 AM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
TorTorden, you are only confusing things. The LPF for LFE is a low pass filter that affects only the LFE channel, and restricts what frequencies that are in the LFE channel from being passed to the sub.
The AVR manufacturers have done their customers a huge injustice by including the LPF for LFE setting, because it is the most misunderstood setting.
Sry, just wanting to help.
As for the "LPF for LFE" it could indeed have been named better, but I would much rather have the setting than not.
As for the confusing part this is what manuals and the internet is for.
I buy higher tier equipment primarily to have just these superfluous options.
TorTorden is offline
post #10297 of 13580 Old 11-03-2014, 09:10 AM
Floran's Avatar
My New 4520 Crapped Out This Morning
Yesterday evening I finally decided that I'm going to keep it, mainly for the rounder, tighter bass compared to my old 4310. To celebrate, I had a glass of wine while listening to Dave Brubeck. Then went to bed.
This morning when I turned it on, no sound. After a few other maneuvers, including input switching, on/off, unplugging for 5 minutes, a loud pop came out of the right speaker then static and a faint buzz. I could not resuscitate it even after a few hard resets. So I guess that was it.
My dilemma now is should I send it out for repair or return it? I'm not sure whether it is something with this particular unit (it was a shelf unit at BB for a couple years) or does the 4520 model have a higher rate of failures in general?
Do you guys have any other ideas I could try out first?
Thanks, F.
Floran is offline
post #10298 of 13580 Old 11-03-2014, 09:48 AM
Liked: 0
HDMI and Zone 3
I am trying to send audio from HDMI to zone 3 without success, can you help ...Thanks
zigggy is offline
post #10299 of 13580 Old 11-03-2014, 09:55 AM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Not possible. The 4520 like most receivers can only send analog audio to other zones.
batpig is offline
post #10300 of 13580 Old 11-03-2014, 10:44 AM
Irwinroad's Avatar
Quoted: 81 Post(s)
Liked: 37
Yes it is possible but the same source will play in all zones
As per Post #3
18. All Zone Stereo: Will play any source (HDMI, optical, digital coax, or analog) to zones 2/3 (via Amp Assign or pre-outs) downmixing the source to Multi CH Stereo in the main zone.
Irwinroad is offline
post #10301 of 13580 Old 11-03-2014, 11:36 AM
Liked: 0
When I hit the option button the "all zone stereo on" is gray I cant choose it ??? Any ideas
zigggy is offline
post #10302 of 13580 Old 11-03-2014, 11:44 AM
Liked: 0
Got this on Denon support website
"There are also some newer models like the AVR-X3000, AVR-X4000, and AVR-4520CI that incorporate an HDMI output strictly for Zone 2 use. These models can either pass an encoded Dolby or DTS based signal through to a second receiver in a Zone 2 application or they can simply pass 2 channel based audio to a secondary TV. This can be altered using the HDMI Output (Zone 2) menu option."
????? dont have zone 2 in HDMI option ??
zigggy is offline
post #10303 of 13580 Old 11-03-2014, 12:04 PM
Irwinroad's Avatar
Quoted: 81 Post(s)
Liked: 37
Do you have your Zone 2/3 turned on?
post #10304 of 13580 Old 11-03-2014, 12:14 PM
Liked: 0
Ok !!! got it, thanks everyone ......have a nice day
zigggy is offline
post #10305 of 13580 Old 11-03-2014, 12:29 PM - Thread Starter
batpig's Avatar
Liked: 3415
As per Post #3
Oops, sorry, yes, I forgot about All Zone Stereo.
zigggy -- you need to manually turn on the other zones first or else AZS will not be available as an option.
The newer models have streamlined this, adding both digital audio output to other zones (without AZS) and also turning on the other zones for you instead of making you turn them on manually first.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10306 of 13580 Old 11-03-2014, 12:30 PM - Thread Starter
batpig's Avatar
Liked: 3415
That's just sloppy writing on the support site. On the 4520CI the HDMI zone output is dedicated to its own zone (Zone 4) instead of piggybacking on Zone 2.
Setup Guide and FAQ
batpig is offline
post #10307 of 13580 Old 11-03-2014, 02:50 PM
Liked: 0
Thanks everyone
zigggy is offline
post #10308 of 13580 Old 11-03-2014, 06:12 PM
Floran's Avatar
Got it fixed?
My 4520ci died in 1 month and five days from brand new. I turned it on last night and POP, brief static, then nothing.
I called denon, they said I needed to take it to an authorized repair shop. I'll do so today.
Did you get it back? Did they mention what was the fault?
I had a 4520 that died in a very similar fashion and makes me curious what could have happened.
Floran is offline
post #10309 of 13580 Old 11-03-2014, 06:15 PM
Archaea's Avatar
Quoted: 2842 Post(s)
Liked: 2421
Not yet.
I haven't heard anything yet...
Archaea is online now
post #10310 of 13580 Old 11-04-2014, 12:45 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3036 Post(s)
Liked: 2969
We still have two brand new 4520's available - call if interested.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #10311 of 13580 Old 11-04-2014, 01:57 PM
ggsantafe's Avatar
Quoted: 196 Post(s)
Liked: 162
Source Volume
Recently acquired the 4520 as a replacement for my 4311 that suffered a non replaceable HDMI Board failure. Anyway - I seem to recall that the 4311 had a setting that allowed you to increase the volume for a specific source, i.e for my Blu-Ray player in the settings menu. I could increase the db relative to the volume for my DirecTV source (all connected via HDMI) I can't find a similar adjustment on the 4520 - am I missing something?
ggsantafe is offline
post #10312 of 13580 Old 11-04-2014, 02:06 PM
Liked: 3608
Sure. Go to the Inputs menu, and select Source Level. You can adjust each source independently.
post #10313 of 13580 Old 11-04-2014, 08:20 PM
audio4life's Avatar
Liked: 299
Originally Posted by jrhooper1963 View Post
I would love to hear your thoughts on the 4520, after you get it set up and dialed in to your liking.
It's supposed to be here by the weekend and I get Monday and Tuesday off to tinker, so I'm sure I'll have soon impressions soon after!
audio4life is offline
post #10314 of 13580 Old 11-05-2014, 06:09 AM
ggsantafe's Avatar
Quoted: 196 Post(s)
Liked: 162
Thanks Jerry - that worked
post #10315 of 13580 Old 11-05-2014, 11:35 AM
4seahorseman's Avatar
Last night I installed HDMI active equalizer extenders on the longer cables to see if it would solve my issues. These are the extenders that draw power from the HDMI line or can be powered with a 5v source that is not included. The instructions don't tell you how to set the equalizer, I set them to 3 for a 30' cable run.
I still am not able to get a 3D signal to go through the AVR. I am able to get a picture on zone 4 and both monitor 1 and 2 outputs all at the same time, but the sound still will not play at all unless I turn off zone 4. I guess my next step is to buy the 5v power sources and see if that works.
4seahorseman is offline
post #10316 of 13580 Old 11-06-2014, 04:24 PM
madhuski's Avatar
Quoted: 553 Post(s)
Liked: 289
When I set up the 4520 (having replaced a 4311)I'm finding I need to turn up both the gain on the subwoofer and the trim on the AVR much higher than I had to previously. Is this something unusual/to be concerned about?
Selling in the Classifieds
Wyred4Sound MC7150 seven channel amp - $899
madhuski is offline
post #10317 of 13580 Old 11-06-2014, 04:27 PM
laserjock II's Avatar
Quoted: 703 Post(s)
Liked: 378
There is a LFC (low frequency containment) setting for watching movies without disturbing those late at night etc, wonder if that's not on by mistake?
laserjock II is offline
post #10318 of 13580 Old 11-06-2014, 04:47 PM
Liked: 3608
I have both the 4520 and the 4311, and I am not observing any difference between the two AVR's WRT levels of either the mains or the subs. I would double-check your settings. What trims are being set when you run the calibration?
post #10319 of 13580 Old 11-06-2014, 07:36 PM
jappleboy's Avatar
Quoted: 123 Post(s)
Thx
Will Denon have Thx with the next Receiver coming out.
jappleboy is offline
post #10320 of 13580 Old 11-06-2014, 07:48 PM
Liked: 3608
Highly doubt it. I have had four Denon AVR's in a row, and none had THX.
Denon Avr 4520ci Receiver
