The **OFFICIAL** DENON AVR-4520CI thread - Page 349 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #10441 of 13580 Old 11-14-2014, 08:06 PM
chi_guy50's Avatar
Quoted: 1255 Post(s)
Liked: 738
Originally Posted by Schwa View Post
Not to stray too far off topic, but I think we're confusing dead pixels with stuck pixels. I have a single dead (i.e. unlit/black) green pixel in the top right corner of my JVC front projector and it's absolutely impossible to see, even if you know exactly where to look, with anything other than a solid green test pattern, and even then only if you're standing right next to the screen. I can imagine that permanently lit (i.e. "stuck") pixels are quite a bit easier to notice than dead ones.
Well, I corrected myself in my subsequent post to specify that the single pixel in my set is stuck on red. That's about as apparent as a single pixel can be, I guess, and yet it's perfectly invisible, even with color test slides, unless your face is within a foot or so of the screen.
This would be completely OT except as it relates to the discussion of similar imperfections in our AVR's. I've had occasional operational quirks in my 3311 and now my X5200 which, for the most part, have represented only a momentary hiccup or slight inconvenience. It's irritating to the perfectionist in me and, when it occurs, does cause me consternation. But, to be honest, I still marvel at how well these machines perform so many complex functions over many years while generating considerable heat around delicate electronic circuits.
I know it's little consolation to those owners who have suffered serious issues with their units (and, full disclosure, the first X5200 I got was DOA), but overall I'd guess from over three years of following these threads that D&M's products have been remarkably reliable.
chi_guy50 is offline
post #10442 of 13580 Old 11-14-2014, 10:41 PM
Quoted: 76 Post(s)
Originally Posted by audio4life View Post
And if I ever said that, I'd be wrong. But I'm not saying that, yet you are saying since you have a troublesome 4520, then they all are lemons.
I, on the other hand, am simply saying that when one looks at this thread, and the many other threads and owner reviews out there to get a concensus, one finds that the vast majority of 4520's out there are performing without issue. Why don't you send yours in for warranty work, it should have a 3 year warranty, no?
What I have now is actually my third (3rd) 4520.
1st one was returned due to very loud explosive pop, the kind that can kill the tweeters, followed by silence and red blinking light.
2nd one was returned due to intermittent noise in the back channels.
3rd one is what I have now with me that I decided not to return anymore when it started misbehaving but to keep in order to dissect and analyse what really is the AVR4520 - then if worth my while, change the things that I find that I do not like with it.
IMHO:
As manufactured, some people find that it suits their needs. I am happy for them. Some people believe the marketing hype and expect more from it and realise too late that it is not what they thought it was. Some find ways to learn to like it. I am also happy for them.
But to those that cannot do or change anything but either to accept its faults or the inconvenience of warranty repairs - they at least deserve the truth.
doognam is offline
post #10443 of 13580 Old 11-14-2014, 10:45 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3546
And the truth is all what we're after.
NorthSky is offline
post #10444 of 13580 Old 11-14-2014, 11:42 PM
audio4life's Avatar
Liked: 299
IMHO:
So now you're saying that as it turns out, you've had 3 4520's? You say that the 4520 has problems with bad board to board connections, that the 4520 has about 500(I guess you counted all 500) of these connections, and this particular connection is unique to the 4520(and how you know this, I guess you've dissected all the Denon models to know that this "connector" is ONLY in ONE Denon). But it seems that your third 4520 is the only unit that suffered from these loose connections. You say that if you "drop" the unit the connection will re-establish? I guess that each time, Denon was willing to replace your unit with a brand new unit too. That's quite a story.
Friend, you are one unlucky Joe.
audio4life is offline
post #10445 of 13580 Old 11-14-2014, 11:46 PM
audio4life's Avatar
Liked: 299
Indeed.
post #10446 of 13580 Old 11-15-2014, 01:11 AM
Quoted: 76 Post(s)
You misquote me and you say instead "this particular connection". There a whole universe of difference between a connection and a connector.
I guess you are dyslexic, but that is not your fault. What is your point?
FACT:
The type of connectors used in the AVR4520 are unique in the modern world of branded avrs.
It uses connectors with female contact elements that DO NOT HAVE grip ability
That is most unique for a "flagship model" to use such a ..d, and perhaps cheap type of connectors. All other models of branded avr's, including other Denons use the type of connectors with female contact elements that spring back to grip the male contact elements to ensure proper and long-lasting contact.
Arithmetic:
The HDMI/processor board has over 240 contact elements going to the audio board. Simple arithmetic dictates that at least 480 contact elements just between these two boards. Add to that the 66 by 66 connectors used for the diagnostic/protection circuitries from the main board to the audio board then add more for those that go all the way to the HDMI board. There are more boards that just these.
There you go, you would easily arrive at a conservative figure of at least 500 potential failure points - simply because of the kind connectors used.
It would have been better if they used the better kind of connectors, would you not agree?
doognam is offline
post #10447 of 13580 Old 11-15-2014, 06:27 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3013
gsr, Craig Peer, laulau and 5 others like this.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #10448 of 13580 Old 11-15-2014, 07:10 AM
xcapri79's Avatar
Quoted: 110 Post(s)
Liked: 101
Doognam, if you can, I suggest just returning your receiver and get an equivalent Marantz or Pioneer instead. You will save yourself a lot of grief. Also look on the bright side, you don't have an XMC-1.
gsr likes this.
xcapri79 is offline
post #10449 of 13580 Old 11-15-2014, 10:34 AM
UHD Addict
aaronwt's Avatar
Quoted: 5203 Post(s)
Liked: 3111
Marantz? Isn't that also the same company as Denon?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #10450 of 13580 Old 11-15-2014, 11:16 AM
ggsantafe's Avatar
Quoted: 196 Post(s)
Liked: 162
Nope - The XMC-1 is manufactured by Emotiva: https://emotiva.com/products/pres-and-pros/xmc-1
ggsantafe is offline
post #10451 of 13580 Old 11-15-2014, 12:48 PM
xcapri79's Avatar
Quoted: 110 Post(s)
Liked: 101
So why is that important? McIntosh has the same parent company namely, D & M Holdings. Would you say eek to McIntosh too?
Matt2026 likes this.
xcapri79 is offline
post #10452 of 13580 Old 11-15-2014, 04:38 PM
Archaea's Avatar
Quoted: 2852 Post(s)
Liked: 2431
Got my Denon 4520CI back from the repair shop last Friday. Hooked it up on Monday. Used it for a few days (a couple hours max). Now when I turn the source to internet radio the unit locks up hard and nothing works. I actually have to pull the power. It freezes up on that source - nothing works - not the remote, not the physical front face buttons, not the source knob. I called Denon support they had me factory reset the unit. Same thing happens.
Guess it's going back again. This unit I got seems to be a lemon. I had it about three weeks new from amazon, and it bellied up last time, now only a couple more hours of use.
As sad as it is I'm considering going back to my Onkyo 5508. At least it has a single known problem that is now covered by warranty till 2018.
Archaea is online now
post #10453 of 13580 Old 11-15-2014, 04:46 PM
xcapri79's Avatar
Quoted: 110 Post(s)
Liked: 101
Was this a refurbished or new unit?
xcapri79 is offline
post #10454 of 13580 Old 11-15-2014, 05:30 PM
Vikkster's Avatar
Liked: 0
Originally Posted by Vikkster View Post
Interesting. It seems to me that it has only happenned while watching cable (directtv). I wonder if I can force the occurance while watching a blu-ray or some other source.
But....it that were the cause, why would jarring the receiver cause the relay to trigger again?
Well, I've eliminated that as the cause. The problem reproduces on other sources. But if I jar the unit I can always get it to,come back on, so,maybe it really is a sticking relay or loose connectors or something.
I'm beginning to,think I have to send it in which sucks because my prior unit was a onkyo 876 ( don't get me started) which failed, so,I'm going to be using tv sound for a while i guess.
Vikkster is offline
post #10455 of 13580 Old 11-15-2014, 05:36 PM
Archaea's Avatar
Liked: 2431
new from amazon.
post #10456 of 13580 Old 11-15-2014, 09:23 PM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 279
When it locks up are you using any type of ip control? App or mobile device.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #10457 of 13580 Old 11-15-2014, 10:38 PM
Tangled Cable's Avatar
Quoted: 115 Post(s)
Liked: 36
What the hell is this?
I was watching a movie tonight and I thought the sound was off somehow in my 7.2 setup, so I ran a channel check, and ... both the left and right channel are coming out of the left front speaker. All other speaker channels are correct ...
What could be responsible for this?
Please weigh in here. My family couldn't care less but its driving me crazy.
EDIT: Never mind. I reset the left and right cables and it seems fine now
Tangled Cable is offline
post #10458 of 13580 Old 11-16-2014, 02:42 AM
Quoted: 76 Post(s)
... I guess that each time, Denon was willing to replace your unit with a brand new unit too. That's quite a story.
Yes, my friend, I am very fortunate that Denon was willing to replace the faulty unit with a brand new one.
Simply because I live in a place where the "consumer guarantee protection" is a LAW that entitles the customer to choose how he wants to be compensated for faulty products that were bought in good faith. As to whether to refund, replace, or repair is the consumer's choice and not the sellers.
I can appreciate that that could be difficult for people who live in places where the norm is "buyer beware".
doognam is offline
post #10459 of 13580 Old 11-16-2014, 06:34 AM
Archaea's Avatar
Liked: 2431
No just the remote it came with, so far the other input modes seem fine.
post #10460 of 13580 Old 11-16-2014, 08:04 AM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 279
Ok, I was having an issue while using the iPhone /iPad apps. It would work fine for a while. Then after you would turn the Denon off and return it would start acting strange and very delayed. One of the times it froze like you described in Internet radio and nothing worked, I had to unplug the Denon. Since not using any ip control I have not had an issue.
bluer101 is offline
post #10461 of 13580 Old 11-16-2014, 08:23 AM
UHD Addict
aaronwt's Avatar
Liked: 3111
Isn't that only a 7.2 receiver?
aaronwt is offline
post #10462 of 13580 Old 11-16-2014, 08:25 AM
UHD Addict
aaronwt's Avatar
Liked: 3111
new from amazon.
It's looking like my 4520 may have been a good decision. SO far I've had no issues. But I guess anything could crop up. I did purchase an extended warranty on it to cover it for five years just in case.
aaronwt is offline
post #10463 of 13580 Old 11-16-2014, 08:29 AM
ggsantafe's Avatar
Quoted: 196 Post(s)
Liked: 162
The XMC-1 is a 7.1 pre-amp - I was responding to the the OP who suggested that the unit was manufactured by Denon or Marantz.
post #10464 of 13580 Old 11-16-2014, 08:30 AM
xcapri79's Avatar
Quoted: 110 Post(s)
Liked: 101
It is a 7.2 preamp/processor which requires amplifiers. Receivers have the amplifiers built-in.
xcapri79 is offline
post #10465 of 13580 Old 11-16-2014, 08:38 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
If I save my configuration to my PC, will it save my Audyssey settings as well? I didn't see anything in the manual about that.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #10466 of 13580 Old 11-16-2014, 10:25 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 690
^^^yes that is one of main reasons to have a few audyssey settings and load them as needed. Single person, multiple person in 1 row, 2 row.
I've asked both Audyssey and Denon to incorporate that into future AVR as multiple settings, with memory so cheap and big can't see reason why they don't do it for mid and high end AVRs
Via Mikes brain/thumb interface, LLAP
mtbdudex is offline
post #10467 of 13580 Old 11-16-2014, 11:40 AM
Quoted: 978 Post(s)
Liked: 506
Perfect! Now I can try different sub tunes with my dsp's before I run Audyssey. I wish that I would have know this.
Thanks Mike!
post #10468 of 13580 Old 11-17-2014, 05:01 AM
chi_guy50's Avatar
Liked: 738
IIRC there are just a handful of settings that are not saved in the config.dat file, such as subscription account ID and log-in (e.g., Pandora), Favorites, and Pre-Set radio stations.
Not pertinent to your current situation, but if you are about to perform a microprocessor reset before loading a previously saved config.dat file you might want to first make a note of any of these settings so that you won't have to re-enter them from memory.
post #10469 of 13580 Old 11-17-2014, 06:18 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6538 Post(s)
Liked: 3625
In my experience, everything is saved. I even remember someone issuing a caution because he noticed that account passwords are stored in the Config file as clear text. This would be very easy for someone to test and report back the results. I would do it myself, but I don't use the network features of the AVR, so there are no passwords stored.
AustinJerry is online now
post #10470 of 13580 Old 11-17-2014, 06:42 AM
Quoted: 978 Post(s)
Liked: 506
Thanks Gentlemen for the heads up! I do not need to do a processor reset, but just wanted mainly my Audessey settings saved. I didn't get around to doing it yesterday because of watching my Eagles get their arse whooped but I should be able to do it tonight after I get home from work.
Denon Avr 4520ci Receiver
