The **OFFICIAL** DENON AVR-4520CI thread - Page 354 - AVS Forum
post #10591 of 10609 Old Yesterday, 03:05 AM
TorTorden's Avatar
Quoted: 33 Post(s)
Liked: 79
Originally Posted by laserjock II View Post
So the one on the 4520 is a hub or a switch?
I haven't been able to sort that out either, all documentation it seems has been written by someone who hasn't the faintest clue about Ethernet networking, and they use the words hub or switch with equal measure.
I would honestly be suprised if it's a hub, considering how cheap and ubiquitous network switches are these days but it seems for us to get any clarity on this one issue we would have to hook up 4 computers and run speed tests. Then again it's not too unlikely denon got offered a bunch of 4-port hubs and thought "hey that's going to look good as an upper end feature, that doesn't serve all that much in practicallity".
Then again it's an AVR. If I where to connect multiple devices to it then those devices would be very close to the avr and mostlybe used one at a time, in other words, it would be considered as a single endpoint on a cabled network and I have a hard time seeing how this would actually matter practically, whether my playstation or blueray player is connected via this hub or a switch.
Personally I have just hooked in a singe Ethernet cable for the avr, since I have had an 8 port 1Gb\s switch not 3 feet from the AV rack for the past 5+ years anyways.
TorTorden is offline
post #10592 of 10609 Old Yesterday, 06:19 AM
bluer101's Avatar
Quoted: 98 Post(s)
Liked: 90
I use the hub/switch only for my oppo 103d. All other devices go to a power line HD switch. The reasoning is if I have the oppo on the avr is on anyways.
bluer101 is offline
post #10593 of 10609 Old Yesterday, 06:38 AM
Pain Infliction's Avatar
Quoted: 168 Post(s)
Liked: 200
I saved my configuration to my laptop over my network and when I went to load it back, it says that the load failed. What is the reasoning behind this? I had to spend all weekend re-tuning everything.
MY THEATER......The Thompson Theater 11.9 channels
"Is not love not unlike the unlikely not it is unlikened to?"
- Leon Phelps
Pain Infliction is offline
post #10594 of 10609 Old Yesterday, 06:51 AM
rlb
rlb's Avatar
Quoted: 209 Post(s)
Liked: 118
Regarding hub/switch issue. I'm no "techie"; but I don't have an issue with hub functionality in my setup. I have an Ethernet jack (Cat 6 from my den router) in the family room behind my primary A/V setup. Ethernet into Denon hub. It has outputs to Samsung F9000, OPPO 103D, and PS3. Since their internet functions are primarily as streaming sources for the display, I obviously only use one at a time. So, in my case I don't see where a switch would offer any advantage.
rlb is online now
post #10595 of 10609 Old Yesterday, 07:42 AM
AustinJerry's Avatar
Quoted: 964 Post(s)
Liked: 881
When you did the save, did you check that the save produced a valid file? Sometimes, the save file is empty (nothing but zeros), in which case it would not load, of course. If the file wasn't empty, it's difficult to explain why it wouldn't load. I assume you tried several times?
While there have been numerous people who have reported issues with the configuration load/save functionality, it does work. So I recommend you don't give up--try it again to see if you can get it working properly.
AustinJerry is online now
post #10596 of 10609 Old Yesterday, 08:15 AM
rbabb2's Avatar
Airplay w/ Airfoil or OSX Yosemite 10.10 working for anyone?
4520'ers,
I was running music over Airplay when I got my 4520 a couple months ago. It seemed to work great and was easily seen on the network by all my Apple devices. Well, sometime in the last few weeks it just seemed to stop. iTunes and Airplay on my Mac devices (OSX) see it fine, but when trying to connect they just can't seem to get it linked and throw an error. The only thing I can think of is that I upgraded to OSX Yosemite recently.
I'm curious if anyone else is having problems with their Airplay when running Yosemite?
Rob
rbabb2 is offline
post #10597 of 10609 Old Yesterday, 02:28 PM
Quoted: 168 Post(s)
Liked: 200
Thanks for the reply. Yes I tried many times because I didn't want to have to re-tune five dsp's again. What do you open the file with when you save it to see if there are all zeros or other info in it?
- Leon Phelps
post #10598 of 10609 Old Yesterday, 02:54 PM
Quoted: 964 Post(s)
Liked: 881
I use the freeware HxD: http://mh-nexus.de/en/hxd/
post #10599 of 10609 Old Yesterday, 03:11 PM
JohnAV's Avatar
Quoted: 68 Post(s)
Liked: 83
In simple terms a Switch has a advantage passing packets to only a learned device on one of its ports, where as a Hub passes the packets to all ports. Unless you have a LAN with a lot of network traffic, using a Hub over Switch has no disadvantages. For Denon they obviously went the hub route as doubtful connected devices are using a lot of network traffic.
We also had discussion concerning why only 100 base vs 1000 base, and as it stands there isn't any applications that are really impacted by the 100 base capacity of this hub.
rlb likes this.
Oppo Beta Group
JohnAV is offline
post #10600 of 10609 Old Yesterday, 05:10 PM
4seahorseman's Avatar
Originally Posted by 4seahorseman View Post
Last night I installed HDMI active equalizer extenders on the longer cables to see if it would solve my issues. These are the extenders that draw power from the HDMI line or can be powered with a 5v source that is not included. The instructions don't tell you how to set the equalizer, I set them to 3 for a 30' cable run.
I still am not able to get a 3D signal to go through the AVR. I am able to get a picture on zone 4 and both monitor 1 and 2 outputs all at the same time, but the sound still will not play at all unless I turn off zone 4. I guess my next step is to buy the 5v power sources and see if that works.
I now have things functioning as I had hoped they originally would. I have a single line out of the monitor 1 output into a hdmi splitter and have the extenders powered with a 5v power source (one each located at the terminus of the long HDMI runs to the TV and projector). 3D works, image on both displays work, and audio works. I do also have the zone 4 output to a second TV and can have all three displays on the same source or something else on the zone 4. FYI adding the power source alone did not solve the issue it took adding the hdmi splitter.
4seahorseman is offline
post #10601 of 10609 Old Today, 06:30 AM
Quoted: 168 Post(s)
Liked: 200
Thank you sir! I will pull another backup tonight when I get home and see what it has in it.
- Leon Phelps
post #10602 of 10609 Old Today, 09:32 AM - Thread Starter
batpig's Avatar
Quoted: 1108 Post(s)
Liked: 1562
FYI - the tip that has always ensured "good" save files for me has been to turn I/P Standby Control to OFF and then power cycling the receiver before performing the Save procedure.
batpig is offline
post #10603 of 10609 Old Today, 12:08 PM
Schwa's Avatar
Quoted: 285 Post(s)
Liked: 290
Originally Posted by rbabb2 View Post
4520'ers,
Rob
Yosemite and Airplay work fine for me (including with both my Denon 4311 and 4520).
Schwa is offline
post #10604 of 10609 Old Today, 04:22 PM
Quoted: 168 Post(s)
Liked: 200
I saw that in the print at the bottom of the screen, but if I turn it off, how can I save my settings? I was saving over my network so maybe if I plug a usb cable into the avr and then to my computer I can do it that way.
- Leon Phelps
post #10605 of 10609 Old Today, 04:25 PM
Quoted: 168 Post(s)
Liked: 200
I just tried the software and opened up my config file. Sure enough, it was all zeros.
- Leon Phelps
post #10606 of 10609 Old Today, 05:07 PM - Thread Starter
batpig's Avatar
Liked: 1562
That setting allows you to access the receiver over the network when it's in STANDBY. When you go to do the save the receiver is powered on. So setting that to off doesn't prevent you from doing the network save.
batpig is offline
post #10607 of 10609 Old Today, 05:47 PM
Quoted: 964 Post(s)
Liked: 881
Please follow Batpig's recommendation, which is also specified in my network save procedure--set the AVR network setting to "Off in standby" and try the save again.
post #10608 of 10609 Old Today, 09:30 PM
WHATTHEDILEO's Avatar
Quoted: 22 Post(s)
Liked: 27
Has anyone updated the firmware of the 4520 to decode Dolby Atmos? Are you getting proper In-Ceiling Rear speaker output?
WHATTHEDILEO
Some people LOVE MUSIC.
Some people LOVE the SOUND of music.
If you don't know the difference, then you LIKE MUSIC.
My lazily meandering Theater Room quest
WHATTHEDILEO is online now
post #10609 of 10609 Old Today, 09:32 PM
Quoted: 22 Post(s)
Liked: 27
Kidding - sorry if I got anyone's hopes up. I was fiddling with custom input names, and thought of a great April Fool's day joke. I didn't think it could wait till next year.
WHATTHEDILEO
Denon Avr 4520ci Receiver
