The **OFFICIAL** DENON AVR-4520CI thread - Page 367 - AVS Forum | Home Theater Discussions And Reviews
 870Likes
post #10981 of 13624 Old 01-14-2015, 06:25 PM
sourbeef's Avatar
Liked: 25
JMHO, again, no one needs to add a fan with this machine. It runs really cool, relatively speaking, even when run hard.
ril850 and cchunter like this.
TV - Panasonic 58PZ700U plasma
L/R - Ascend Sierra Towers with RAAL Tweets in piano black
C - Ascend Sierra Horizon with RAAL Tweet in piano black
Surr - Polk Fxi-A6
Sub - SVS PC-13 Ultra
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #10982 of 13624 Old 01-16-2015, 06:26 AM
TV addict#2's Avatar
Quoted: 26 Post(s)
this is gonna be my next avr to replace my 1992 model Kenwood,are the latest units pretty much trouble free now
1.AsusXonarD2X...Kenwood8540...CarverTFM55x....... .901Bose
2.nVidiaHDmi...DENON AVR-4520CI...EMPTeKR55Tix4... R56Ci...SVSUltra/2...Toshiba55WX800U
TV addict#2 is offline
post #10983 of 13624 Old 01-16-2015, 07:25 AM
Alan P's Avatar
Quoted: 4896 Post(s)
Liked: 3532
OK, so last night watched Star Trek (1st JJ Abrams version) and was totally underwhelmed by the audio....I figured something had to be going on so I checked some settings.
Why in the world does my new 4520 default to "Dynamic Compression AUTO" and "Loudness Management ON" with Dolby True-HD (and DD/DD+) signals???
After I turned that crap off, it sounded great!
Seriously, these options should not be enabled by default.
Loudness Management
On : Outputs using the settings made in “Dynamic Compression” and “Dialogue normalization” are enabled.
Off : “Dynamic Compression” settings and “Dialogue normalization” are disabled, and the signals on the disk are output as is.
Dynamic Compression - Compress dynamic range (difference between loud and soft sounds).
Auto : Automatic dynamic range compression on/off control according to source.
Low / Medium / High : These set the compression level.
Off : Dynamic range compression always off.
Alan P is offline
post #10984 of 13624 Old 01-16-2015, 09:00 AM - Thread Starter
batpig's Avatar
Quoted: 3654 Post(s)
Liked: 3493
Yeah you really have to be carful with all the possible settings. I always like to take a run through all the submenus in the Audio section just to make sure everything is how I want it. And remember many of those settings are input and/or signal specific. To make things more complicated there are often audio settings on the source side which can impact what you are hearing.
This is also one reason why it's difficult to make fair comparisons between different receivers. Each one will handle this stuff a bit different so it's tough to get everything apples to apples.
batpig is offline
post #10985 of 13624 Old 01-16-2015, 10:59 AM
UHD Addict
aaronwt's Avatar
Quoted: 5602 Post(s)
Liked: 3396
Loudness Management
They seem to typically default to enabled. Those ere some of the first things I make sure are off when I setup a new receiver.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #10986 of 13624 Old 01-16-2015, 01:38 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3518 Post(s)
Liked: 3485
Loudness Management
I agree that it is irritating they default to on with a new unit ( at least mine was that way ). Batpig's advice is good. In fact, I need to check sources other than Blu Ray tonight just to make sure they are set the way I want them !!
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #10987 of 13624 Old 01-16-2015, 02:11 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4777
Loudness Management
I remember watching Super8 the first time and commenting in Ralph Potts' review thread and saying I thought the audio was less than overwhelming and he came up with this response:
"This is a Dolby TrueHD soundtrack which automatically sets the Onkyo's Night Listening Mode to "Auto". You have to manually set it to off once the track begins playing. Do that and watch some of these scenes over and see what you think"
Sure enough, it was so and I have found myself checking on others and finding it on again. Denon doesn't do that?
lovinthehd is offline
post #10988 of 13624 Old 01-16-2015, 02:43 PM
Alan P's Avatar
Liked: 3532
That's just ridiculous...why do AVR manufacturers assume those soundtracks need compression?? I just don't get it.
Anyways....no, after I turn those 2 options off they seem to stay off. I tested with multiple sources and multiple movies.
Alan P is offline
post #10989 of 13624 Old 01-16-2015, 02:48 PM
lovinthehd's Avatar
Liked: 4777
Why does Microsoft think we need the appearance of a clock and the idiotic charm thing in 8.1 whenever you mouse over to the right side of the screen? I wonder if it was even intentional and I don't think it happens on every TrueHD soundtrack but I've never really checked.....but guess if I get a working 4520 I won't have to worry about it any more....
post #10990 of 13624 Old 01-16-2015, 02:58 PM
Alan P's Avatar
Liked: 3532
You can turn that off.
Alan P is offline
post #10991 of 13624 Old 01-16-2015, 03:02 PM
lovinthehd's Avatar
Liked: 4777
Completely off? I haven't found how to do that, got it to where it doesn't appear as frequently....
post #10992 of 13624 Old 01-16-2015, 03:07 PM
Alan P's Avatar
Liked: 3532
Don't really remember how I did it, but I just found this link and I think this is how I did it.
http://www.tomshardware.com/faq/id-2...e-windows.html
Alan P is offline
post #10993 of 13624 Old 01-16-2015, 03:30 PM
lovinthehd's Avatar
Liked: 4777
Yes, turned those off a long time ago but I can still get the charms to appear with the touchpad cursor in motions on the right side, when I've come up from the bottom (where I often put the cursor so its out of the way). Not nearly as annoying as the out-of-the-box settings. The thinking by HP/Microsoft on implementation of a touchscreen on a laptop was just pitifully poor IMO. I'm just too old to see any benefit to making such an "automatic" feature I suppose, maybe I should have more ADHD or something...would much prefer a more rigorous routine on how to setup/personalize the actions of the computer in the first place rather than have some twit decide what they like as an unexplained starting point.
post #10994 of 13624 Old 01-16-2015, 03:48 PM - Thread Starter
batpig's Avatar
Liked: 3493
I think you have to remember that most users are consuming their media with the audio provided by TV speakers or, at best, a soundbar or a dinky HTIB package. For these people, dynamic range compression is really a necessity. It's really a "lowest common denominator" thing.... folks who have setups that are capable of comfortable, intelligible playback with full dynamic range are pretty rare.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10995 of 13624 Old 01-16-2015, 04:07 PM
lovinthehd's Avatar
Liked: 4777
FWIW the carrier picked up the non functioning 4520 yesterday and today A4L prepared the shipping tag on the exchange unit, even though ETA of the defunct unit at A4L is 1/22. So far so good...
post #10996 of 13624 Old 01-16-2015, 04:19 PM
UHD Addict
aaronwt's Avatar
Liked: 3396
I have been very pleased with the responsiveness from A4L. I got my refurb 4520 and extended warranty from them. Then I lost my receipt(I purchased the 4520 from A4L through ebay) and they responded quickly with a copy of the receipt after I emailed them.
post #10997 of 13624 Old 01-16-2015, 07:36 PM
Alan P's Avatar
Liked: 3532
I agree...but this is on a 4520ci!
Matt2026 likes this.
Alan P is offline
post #10998 of 13624 Old 01-18-2015, 07:15 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
I have a phono issue. Not sure what the possible cause is as have replaced my stylus at same time as receiver.
Running an ancient Pioneer PL570 turntable with a Shure V15 Type IV with a brand new Jico SAS replacement stylus - moving magnet cartridge. Neither the turntable or cartridge has seen any use for about 15 years. So plugged it into the phono input of my 4520 and found virtually no bass. Had to turn the bass output up all the way to +12 to get any.
I don't have another cartridge to try nor do I have an external phono preamp.
Any thoughts to which item would be the cause of this problem? I purchased the cartridge new in the 70s and it doesn't have a lot of usage.
Only thing I can try is tearing my system apart and using my Pioneer VSX-49TX. Only issue is that I never used the phono input on it so not sure it will accomplish anything.
Thanks for any tips. Pete
PeterK is offline
post #10999 of 13624 Old 01-18-2015, 07:15 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Duplicate post. Sorry
PeterK is offline
post #11000 of 13624 Old 01-18-2015, 02:22 PM
lovinthehd's Avatar
Liked: 4777
Perhaps just selective memory?
At least I've put a cartridge away for a long time with no ill effects. Seems to point at the non-Shure replacement stylus. It played fine when you put it away last and only difference is the stylus?
post #11001 of 13624 Old 01-18-2015, 03:28 PM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Yea I was questioning memory Myself!
There is NO bass unless I turn up the subwoofer output. Even at maximum of +12 it is still very low. Makes me question the phono input as to me sounds like it is not doing the RIAA correction possibly. Hard to believe the new stylus could be the culprit. Guess I will just have to dig out my other receiver and temporarily try that. If that works I will probably look for a decent phono preamp.
PeterK is offline
post #11002 of 13624 Old 01-18-2015, 03:51 PM
lovinthehd's Avatar
Liked: 4777
I have a 4520 on the way and plan to use the phono input. I do have a stand alone phono preamp also. Will post if any difficulties. Googled Jico so seems they do have some chops on the replacement stylus. You could plug into another input that has no RIAA curve and see if they sound different?
post #11003 of 13624 Old 01-18-2015, 09:25 PM
Walternate's Avatar
Quoted: 18 Post(s)
I have a Denon DP-47F TT with a Denon 110 MC cartridge hooked up to my 4520's phono inputs. Sounds great. Lots of bass with very nice detail. And that's with a MC cartridge. It's a high output MC for sure but much lower than a MM. At one time I had my Technics 1600 MKII turntable on the 4520 with the same cartridge and it lacked bass as well. Very detailed but lacking bass. So I think, in my case, it may be TT dependent.
I now have the Technics TT hooked up to a vintage Pioneer SX-1080 receiver and it sounds pretty good. However I have a Shure M97 MM cartridge on it now. I do have an extra Denon 110 cartridge so maybe I'll try it with that cartridge and see how it sounds to compare.
I would think that any decent MM cartridge, which your V15 is more than decent, much better than my M97, should sound very good on the 4520 as well. I suppose it could be something wonky on your 4520's phono inputs but I would be more inclined to think it's something in your PL570. I mean, if it's been sitting around for 15 years you might be having corrosion issues with your TT's RCA connectors/ cables or the tonearm wires? Or even the contacts on the headshell?
Walternate is offline
post #11004 of 13624 Old 01-19-2015, 05:49 PM
sonofsoren's Avatar
Quoted: 101 Post(s)
Liked: 29
I have been having an issue with my 4520 and it has been just since I upgraded my tv to a Samsung UN75HU8550. Every couple of weeks when I turn on my system, I get no picture and sound out of the 4520. I have to do a soft reset by unplugging the 4520 for 2 minutes or so and it always corrects the problem. Is this because the new Samsung is an UHD TV with hdmi 2.0 jacks? Does it have to do something with the EDID between the 4520 and the Samsung? I plan to upgrade to the Denon X7200 sometime this spring/summer. Will that new piece solve my problem? Should I just go ahead and upgrade now?
sonofsoren is offline
post #11005 of 13624 Old 01-21-2015, 12:20 PM
travis-g's Avatar
Quoted: 114 Post(s)
Liked: 64
I have the same problem but it's intermittent. Please help.
travis-g is offline
post #11006 of 13624 Old 01-21-2015, 04:24 PM
Liked: 0
Originally Posted by ril850 View Post
Well I figured it out, the FLAC files do play, I just had to scroll down. For some reason I get files that start ._01 Track Name and it won't play, but if I scroll down on the folder I get the 01 Track Name and then plays fine. See pic below.
Here's the kicker though, when I tried playing files on my Oppo 103, the files take forever to load and I don't get artwork or that much track info like before. I know I should ask in Oppo 103 thread, but I just thought I mention it here.
Not sure you you ever resolved this issue. I am having the same trouble but think it might be related to using a Mac. There are hidden files on my USB that the spotlight feature of OS X makes automatically. I am wondering if these are the files that are showing up. Revealing hidden files on my mac did not reveal the ._01 files. I was wondering if you are using a mac, or if you have plugged the USB into a Mac. Hoping to resolve this issue as scrolling to the bottom of there list is annoying.
Dale T. J. Sandberg is offline
post #11007 of 13624 Old 01-21-2015, 04:59 PM
UHD Addict
aaronwt's Avatar
Liked: 3396
Did you try going to another input on the 4520 and then go back to the input you want to watch? I've had to do this on occasion with all HDMI receivers I've used over the last ten years. It doesn't happen often but when it does I just go to an empty input and then back to the one with content and everything is fine.
post #11008 of 13624 Old 01-21-2015, 05:11 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
I remember watching Super 8 the first time and commenting in Ralph Potts' review thread and saying I thought the audio was less than overwhelming and he came up with this response:
"This is a Dolby TrueHD soundtrack which automatically sets the Onkyo's Night Listening Mode to "Auto". You have to manually set it to off once the track begins playing. Do that and watch some of these scenes over and see what you think".
Very very important piece of info.
'Super 8' on Blu, with the "Late Night Mode" manually selected to Off (because indeed it automatically defaults to Auto, very unfortunately), is a gem to behold. ...Acting wise (from the young actors), and from the audio's perspective (awesome LFE/Bass, and surround sound effects). And I bet it must also sound awesome with DSU engaged. ...Or with Audyssey DSX.
...Excellent flick all around.
__________
By the way, there are few more Blu-ray movies with a Dolby TrueHD audio soundtrack that automatically engage the receiver's (pre/pro) Late Night Audio Mode to Auto (embedded in the discs themselves). /// 'Iron Man' is another one.
And you have to always manually select Off, or you going to have dynamic compression with those flicks. ...You just have to remember.
* Check in your Denon 4520, and see where it is set @ after you start playing one of those BD titles.
But for sure it does it with a bunch of Onkyo/Integra receivers and pre/pros. ...Very very unfortunate.
And if Denon/Marantz receivers aren't automatically triggered by those discs (Late Night Listening Audio Mode set to "Auto" from its "Off" selection),
then big bonus point for Denon/Marantz, and big point deduction for Onkyo/Integra.
NorthSky is offline
post #11009 of 13624 Old 01-21-2015, 07:57 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3036
Need a little help here....
I am going to hook-up my Emotiva MPS-1 Amp and use the 4520 as a pre.
The manual isn't helping me out too much.
Which settings inside the Denon do I need to change?
oink is offline
post #11010 of 13624 Old 01-21-2015, 08:32 PM
sonofsoren's Avatar
Quoted: 101 Post(s)
Liked: 29
I tried switching inputs but it totally blocks all audio and video on all inputs when it happens. The only thing I have changed in my setup has been the tv which seems likely that it is the culprit. Anyone know of a fix to this or do I need to upgrade my AVR?
Denon Avr 4520ci Receiver
