The **OFFICIAL** DENON AVR-4520CI thread - Page 393 - AVS | Home Theater Discussions And Reviews
post #11761 of 11775 Old 03-23-2015, 02:33 AM
Philm63's Avatar
Liked: 1
Originally Posted by lovinthehd View Post
Do you have an android device?
iPhone only.
So is that a "...no, it won't work that way using the 4520's remote"? If so, I suppose I'll have to finally start looking into a universal remote.
Philm63 is offline
post #11762 of 11775 Old 03-23-2015, 04:41 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 340 Post(s)
Liked: 294
^ Give DeRemote a try. That's what is usually recommended for iOS.
ggsantafe likes this.
gsr is online now
post #11763 of 11775 Old 03-23-2015, 08:26 AM
lovinthehd's Avatar
Quoted: 1090 Post(s)
Liked: 1435
Originally Posted by Philm63 View Post
iPhone only.
I haven't tried to program my Denon remote as I don't use it very much, I mainly use a Harmony and occasionally my android phone and I don't change sub level often enough to look into something like that since its fairly easy to access via setup in any case. I believe you should be able to program it for that with one of the programmable presets IIRC. @batpig probably can confirm or not better than most....
lovinthehd is offline
post #11764 of 11775 Old 03-23-2015, 12:49 PM
jappleboy's Avatar
Quoted: 57 Post(s)
Stand by
Hi all lost my CD how do you turn off stand by, i do not want to see the red light that it tells me it is in stand by
jappleboy is offline
post #11765 of 11775 Old 03-23-2015, 01:35 PM
AustinJerry's Avatar
Quoted: 2154 Post(s)
Liked: 1162
The red ring remains illuminated it you set the network option to "Always On". Change it to "Off in Standby" to turn the red ring off.
AustinJerry is offline
post #11766 of 11775 Old 03-23-2015, 01:45 PM
jappleboy's Avatar
Quoted: 57 Post(s)
stand by
Sorry i guess i did not say it right, how do you kill all power when you turn it off.
post #11767 of 11775 Old 03-23-2015, 02:28 PM
Liked: 1162
Your question still is not clear. What do you think is still on when you turn the power off? Do you mean the other zones?
post #11768 of 11775 Old 03-23-2015, 02:54 PM
Alan P's Avatar
Quoted: 1708 Post(s)
Liked: 848
The only way to truly power-off the AVR is to unplug it from the wall. Modern AVRs will all go into "standby" when you turn off the power (whether via the remote or power button on the unit itself). However, the power draw in standby is negligible and most folks don't worry too much over it...I know I don't.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC-64ii, SUR: Polk LS/FX x4, FH: Klipsch RB-51ii x2, SUB: PSA T-18 x2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #11769 of 11775 Old 03-23-2015, 03:23 PM
Dreamliner's Avatar
Quoted: 84 Post(s)
Liked: 39
Will deremote do all 11 channel levels on the 4520? Will it allow me to switch between NEO:X, Audyssey DSX, etc?
Dreamliner is online now
post #11770 of 11775 Old 03-23-2015, 03:36 PM
ggsantafe's Avatar
Quoted: 83 Post(s)
Liked: 98
It will certainly allow you to switch formats, i.e. Neo X, DSX, etc. I have 9 channels connected and it will adjust each channel level - I assume it will adjust 11 if thats what you have connected to the AVR.
ggsantafe is online now
post #11771 of 11775 Old 03-23-2015, 05:00 PM
Liked: 0
Hello all, I am new to this forum. Like a few others on here I had a $500 budget and was looking at a 2100. I ended up purchasing a refurbished 4520, which will be replacing a 2808. I hope I don't end up with someone else's problem. Has there been many problems with these units or the refurbs?
nxs450 is offline
post #11772 of 11775 Old 03-23-2015, 05:19 PM
AVS Club Gold
aaronwt's Avatar
Quoted: 1285 Post(s)
Liked: 906
I've had a 4520 refurb since last Summer and mine has been fine.
53TB unRAID2--38TB unRAID3--33TB unRAID1a
LED DLP
XBL/PSN: WormholeXtreme
aaronwt is offline
post #11773 of 11775 Old 03-23-2015, 06:46 PM
Liked: 0
Good to here! I hope I don't have any problems.
nxs450 is offline
post #11774 of 11775 Unread Today, 09:26 AM
SherazNJ's Avatar
Quoted: 280 Post(s)
Liked: 33
Hi guys,
Can I use Denon 4520 as an amp considering it has 9 channels of amplification, rated at 150W/ch (8 ohms, 0.05% THD)?
thx
SherazNJ is online now
post #11775 of 11775 Unread Today, 11:41 AM - Thread Starter
batpig's Avatar
Quoted: 1544 Post(s)
Liked: 1831
Originally Posted by SherazNJ View Post
Hi guys,
thx
You can -- although you'll only be able to use 7 of the 9 amps in this role since there are only 7.1 external analog inputs -- but it seems sort of a waste of resources.
batpig is online now
Denon Avr 4520ci Receiver
Gear in this thread - 4520ci by PriceGrabber.com
