The **OFFICIAL** DENON AVR-4520CI thread - Page 405 - AVS | Home Theater Discussions And Reviews
post #12121 of 12130 Old Yesterday, 12:38 PM
AustinJerry's Avatar
Quoted: 2409 Post(s)
Liked: 1227
Originally Posted by mnc View Post
Just got around to doing measurements for the first time and discovered a huge peak around 60Hz! I thought Audyssey was supposed to fix big peaks. Should I just try it again with slightly different mic placements? I don't exactly have a boom mic, I'm using a stand from my drum set that is similar to a boom mic. It allows me to set the stand on the floor just behind my sofa and extends out to where my head would be. Any suggestions?
Mic placement won't fix a big peak. The peak is likely due to speaker or sub position in your room. Experiment with different placements.
AustinJerry is offline
post #12122 of 12130 Old Yesterday, 02:44 PM
PeterK's Avatar
Quoted: 38 Post(s)
Liked: 54
Killed power for 10 minutes and it worked!! Thanks.
PeterK is offline
post #12123 of 12130 Old Today, 07:36 AM
mnc
mnc's Avatar
Quoted: 354 Post(s)
Liked: 214
OK I'll try. I just thought the whole point of Audyssey was to fix large peaks. I thought maybe I did something wrong in the mic placement was the reason why it didn't work.
NHT speakers, Denon 4520, Panasonic 65VT50, PSA XS30SE
mnc is online now
post #12124 of 12130 Old Today, 08:28 AM
kbarnes701's Avatar
Quoted: 4090 Post(s)
Liked: 3078
It depends how big the peak is. Audyssey has limitations on how much it can boost or reduce frequencies. What do you call a "huge peak"?
kbarnes701 is online now
post #12125 of 12130 Old Today, 08:40 AM
mnc
mnc's Avatar
Quoted: 354 Post(s)
Liked: 214
12dB
mnc is online now
post #12126 of 12130 Old Today, 08:53 AM
kbarnes701's Avatar
Liked: 3078
12dB
Audyssey should pull most of that down. If it isn’t, then there is another issue. You may need to optimise speaker/sub locations, experiment with different positions for MLP and so on, assuming you are following best practice for the Audyssey calibration. Chance are, for a 60Hz peak, that is room-induced and EQ may well struggle with it. If you are crossing to your sub at a typical 80Hz, most of that peak will be coming from the sub. What measures have you taken to optimise the placement of the sub in the room - sub crawl, measurements etc? Have you tried moving the sub to a different location, even if only temporarily, and observing the effect?
post #12127 of 12130 Old Today, 09:24 AM
mnc
mnc's Avatar
Quoted: 354 Post(s)
Liked: 214
I haven't had time to try anything. I'm off tomorrow, so I will try as much as I can. Thanks.
mnc is online now
post #12128 of 12130 Old Today, 10:08 AM
mnc
mnc's Avatar
Quoted: 354 Post(s)
Liked: 214
Well I actually had a few minutes to do some quick measurements. The peak, which is centered at 63Hz, actually isn't as bad as I thought. I did about 10 different measurements all around the MLP. It's amazing how much the response varies from spot to spot! This is why I have always planned on gettting TWO subwoofers. I guess I won't worry too much about it until I am able to get my second sub.
ellisr63 likes this.
mnc is online now
post #12129 of 12130 Old Today, 11:13 AM
kbarnes701's Avatar
Liked: 3078
Yes, dual subs will certainly help you get a smoother response in more places across the room.
post #12130 of 12130 Old Today, 11:44 AM - Thread Starter
batpig's Avatar
Quoted: 1637 Post(s)
Liked: 1893
That's exactly why Audyssey (and many other room correction programs) preach the value of multiple measurements -- there is a lot of spatial variation in low frequencies. Even when optimizing for one seat. Once you know your room you can usually "cheat" and do one position but it's good to understand what's happening spatially so you (or an auto EQ program like Audyssey) doesn't wxpend resource on problems that exist only at a small point in space.
batpig is online now
Denon Avr 4520ci Receiver
Gear in this thread - 4520ci by PriceGrabber.com
