The **OFFICIAL** DENON AVR-4520CI thread - Page 408 - AVS | Home Theater Discussions And Reviews
post #12211 of 12230 Unread 05-02-2015, 05:42 PM
JohnAV's Avatar
Quoted: 98 Post(s)
Liked: 107
Originally Posted by doognam View Post
That would be around 44 Celsius.
Can you put your ears close to the avr to determine whether or not the internal fans are running?
The avr may be cool because its internal fans operate prematurely. Fans operating at just 44 Celsius indicate a loose contact in the same board-to-board connector that's been the source of loose contacts that have caused a myriad of other symptoms.
With a 6 to 8 ohm speakers load a 4520CI doesn't get very hot for 5.0 setup typically. You assuming because the AVR is not getting hot that the fans are kicking in, never encountered that situation.
Oppo Beta Group
JohnAV is offline
post #12212 of 12230 Unread 05-02-2015, 05:52 PM
maxxzinno's Avatar
Hi my question is about Denon 4th Link on the 4311 and Denon HD Link on newer Blu-Ray players.
I know HD Link is not backwards compatible but would it be possible to connect a RJ-45 to Coax Balun converter to get it to work..
Has anyone tried this ?
Any help appreciated.
Thanx.
maxxzinno is offline
post #12213 of 12230 Unread 05-02-2015, 06:37 PM
Quoted: 45 Post(s)
I would not assume anything of that sort so I asked and if I may ask again for whoever is concerned to find out, one way or another, whether the fans are actually running.
Fact is, the internal fans should not activate until around 70 Celsius or 184 Fahrenheit (if my conversion is correct), unless there is a loose contact or short in the thermal sensing circuitry.
Last edited by doognam; 05-02-2015 at 06:47 PM. Reason: add "circuitry" to remove ambiguity
doognam is offline
post #12214 of 12230 Unread 05-02-2015, 10:09 PM
Dreamliner's Avatar
Quoted: 88 Post(s)
Liked: 42
It's always fun to see these heat posts come up every few pages. I have all my equipment in a rack with about a 1" air gap on the top of the 4520, I have four 140mm fans in the back of the rack pulling air through; every component (including the 4520) is cool to the touch.
Dreamliner is offline
post #12215 of 12230 Unread 05-03-2015, 07:32 AM
laserjock II's Avatar
Quoted: 225 Post(s)
Liked: 97
Are they "triggered" or how are they implemented?
laserjock II is offline
post #12216 of 12230 Unread 05-03-2015, 07:49 AM
Zen Traveler's Avatar
Quoted: 374 Post(s)
Liked: 427
Originally Posted by AustinJerry View Post
Not Dallas, but Pyramid Audio in Austin is a highly-regarded authorized Denon repair facility. I had a board replaced in my 4520 by Pyramid, and they did a great job with a reasonably quick turn-around (about a week).
http://www.pyramid-audio.com/
My experience with them wasn't as good when I sent them my AVR-4802R--After 2 to 3 months of unresolved complaining I contacted Denon HQ in New Jersey and they rectified the situation to my satisfaction, but I wasn't happy with the journey....
Of course and as quoted above--YMMV.
AVSF458 likes this.
Zen Traveler is offline
post #12217 of 12230 Unread 05-03-2015, 11:25 AM
Dreamliner's Avatar
Quoted: 88 Post(s)
Liked: 42
I was trying to find a way to get a "triggered outlet" controlled by my receiver but I couldn't find anything economical.
I ended up buying one of those smart strips that turns on power to a strip based on control device. Cheapest here: http://mobile.walmart.com/ip/CyberPo...ector/14968093
Whenever my receiver is on the fans automatically turn on, when my receiver turns off the fans automatically turn off too. It's awesome.
I bought four 140mm computer fans and zip tied them together so I have one big square, I bought a power brick power adapter that has a computer Molex plug on the one end to connect the fans to and is plugged into the power strip.
post #12218 of 12230 Unread 05-03-2015, 01:52 PM
Bullitt5094's Avatar
In the Direct or Pure modes using an analog stereo input, is there any crossover processing done? Are all the outputs full range including the sub woofer outputs? What about if you are bi-amping? Is the full signal range sent to the R/L mains and the R/L Wide outputs that are normally connected to the tweeter in a Bi-Amp mode?
Bullitt5094 is offline
post #12219 of 12230 Unread Yesterday, 09:18 AM
Toddpritch's Avatar
Liked: 1
So I'm having a pretty frustrating issue. Currently when I have my roku stick hooked up to the 4520ci it outputs video and sound fine when it's on the menu screens, but when I try to watch a streaming show (netflix, amazon, HBO GO) the sound comes through but the video completely cuts out, I don't even get the Denon on screen display and I have to unplug the roku to even get the picture back on the roku menu screen after that. When I'm on the menu screen the sound is pcm stereo, but every streaming feed I've tried so far has had either dolby digital 2.0, 5.1, or plus, all have done the same thing when the sound changes from 2ch pcm to dolby. I've tried both monitor outs, 1 and 2, I've tried turning off the different monitor outs, I've tried different HDMI inputs on both the denon and my tv and so far they all do the same thing. My tv is a Mitsubishi 73833. The weird thing is when the tv was hooked up the previous day to my old Sony 42" LCD from like 2007 it worked perfectly fine even when sent a dolby digital soundtrack. The only difference was while the roku was sending a digital soundtrack I only had two speakers hooked up to the Denon. When I moved it to the room with the Mitsubishi I hooked it up in a 7.1 setup with the 5 main channels being run by a separate 5 channel amp (the denon amps were only handling the wides.) I don't know if it's the TV, if it's because there are more channels active or if I'm missing a setting somewhere, but I'm really worried because this was a refurb unit and I REALLY don't want to send this thing back. Has anyone else experienced this or have any idea how to fix this? Thanks
Toddpritch is offline
post #12220 of 12230 Unread Yesterday, 09:41 AM - Thread Starter
batpig's Avatar
Quoted: 1668 Post(s)
Liked: 1914
I think it's a weird HDMI handshake issue. I have a similar problem with my Roku 2XS. Never had an issue with my older Denons but when I swapped to a new X5200W all of a sudden the screen would go crazy (horizontal flickering) whenever I tried to play videos. I eventually traced the problem to the same thing you noticed -- it only happened with 5.1 DD/DD+ streams. If I set the Roku to 2ch stereo output it never happens.
Not much solace here as I haven't found a solution. I've tried everything (different HDMI ports on the receiver, different HDMI cables etc) and it always happens. Every time I get a firmware update on the receiver or the Roku I check again just in case, but it hasn't fixed itself yet
I'm probably just going to try a different Roku model and cross my fingers that it works correctly.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #12221 of 12230 Unread Yesterday, 12:26 PM
ggsantafe's Avatar
Quoted: 98 Post(s)
Liked: 106
I'm running the Roku 3 with the 4520 without any problems - have you tried playing in the audio settings menu experimenting with setting to Auto, DD+,etc. Might also try posting here: http://forums.roku.com/
ggsantafe is online now
post #12222 of 12230 Unread Yesterday, 12:47 PM
AVS Club Gold
aaronwt's Avatar
Quoted: 1405 Post(s)
Liked: 937
I've never noticed the internal fans on. I have one, whisper quiet, fan on top. I think it's a 120mm fan. I have it in the middle, closer to the back. I'm running a 9.1 setup with Front Heights.
ellisr63 and Matt2026 like this.
53TB unRAID2--38TB unRAID3--33TB unRAID1a
LED DLP
XBL/PSN: WormholeXtreme
aaronwt is offline
post #12223 of 12230 Unread Yesterday, 12:49 PM
ellisr63's Avatar
Quoted: 334 Post(s)
Liked: 279
I have never noticed any fans on mine either.
Denon 4520ci, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, (3) MiniDSP 2x4s, (4) Klipsch HIPs,  PS3, XBox 360, (3) Intel NUCs, Redmere, Monster HTPS7000, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diagonal) scope screen, Darbee Darcet, Yamaha P7000s, (2) Yamaha P2500s, & (3) Topping 25wpch T chip amps.
The Ellis Family Go Big or go Home HT
ellisr63 is online now
post #12224 of 12230 Unread Yesterday, 12:50 PM
AVS Club Gold
aaronwt's Avatar
Liked: 937
I was going to do that with mine. Until I remembered that the APC UPS my 4520 is connected to has that feature. So the UPS turns the outlet on/off that the fan is plugged into, when the 4520 turns on and off.
Matt2026 likes this.
LED DLP
aaronwt is offline
post #12225 of 12230 Unread Yesterday, 12:51 PM
AVS Club Gold
aaronwt's Avatar
Liked: 937
I initially was going to buy one of those smart power strips since they have worked well with my three unRAID setups.. Until I remembered that the APC UPS my 4520 is connected to has that feature. So the UPS turns the outlet on/off that the fan is plugged into, when the 4520 turns on and off.
LED DLP
aaronwt is offline
post #12226 of 12230 Unread Yesterday, 01:49 PM
Quoted: 45 Post(s)
The receiver's internal fans are also whisper quiet so it would take some effort to determine whether or not they are running. Like, perhaps, turning OFF everything else except the avr and putting an ear or an spl meter very close to the unit. It is also possible, if the top of the unit is exposed, to see part of the fans and blades thru all the electronics when they are off. You might not be able to recognise the fan blades when they are running.
It is not bad for the fans to activate prematurely. In fact, it could help prolong the life of the avr. On the other hand, it could make some feel uncomfortable knowing that parts of the unit may "not be behaving as designed".
doognam is offline
post #12227 of 12230 Unread Yesterday, 02:12 PM
Toddpritch's Avatar
Liked: 1
Yeah I was thinking it was a handshake issue, but it's so strange that the roku in the denon would work on my 42" tv and the roku will work fine plugged directly into the mitsubishi tv, but the roku plugged into the denon and then out to the mits tv won't work. ARGhhhh, super frustrating especially considering MOST of my tv watching right now is on the roku. I'll try the roku 3 (it's in a different room) and see if that does the same thing, the HDMI is the only one I've tried. I just couldn't imagine I'd be the only one with this issue or that tv would be the only one.
post #12228 of 12230 Unread Yesterday, 02:33 PM
AVS Club Gold
aaronwt's Avatar
Liked: 937
Whne I first got the receiver, and before I put the fan on top, i checked for the internal fans running and didn't notice them on. But that was last year.
LED DLP
aaronwt is offline
post #12229 of 12230 Unread Yesterday, 02:36 PM - Thread Starter
batpig's Avatar
Liked: 1914
Yeah I've played with almost every audio related setting on the Roku. I eventually gave up -- when I want "critical" viewing (as critical as you can get from streaming services) I also have Netflix, Vudu, Amazon Prime apps on my Sony BDP which can bitstream the DD+ no problem. If I'm just watching House Hunters with the wife or Octonauts with the kids I can handle 2.0 PCM with DSU upmix
I'm about to move into a new house in a few weeks at which point I'll have a semi-dedicated room upstairs and casual viewing downstairs in the living room. I'll probably end up getting a newer Roku for the dedicated room and use the older 2XS downstairs where I probably won't have a full surround setup.
Setup Guide and FAQ
post #12230 of 12230 Unread Today, 11:48 AM
Quoted: 203 Post(s)
I am finding out that for all their size these manufacturers no longer maintain their own Service Centers and it is a crap shoot as to your experience. I did not want to say this but quite a few of the Customer experiences posted online say that along with some real good ones as well. I think they are rated 3.5. So if they are the best then I dont even want to think about those who have no reviews.
Denon Rep did not say anything about the local Dallas company so I just have to take it to these guys and hope for the best. I hope my experience is similar to Jerry's.
AVSF458 is online now
Denon Avr 4520ci Receiver
Gear in this thread - 4520ci by PriceGrabber.com
