The **OFFICIAL** DENON AVR-4520CI thread - Page 448 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #13411 of 13595 Old 08-15-2016, 05:53 PM
Matt2026's Avatar
Quoted: 381 Post(s)
Liked: 14275
Originally Posted by Dreamliner View Post
It's just a fan. I have my receiver in a rack and fans in the back that draw cool air from the front over all of my electronics. Everything is cool to the touch. Some people have used this cooler. Its pretty, but expensive.
I am a very firm believer that heat kills components. I like fans and use them a lot.
I'd look at the upcoming Denon 6300, thats what I'm getting next. I've not yet had a AVR failure, but I'd imagine the repair process will suck regardless of brand.
I worked in the electronics industry here in Silicon Valley for 40 years. Some of that time was related to the military. Silicon components typically have two failure humps. The first hump occurs in the first 1,000 hours. For every 10*C rise in junction temperature the time is cut in half, so 10*C higher the hump come in to 500 hours and going to a still safe higher temp the burn in time can be reduced considerably which the IC manufacturers did on a qualified line so they greatly reduced early failures which you don't want happening on a mission.
One might choose to run new audio/video equipment at an elevated temp to see if it will break early in the warranty period...
Once past what is called infant mortality hump, that first hump, the next cluster of failures occur around 10,000 hours and we don't want to pull that one in but keep it as far out as possible. There are also random failures which we can't do much about but maybe hotter temperatures increase those events also. For units that do not experience either of those two failure humps can have a very long life.
Knowing what I do I put active cooling in place from day one on my 4520: http://www.ebay.com/itm/Receiver-Amp...kAAOSw7ThUpJJJ I like this unit as it is thermostatically controlled and if the unit is above the temperature setting the fans continue to run even after I shut the AVR down. I see no reason to let it continue to "bake" any longer than it has to.
As a side note I had to pull plenty of printed circuit boards and clean the contacts with an eraser and reinsert them to fix various problems... All those circuit boards had gold plated contacts to avoid corrosion and there were still problems at times. In some applications mechanical contacts, such as plug in circuit boards or ICs in sockets, were not allowed. Mechanical connections are a weak link.
Alan P, batpig and bmcn like this.
Regards, Ken (Retired)
9.1) Denon 4520CI; Samsung 55H8000 & BD-F7500; LRS/L/R SVS Ultra BS, Ultra Center;
RRS Celestion 5; FH & SS Polk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nakamichi RE-1, CDC-4A, CR7A, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #13412 of 13595 Old 08-16-2016, 10:41 AM
Michaeldef's Avatar
Quoted: 42 Post(s)
4520 red blinking
Does anyone know where to get a svc manual for the 4520, or know whats involved after lightning damage ? Since wa hit the red light just blinks at the power switch
Michaeldef is offline
post #13413 of 13595 Old 08-16-2016, 10:45 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
Not sure what power sw is particularly (abbreviation for switch?). Try a soft reset and if that doesn't work then try a microprocessor reset. It may have been damaged more seriously, though, if lightning is involved....
ps Never saw a service manual for the unit myself....
lovinthehd is offline
post #13414 of 13595 Old 08-16-2016, 11:01 AM
Michaeldef's Avatar
Quoted: 42 Post(s)
It had dozens of resets ! All the other gear had fried power supplies, which I replaced and fixed. Just no info for the 4520, thank you
post #13415 of 13595 Old 08-16-2016, 11:04 AM
hltr's Avatar
Liked: 25
See first post of the thread for manual link.
____________________
Brian's Bar Build
hltr is offline
post #13416 of 13595 Old 08-16-2016, 11:43 AM
Schwa's Avatar
Quoted: 1028 Post(s)
Liked: 1087
There's no service manual link.
Schwa is online now
post #13417 of 13595 Old 08-16-2016, 01:36 PM
jdsmoothie's Avatar
Quoted: 12602 Post(s)
Liked: 5770
You may be able to obtain one directly from the Denon Parts division or one of their authorized Parts distributors.
http://denon.custhelp.com/app/answer...ng-denon-parts
jdsmoothie is offline
post #13418 of 13595 Old 08-16-2016, 01:36 PM
hltr's Avatar
Liked: 25
Ah, sorry
Brian's Bar Build
hltr is offline
post #13419 of 13595 Old 08-24-2016, 02:50 PM
Quoted: 238 Post(s)
Liked: 24
Using something like this is active cooling
What changes to Audyssey do you typically make? Shouldn't be an issue to tweak to your liking.
For your Dish pass thru do you have picture mode (under video/picture adjust in the video menu) set to off?
Hard to imagine a 10-12 dB boost by raising sub level doesn't have an effect. How did you choose the placement of your subs? BTW if set to -12 then your avr is telling you the gain on your sub amp is set a bit too high, anything above -12 should be okay, tho.
I agree @LOVE inthehd. It should have an effect but the effect is minimal. It does not add more ooph but add more muddiness and echo that is not pleasant to the ears. Also seems to create more pressure on the ears if you know what I mean.
When I start the Audyssey, I do the sub level matching and set them each as close to 75db as possible. The noise from the two Amps for the subs creates an issue with pinning it to 75. I put the Inukes at 50% where the dot is at the 12 O'Clock position and then increase it from there to get to 75 db on each sub as suggested on the 4520. Then I run the Audyssey for all 8 positions where all of them are on my 3 seat couch in front.
The subs are on the Front Left (When I am sitting the couch) and the Rear Right.
I will check on the picture mode on the Dish, I am not sure it has one. I have it off on the 4520. The dish is connected to the 4520 via HDMI and then the HDMI out on the 4520 goes to the Sharp LC-80LE857.
My 5 speakers are from Ascend. The Towers with RAAL, the Center with RAAL and two rears are their Sierra-1's. I have made them mad here talking about how I dont think their speakers are as great as everyone thinks at least in my setup. My room acoustics are bad and that is the cause of a lot of my issues but I still think the sound should not be as bad as I think it is or as muted.
For sound the only options on the dish are Dolby Digital or PCM and I have it on PCM. The Dolby Digital sounds worse.
I still did not get it, should i turn Audyssey off once I mess with what audyssey has set up or keep audyssey turned on and at that point it is working with the changed settings?
Thanks for trying to help me.
AVSF458 is offline
post #13420 of 13595 Old 08-24-2016, 02:50 PM
Quoted: 238 Post(s)
Liked: 24
BTW is the Pioneer Elite SC91 an improvement over the Denon 4520?
AVSF458 is offline
post #13421 of 13595 Old 08-24-2016, 05:05 PM
lovinthehd's Avatar
Liked: 4776
Hard to know what you mean by "does not add more ooph but add more muddiness and echo that is not pleasant to the ears. Also seems to create more pressure on the ears" although subs do pressurize rooms, so that may be what you're feeling. Muddiness and echo may depend on your definitions or even expectations, or can be influenced by how you setup eq with your iNukes (assume this is the DSP model since they're ported, so your dsp settings need to be explained, and best done so in the diy sub subforum where there is some expertise on ths). Do you have the ability to measure your subs and share those measurements?
How loud are your amps from the measuring position? No way to quiet your amps or put something around/over them during calibration to keep their noise out of the measurement? How does that affect sub readings? What frequency is the fan noise? Sounds like a fair way to setup the sub levels but I usually aim for a higher level for the subs to set my trim well into the negative range. What do you position your Audyssey mic with? What pattern are you using for the 8 positions? Have you tried the Audyssey setup thread for assistance?
Your sub positions sound reasonable, how did you choose them?
Never heard much good about Dish quality, I use DirecTV myself for sat. As to audio settings why 2ch PCM so everything needs to be upmixed? I'd think the basic DD surround setting would be better so you at least get discrete content when available.
As far as Ascend, I use several myself (Sierra-1s NrT, 170SE & 200SEs). You should be getting very good results from them. Whether that's to your taste/expectation or not, hard to know, that's for you to determine.
It's your preference whether to use Audyssey for setup or do it manually. If you use Audyssey as the auto setup afterwards you may want to use Audyssey for movies, Audyssey Flat for music, or Bypass L/R or turn it off or whatever floats your boat, it's a matter of preference.... If you use Audyssey for setup and then turn it off it just retains your level/delay settings and turns the eq part off. It gives you a lot of choices, there's no one setting I use for everything, I vary it with specific content. Dynamic EQ I also use, Dynamic Volume I don't; if you use DynamicEQ you might note how to use the accompanying Reference Level Offset settings. If you tweak the speaker/sub levels or delay (distance) Audyssey still works; you simply cannot change the basic EQ curves(Audyssey, Audyssey Flat, Bypass L/R).
Hope that helps, but it does take some work to get it right. Your expectations are your own, though. It can be hard to share setup info without sharing measurements to show others what may or may not be going on....your use of descriptive words may not be universal either.
I like the 4520 a lot, my old Pioneer crapped out but I did like the MCACC somewhat, but prefer what Audyssey can do for subs.
AVSF458 and bmcn like this.
post #13422 of 13595 Old 08-24-2016, 05:34 PM
Quoted: 238 Post(s)
Liked: 24
@lovinthehd
Thank you again for taking the time to send in a detailed reply.
Yes, I have been to the Audyssey post when I first set the system up.
I believe I need to find a person who does this as a hobby or for money in the DFW area who can come and set it up for me.
I have exhausted the limit of my ability. I have the Mic and have done the REW thing etc etc to set up the DSP on the iNukes. The iNuke setup was done after reading some of the posts in that forum. I have one attached to each sub. After Audyssey I turn the knobs to 75% on the volume and it still is more noise no thump if that is a better word to describe what is missing. There is bass just not what I recall it used to be. I will try and do the REW stuff again and post in that forum.
I picked the location based on availability of space in my room. There is no other place to put them given my circumstances. Hence the mention of the limitations.
Well there is just not a lot of heart thumping or anything thumping base as any volume no matter how I tweak the iNuke or the Audyssey setup. All I can create is more pressure to my ears and more of an echo. I know at one time they sounded good when I first bought the 4520 but after it came back from repairs it has never been the same again. Wish there was an easy way to know if there is something wrong with the 4520. I have also done a hard reset and then gone through the settings but i can try that one more time.
My readings are taken 4 times close to the middle seat of the couch and twice each on the left and right seats with the last two readings being in the middle. The mic is at ear level and is on a tripod at 90 degrees to the ground.
AVSF458 is offline
post #13423 of 13595 Old 08-24-2016, 05:57 PM
lovinthehd's Avatar
Liked: 4776
@lovinthehd
Could be something wrong with the 4520 if you've had issues/repairs, hard to know but in resetting everything up something could have changed; sometimes a complete fresh start is in order. Could be what you're basing your expectations on, what is that experience with bass or speakers in general? Cars? Not a good comparison for several reasons.... You keep saying thump so I'm starting to think mid-bass range is what you're after, and you can probably emphasize that with the iNuke dsp. Bought a condo in Grapevine once back in '80 but the deal didn't work out and never looked back
post #13424 of 13595 Old 08-27-2016, 06:58 AM
pndiku's Avatar
My 4520 suddenly doesn't allow me to select the media player input for zone 3. Any reason for that? Didn't know it was even possible to hide inputs on a per zone basis.
Sent from my HTC_M10h using Tapatalk
pndiku is offline
post #13425 of 13595 Old 08-27-2016, 07:30 AM
jdsmoothie's Avatar
Liked: 5770
The "HIDE" setting applies to all zones. Is the Media Player connected by analog audio cables as that would be the only way to pass it to Zone 3?
post #13426 of 13595 Old 08-27-2016, 07:31 AM
pndiku's Avatar
Yes. It's connected with analog cables. My cable box isn't connected with analog cables but shows up for selection.
pndiku is offline
post #13427 of 13595 Old 08-27-2016, 07:34 AM
jdsmoothie's Avatar
Liked: 5770
Could be a firmware glitch then. Power off and unplug the power cable for 10 minutes and try again.
post #13428 of 13595 Old 08-27-2016, 07:35 AM
pndiku's Avatar
Ok. I'll try that when I get back home. Thanks.
pndiku is offline
post #13429 of 13595 Old 08-30-2016, 10:43 PM
pndiku's Avatar
Still no luck. I'll probably do a full reset over the weekend and see if that works.
pndiku is offline
post #13430 of 13595 Old 09-09-2016, 05:28 PM
Mkard's Avatar
Quoted: 33 Post(s)
Liked: 31
Belated thanks
@Mkard While you don't need the codes for Harmony, if you'd like a copy I saved one when I got my 4520. PM me with your email addy and I'll send it to you.
Originally Posted by batpig View Post
Yes one of the features of harmony is the codes are already in the database.
Originally Posted by bgoering View Post
I believe Harmony has Denon codes in their database already, but not sure as I am using a URC remote with mine. That 2015 IR Codes is an Excel spreadsheet (.xls) not a PDF file.
I didn't do a whole lot with setup on mine, just followed along the walkthrough for initial setup and Audessey when I put mine in.
As is usual for AVS, you are all spot on. Still messing w/ the endless "getting HT dialed in..." but unit sounds great and the spouse can now access what she wants with the Harmony. Peace at last.
Mike K
Mkard is offline
post #13431 of 13595 Old 09-11-2016, 09:53 AM
wowzors's Avatar
Quoted: 18 Post(s)
Is anybody in this thread using a 4520 with a LG OLED like an E6?
I am thinking about purchasing the TV but I'm not sure on how I would connect everything as the receiver only has 4K paasthrough and no HDR. The ARC HDMI can only do up to Dolby or DTS so I would be losing out on lossless if I am correct?
I guess my question is. Is it time to move on from the 4520 or should I look into an oppo or something to have a audio HDMI out and Video. I also play a lot of consoles but I don't care about lossless as much for games.
wowzors is offline
post #13432 of 13595 Old 09-13-2016, 09:39 AM - Thread Starter
batpig's Avatar
Quoted: 3600 Post(s)
Liked: 3445
Since the 4520 doesn't support copy-protected 4k passthrough, you can bypass the receiver for video from these specific sources. If you only have one or two such sources it may be worth keeping the 4520 if you are happy with it, just run an HDMI for video to the TV and a separate audio connection to the receiver (don't have to rely on ARC for this). Any UHD BDP will have dual HDMI outs so you can still get hi-rez audio to the processor even if you are running a separate video feed to the TV. And any 4k streaming apps built into the TV will not have to pass through the 4520 so you don't have to worry about HDCP on that front.
Obviously, the more external 4k sources you have, the more cumbersome this becomes. It's up to you whether you want to work around it or upgrade an otherwise good receiver.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #13433 of 13595 Old 09-13-2016, 10:15 AM
wowzors's Avatar
Quoted: 18 Post(s)
To be honest the only 4k thing i plan on buying is a BD at this point. The consoles dont seem to have any true 4k output and even if they did I would just plug the HDMI into the TV and rely on the ARC or Digital Output for the audio to the receiver Ill miss DDHD and DTSMA (on the consoles) but not for $1500 for a the new x4300H.
Thank you for the clarification, sounds like the 4520 can live on for a couple more years.
wowzors is offline
post #13434 of 13595 Old 09-14-2016, 04:42 PM
paligap's Avatar
Quoted: 116 Post(s)
Liked: 42
Would it be possible to use another receiver, say a 4200, to to do all the processing and power the surrounds, while using the 4520 to power the LCR channels? If so, would there be a way to assign more than one amp in the 4520 for each of the LCR channels?
Sony XBR-75X940D
Oppo BDP-103D
Denon 4520
Custom UFW-15 (2)
Rocket RS850 (2), Rocket Bigfoot Center, Rocket RSS300 (2), Rocket RS250MKII (4)
paligap is online now
post #13435 of 13595 Old 09-14-2016, 05:09 PM - Thread Starter
batpig's Avatar
Liked: 3445
yes, because the 4520 has 7.1ch analog inputs (circled in attached back panel photo) that are intended for an external processor, you can use it to power up to 7 channels.
just set it to EXT IN mode and make sure to zero out all the distances/levels for the speakers, and connect it up like an external amp
when connected these inputs it's basically a straight passthrough to the amps, the signal is never digitized so there is no processing.
if you want to "bi-amp" a speaker with this setup you just do an RCA splitter from the pre-amp to two inputs on the 4520.
Setup Guide and FAQ
post #13436 of 13595 Old 09-15-2016, 05:30 AM
paligap's Avatar
Quoted: 116 Post(s)
Liked: 42
Thanks for the reply. How would I zero out the distances/levels, and would I do that in the 4520 or in the pre-amp?
So the only way to "assign" multiple amps to a speaker if with this wiring method, and not internally in the 4520?
One last question: If I wanted to do a 7.2.2 configuration, could I achieve it with this setup, or does the 7.1 limit of the analog inputs on the 4520 prevent this? I know it has 9 amps.
Sony XBR-75X940D
Oppo BDP-103D
Denon 4520
Custom UFW-15 (2)
post #13437 of 13595 Old 09-15-2016, 09:10 AM
lovinthehd's Avatar
Liked: 4776
Set all delays (distances) and levels to 0 in the 4520, you're going to do the processing with the 4200. The channel limitation will be in the processor. I wouldn't bother with the passive bi-amping, just no real benefit to be gained, but if you insist, just split any signal L/C/R pre-out signal from the 4200 into any two amps in the 4520 and then connect those appropriate amp outputs in the 4520 to the your speakers. Waste of wire.
batpig, paligap and Matt2026 like this.
post #13438 of 13595 Old 09-15-2016, 10:25 AM - Thread Starter
batpig's Avatar
Liked: 3445
You'd zero everything out in the 4520 so that it's "flat" and simply amplifying the signal. As I noted above the EXT IN multich analog inputs are never digitized so it will bypass any other processing (e.g. no bass management or EQ) but the speaker levels do apply and I think the delay/distance might apply as well. So just be safe and zero out, you can simply perform a microprocessor reset on the 4520 if you want it to be at all default settings (with all levels/distances equalized).
Right, remember that in this configuration the 4520 is simply a "dumb" amplifier, it's not doing any processing. You are simply feeding an RCA input with a signal that goes directly to that channel of amplification, gets amplified and comes out the speaker terminal with the same label as the RCA input. It doesn't "know" what it is amplifying. Although I do agree with the above that it's probably a waste of wire to do it that way, at best there will be incremental benefit.
No such limitation because remember you still have the amps/channels in the 4200 which is the processor here. So whatever 2 speakers are left over will be powered by the 4200. In fact you might want to split the load a bit more evenly, e.g. power the LCR + surrounds with the 4520 and the s.backs + heights with the 4200. Then the 4520 is only powering 5 speakers (giving it a little more available power for those 5 channels) and the 4200 is powering 4 speakers which are pretty easy to drive.
Setup Guide and FAQ
post #13439 of 13595 Old 09-15-2016, 04:50 PM
paligap's Avatar
Quoted: 116 Post(s)
Liked: 42
Thanks for your answers, batpig and lovinthehd.
What would I lose, in practical terms, by going from the AL32 processing in the 4520 to the AL24 processing in the 4200? I listen to multichannel, hi-res music fairly often, but I'm not really an audiophile. I had a 4310 before my 4520, and the biggest difference I perceived was the XT32 and SUB EQ HT.
Sony XBR-75X940D
Oppo BDP-103D
Denon 4520
Custom UFW-15 (2)
post #13440 of 13595 Old 09-15-2016, 05:57 PM
floatingkiwi's Avatar
Hi all
Quick question re 4K in the 4520.
Now, I have a Cambridge audio 752bd which upscales to 4K, but I have no device which plays native 4K discs (and probably wont for a while). I'm looking to upgrade my old Panasonic PT-200E (720P) projector to either a Epson 6030 or the new 6040 (1080P vrs 4K).
Now, if I understand this right the 4520 would pass the upscaled 4k to the proj, but it would never pass the 4k from a full blu ray 4k player even if I got one?
Basically I'm trying to figure out if going to a 4K projector is worthwhile for me. I want to get 3D and full HD etc at least for now.
floatingkiwi is offline
Denon Avr 4520ci Receiver
