The **OFFICIAL** DENON AVR-4520CI thread - Page 451 - AVS Forum | Home Theater Discussions And Reviews
 870Likes
post #13501 of 13624 Old 12-03-2016, 04:17 AM
pndiku's Avatar
Correct. Although some of the 2012 models (to include the 4520CI) can upspcale to 4k, they will not pass a 4k/HDCP 2.2 signal from a new 4k UHD BDP.
Would you say the 4520 has better up scaling than the average 4k TV?
Sent from my HTC 10 using Tapatalk
pndiku is offline
post #13502 of 13624 Old 12-03-2016, 04:22 AM
jdsmoothie's Avatar
Quoted: 13306 Post(s)
Liked: 6170
Not likely, no, but best if other 4520CI owner's chime in with their experience as it would depend on the capability of upscaling by the TV.
jdsmoothie is offline
post #13503 of 13624 Old 12-03-2016, 07:05 PM
wowzors's Avatar
Quoted: 18 Post(s)
Sorry if this is a stupid question.
What would be the best way for me to keep my 4520 but still get DTSHD audio from my 4k systems (ps4 pro, Xbox 1, blu ray player and such) and my TV.
I don't want to get a new receiver because if I do I am not glong to go flagship and I feel like the audio quality will be less on a cheaper new 4k hdcp 2.2 receiver.
wowzors is offline
post #13504 of 13624 Old 12-04-2016, 02:42 AM
jdsmoothie's Avatar
Liked: 6170
Either pass the video directly to the TV with audio only to the AVR or purchase an HD Fury Integral.
https://www.hdfury.com/shop/splitter...60-444-600mhz/
post #13505 of 13624 Old 12-04-2016, 09:15 AM
wowzors's Avatar
Quoted: 18 Post(s)
How would I send audio only from a ps4 pro? There is only one hdmi and as far as I know I can plug that into the TV and use the TV ARC for audio but it will top out at 5.1 dts, no lossy.
wowzors is offline
post #13506 of 13624 Old 12-04-2016, 12:15 PM
jdsmoothie's Avatar
Liked: 6170
DD/DTS 5.1 is lossy.
Without using a dual HDMI BDP, you wouldn't be able to pass the "lossless" audio.
post #13507 of 13624 Old 12-05-2016, 08:00 AM
Alan P's Avatar
Quoted: 4896 Post(s)
Liked: 3532
Originally Posted by Alan P View Post
So, I just got a new 4K TV the other day, and come to find out that the 4520 upscales to 4K...who knew??
Seems to do a good job of it as well. As far as I can tell, it's a definite improvement having it on with BRs.
After some more testing, I've found I can't really tell a difference between on/off on my Vizio E series.
pndiku likes this.
Alan P is offline
post #13508 of 13624 Old 12-05-2016, 08:02 AM
pndiku's Avatar
Thanks Alan
pndiku is offline
post #13509 of 13624 Old 12-05-2016, 09:25 AM
Alan P's Avatar
Liked: 3532
So, I've been running with Audyssey off and using the GEQ lately...I'm liking how it sounds.
But, I've run into an issue that jdsmoothie may have an answer to; it seems that when I switch surround modes (from say, True HD to True HD + PLIIz) the 4520 turns Audyssey back on. This is quite annoying.
Is there any way to stop the AVR from turning Audyssey back on and leave it on GEQ??
Just as I'm typing this I had a thought...maybe I need to set every surround mode to use GEQ and then the AVR would remember the setting...? Is that maybe the answer?
Alan P is offline
post #13510 of 13624 Old 12-05-2016, 10:43 AM - Thread Starter
batpig's Avatar
Quoted: 3654 Post(s)
Liked: 3493
The Audyssey settings should be linked to a specific input, not surround mode. Are you maybe using Quick Selects?
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #13511 of 13624 Old 12-05-2016, 10:57 AM
Alan P's Avatar
Liked: 3532
Thanks batpig!
Nope, not using any Quick Selects.
However, I change surround modes by holding down the Audio button and then cycling through all the available modes. So, to get from PLIIz to Stereo for instance, I have to go through all the other surround modes to get there. Is that what is causing my issues?? Maybe I should be using Quick Selects (never have used them)....?
Alan P is offline
post #13512 of 13624 Old 12-05-2016, 11:54 AM
jdsmoothie's Avatar
Liked: 6170
Thanks batpig!
Would help .. yes.
post #13513 of 13624 Old 12-05-2016, 12:01 PM - Thread Starter
batpig's Avatar
Liked: 3493
That's still not normal behavior though IMO. I change surround modes all the time and it doesn't affect the Audyssey settings.
Setup Guide and FAQ
batpig is offline
post #13514 of 13624 Old 12-05-2016, 12:02 PM
Alan P's Avatar
Liked: 3532
Would help .. yes.
OK then, I'll set those up tonight.
Any tips for a first time user of Quick Selects? I'll have to pull up the manual.....
Alan P is offline
post #13515 of 13624 Old 12-05-2016, 02:58 PM
Alan P's Avatar
Liked: 3532
OK, probably a stupid question but I've looked at both pages of the manual that refer to Quick Selects. Can these be accessed through the remote or only the front panel??
Alan P is offline
post #13516 of 13624 Old 12-05-2016, 11:43 PM
jdsmoothie's Avatar
Liked: 6170
On just about every remote before and after the year the 4520CI was released, the Quick Selects are on the remote. For some reason, that year, they chose to remove them, so only on the front panel.
AFAIK, you should however, be able to program them into a Harmony remote.
post #13517 of 13624 Old 12-06-2016, 08:15 AM
Alan P's Avatar
Liked: 3532
Thanks JD.
I use a URC MX-700 and I bet I can find hex codes for those buttons.
Off to Remote Central!
Alan P is offline
post #13518 of 13624 Old 12-07-2016, 06:06 PM
tknx's Avatar
Quoted: 34 Post(s)
Is there a way to use the 7.1 surround in with a MiniDSP 88A to get Dirac Live?
I assume not but figured I would ask.
Denon X4300H | Salk Veracity ST | Chane AR1X | SVS SB13 Ultra
tknx is offline
post #13519 of 13624 Old 12-08-2016, 11:12 AM - Thread Starter
batpig's Avatar
Liked: 3493
I think your best bet would be to use external amplification if you wanted to use the 88A for Dirac EQ.
Setup Guide and FAQ
batpig is offline
post #13520 of 13624 Old 12-08-2016, 11:13 AM
jdsmoothie's Avatar
Liked: 6170
You would need to use external amps in order to take advantage of the MiniDSP 88A.
post #13521 of 13624 Old 12-09-2016, 08:22 AM
Quoted: 33 Post(s)
Help please. I have googled and read through here and just can't find information. I want to hook up a Bluetooth adapter to this receiver. Which one works the best? I am wanting to stream HIFI music. Or should I wifi? What is the best option for going wireless with music for this receiver. Again looking at HIFI quality through Tidal.
mr.sooner is offline
post #13522 of 13624 Old 12-09-2016, 09:21 AM
RobLee's Avatar
Quoted: 283 Post(s)
Liked: 286
There are a number of Bluetooth receivers on the market, usually selling for $20-30. Some may be better than others. I have tried several and never been fully satisfied. There is always some loss of sound quality that comes with compressing and retransmitting the signal... in addition to the usual connection pairing issues associated with Bluetooth.
Recently I've been playing with the Chromecast Audio. It features high fidelity optical output in addition to RCA and headphone jack connections. The hookup is easy but takes a little bit of technical savvy to get it running but it actually quite straightforward. Costs $35 but can be found on sale or $25 and is well worth it. Check this out:
*Official* Google Chromecast AUDIO owners thread
Denon AVR-4520ci, Polk LsiM703's, 704c, Rti4 surrounds, some Klipsch subs. Bedroom: Lsi9's, Onkyo TX-8050
RobLee is offline
post #13523 of 13624 Old 12-09-2016, 11:28 AM - Thread Starter
batpig's Avatar
Liked: 3493
BT is the opposite of HiFi, it's fairly compressed and lossy. Especially if you are thinking of hi-rez services like Tidal.
Check out the Denon HEOS Link or equivalent Sonos product. Or do it through a smartphone and then use Airplay or DLNA to stream to receiver.
Setup Guide and FAQ
batpig is offline
post #13524 of 13624 Old 12-10-2016, 07:38 PM
turnne1's Avatar
Quoted: 1826 Post(s)
Liked: 421
I doubt many owners could say
Since most 4K material has the HDCP 2.2 copy protection that the 4520 cant pass
A UHD 4K player with two HDMI outputs is your friend
One to the TV and one to the AVR
Warren
Rm 1 Samsung 64F8500 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon 4520 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is offline
post #13525 of 13624 Old 12-11-2016, 12:01 AM
pndiku's Avatar
Warren
The issue was to do with 4K upscaling of normal HD content, not native 4K material.
pndiku is offline
post #13526 of 13624 Old 12-11-2016, 05:16 AM
turnne1's Avatar
Liked: 421
IME...a UHD player does a lot better job of scaling non native 4K content on a 4K TV
Warren
turnne1 is offline
post #13527 of 13624 Old 12-11-2016, 05:18 AM
pndiku's Avatar
Warren
Ok. But between the TV and the Denon? That's the question being discussed.
pndiku is offline
post #13528 of 13624 Old 12-11-2016, 05:29 AM
turnne1's Avatar
Liked: 421
Using a true native 4K player
directly to the TV...
Skip the Denon in the video loop...
Warren
turnne1 is offline
post #13529 of 13624 Old 12-11-2016, 05:31 AM
pndiku's Avatar
Warren
Ok. Thanks for your input.
pndiku is offline
post #13530 of 13624 Old 12-12-2016, 07:07 PM
JohnAV's Avatar
Quoted: 323 Post(s)
Liked: 483
Observed a firmware update available tonight for 4520CI
3525-8853-5460
Oppo Beta Group
JohnAV is online now
Denon Avr 4520ci Receiver
