The **OFFICIAL** DENON AVR-4520CI thread - Page 454 - AVS Forum | Home Theater Discussions And Reviews
 865Likes
post #13591 of 13617 Old 03-22-2017, 05:02 AM
donnyb's Avatar
How many 4k sources do you plan on using?
The HD Fury Integral would be a less costly option.
https://www.hdfury.com/shop/splitter...60-444-600mhz/
Looks interesting, and thanks for the info. I only have two sources at this time, but may need room to grow.
donnyb is offline
post #13592 of 13617 Old 03-22-2017, 05:27 AM
turrmoil's Avatar
Quoted: 39 Post(s)
Hello fellow 4520 owners...
I have a situation where when I connect my Denon to the TV I see the Denon logo and everything seems fine including sound playback.
When I play music using airplay I see the art label on the TV.
However when I connect my Roku or Apple TV it says "no signal". I even tried connecting that using a Ethernet hdmi extender thinking I may have a lengthy hdmi cable.
I've tried connecting both of these devices on multiple inputs but same result.
When I connect the Roku or Apple TV to my Marantz 5008 they show up fine on the tv with the same HDMI cable. So I'm kind of leaning towards that the hdmi board may be bad.
But if the hdmi board would be bad should I expect to see the Denon logo and airplay stream screen? Or even for that matter the setup menu etc?
I have tried the factory reset pressing menu and back buttons technique multiple times.
Any help is truly appreciated.
Thanks all.
turrmoil is offline
post #13593 of 13617 Old 03-22-2017, 05:32 AM
jdsmoothie's Avatar
Quoted: 13078 Post(s)
Liked: 6040
Thanks all.
Have you tried every HDMI input on the AVR? What about other sources?
jdsmoothie is online now
post #13594 of 13617 Old 03-22-2017, 05:28 PM
turrmoil's Avatar
Quoted: 39 Post(s)
Thanks all.
Yes... when there is nothing connected to the input I see the Denon text on my TV.
As soon as I connect my Roku or Apple TV it goes to no signal!!!
turrmoil is offline
post #13595 of 13617 Old 03-23-2017, 12:01 AM
jdsmoothie's Avatar
Liked: 6040
Try first doing a soft reset by simply powering off the unit and unplugging the power cable to the AVR and TV for 10 minutes. If still no joy, do a microprocessor reset as described in post 3 of this thread.
post #13596 of 13617 Old 03-23-2017, 06:17 PM
RobLee's Avatar
Quoted: 282 Post(s)
Liked: 285
Something nagging me in the back of my mind says this is a sync problem, like the input is/inputs are set to a specific resolution that the ATV & Roku can't match. If you plug these devices directly into your TV, what type of signal info is shown?
RobLee is offline
post #13597 of 13617 Old 03-29-2017, 02:42 PM
josserman's Avatar
Quoted: 16 Post(s)
Thanks all.
Yes, all the time, it's so frustrating since my AVR is in my basement and TV is upstairs! I spoke with one of the main HDMI engineers at Denon (have an inside connection), and he had me do basic stuff like changing cables, reseting it.... no luck still happens
josserman is offline
post #13598 of 13617 Old 03-29-2017, 02:53 PM
Liked: 0
Thanks all.
does this happen with all HDMI sources or just those two? Does it happen on the front input too?
Wflagg is offline
post #13599 of 13617 Old 04-13-2017, 03:39 AM
Liked: 0
Hi guys, a fast question.
This Denon avr-4520 or the new avr-x6200 to use them only with the ARC HDMI tv out audio?
thank you so much.
Mo Ai is offline
post #13600 of 13617 Old 04-13-2017, 03:55 AM
jdsmoothie's Avatar
Liked: 6040
thank you so much.
The 4520CI as it's a former "flagship" model unless you also want to experience Atmos/DTS:X (or simulate the ARC audio to 4 height speakers), then the X6200W.
post #13601 of 13617 Old 04-13-2017, 04:20 AM
Liked: 0
I have just a 5.1 sistem... so?
Mo Ai is offline
post #13602 of 13617 Old 04-13-2017, 05:02 AM
jdsmoothie's Avatar
Liked: 6040
Originally Posted by mo ai View Post
i have just a 5.1 sistem... So?
4520ci
post #13603 of 13617 Old 04-13-2017, 05:30 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1137 Post(s)
Liked: 1108
^ Shouldn't 4K / HDCP 2.2 support be a consideration here given that 4K passthrough support on the 4520CI is limited? I realize that many 4K devices, especially UHD players have 2 HDMI outputs, but not everything will. If I were buying a "new" AVR right now, I wouldn't want to go with something that's going to (partially) cripple me functionality wise.
gsr is offline
post #13604 of 13617 Old 04-13-2017, 09:29 AM
Schwa's Avatar
Quoted: 1055 Post(s)
Liked: 1128
No, as the OP stated he only wanted to use the receiver with ARC audio. If so, then it wouldn't matter whether the receiver could pass 4K60 or handle HDCP 2.2 encryption.
Schwa is offline
post #13605 of 13617 Old 04-13-2017, 03:21 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1108
It won't matter until he buys a UHD source that the 4520 can't handle tomorrow...
gsr is offline
post #13606 of 13617 Old 04-13-2017, 05:14 PM
Schwa's Avatar
Liked: 1128
Just to play devil's advocate...
I assume that since he's only using ARC he must be using his TV to switch video sources. If so, then it won't ever matter whether his receiver can handle 4K/HDCP 2.2, even if he gets a UHD BD player!.
Schwa is offline
post #13607 of 13617 Old 04-13-2017, 05:17 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1108
If so, then he's limiting the quality of the audio. In any event, IMHO it's important to be aware of the limitations just so he's aware of them so there aren't any surprises down the road. If he really doesn't care about 4K / HDCP2 combos the 4520 can't handle, then the 4520 should be a fine choice.
Schwa likes this.
gsr is offline
post #13608 of 13617 Old 04-15-2017, 09:59 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 746
Arghhh , had to full hard reset my 4520CI, it's been a few years.
I use a 3ch Emotiva for front RCL.
Discrete 11.2 can only assign pre outs as R L, yet there is a signal going to the C preout as my Emotiva amp does power it still as connected
Or use full custom assignment, which is what I desire to do (and did in my memory)
In the discrete 11.2 then is the center amp still open for current, so possible current going to other amps not available? Or, even though "on" if no signal to it then of course no current lost, so the 4520 can does use full capacity to the remaining amps as demanded by input signal?
mtbdudex is online now
post #13609 of 13617 Old 04-15-2017, 10:09 AM
jdsmoothie's Avatar
Liked: 6040
Discrete 11.2 can only assign pre outs as R L, yet there is a signal going to the C preout .....
The Pre-Out setting under AMP ASSIGN simply assigns the 2CH that will be externally powered to expand the AVR from 9CH --> 11CH. All pre-outs themselves are always hot (ie. you can use the AVR as a pre/pro if you desire even without using the Amp Assign = Pre-Amp).
mtbdudex likes this.
post #13610 of 13617 Old 04-15-2017, 10:42 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 746
So practically there is no difference for my situation then, got it. Thx for quick reply as you usually do.
We lost power 3 weeks ago for 8 hours and the AVR kept everything, however 2 days ago it flickered twice and that scrambled my AVR.
Both times AVR off, and fed thru my Panamax 5300.
post #13611 of 13617 Old 04-15-2017, 12:28 PM
jdsmoothie's Avatar
Liked: 6040
Normally ... all settings should be retained for about 1-2 weeks if power is lost. This may not necessarily hold true for a brown out of quick power outage.
post #13612 of 13617 Old 04-16-2017, 09:03 AM
youra6's Avatar
Quoted: 23 Post(s)
So only about 100 hours of use from A4L, my unit won't even power on for 20 seconds before it trips protection mode. This is with nothing but the power cord connected.
Tried using different power cord and outlets and the issue still persists. I believe the issue is either the power amp or power supply. Since its OOW, should I just take it to a reputable AV repair store or dish out the dough and take it to a authorized Demon repair center?
Hope it won't be too expensive...
youra6 is offline
post #13613 of 13617 Old 04-21-2017, 06:39 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 746
Did anyone else get an firmware update notice?
This showed up just tonight .... I'll look to see what my current firmware is
post #13614 of 13617 Old 04-22-2017, 01:23 AM
jdsmoothie's Avatar
Liked: 6040
If you already installed the Pandora fix update from last December, then most likely the same update the newer models have been receiving recently:
Allows continued use of Spotify Connect after Spotify Connect Servers are updated
post #13615 of 13617 Old 04-22-2017, 01:27 AM
jdsmoothie's Avatar
Liked: 6040
Depends on whether or not you want to take advantage of any of the following features on the newer models: 4k/HDCP 2.2/HDMI 2.0a(HDR); Atmos/DTS:X/Auro 3D, HEOS built-in module, digital audio to Zones 2/3, and Zone 2 HDMI output.
If you do decide to go the repair route, please post back with the repair costs. Thanks.
post #13616 of 13617 Old 04-22-2017, 03:56 AM
Chris Albert's Avatar
Quoted: 17 Post(s)
Looking up my 4520 on the Denon site for firmware updates it said this:
[AVR-4520CI] (12/12/2016)
North American Version Only - December 2016 Release
Release Date: December 12 2016
Chris Albert is offline
post #13617 of 13617 Old Today, 05:23 AM
HTNUT1975's Avatar
Quoted: 38 Post(s)
I have a question about sample rates and sound processing. Right now, I'm on a free trial of Tidal music streaming. I've had Spotify for a couple of years and I'm doing a comparison. It is pretty difficult to discern the difference between the two when using airplay on the 4520 and their respective apps. The difference with most tracks is that of CD quality (Tidal) and 320kb with a Spotify. Maybe I notice a slight difference here and there on select tracts as the volume goes up? Anyway...
Now I've read about Tidal getting into hi resolution music under the category "masters". It supposedly can get the master tracks of recordings at a very high sample rate (usually 96 kHz or higher when using MQA format, or something like that), but right now it is only working with its desktop app. So, I did an experiment. I hooked up my desktop to the Denon via my graphics card HDMI out. When any song streams, the Denon will temporarily say "PCM 192 kHz" on the front. So, I'm pretty sure that I have the settings correct. With that said, I believe I can tell a little difference in the streaming quality....
However, I know if audyssey is applied, it downsamples to the normal cd quality of 44 kHz (or whatever it's called). So, with Tidal masters' tracks, I've been using direct pure with my towers to ensure that there is no downsampling involved. Am I correct in assuming that that is true?
Second, suppose I wanted to get a music streaming box like blue sound node 2, which has its own dac and can pass the stream via rca but which can also pass through the stream digitally straight to the Denon. It looks like there's a way to do that via optical or coax digital from the box. If I passed the sound via analog, and used pure direct as the output to my towers, would that mess with the stream? In other words, would the Denon be converting it back to digital and then re converting? What if I used stereo or direct instead of pure direct? Would the Denon then be doing an analog to digital conversion before it converted the stream back to analog?
HTNUT1975 is online now
Denon Avr 4520ci Receiver
