The **OFFICIAL** DENON AVR-4520CI thread - Page 457 - AVS Forum | Home Theater Discussions And Reviews
 878Likes
post #13681 of 13692 Old 07-26-2017, 07:09 PM
drh3b's Avatar
Quoted: 396 Post(s)
Liked: 379
Originally Posted by osogovo View Post
I bought the Denon 4520 a couple weeks ago and I am very happy with my purchase.
Sounds just great.I can't seem to find the measurements of my two subs in Audyssey results.Ran the set up twice and all I get is sub levels and distances and also Graphic EQ has no subwoofer option for adjustments.Ownners manual didn't help.
Those graphs are just approximations, and don't show what Audyssey is really doing. And, AFAIK, they don't have those graphs for the subwoofers, just all of the others.
Denon AVR-X4300H
Emotiva XPA Gen3 3 channel
Klipsch RP-280f LR, RP-260f SR, RP-450c, RF-82 II SB, RC-10 height
SVS SB12-NSD x4
OPPO UDP-203
TiVo Roamio, sometimes buzzy Samsung Plasma
drh3b is offline
post #13682 of 13692 Old 07-26-2017, 10:10 PM
osogovo's Avatar
Quoted: 18 Post(s)
Thank you
osogovo is offline
post #13683 of 13692 Old 07-27-2017, 01:30 AM
jdsmoothie's Avatar
Quoted: 14573 Post(s)
Liked: 6919
Correct. Not listed.
jdsmoothie is offline
post #13684 of 13692 Old 07-27-2017, 10:05 AM - Thread Starter
batpig's Avatar
Quoted: 3694 Post(s)
Liked: 3547
First, be aware that Graphic EQ is NOT the same thing as Audyssey, it's a totally separate (and much cruder) version of EQ.
Second, the Sub EQ graphs are not displayed in the results check of the Audyssey section. Just the way it is.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #13685 of 13692 Old 08-07-2017, 12:09 PM
Tachy's Avatar
It is probably somewhere in this thread, but I have been unable to find it.....can someone explain when to use the different settings of Restorer......Low, Med, High and HQ? I have played with them a little when listening to things like Pandora and Amazon music via a Sonos and directly via the Denon Network radio. Any input appreciated. Thanks.
Tachy is offline
post #13686 of 13692 Old 08-07-2017, 12:27 PM
Tachy's Avatar
Power toggle question
Also, as an unrelated question, I know you can do it with the ipad/iphone app, but with my Logitech Ultimate remote, cannot figure out if you can turn off Zone 1, but keep on Zone 2. Is there a remote command for the 4520 that just turns off Zone 1. I do have programed into my Harmony Power on, Power off, Power Toggle, Zone 2 toggle, Zone 3 toggle and Zone 4 toggle.
It seems Power on, Power off and Power toggle seem to turn on/off all zones. (And Zone 2, Zone 3, Zone 4 toggle just their zones). I guess I could program a combination code of Power off, Zone 2 on that would do what I want, but was curious if there is an easier way. Thanks
Tachy is offline
post #13687 of 13692 Old 08-08-2017, 01:54 AM
jdsmoothie's Avatar
Liked: 6919
You should be able to select the <Zone Select> button which defaults to "M" (main zone) and then press the power button.
post #13688 of 13692 Old 08-09-2017, 02:07 AM
Tachy's Avatar
Thanks JD. It worked like a charm. I guess I was using the System Off on my Harmony which is what I wanted, 98% of the time. Now I added Main On/Off toggle as well.
Any help on clarifying the 4 Restorer choices is appreciated.
Tachy is offline
post #13689 of 13692 Old 08-09-2017, 02:34 AM
jdsmoothie's Avatar
Liked: 6919
The Owner's manual (p. 124) explains when to use them.
post #13690 of 13692 Old 08-09-2017, 04:10 AM
Tachy's Avatar
Yes, but the manual has no mention of this Restorer HQ though.
Tachy is offline
post #13691 of 13692 Old 08-09-2017, 09:20 AM
jdsmoothie's Avatar
Liked: 6919
On older models, Mode 3 = HQ. Just use the mode you believe sounds best to you.
post #13692 of 13692 Old 08-14-2017, 01:30 PM
Alan P's Avatar
Quoted: 5050 Post(s)
Liked: 3725
Originally Posted by Alan P View Post
I've recently began running the input on my 4520 for my Kodi box, which I use mainly for streaming MKV BR rips, with Audyssey off. Over the last few weeks, there have been two occasions that Audyssey has reverted back to "On" without me telling it to do so.
Is there any reason you guys can think of that would cause this setting to spontaneously change? I don't want to have to check the settings every time I watch a movie.....
OK, I figured out what was causing Audyssey to get turned on...I think.
When I change surround modes...I always use the "hold button (Music or Movie) to bring up the surround modes, then short button press to cycle through modes" method...Audyssey then gets turned on. I'm assuming if I go through all of the surround modes and turn Audyssey off it would then remain off (?).
Alan P is offline
Denon Avr 4520ci Receiver
