The **OFFICIAL** DENON AVR-4520CI thread - Page 459 - AVS Forum | Home Theater Discussions And Reviews
 2377Likes
post #13741 of 13768 Old 09-29-2017, 10:09 AM
ppasteur's Avatar
Quoted: 18 Post(s)
If you found the correct set of pictures the locations are circled in red. The HDMI board is the top level board on the back of the unit that is home to the HDMI connectors.
ppasteur is offline
post #13742 of 13768 Old 09-29-2017, 10:17 AM
ppasteur's Avatar
Quoted: 18 Post(s)
Try starting there and scrolling through the next few pages. Dognam has pictures and I posted some as well. He also describes the process.
ppasteur is offline
post #13743 of 13768 Old 09-29-2017, 01:17 PM
Quoted: 80 Post(s)
Well I can't get it to do nothing. I pulled all of the plugs loose and cleaned with Deoxit. Put back together and nothing. Tried wiggling connectors while powered on and still nothing. I am thinking about replacing with a new 4300?
nxs450 is offline
post #13744 of 13768 Old 09-29-2017, 01:54 PM
ppasteur's Avatar
Quoted: 18 Post(s)
Sorry that it did not work. Probably worth the try though. It did settle mine down and it has been OK since.
ppasteur is offline
post #13745 of 13768 Old 10-01-2017, 04:41 PM
drh3b's Avatar
Quoted: 449 Post(s)
Liked: 435
Make sure you get it from an authorized dealer. I loved mine until the network card apparently went out(I had(and still have) a 4520 previously). I did get mine from an authorized dealer and just haven't dealt with the warranty process yet. Going to either have to ship it or drive 10 hour round trip to KC(ugh, either way).
Denon AVR-X4300H (wounded)
Emotiva XPA Gen3 3 channel
Klipsch RP-280f LR, RP-260f SR, RP-450c
SVS SB12-NSD x4
OPPO UDP-203 TiVo Roamio, adequate Samsung UHD LED TV
drh3b is offline
post #13746 of 13768 Old 10-03-2017, 09:18 AM
Quoted: 80 Post(s)
So how do you like your 4300 stacked up against the 4520? I am liking mine, haven't watched a whole movie yet but so far sound is powerful and clean!
nxs450 is offline
post #13747 of 13768 Old 10-03-2017, 02:36 PM
drh3b's Avatar
Quoted: 449 Post(s)
Liked: 435
I use a 3 channel amp for the fronts, so the 4520's better amps aren't important in my case, and the x4300 is just more modern, has more features. It sounds just as good to me. Basically, the 4520 has more powerful amps, and reacts to some commands slightly faster than the 4300. It's possible the 4520 uses better componentry, but any theoretical sound improvement I don't hear.
SVS SB12-NSD x4
drh3b is offline
post #13748 of 13768 Old 10-11-2017, 02:07 PM
OldGatorDelt's Avatar
First Issue In Almost 3 Years
Bought my 4520 new from Acc4Less almost 3 years ago.... Has worked flawlessly daily since purchase... Last night, it wouldn't pass video from any of my 5 attached devices... Called Acc4Less tech support and they suggested a microprocessor reset... I've had various Denon receivers for the last 30 years and never had to do one of those... But, I did it, and it fixed the problem... Just had to rename a bunch of stuff and re-do what connected to where... What have you folks experienced in microprocessor resets ??? Is my unit fixing to have a serious issue... It gets well filtered power.... And we've had no blips...
OldGatorDelt is offline
post #13749 of 13768 Old 10-12-2017, 05:15 AM
jdsmoothie's Avatar
Quoted: 15339 Post(s)
Liked: 7498
When the issue involves only one source, it could be a problem with that source's HDMI cable. When the issue involves all sources, then the issue could be the HDMI cable connecting the AVR to the TV which could simply have become loose. When an issue presents out of the blue, the first troubleshooting step is to do a "soft reset" (which doesn't result in loss of settings) by simply powering off the AVR and disconnecting the power cable and HDMI cables for 10 minutes. Then reconnect all cables ensuring the HDMI cables are securely fitted at each end. This can solve a number of issues, however, if not, the microprocessor reset (which does result in loss of settings so be sure to SAVE the config file to a PC file prior to doing this so you can LOAD all settings and Audyssey after the reset) is the next step although it's better to do at least 4-5 in a row as in some cases doing just one reset will not resolve the issue.
Alan P likes this.
jdsmoothie is online now
post #13750 of 13768 Old 10-12-2017, 06:01 AM
Thanks jdsmoothie for the information... Since it had worked well for a long time, I had forgotten about the "soft" reset process and a lot of what's in the manual.... At any rate, it worked well last night...
post #13751 of 13768 Old 10-13-2017, 12:22 AM
AV_mike's Avatar
Quoted: 120 Post(s)
Liked: 106
As usual JDs advise is spot on. Once you have everything reconfigured, and working how you like, try to get the configuration saved via a network connection - it saves a lot of time being able to reload, instead of going through the whole process manually.
Regards, Mike.
AV_mike is offline
post #13752 of 13768 Old 10-13-2017, 05:48 AM
Regards, Mike.
Thanks Mike.... This is probably in the manual, which I need to read... I did hit "Save" after re-running Audessey, and it saved it... Where is the question... I have the 4520 online via cable, so it's a solid connection... It shows up in my WIN10 as a media device... If I click on it, it brings up a web interface page that would allow me do to a setup.... I will read the manual today to see where it puts the file... I saw where you can load and search for a file to load... I thought opening the load search process would default to the location where the config files are stored, but not... Something to do this morning... Thanks again, Ernie
post #13753 of 13768 Old 10-13-2017, 11:40 AM
herbg's Avatar
Firmware change log information is listed in post 4 of this thread.
I also noticed a waiting firmware update.
My 4520 is running well so I'm thinking of skipping the firmware update? Any reason why I don't want to do that?
Herb...
herbg is offline
post #13754 of 13768 Old 10-13-2017, 12:03 PM
Matt2026's Avatar
Quoted: 419 Post(s)
Liked: 16868
Herb...
I'm interested to see what answers you get
I'm an old guy, a plug and play kinda guy. My 2 channel setup is mostly all the gear I bought in the early '90s.
I put my HT gear together starting with the 4520 and Samsung TV in early 2014... Haven't updated the 4520 ever. The Samsung TV and BR player update automatically.
I figure if it ain't broke don't fix it
Regards, Ken (Retired)
9.1) Denon 4520CI; Samsung 55H8000 & BD-F7500; R&LRS/L/R SVS Ultra BS,
Ultra Center; FH & SS Polk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nakamichi RE-2, CDC-4A, CR7A, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #13755 of 13768 Old 10-13-2017, 12:37 PM
herbg's Avatar
My thoughts exactly!
Matt2026 likes this.
herbg is offline
post #13756 of 13768 Old 10-13-2017, 01:39 PM
wowzors's Avatar
Quoted: 21 Post(s)
Had my Media Player HDMI Port fail last week, not really sure what to do about it.
wowzors is offline
post #13757 of 13768 Old 10-13-2017, 01:42 PM
jdsmoothie's Avatar
Liked: 7498
Use another port.
post #13758 of 13768 Old 10-13-2017, 01:45 PM
wowzors's Avatar
Quoted: 21 Post(s)
Use another port.
Quite the simple solution, the issue is they are all used up My current solution is plugging what was in that port into AUX 1 on the front it's ugly, but it works.
wowzors is offline
post #13759 of 13768 Old 10-13-2017, 01:52 PM
jdsmoothie's Avatar
Liked: 7498
You can also refer to post 3 for the various reset procedures, starting with a "soft reset" by simply powering off and unplugging the power cable and the Media Player HDMI cable followed by a microprocessor reset if no joy, otherwise, another option would be to add an HDMI switch.
post #13760 of 13768 Old 10-13-2017, 02:09 PM
Guess I'm Half-blind
After Mike suggested I save my config and reload it if I need another microprocessor reset, I honestly scanned the whole manual, and the Index in the last pages, and I simply can't find how to save my config to a file somewhere that I can subsequently reload... Any help on where to look, or how ???? If I access my 4520 online, all I get is the setup process if I want to do it... No listing of files...
post #13761 of 13768 Old 10-13-2017, 09:11 PM
laulau's Avatar
Quoted: 82 Post(s)
Liked: 129
Credit to AustinJerry: Network Save and Load.
HT:: Salk STRT / SongCtr-RT / SongSurr ; Rythmik F12 (x2) (latest Dialing-in guide) ; Denon 4520; ATI AT522NC; Oppo BDP93; Panny 65VT50; BJCables; CCast; FireTV; Furman Elite15PFi; Salamander Synergy; Omnimic
CANs:: RPi3Digi+ >AGD DAC19 >Cavalli LC >HFM HE400i :: RPi3Digi+Pro >Schiit Bifrost 4490 >Schiit Valhalla >Senn HD600 & HD6XX :: RPi3Digi+Pro >Schiit Mimby >Schiit Vali 2 >Meze 99 Classics :: RPi3Digi+Pro >Schiit Modi2U >Schiit Magni2U >Oppo PM3
laulau is offline
post #13762 of 13768 Old 10-14-2017, 06:31 AM
Thank you laulau very much.... On today's agenda....
post #13763 of 13768 Old 10-15-2017, 03:23 PM
jdsmoothie's Avatar
Liked: 7498
Owner's manual (p. 109) discusses the SAVE and LOAD.
post #13764 of 13768 Old 10-15-2017, 03:49 PM
Your correct jdsmoothie, it is mentioned on page 109.... I wouldn't have found it without your input... However, we should thank AustinJerry for his write-up, which far surpasses the line and a half of fine print the manual contains... FWIW, I tried the "Save" twice using Edge on WIN 10 without success, but using Chrome it worked fine the first time.... My backup appears good, and is 727 KB... Unit continues to work fine...
post #13765 of 13768 Old Yesterday, 05:00 AM
herbg's Avatar
After reconfiguring my room, I'm about to setup my system again from scratch. A bit rusty on the process since it's been a few years.
So have a few questions:
I have the AVR connected to a new LG OLED65B7P via HDMI/ARC and a separate digital audio cable. It's a 5.2 system.
When watching Netflix/Amazon (or any other source) from the LG, it seems that I don't have a large selection of "Sound Modes" on the 4520? I see "Dolby PLIIx Cinema" "Stereo" and "DTS NEO:X Cinema".
1) Shouldn't I see "Dolby Digital" or any of the other digital surround formats?
2) Shouldn't the AVR select it's own "Sound Mode" based on the signal received?
Thanks for your patience.
Herb...
herbg is offline
post #13766 of 13768 Old Yesterday, 08:25 AM - Thread Starter
batpig's Avatar
Quoted: 3725 Post(s)
Liked: 3601
The lack of options indicates that you are getting a stereo 2.0 input signal to the Denon. It's a good idea to learn how to check the input signal info on the AVR so you know what it's getting -- the receiver can only play the signal it receives.
Dolby Digital would only be an option if the TV is sending back a 5.1 DD signal. In this case it seems the TV is sending stereo only. Whether that's a limitation of the TV app, or some setting you have off on the TV side, not sure.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #13767 of 13768 Old Yesterday, 08:31 AM
herbg's Avatar
I'll double-check the settings in the LG to confirm that a 5.1 signal is being sent. Does it matter what the initial "Sound Mode" is set to?
And, because I'm sending back a separate audio signal via Optical cable from the LG, is there an additional setting in the Denon that I need to be adjusting?
herbg is offline
post #13768 of 13768 Old Yesterday, 08:33 AM - Thread Starter
batpig's Avatar
Liked: 3601
The relevant settings would all be on the source side -- the AVR will only play what it receives.
Setup Guide and FAQ
batpig is offline
Denon Avr 4520ci Receiver
