Need a decent temporary avr receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-19-2012, 07:37 PM - Thread Starter
mrfixit58's Avatar
Quoted: 38 Post(s)
While I have most of the parts for my new Den theater, I am waiting to redo the den. My ancient onkyo avr has decided to not read my dvrs optical input any more, so.... I need a new receiver probably in the 5 to $600 range. Suggestions would be greatly appreciated as looking on line at site reviews seems to be skewed. Possibly I may use this in another system in the future.Thanks!
mrfixit58 is offline
post #2 of 12 Old 09-19-2012, 09:45 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
What features are essential to you? What's your speaker setup? There are some decent receivers (last year's models) on clearance right now that could meet your needs like the Marantz SR-5006, Denon 1712, or Yamaha RX-A810.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 12 Old 09-20-2012, 06:29 AM
ccotenj's Avatar
Liked: 101
does your onkyo have a coax spdif input? if so, you could just use a optical to coax adapter, and not have to buy a new avr...
- chris
ccotenj is offline
post #4 of 12 Old 09-20-2012, 08:10 AM
jdsmoothie's Avatar
Quoted: 12088 Post(s)
Liked: 5502
+1
There are several work arounds to avoid having to procure a "temp" AVR. Many DVRs also have a coax digital output (orange) so simply connect a RCA "yellow" composite video cable (from a red/white/yellow cable set) from the coax digital output to the coax digital input on the AVR.
jdsmoothie is online now
post #5 of 12 Old 09-20-2012, 09:25 AM - Thread Starter
mrfixit58's Avatar
Quoted: 38 Post(s)
I use the coax for my oppo audio input. I'm not sure what is essential as I have not really pondered that question. I am using PMC speakers fronts with 2 fairly cheap rears.and a JL audio 113 sub.
post #6 of 12 Old 09-20-2012, 09:52 AM
jdsmoothie's Avatar
Liked: 5502
You can also consider using a "Y" coax digital splitter to create a 2nd input to the AVR ....
http://www.radioshack.com/product/index.jsp?productId=2103638&cp=&sr=1&origkw=rca+y+cable&kw=rca+y+cable&parentPage=search
post #7 of 12 Old 09-20-2012, 07:06 PM - Thread Starter
mrfixit58's Avatar
Quoted: 38 Post(s)
That looks like a great idea! Obviously only run one source at a time. So I don't need a second optical cable, just the yellow composite video cable? Thanks so much!
post #8 of 12 Old 09-20-2012, 07:49 PM
ccotenj's Avatar
Liked: 101
yup... just about any rca cable you have lying around will do...
- chris
ccotenj is offline
post #9 of 12 Old 09-21-2012, 09:32 AM - Thread Starter
mrfixit58's Avatar
Quoted: 38 Post(s)
Hey you guys are the BOMB! Thanks
post #10 of 12 Old 09-21-2012, 09:47 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
hi guys is this a good set up? i have a 3D tv, PS3 for gaming and blurays, and cable box from DTV. i am planning this for my set up but im not sure if this is a good combo for my set and i want to get 5.1 surround sound.
here it is,
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
and this
http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44
is this a good combo for my sets guys? ty
caloyzki is offline
post #11 of 12 Old 09-21-2012, 10:36 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Its fine if you must have small satellite speakers. I used to have Takes but eventually replaced them with larger speakers.
The Pioneer BS-21 and C21 would be better if you can get something larger.
Or even better if you have room for the Pioneer towers.
FS-51 with $119/pr with $20 discount using promo code EMCNAJB224
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117403
C21 center, $49 each with $20 discount using promo code EMCNAJB225
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117404
BS-21 bookshelf, $49/pr with $30 discount using promo code EMCNAJB226
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
All together that's $220 for a 5.0 setup. If you cant have tower speakers then get two pair of the BS-21. Then the 5 speaker package is $150.
Add this subwoofer for $200 and you're set.
Energy s10.3
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
$350 for the small Pioneer speaker setup is way better than the Take Classics. $420 for the tower setup would be a big improvement.
Afro GT
afrogt is offline
post #12 of 12 Old 09-21-2012, 11:13 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Energy s10.3
hi, i really like the big speakers but i only live in the apartment and my apartment is not that big for big speakers, currently this is the surround i have Philips HTS3372D/F7 and i want to upgrade my surround sound. and i am also looking those kind of speakers the one that i have coz its fit on my small living room. any recommendations those kinds of speakrs? is the energy the one that i post b4 is good enough? thanks.
caloyzki is offline
