Recommended sub for Denon AVR-1612 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-20-2012, 08:14 AM - Thread Starter
EpicVegas's Avatar
Looking for a sub woofer under $100 for my Denon AVR-1612 receiver.
Let me know some options please.
I also have a "non powered" sub that I might try If the receiver can power it??
EpicVegas is offline
post #2 of 3 Old 09-20-2012, 08:29 AM
ccotenj's Avatar
Liked: 101
a "subwoofer" under $100 doesn't exist, to my knowledge... however, if you post in the subwoofer subforum, you might find an answer...
no, you can't power your passive sub off the avr...
- chris
ccotenj is offline
post #3 of 3 Old 09-20-2012, 09:05 AM - Thread Starter
EpicVegas's Avatar
I'm glad I didn't waste time trying to setup my passive sub with the avr.
I just picked up a 8" powered sub off monorpce for $58
Thanks ccotenj!
Denon Avr 1612 Receiver
