Marantz SR5005 video upscaler: use it or keep it off? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-21-2012, 05:32 PM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
I replaced my Onkyo TX-SR606 with a lightly-used Marantz SR5005. It has options for video upscaling. I record 99% HD content (720p and 1080i) on a TiVo HD; the Marantz can upscale "automatically" or I can set it to a static 1080p. They don't say whose upscaler it is (Faroudja, etc). The 6005 is an Anchor Bay 2015.
Alternatively, I can use the TiVo's upscaler to convert all content to 1080i.
Or I can just run 100% native resolution, but that's annoying because my Sammy DLP is rather slow and clumsy to switch between HD resolutions.
Thoughts?
Marantz AVR & monoblocks + MartinLogan Motion 3.1 setup
TheGSRGuy is offline
post #2 of 6 Old 09-21-2012, 06:40 PM
jdsmoothie's Avatar
Quoted: 12139 Post(s)
Liked: 5528
The 5005 uses the ABT 1030. Use whichever configuration looks best to your eyes.
jdsmoothie is online now
post #3 of 6 Old 09-21-2012, 06:52 PM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
Truthfully I can't tell much of a difference, but I've only had it hooked up for a little while.
Is there a good method or type of content to test?
post #4 of 6 Old 09-21-2012, 06:59 PM
jdsmoothie's Avatar
Liked: 5528
In most cases, there is no difference, (most especially in your case as you're primarily passing HD video) which is why folks just bypass the AVR and let the TV or the source do the upscaling.
post #5 of 6 Old 09-21-2012, 07:36 PM - Thread Starter
TheGSRGuy's Avatar
Quoted: 17 Post(s)
I figured as much. I can't even remember the last time I watched SD content. Thanks for the info.
post #6 of 6 Old 09-22-2012, 03:23 AM
Kilian.ca's Avatar
Liked: 37
Scaling isn't the only consideration, also important is de-interlacing and other picture controls.
If you have 720p content you should avoid 1080i output and unnecessary p-i-p steps.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
Marantz Sr5005 Audio Video Receiver Black
