DENON AVR-1911. No sound from HDMI input if TV is not turned on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-24-2012, 12:11 AM - Thread Starter
denonjens's Avatar
Hi,
I've owned a DENON AVR-1911 for a few years and one issue is now seriously threatening me from a WAF point of view.
My setup is as follows: A small form factor media PC (a shuttle XS35GT) is used to handle all media (TV, videos, music, pictures). The box is connected via a HDMI cable to the AVR-1911 (DVD HDMI input plug). From the AVR-1911 another HDMI cable runs the to TV (LG 42LS9000 LED TV). A full surround sound speaker set is attached to the AVR-1911 for excellent sound smile.gif
This works well (very well in fact) for movies, recorded TV, etc.
It also works well for music AS LONG AS THE TV IS ON. If I do not turn on the TV, or turn it off after starting playback, the playback (via the stereo speakers - not the TV :-) stops...
I really don't want the TV on when playing just music, especially since I may control music player apps (e.g. iTunes) via SmartPhone table without ever turning on the TV.
Is this behaviour to be expected? If so, is there some configuration/trick I might use to change it?
Thanks a lot
Jens
denonjens is offline
post #2 of 6 Old 09-24-2012, 03:03 AM
jdsmoothie's Avatar
Quoted: 15374 Post(s)
Liked: 7518
Try placing an HDMI switch/splitter between the HTPC and AVR or between the AVR and TV.
jdsmoothie is offline
post #3 of 6 Old 06-01-2013, 07:05 AM
kort3x's Avatar
I have exactly the same problem. Any ideas?
kort3x is offline
post #4 of 6 Old 06-01-2013, 07:23 AM
jdsmoothie's Avatar
Liked: 7518
post #5 of 6 Old 04-09-2014, 12:49 AM
turtleburgers's Avatar
Thanks for the reply jdsmoothie, I too have this problem and would like to try what you are suggesting.
Could you elaborate on what type of switch/splitter I should get and what the idea behind this approach is?
Best regards
Kasper
turtleburgers is offline
post #6 of 6 Old 04-09-2014, 03:06 AM
jdsmoothie's Avatar
Liked: 7518
Any type should work. The point is you want the EDID of the TV to be copied to the switch/splitter so the AVR can still detect it even when the TV is off.
Denon Avr 1911 Receiver
