Emotiva XPR 5 - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2012, 10:31 PM - Thread Starter
TVMAN1991's Avatar
Quoted: 54 Post(s)
Liked: 54
Anyone have this hulking brute of an amp yet? Any comments on construction quality etc?
TVMAN1991 is offline
Old 09-25-2012, 01:43 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Here.
I got a pretty good deal on it at EmoFest. Construction quality and, more importantly, SOUND quality is stellar. Barely fit in the TV stand but it does not run hot at all, even when pushing it. I'm going to raise the glass shelf another inch as soon as I pick up the Oppo BDP-103 that will replace the tank-like Denon BD player. The amp is huge, 9.5" tall, and weighs in at about 100 pounds -- about the same weight as the girlfriend. LOL
It requires nothing less that a TRUE 20 Amp circuit. I wired up four 20 amp circuits and reserved two for amp power -- I was looking at the D-Sonic M2-3500 before going with the XPR-5. I use one for the subs and the other for the components -- TV, DVRs, disc players
The accent lights can be turned completely off. I usually run it with just the status lights ( the 5 blue ones ) with NO accent light or power level LEDs.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Old 09-25-2012, 11:43 AM - Thread Starter
TVMAN1991's Avatar
Quoted: 54 Post(s)
Liked: 54
Originally Posted by jevans64 View Post
Here.
Thanks! Looks like a very very nice amplifier. Such a monster.
Old 09-25-2012, 03:37 PM
erwinfrombelgium's Avatar
Quoted: 411 Post(s)
Liked: 216
I tested the XPR-5 with my Jamo R909 pair with good result. Very convincing low grunt. I bought it for my HT I am building. Normal amps are two XPA-1.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
Old 09-26-2012, 03:37 PM - Thread Starter
TVMAN1991's Avatar
Quoted: 54 Post(s)
Liked: 54
Beautiful. I just purchased one earlier today mainly to eliminate the two clunky Emotivas I have now lol. It will be powering my B & W 800 Diamond 5 channel setup. As of right now I'm in a small room and won't be using anything near the full potential, but when I buy a house and have a large dedicated theater I want to be able to raise the volume and not worry about distortion. Although it's only 3 more dB of volume over 200/channel, there are still peaks in power to account for as well. This beast will have a nice home.
Old 09-27-2012, 12:47 PM
Quoted: 411 Post(s)
Liked: 216
And compared to the cost of five 800D's (or do you mean the series, not the model, still..) the XPR-5 is a no brainer investment.
Old 06-19-2013, 10:13 AM
buggs1a's Avatar
Quoted: 179 Post(s)
Liked: 24
Except there's no difference in sound quality with this amp against most other amps. I've tried the xpa5 on my Integra dtr40.3 and the sound was the same. And Emotiva told me that they won't sound different then anything else since its job is to make things louder and not make things sound different/better.
buggs1a is offline
Old 06-19-2013, 10:38 PM
buggs1a's Avatar
Quoted: 179 Post(s)
Liked: 24
Will the xpr5 work on normal plug in?
buggs1a is offline
Old 06-20-2013, 06:11 AM
Bill Mac's Avatar
Quoted: 1265 Post(s)
Liked: 1442
Here is a link to the XPR-5 product page on the Emotiva website. Below is text from the product page that indicates that the XPR-5 requires a 20 amp circuit and an IEC outlet. If you look at the picture of the rear panel of the XPR-5 you will see how the plug is different than a standard type.
The XPR-5 requires a 20 Amp circuit and standard IEC 20 Amp outlet (which is different than a 15 Amp outlet).If you don’t have a proper circuit and outlet, we recommend you have one installed by a qualified electrician. We recommend that the XPR-5 be plugged into its own dedicated 20 Amp circuit.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 06-21-2013, 06:41 AM
buggs1a's Avatar
Quoted: 179 Post(s)
Liked: 24
Then this amp isn't for me. Parents wouldn't let me do this.
buggs1a is offline
Old 06-21-2013, 07:54 AM
Bill Mac's Avatar
Liked: 1442
An amp that requires a dedicated circuit and an IEC outlet wouldn't work for me either. I have a fairly new home but I wouldn't go to all that trouble just to be able to have an amp such as the XPR-5. If I was setting up a dedicated HT room or a new home I would definitely install a few IEC outlets and dedicated circuits without a doubt. One never knows if they'll need mega power some day biggrin.gif. I honestly think the XPA-5 would be a great amp for you. The XPA-5 has plenty of power and is very affordable. I believe Emotiva sells some products on Amazon so that could be an option if they offer 0% financing.
Bill
Bill Mac is offline
Emotiva Xpr 5 Reference Five Channel Power Amplifier
