Video Dropout from Receiver when AC unit turns on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-25-2012, 02:26 PM - Thread Starter
Tadimsky's Avatar
Hi all
I am having an issue with the Onkyo HT-S5400 in that whenever the AC unit in the room turns on or off, the video signal out drops for a just under a second. I don't know if this is due to interference or just because of the voltage load.
It was not doing this before I added in the HT-S5400 system (i.e. plugged straight into projector).
Do you think this is related to the voltage? if so, if I got a voltage regulator do you think it would solve the problem? http://www.amazon.com/APC-LE1200-Automatic-Voltage-Regulator/dp/B00009RA60/ref=sr_1_5?ie=UTF8&qid=1348534546&sr=8-5&keywords=power+conditioner
Tadimsky is offline
