Question about improved video through a receiver or not - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-28-2012, 03:24 PM - Thread Starter
Djscoe's Avatar
I recently replaced my Panasonic 42" 720P television with the new 1080P 55" Panasonic TC-P55VT50. I also purchased the TiVo Premiere XL4 DVR. My Verizon FIOS is connected to the TiVo. I also have a Sony Networked Blu-Ray player. It's all connected to an older Onkyo TX-SR803. The video from both the TiVo and Blu-Ray player is connected to the receiver through HDMI cables. The receiver then outputs the signal to the TV from one HDMI out connection. When setting up the TiVo, it gave me the message that the receiver did not support 1080P 24fps, which the TV does, so it switched it to 1080i. I also run digital optical cables to the receiver from both the TiVo and the Blu-Ray player.
My question is this: Should I replace the Onkyo with a newer model (NR818?) and continue to run both audio and video through the receiver or am I just as well off running the HDMI cables from the sources directly to the tv and keeping the audio running through the optical cables connected to the receiver? Does a receiver make that much of a difference in the video or is it just for switching convenience? I assume the audio will be the same either through the optical cables or the HDMI cables.
Thanks for any help anyone can offer.
Scoe
Djscoe is offline
post #2 of 6 Old 09-28-2012, 09:08 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
AVR manufacturers are all going to pass through video so that should tell you something. The best video processing is done in the display IMO. As long as the source is sending the same resolution as the native resolution on the display no processing is necessary. As long as you don't mind the lossy audio from your 803 (assuming you don't use the analog inputs from the BRP) then there is little to be gained IMO. The difference between lossy (coax or optical) audio and lossless is minuscule - most people can't tell one from the other. There are audible differences IF you know what to listen for on a particular track. Critical listening during a movie? I'd rather watch and enjoy the movie.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 6 Old 09-29-2012, 06:36 AM - Thread Starter
Djscoe's Avatar
Thank you for your reply. That's kind of what I've been thinking is to just keep the HDMI going straight to the tv and run the audio through the receiver. But, one question, you referred to my optical audio connections as lossy. Does that mean the HDMI audio is lossless and that would be an argument, although not major, to run everything through the receiver?
Thanks again for your help.
Scoe
Djscoe is offline
post #4 of 6 Old 09-29-2012, 06:57 AM
GoodOmens's Avatar
Optical audio doesn't support streaming TrueHD/DTS-HD (even if your blu-ray decodes the tracks first). You would need to run analog cables from your blu-ray player in order to play those tracks as using optical you would be playing the lossy DTS/DD tracks.
GoodOmens is offline
post #5 of 6 Old 09-29-2012, 08:35 AM - Thread Starter
Djscoe's Avatar
Thank you. Now the decision is whether or not to spend the additional $1000 to get the new receiver. eek.gif
Scoe
Djscoe is offline
post #6 of 6 Old 09-29-2012, 09:27 AM
Quoted: 385 Post(s)
Liked: 332
Optical/coax is lossy audio (DD & DTS) - and as I mentioned above - it is very good audio. There are two ways to get lossless audio (called high definition audio) - one is by connecting the 5.1/7.1 analog outs from your bluray player (if it has them) to the analog inputs on your current AVR if it has them. The other is to buy an AVR with HDMI - almost all current AVRs decode the latest HD audio signals these days. The best argument for HDMI is the 'single cable' connection theory. One to the AVR for each source (cable satellite DVD etc) to the AVR and a single HDMI cable to the display. I call it 'theory' because there will usually be a few extra cables. I think a better argument can be made for a new AVR with the room correction they carry. The Onkyo 818 you are considering has Audyssey MultEQ XT32 - top of the line Audyssey. Thats a difference you'll notice.
***GO SEAHAWKS ***
