AVIC Z140BH faceplate peeling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-29-2012, 04:19 PM - Thread Starter
Michaelavs's Avatar
I just had an AVIC Z140BH installed a couple of months ago and I recently noticed that the panel with all of the buttons on it is starting to peel up and buckle. This is happening between the "HOME" and "MODE" locations on the panel. When I press one of those buttons, the panel crinkles and the bulge shifts as other areas of the panel start to peel-up.
I called Pioneer and was told that the warranty doesn't cover damage. I told them that I didn't damage the unit, but that the faceplate just started peeling up on its own. Then then told me I'd have to remove the unit and ship it to Pioneer to determine if it's something that they would cover under warranty.
Luckily I purchased the unit from a very responsible Pioneer dealer and they will help me with this issue.
Anyways, just wondering if this is an adhesive design issue on the unit and if others are seeing this problem. It was peeled up more than in the picture, below, in the morning, but after pressing it down, it wasn't quite buckled up as much, but I think this would get worst over time.
Michaelavs is offline
