Totaly baffled - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-01-2012, 10:14 AM - Thread Starter
u8myufo's Avatar
First a Hi to all at AVS. I am trying to sort out a problem with a brand new 818. The first unit I receievd a couple of weeks back ended up blowing the base driver on my front right B&W 602. The amp was replaced, I have now tried the initial setup with the new amp, the speakers are biamped. All connections have been checked three times and are as they should be. I have a brand new active sub connected.The problem is when it sends out the test tone for the front high,the two subwoofer icons show up in Blue on screen and the test tone comes out of the sub.After finsihing a minimum of three listening positions, if I go into speaker configuration the front peaker high settings are greyed out. I have the latest firmware as well. Has anybody heard of this problem? Any help would be appreciated.
u8myufo is offline
post #2 of 3 Old 10-01-2012, 10:19 AM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Try connecting your speakers normally. Remove the bi-amp wires. Are you using the 818 to bi-amp or do you have an external amp?
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 3 Old 10-01-2012, 10:40 AM - Thread Starter
u8myufo's Avatar
Hi and thanks for getting back to me, yes this was something that the shop suggested I do. Have had a long day today so will do it tomorrow when I get back from work. Are you suggesting then that if I wire the front speakers up as normal and run the setup again, that I should then be able to go back to B-iamp and it should reset itself? Yes I am using the 818 to bi-amp, on the first amp it worked fine. I am also wondering, am I right in setting the 602 S3`s to 40hz and not full band?
u8myufo is offline
