Marantz AV8801 Preamp/Processor Official Owner's thread - Page 100 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
Old 02-17-2013, 06:34 PM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
Originally Posted by thrang View Post
The setup is just a hookup guide I think - both outputs are active all the time afaik...I just switched my center to RCA in the setup menu (though its connected xlr) and it continues to function.
They are definitely both active that what made me wonder.
It makes sense that this is a guide only.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 02-17-2013, 09:48 PM
WestCoastD's Avatar
Quoted: 253 Post(s)
Liked: 96
Originally Posted by Ettepet View Post
What caught my eye is that all these neatly stacked circuits are populated with Electrolytic capacitors, which are generally considered a big no-no anywhere in the signal path of a high-end audio device. The presence of such cheap components, possibly aided by a long internal wiring path to get there, could easily be the main culprit of what you are experiencing: degradation of all pre-amplified signals no matter which input is used
the only way to decipher what's really going on is to observe the actual schematic diagram
WestCoastD is offline
Old 02-17-2013, 10:42 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
Rich, if you change the balanced/unbalanced switch with signal present, can you hear a level change? Like a 6 dB shift?
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 02-17-2013, 10:46 PM
Ettepet's Avatar
Originally Posted by Roger Dressler View Post
Yes. I was referring only to the signal path, as were you when you wrote:
I took your post at face value. I had not seen your later reply to Mark Rubin where you added: >>I don't know if these capacitors are inside the signal chain.<< That might have been useful to state in the original post -- if you'll forgive me for saying.
Yes, in hindsight it would have been useful. It let to what I called misquoting (saying something, and someone else responding as if it was written differently). To me it came natural to use the term "misquote" for that, it was not meant literally.
I suppose I should have read all the rest of this fast-moving thread before posting a reply, so I apologize for that. It's part of the peril of an internet "conversation."
Since no one has stepped in for me, and seeing my efforts only leading to a derailment of the topic at hand (=the Marantz AV8801) I have decided not to respond any further here for a bit. Unless about fun stuff, or technically interesting matters concerning the Marantz or Oppo used as a source.
I am going to further enjoy my 8801, who some now claim I don't own and wasn't doing.
Ettepet is offline
Old 02-17-2013, 10:59 PM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
I did not change them while live but I did mix my center as unabalanced with others balanced and found not much change in volume.
It looks like my amp accounts for the voltage change and keeps the volume approximately the same.
- Rich
RichB is online now
Old 02-18-2013, 12:27 AM
AndersT2's Avatar
Originally Posted by jslaw81 View Post
So its a known issue? No remedy for this yet?
You can easily fix this yourself, just go to the component tab, and relearn the power on function, and use an input button instead of the powerbutton.
And at the same time, make it re-learn the cbl/sat button too, it didn't have the right command for me.
AndersT2 is offline
Old 02-18-2013, 05:14 AM
Super Moderator
markrubin's Avatar
Quoted: 1047 Post(s)
Liked: 2300
posts deleted
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
Old 02-18-2013, 07:10 AM
thrang's Avatar
Quoted: 1613 Post(s)
Liked: 1387
It appears that the 8801 does not have 8 A-D converters for the 7.1 analog input, which is why none of the digital processing options apply. The gain changes are all analog. So that would mean there's no delays in the 8801 either.
By gain changes here you mean the 8801 trims would apply, correct?
While on this point in general, the two channel XLR inputs on the 8801 do however have A-D conversion if desired, as I'm able to apply Audyssey to playback from my DAC which is connected this fashion...
@Rich, can you clarify if my understanding of your issues is correct?:
1) Video Conversion on/off is affecting sound quality of Pure Direct mode via 7.1 analog inputs, but NOT any other input (also in Pure Direct)?
2) 7.1 analog input sounds brighter to you compared to HDMI or other inputs (with Audyssey disengaged? Direct or Pure Direct sound mode for all?)
thrang is offline
Old 02-18-2013, 08:05 AM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
It does appear that the XLR's can be digitized for processing.
Since this is not explicitly stated, I am not sure it is safe to conclude that Pure Direct bypasses the A to D.
It should...
Perhaps this explains the change in sound with 7.1 between Pure Direct ON/OFF. With Pure Direct OFF (standard 7.1), it could be that the TRIMS are applied.
1) I find it easiest to detect with Pure Direct mod via the 7.1 analog inputs. However, I can also hear a change watching DD via the TiVo HDMI.
I am not saying this is a big deal. However, it exists. To those out there that are not completely happy with the sound quality, this is something to try.
2) With my first 8801, the 7.1 sounded brighter so me in Pure Direct than directly connecting my Oppo BDP-105 to the amp.
I chose this one example because it should sound virtually the same.
However, I am not sure this issue exists, on the replacement unit.
For the heck of it, I connected the 8801 unbalanced to my AMP and listened to music, watched some movies including Skyfall and it sounded fantastic.
I am very happy with the sound.
I am not ruling out the XLR's. After you change the settings there is a solenoid click that when you edit the process.
Perhaps there is something going on here beside guidance.
3) Usability Issues: I posted some a while back where I think a firmware update could improve the usability of the product.
Is there a place where these could be collected?
- Rich
RichB is online now
Old 02-18-2013, 08:16 AM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
@Thang,
Why not pick up a BDP-105 and connect the 7.1 analogs? You can always return it if that is not your thing.
The 105 USB DAC is very nice as well. I have been ripping my CD collection tot he NAS and using J River (and my IPAD) push music Oppo.
Rich
RichB is online now
Old 02-18-2013, 08:31 AM
thrang's Avatar
Liked: 1387
@Thang,
Rich
I have the 103, which also has 7.1 out, though I was thinking of getting the 105 to compare to the McIntosh D100 DAC for music. But the D100 is very sweet!
thrang is offline
Old 02-18-2013, 08:45 AM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
Looks like a very nice piece.
There has to come a point of diminishing returns so I am not sure you will hear a difference.
The most difficult part of involving a PC is getting the sound out unmolested.
There are at least 8 sound driver options and they are not even close to sounds the same.
This is when I think a MAC/MAC mini might be the right answer.
Of course, these days you could push (DMR) directly to the AV8801.
I have not played with that much.
The 8801 does the best job of playing Pandora I have heard on a Processor/Receiver.
Much better than my Onkyo's and Yamaha Aventage A820 receiver.
However, in the Aventage's defense it is mounted on an open air rack so the fifth foot is not properly stabilizing the unit. tongue.gif
- Rich
RichB is online now
Old 02-18-2013, 08:56 AM
thrang's Avatar
Liked: 1387
- Rich
I've done a fair amount of testing of the D100, comparing to direct digital into the 8801, and also against a MiniMax Plus Dac, an M2Tech Young DAC, and a HiFace 2 converter. and I've had and returned the W4S DAC2 in the past.
The D100 is really special if you like two channel music, but my preference is also to use Audyssey Flat (I know there is an additional AD conversion, but it doesn't matter - the summed benefit is still greater than going directly into the 8801 digitally). I use Audirvana on a Mac Mini, and the D100 supports Direct/Integer mode, which is the cleanest way to get the audio out of the Mac. Content is all lossless AIFF or higher res FLAC. I couldn't tell you why, but the D100 is a little bit of magic (maybe the stereo quad balanced mode using the 8-channel Sabre chip?).
thrang is offline
Old 02-18-2013, 10:21 AM
Liked: 711
Yes. Both trims or volume will work. They are done in the same chip, usually.
Old 02-18-2013, 10:47 AM
videoray's Avatar
Quoted: 37 Post(s)
The 8801 review quote "Also cool is a fourport Ethernet switch on the back which will lets the 8801 serve a network hub for other components (sadly, it is only 10/100 and not Gigabit.) A USB input on the back will be a welcome addition for owners wanting a permanently connected drive. The 8801 is Control4-certified and also has an RS-232 port". I've read most forum replies, but fail to understand why 4 switch Ethernet ports, USB for a permanently connected drive, and Control4-certified with RS-232 port. If I'm going to route wires in the attic, it would be nice to know all possibilities before doing so. I have a three room situation. One room for the computer, one room for the display and speakers, and one room for the components. Any help would be greatly appreciated.
videoray is offline
Old 02-18-2013, 10:55 AM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
^^^ I am not sure what you are asking.
But here goes:
Run a single 1 Gig Ethernet cable CAT-5E or CAT-6. You may put your own switch in if and when you need more or faster.
USB has to be local so if you ever get a device that outputs USB It has to be pretty close, although you can get USB repeaters.
Don't know much about Control-4.
- Rich
RichB is online now
Old 02-18-2013, 11:10 AM
whoaru99's Avatar
Liked: 69
The Ethernet port part is pretty straightforward. While I don't have a 8801, I do have a 7005 connected to my network, along with a BD player, a WDTV Live, and a computer all in close proximity. Currently I have an ethernet wire from my back room to a switch behind the rack to provide the connections for all these devices. Since the 8801 has a built-in switch or hub, it would eliminate the need for the separate switch. I'm guessing most people don't currently have an internet connection >100Mbps and streaming content doesn't require it AFAIK, being just 10/100 isn't that big of a deal for a media center.
The USB drive attached for local media storage seems fairly straightforward, and Control4 is with regard to system integration/home automation. Try an internet search for "Control4".
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 02-18-2013, 11:56 AM
WestCoastD's Avatar
Quoted: 253 Post(s)
Liked: 96
just curious, what are you using for NAS? external drive?
I've been using WD "MyBookLive", seems to work beautiful so far as an NAS server. My music archive are primarily WMA (Windows Media) files derived from CD collection, 84kbps - 280kbps. However now I'm looking into re-ripping everything to FLAC. Figuring out what's best to use for ripping and/or playback.
Old 02-18-2013, 12:14 PM
Super Moderator
markrubin's Avatar
Liked: 2300
I am using the extra Ethernet ports on the 8801 for OPPO 95 and 105 players: works fine
I am not sure the 10/100 speed limit makes a big difference: as pointed out that is all you get from a cable modem: but it could be argued the local intranet could run at higher speeds
Old 02-18-2013, 12:52 PM
Quoted: 1394 Post(s)
Liked: 589
Does anyone know what exactly the 8801 video processor does to the signal. I'm referring to RGB, 444, 422, etc.
JimP is online now
Old 02-18-2013, 01:26 PM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
Sure, if you turn it off no changes.
However there is a System Information command I found in the excel spread sheet that causes the big rectangle display to show you that information.
It is also shown in the menu information, it shows what is coming in and going out.
On the video side, it can make sense to use the deinterlacing and scaling.
But if you want more, get a video processor like the Lumagen Mini.
Folks either calibrate their displays or with video processors. It is just too cumbersome to try to use the cotrols in these processors.
The Lumagen Mini 125 point calibration is the Audyssey of the video world.
- Rich
RichB is online now
Old 02-18-2013, 01:28 PM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
I use a ReadyNas pro which works well enough, but were I looking now, I woulc checkout Synology.
Lots of good reviews.
- Rich
RichB is online now
Old 02-18-2013, 02:24 PM
videoray's Avatar
Quoted: 37 Post(s)
The 105 oppose to 8801 has a more advanced DAC have you tried using the audio outs to see if there is a difference?
videoray is offline
Old 02-18-2013, 02:25 PM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
I use DBPoweramp sottware for ripping CD's and store my main library in FLAC. The Logitech Media Server converts FLAC to PCM in the PC and delivers the PCM music file Squeezebox Touch. I've A/B'd Touch anolog output with my Sony CD player and was not able to detect much difference. I've borrowed my friends Rega DAC and detected very slight improvement in midrange area via SPDIF input. In my opinion Rega was not worth the money for marginal (insignificant) improvement.
I'm investgating if streaming FLAC via Foobar with WASPI USB driver in to Oppo 105 as an alternative DAC would deliver similar (better) result.
- Alex
AlxG is offline
Old 02-18-2013, 03:03 PM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
I have the 105 connected by 7.1 analog, XLR, COAX and HDMI.
I can easily toggle between them playing CD's which are LPCM.
Here they are ranked from best to worst on my system:
  1. 7.1 Analog has tremendous bass, highs and Dynamics and is the fullest most natural presentation.
  2. XLR is the brightest with lots of dynamics and bass. I find this too bright on my system.
  3. COAX: This sound very good about as bright as XLR with a bit less imaging and bass (uses the internal DAC)
  4. HDMI: This sound compressed and less extended in both bass and high-frequencies (uses the internal DAC)
My Revel Salons are very dynamic speakers that will keep producing more sound if you give them lots of power.
Since these are driven by a Sunfire 7400 400 PWC amp, the sound is aggessive to say the least.
I cannot stand the volumes higher than low 90 DB range on average (I estimate at least 10 DB peaks since my meter is slow).
This translates to 70 on most CDs and 80 on low average volume content.
I have described the AV8801 as bright and it is clearly brighter than my Onkyo PR-SC5507 preamp.
The AV8801 is incredibly detailed and does not compress sound so if your speakers/amp don't compress much, this thing is a beast.
It can hurt you.
I turned down my Rear-Tweeters (-3 DB) but left the front Tweeters alone and that has gone a long way to releaving some of the brightness.
I am much happier now.
- Rich
P.S. for those following this, this is my replacement AV8801 which behaves the same. There was nothing wrong with the first one.
RichB is online now
Old 02-18-2013, 04:09 PM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
I'm confused... In his review, Kal compared the 8801 to his Integra 80.2, and unless I'm mistaken, he thought the 80.2 the "brighter" of the two. Did you test in a different way than Kal, or could this be a system dependent issue?
TL5 is online now
Old 02-18-2013, 04:41 PM
comfynumb's Avatar
Liked: 410
Under the input source level menu. How are you guys setting the analog and digital inputs, are you leaving them flat or stepping up the db's?
comfynumb is offline
Old 02-18-2013, 04:47 PM
videoray's Avatar
Quoted: 37 Post(s)
    I have the B&G Radia Z62's for 7.1. These are very transparent speakers with huge dynamics. Maybe I should consider staying with just the Oppo 105; although, I'll be missing the XL32.
videoray is offline
Old 02-18-2013, 05:15 PM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
It looks like you must have those paired with subs.
It all depends on your tastes and your room.
Many folks here have tremendously positive experiences with XT32.
- Rich
RichB is online now
Old 02-18-2013, 05:19 PM
Oppo Beta Group
RichB's Avatar
Quoted: 873 Post(s)
Liked: 573
I tested with the BDP-105 7.1 analog inputs, XLR, COAX, and HDMI Pure Direct.
For Pure Direct, I would not characterize the PCM over HDMI as overly bright but it also my least favorate listing source.
I have not read the article nor have I heard the 80.2.
- Rich
RichB is online now
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
