Marantz AV8801 Preamp/Processor Official Owner's thread - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 293Likes
post #3331 of 13521 Old 02-26-2013, 05:27 PM
comfynumb's Avatar
Liked: 410
S
Originally Posted by beastaudio View Post
I am a bit confused on the bi-amp situation you are doing right now too. you are using 4 channels of amplification coming from the FL/FR of the marantz, into a 4 channel amp and two +/- wires going to each speaker with one for the mids and one for the highs? It certainly sounds to me as well that the mids are not either getting the proper wattage to operate fully compared to the highs. If the amp doesn't have separate gain adjustments, this would certainly be the case as the highs probably take 1/10th of the power to operate at appropriate listening levels as the mids/woofers do. feeding them both the same amount of power at the same gain level would be exactly what you are seeing.
Man, I like this thread, SBIR is all to often not even mentioned when properly calibrating systems biggrin.gif Good points sir, I learned the effects of SBIR after way too late in my initial journey biggrin.gif
In reference to this and your above quote, I will expound on how I take Audyssey's results. First off, it sets my subs a good 10-15dB lower than they should be to match the rest of the system, and it does it every time. A cheap radioShack SPL meter is your best friend. Quite possibly the best $40 I spent on my theater so I can go and see where Audyssey missed some very important things.
Dynamic EQ will only accentuate the surround mix, and the low freqs when listening below reference to help make the sound appear more "full" when not cranking the system to higher listening levels. My guess here is it is helping your already anemic sub system that was set incorrectly to bring it back to where it needs to be, but is still inaccurate. SO on to my post Audyssey regiment:
1) go in and adjust crossover points, my rears I know are not capable to 40hz, so I bump it up a shade to prevent damaging the speakers. Mains are set as full range but IN MY ROOM my system measures better when they are set to 100hz so I do that. YMMV
2) Confirm that the speaker distances look to be correct on all channels, which Audyssey does a much better job at this part.
3)and most important, I take my RS Spl meter and make sure that all the levels are matched at 75dB (or the standard 72 that your 8801 probably has them close to minus the sub channel)
4) If on any of the speakers your post Audyssey results show a -12 on the meter, as has been said, Audyssey could not EQ as it felt the level was too high and left it out. If you have any of these in your setup after a test, either move the mic further away from the MLP (not always the best idea), adjust the gains on the amp down so post Audyssey results show the majority of your speakers are at 0-0dB +/- 5dB or so, or if you don't have gain adjustments on your amp, then look into getting some RCA line attenuators from PE:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=266-244
The whole part about Audyssey reading your mains as reversed polarity could either be side wall reflections being too prominent in the frequency response or your overall delay coming from your front stage to the mic but I would guess the former. Side wall absorbtion/diffusion would be advisable, but before that try adjusting the toe-in of your mains to see if this helps.
The Sunfire multi channel amp is biamp able, one RCA to the left rear in my case as I wasn't using it. Then daisy chain with an RCA that to the left front current source (Sunfire has both current and voltage sources for the front speakers) this gives me two speaker leads for one front speaker, both at the rated 200 WPC into 8 ohms. Same goes for the right. It does list this technique in the book. I just tried this and by no means did it improve anything IMO. So I will be going back to normal. It definitely sounds like I need an spl meter and I'm going to try your suggestions. So if I'm getting side wall deflection, which I agree with you I am. Should I toe the fronts in past the main listening position? This is my first pre/pro with these advanced settings and I appreciate the help.
One more question, Audyssey wanted me to turn the low and high pass filters on my powered sub up all the way. Should these be left there or set to relatively the same Hz that I have my mains crossed at?
comfynumb is offline
post #3332 of 13521 Old 02-26-2013, 05:58 PM
dahlgren's Avatar
Originally Posted by wse View Post
Good for you experimentation is all it takes, I love experimenting as well. What are your speakers?
Tannoy Defininition DC8T (front)
Tannoy Definition DC8 (surround)
Tannoy Definition DC6 LCR (center)
Tannoy Revolution DC6 (height & back)
McIntosh SL1 (powered sub)
McIntosh HT-2 (sub)
dahlgren is offline
post #3333 of 13521 Old 02-26-2013, 06:33 PM
be83663's Avatar
be83663 is offline
post #3334 of 13521 Old 02-26-2013, 06:42 PM
Geronimo.USMC's Avatar
Quoted: 133 Post(s)
Liked: 76
Originally Posted by Dave Vaughn View Post
In my initial testing of the AV8801, it failed the Chroma Resolution test, but Marantz sent me a new firmware today and it now passes this test. This update will be pushed out in the near future for everyone.
Any idea if the firmware includes any other fixes? Did they hint at an ETA?
-HTPC/Gaming Rig: Silverstone CW02B, Core i7-5820K, ASUS X99-A, 16GB, EVGA GeForce GTX 1080 SC GAMING ACX 3.0 >Samsung 78JS9500
-Auzen HDMI XFi> 7.2 via Marantz AV8802A>Wyred4Sound monoblocks + Halo A51>Paradigm 100'sV5, ADP590'sV5, 690v5, 20v5's, + Dual SVS SB13 PLUS Subs
-40TBof Blu ray .iso's in a Synology DS1815+ controlled by a Dune Solo 4K
-Samsung UBD-K8500 4K UHD WCG HDR Player
Geronimo.USMC is offline
post #3335 of 13521 Old 02-26-2013, 07:14 PM
sfav's Avatar
Quoted: 23 Post(s)
You get a discount on both not a huge discount on the amp alone. You can look at it that way but I can assure you my invoices are not priced that way on the bundle. If you apply a proportionate discount to each piece that is the price of each component not $5K less $3600. You can see it how you want but Marantz sees it another way. By your logic if I sell the amp at your price I get no discount on the 8801, but the reality is you get both at a discount, that's why they are BOTH required to get the pricing. Feel free to apply the numbers where you like but it is a straw man argument to say the amp is the only discounted item to prove a performance/ price point argument on the amp alone. In fact why not subtract the retail price of the amp from the $5k and make that the price of the 8801. This works for the person arguing the 8801 against another preamp at a reduced price:) Your argument reversed. The amp is compared at the retail to retail price for value to another amp, if you want to compare it at a lower price then do the proportionate discount but assume that is available for the other product as well or compared to a bundle for $5K total.
sfav is offline
post #3336 of 13521 Old 02-26-2013, 07:52 PM
Quoted: 133 Post(s)
Liked: 76
Do you guys turn off "loudness management" under surround parameters when playing True HD movies. I have it turned off. Kind of second guessing myself....
post #3337 of 13521 Old 02-26-2013, 08:01 PM
bbar's Avatar
I do
bbar is offline
post #3338 of 13521 Old 02-26-2013, 10:10 PM
Bill222's Avatar
Audyssey basic setup question
I ran Audyssey with just 1 mic position - just to check speaker levels before moving on. The first few times it kept saying my sub-woofer is too loud - turn it down and try again. So I did. This time - it ran to completion.
BUT - for speaker levels - it has:
Front Left -12.0 db
Front Right -12.0 db
Center -12.0 db
Surround Left -12.0 db
Surround Right -12.0 db
Sur. Back Left -8.0 db
Sur. Back Right -8.5 db
Sub -5.5 db
Ummm - help? I remember reading anything tuned to -12db is "bad" - that it's outside the limits of Audyssey to adjust... But my speakers don't have adjustments. Only the sub has adjustments. The other speakers are just good, old, large (in size - 100+ pound) speakers - all being run by nice, old, amps that also don't have adjustments (just on/off for the amps).
What's the next step to get a "good" Audyssey calibration?
Bill222 is offline
post #3339 of 13521 Old 02-26-2013, 10:27 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
Front Left -12.0 db
Center -12.0 db
Sub -5.5 db
What kind of speakers are they? You may need a line attenuator...
mookie b is offline
post #3340 of 13521 Old 02-26-2013, 10:50 PM
Bill222's Avatar
http://www.klipsch.com/cf-4 They're mainly Klipsch CF-4 (Fronts and Surrounds).
http://www.klipsch.com/cf-3 Rear Surrounds are Klipsch CF-3.
http://www.klipsch.com/kv-4 Center is a Klipsch KV-4
Each of those pages have "Spec" tabs for more details. (Yes - my speakers are all from the mid-90's. That's new to me... Where's the dinosaur emoticon?)
Bill222 is offline
post #3341 of 13521 Old 02-26-2013, 11:30 PM
Roger Dressler's Avatar
Quoted: 1544 Post(s)
Liked: 733
Originally Posted by Calvin Hobbes View Post
Roger: No one takes issue with your subjective opinions of the sound.
I am not making a subjective opinion. I am stating that there is an observable difference in the sound.
When you observe something with your ears, that is subjective. Until we see some measurements comparing direct with stereo, that's all we have to go on.
I have referenced two measurements by others that, although the same Audessey XT32 is used, show different very different FR curves that should not exist at this level of Audessey.
Were there two? The only reference I saw was to Beastaudio’s post, regarding which you stated:
If you look at the first graph in post #59 starting at 300 hz it measures 80 db, at 2500 hz it measures 88 db with the first two octaves staying above 85 db a dip starting at 1200 then a sharp rise back up at 2500 hz.
That plot could hardly be laid at the feet of Audyssey, since there was no EQ operating at the time. That's just the raw response of the speaker/room.
These measurements that we are discussing are known by the manufacturers and they choose NOT to publish them. That in and of itself is a red flag. What else are they not telling us? Where are the Emperors new clothes?
I see no point in publishing straight-line response plots. Based on all the test reports I have seen in magazines and at Dolby, there’s nothing funny going on. Flat is flat.
Sidenote to Roger- Do you remember the Fosgate Gavotte? I was running one during 89-92 on the IASCA circuit in socal.
Sure do. Talk about being ahead of one's time!
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #3342 of 13521 Old 02-26-2013, 11:32 PM
audiofan1's Avatar
Quoted: 1684 Post(s)
Liked: 1708
Hi Bill ! are you using rca or the balanced outs ,if balanced and your amps have no gain controls you will have to use the rca outs , this happened with my Anthem MCA 30 but not my Halo A21 a simple swap sould do it!
audiofan1 is offline
post #3343 of 13521 Old 02-26-2013, 11:36 PM
Bill222's Avatar
Yes - I'm using the balanced outs to amps with no gain control. The amps are old Aragon amps from their 8008 line.
Uh-oh. I don't want to go back to RCA.... It's a long run to the amp for the rear-surrounds (maybe 30 feet as the cable goes). And even the short runs up front (10 or 15 feet) are all running next to many other cables - many of them power cables. I really don't want to go back to RCA.
Bill222 is offline
post #3344 of 13521 Old 02-27-2013, 12:00 AM
audiofan1's Avatar
Liked: 1708
Looks like the line attenuator may be an option as posted a few threads back but only for those with levels at -12 anything above that is fine.
post #3345 of 13521 Old 02-27-2013, 04:03 AM
Bill222's Avatar
Sigh. Thanks. Just not the answer I was looking. I was looking for "press this magic button combination, access this secret menu, and viola! You can fix the gains without changing anything else!". So, no magic today....
I've ordered the attenuators. It will be a week or so before they get here. In the meantime, I'll probably try going back to RCA cables since I have to re-do cables in that part of the room anyway for a PC replacement...
Thanks again to those who replied!
Bill222 is offline
post #3346 of 13521 Old 02-27-2013, 05:16 AM
jdlynch's Avatar
Quoted: 174 Post(s)
Liked: 66
Originally Posted by Roger Dressler View Post
Looking back at the context (below), I am no longer certain if Mr. Lynch was referring to the LPF in the 8801 LFE channel (as I first thought) or the filter on the Seaton's amp. If he was referring to the Seaton, then I agree it should not be set to 80 Hz. But neither 120 Hz. It should be turned off if at all possible, or set as high as it can go. I hope he can clarify which he meant.
Roger-
I use no filters on my submersive subwoofer. My question was in regards to the subwoofer settings in the AVR8801.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. Datasat RA7300, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 106" Carada BW screen, Oppo BDP-103.
jdlynch is online now
post #3347 of 13521 Old 02-27-2013, 07:49 AM
Point Source
beastaudio's Avatar
Quoted: 3775 Post(s)
Liked: 3060
Originally Posted by comfynumb View Post
S
Try toeing them in a little more to where they cross a few feet in front of the MLP, but no more. If that doesn't fix it, some acoustic panels might help on the side walls(and rear wall too for that matter). I strongly recommend these in any case. On your sub, either defeat any LPF on it altogether, or set it as high as possible. Matching the XO on the sub AND the receiver make the dual filter double the rolloff which is more than likely a bad thing to do...
Front Left -12.0 db
Center -12.0 db
Sub -5.5 db
You still might want to look at line attenuators, but give the switch to RCA a try first. Another option would be to put "Bump-boxes" in line on each of the channels to dump some signal. It is funny, as most people use them to GAIN additional signal when going from Unbalanced RCA consumer to balanced XLR pro level, but in your case, it could actually do the opposite. For main speakers look at the new samson convert or the art cleanbox pro. Not sure if you want anything else in the chain to begin with, but it is certainly another option to running all new wire.
beastaudio is online now
post #3348 of 13521 Old 02-27-2013, 08:12 AM
comfynumb's Avatar
Liked: 410
Ok, I'm going to give this a try. I've been thinking of the about some acoustic panels, I'll have to look into it. For right now the bass part seems pretty good, it is less boomy than it was. For all the obstacles in my room it really does sound decent. Thanks.
post #3349 of 13521 Old 02-27-2013, 08:51 AM
Dave Vaughn's Avatar
Quoted: 1018 Post(s)
Liked: 1487
All I was told was "the next update." No date was given, but it's coming!
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #3350 of 13521 Old 02-27-2013, 10:04 AM
dahlgren's Avatar
Found this link on the MX150 forum. The best I have seen in explaining tuning your system XO'settings with full range mains adding in sub (s), LFE, sub placement, cancelation of frequencies when you don't XO let's say at around 80hz as the experts here suggest.
http://www.soundoctor.com/whitepapers/subs.htm SoundDoctor All about Subs
http://www.soundoctor.com/testcd/ crawl-around test for sub placement
dahlgren is offline
post #3351 of 13521 Old 02-27-2013, 10:43 AM
Calvin Hobbes's Avatar
Disney Concert Hall sounds different from Segerstrom Concert Hall. Wilson Watt Puppies sound different from Revel Salon 2's. These are objective observations - A/B comparison. Direct sounds different from stereo in the AV8801. Two valued members here state that the Av8801 sounds different from the Integra 80.2 with the same setup with Audyssey XT32. I agree with their observations. There is a reason that they do sound different and I then chose to investigate the why.
The reading of the graph I referenced by beastaudio, is after he used Audyssey but before he used his 31 band EQ to further smooth the FR. The other reference is buried in another posted response to Dr. Rubinson. In Music in the Round #50 he took measurements of the 80.2 with Audyssey engaged.
I do agree with you that I cannot hear a difference in the Dolby outputs. Music is easier to pick out differences in FR than movies. I would like to see measurements of Prepros/AVR's that are more extensive than the speaker measurements we get. The electronics are much more complicated than simple passive speakers.
Unfortunately, I am returning the AV8801. I am not happy with the quality of my 80.2, which was the catalyst for purchasing the Marantz. The styling, gui and the myriad of options are wonderful. I like what Audyssey sets as a baseline, before some minor tweaking with my setup. I want as few as components as possible in the signal path to obtain accurate sound. Back to the drawing board.
Calvin Hobbes is offline
post #3352 of 13521 Old 02-27-2013, 11:14 AM
audiofan1's Avatar
Liked: 1708
post #3353 of 13521 Old 02-27-2013, 11:44 AM
Point Source
beastaudio's Avatar
Liked: 3060
Wait you are returning the 8801 and are going to the 80.2? or you are looking at option separate from both?
post #3354 of 13521 Old 02-27-2013, 11:53 AM
Oppo Beta Group
RichB's Avatar
Quoted: 974 Post(s)
Liked: 646
Calvin,
For music my path : BDP-105 -> AV8801 (Pure Direct) -> Sunfire 7400 -> Revel Salons -> Ears -> Brain -> Soul smile.gif
I agree with you that Pure Direct and Direct sound different from using the BDP-105 7.1 analog inputs.
I attribute this to the extra processing for bass management. It may be something else, but on my system it is not the same.
I do not have the equipment so I cannot measure it in my room.
My Sunfire amp is a bit bright so it may exaggerate the different. I will be trying an Outlaw 7500 tomorrow.
I would like to see reviewers show results for the analog performance and I also agree the DD is not that meaningful.
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #3355 of 13521 Old 02-27-2013, 11:54 AM
be83663's Avatar
I am sorry to hear that.
Marantz AV8801 is so Flawless, and Perfect for me!!!
It sounds so Movie-Theatre-Like and Life-Like!!!
I hope you will like your next Pre-Amp though.
AV8801 cannot be beatten!
Ken.
be83663 is offline
post #3356 of 13521 Old 02-27-2013, 12:24 PM
GerryWaz's Avatar
Quoted: 29 Post(s)
Originally Posted by GerryWaz View Post
Anyone have this issue? The AV8801/MM8807 suddenly goes into something like a "mute state" and the only way to address the issue is to turn everything off and then back on.
Has happened to me three times over the past two weeks, the most recent last night when I was watching "The Colbert Report" on cable TV. The other two times were with FM and HD radio.
More of an inconvenience . . .
Hmm, I must be the only one seeing this . . .
Happened again last night.
Trying to remember but it may happen only when all the zones are on (need to fix that with my Harmony Remote). Definitely not an airflow issue (I think)--the units have plenty of open space above and behind in a ventilated cabinet.
What's the best way to contact Marantz? Through the Owner Circle?
GerryWaz is offline
post #3357 of 13521 Old 02-27-2013, 01:03 PM
erwinfrombelgium's Avatar
Quoted: 438 Post(s)
Liked: 236
Originally Posted by exm View Post
Most people who purchase the MM8077 are getting the combo deal - so the MM8077 will be $1,399
The $1,399 is even more proof the MSRP is too high. Add two MM7025 for 11 channels total and you will have payed $3K which is at least double the price per Watt vs XPA's. BTW Emotiva has sales also where all the models are reduced. Not 30% off obviously.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #3358 of 13521 Old 02-27-2013, 01:09 PM - Thread Starter
exm
exm's Avatar
Quoted: 136 Post(s)
Liked: 82
True that Marantz/dealers see it another way. But for me it's simple - let's assume I pay full MSRP: the AV8801 is $3600, and if I get the amp with it, I can get the amp for $1400 more (with the $1000 discount). For people that are purchasing the Marantz and need an amp, this is a very valid argument especially if you compare the amp to the competition. Anyway, just my $0.02
exm is offline
post #3359 of 13521 Old 02-27-2013, 02:59 PM
ninjahifi's Avatar
Quoted: 14 Post(s)
Liked: 24
Would someone mind pm what a good price on the 8801 would be and where I can get it. Thanks.
ninjahifi is offline
post #3360 of 13521 Old 02-27-2013, 03:08 PM
dahlgren's Avatar
This is an HDMI/set top box issue. I switched to composite/coax for my FiOS STB and problem solved. Never happens with my UD9004 using HDMI. First tried switching HDMI to 3ft but it still happens so gave up and went the other route.
dahlgren is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
