Marantz AV8801 Preamp/Processor Official Owner's thread - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
Old 03-05-2013, 01:48 PM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
Originally Posted by comfynumb View Post
I'm going to have to try them, your about the third person that said they sounded better. Is it a warmer sound or more dynamic?
It is warmer when using Pure Direct and disabling all video processing, including setting Video Mode to Game.
But, the big difference I find in Pure Direct is in the sound stage and overhang. I guess they made that mode for a reason smile.gif
I have no need for processing in the Marantz since the Oppo can do all the audio processing I need on the 7.1 inputs and it does a great job on video.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 03-05-2013, 02:10 PM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
While there is a difference indeed between feeding the 8801 hdmi/xlr or using the 7.1 inputs I cant say one indeed sounds better but shall we say presents the music different, After getting Audyssey dialed in to satifaction with mains set to 80hz and using Dynamic EQ the sound is indeed compelling vs. using the xlr from the 105 ( full range) which has what what can be called a "fuller" or "warmer" sound, but the 8801 + Audyssey for 2ch can have a pristine detailed deeper sound stage with even tighter bass definition ( not thin sounding at all) because of the use of the sub, both configuration have there merits and detractors of course but both sound extremely good and out shines the other depending on material. now using the 8801 hdmi with no Audyssey still retains a toe tapping midrange and drive and pace which again depending on material can hold its own against the 7.1( for stereo) or the xlr inputs. But hands down with multi ch sacd the hdmi 8801 + Audyssey is a beast!
audiofan1 is online now
Old 03-05-2013, 02:21 PM
dahlgren's Avatar
Originally Posted by DHF View Post
I abandoned Harmony and all IR for that matter. Went to iRule and am controlling through the home network. Individual speaker up downs are available, as well as some limited feedback from the Marantz.
A bit of a learning curve - but the whole iRule project has gotten a very high WAF from she who must be obeyed.
I have an iPhone, do you recommend an iPad?
dahlgren is offline
Old 03-05-2013, 02:27 PM
dahlgren's Avatar
Originally Posted by markrubin View Post
I also abandoned IR control when I realized my plasma and CCFL LCD displays caused major IR interference and compromised IR control: an IR repeater made things worse
but it is a lot of work to set up and keep it working
What did you replace it with?
dahlgren is offline
Old 03-05-2013, 02:29 PM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
Sounds good to me.
Now that I fixed some issues, and installed the Outlaw 7500 I love the sound.
I may try direct from the Oppo to the Amp, but Oppo recommends that the input impedance for directly connecting an amp to the 105 be 47k ohms.
- Rich
RichB is online now
Old 03-05-2013, 04:04 PM
audiofan1's Avatar
Liked: 1666
Originally Posted by RichB View Post
Sounds good to me.
- Rich
Old 03-05-2013, 04:07 PM
Super Moderator
markrubin's Avatar
Quoted: 1036 Post(s)
Liked: 2273
an RTI system with touch pads and remotes
my second choice would be iRule: excellent program
my opinion only...
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
Old 03-05-2013, 04:09 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
Mini ipad would be good size.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Old 03-05-2013, 04:38 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
I've been using an iPad mini with Roomie Remote. It does all the major stuff on the Marantz....but definitely not all inclusive. Missing STATUS as mentioned earlier I think, the Harmony was able to use an older Marantz code for that.
mookie b is offline
Old 03-05-2013, 05:05 PM
pwz414's Avatar
I turned my processor on today when I got home and it's not passing video or audio. I tried both monitor outputs. I checked the cable too. It's good. Any ideas? The front display is working properly, so I'm guessing I have menu access.
pwz414 is offline
Old 03-05-2013, 05:23 PM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
See if you can access the menu system using the LCD display make sure the HDMI output is set.
Try another cable.
If you have an HDMI computer monitor then try hooking it up.
- Rich
RichB is online now
Old 03-05-2013, 05:39 PM
Geronimo.USMC's Avatar
Quoted: 133 Post(s)
Liked: 76
First put it in standby, then unplug it. Wait 2-5 seconds, then plug it back in & turn it on &try again. IF IT DOESN'T WORK, it should though, try again. Lastly, fixed or not, call marantz & report your loss of HDMI signal. Exactly the same problems. I get these random loss of video. Either from standby or switching inputs on two different units. Please call & let them know. The more people report, they can fix it.
-HTPC/Gaming Rig: Silverstone CW02B, Core i7-5820K, ASUS X99-A, 16GB, EVGA GeForce GTX 1080 SC GAMING ACX 3.0 >Samsung 78JS9500
-Auzen HDMI XFi> 7.2 via Marantz AV8802A>Wyred4Sound monoblocks + Halo A51>Paradigm 100'sV5, ADP590'sV5, 690v5, 20v5's, + Dual SVS SB13 PLUS Subs
-40TBof Blu ray .iso's in a Synology DS1815+ controlled by a Dune Solo 4K
-Samsung UBD-K8500 4K UHD WCG HDR Player
Geronimo.USMC is offline
Old 03-05-2013, 08:50 PM
whoaru99's Avatar
Liked: 69
Its whether or not I can hear the difference.
I cannot hear the difference in sending the status code to display information in the large LCD window while playing a source in Pure Direct Mode.
Not when it turns on, not when it turns off.
This is something you can try.
Perhaps there is a difference but not one I can detect.
I can hear the difference in Pure Direct mode turning Lip-Sync: Off, Video Mode: Game, Video Processing: Off.
Many cannot hear any difference between Pure Direct and Direct.
I hear one and prefer Pure Direct.
- Rich
At the risk of being redundant, the point was whether or not there is a command to do what you wanted (turn on the display in Pure Direct), not whether or not you can or believe you can hear a difference in any of that.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 03-05-2013, 09:01 PM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
Actually, I was looking for a command to turn the circle display on while in Pure Direct mode so I could see the volume.
I couldn't find one and I programmed a bunch into my Pronto.
Plenty turned on the rectangle display.
In order to do this, I programmed volume up/down sequence.
The other point was illumination of these displays has no audible effect on the sound quality.
I really have no idea what point your point is.
Are you asking a question?
- Rich
RichB is online now
Old 03-05-2013, 09:57 PM
Mike Garrett's Avatar
Quoted: 5557 Post(s)
Liked: 3541
I did not see this review posted, so I thought I would post it. http://www.hometheater.com/content/marantz-av8801-surround-processor-amp-mm8077-amplifier All of our customers have been very happy with this unit. I guess that explains the glowing review. smile.gif
Scott-C likes this.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 03-05-2013, 10:18 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Who is using more than one zone? I would like to connect a 2nd room with dedicated system for 2.0 playback. Anyone doing the same? What connection did you use? I only see analog as my choice. I would have preferred to send it spdif, toslink or coax.
zuluwalker is offline
Old 03-06-2013, 04:30 AM
jdsmoothie's Avatar
Quoted: 12086 Post(s)
Liked: 5502
Correct. D&M dropped the optical audio out beginning with the 2011 models. You do have the Zone 4 (HDMI) available to another AVR.
jdsmoothie is offline
Old 03-06-2013, 07:06 AM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
I have to agree, I love my 8801. I was on the hometheater forums and asked about the MM8077 amp. I was refered to a $300 stereo crown amp instead of the 8077. I think I will keep my order for the 8077 instead. Should be here soon.
Life is enjoyable with good quality
Dr_Mark is offline
Old 03-06-2013, 07:23 AM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
I have an Outlaw 7500 paired with the AV8801 and it sounds fantastic.
It is more powerful, no fans, and a great deal.
You might want to stay tuned for Mark's review.
I think he had the 8807 for a time.
- Rich
RichB is online now
Old 03-06-2013, 08:16 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
If the crown was a drivecore, I will attest to it's capability. I have one now for my L/R and the thing is dead silent. They are pretty solid performers for sure, but alas, they are only 2 channel so you need several to get your whole system going. This is my second one I've owned and I see possibly more in my future for sure smile.gif
beastaudio is offline
Old 03-06-2013, 11:17 AM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
I am using 3 amps now for an 11.1 system and am looking forward to reducing my amps to 2. I would prefer to not need 5. If that was the care I would just go with 11 mono-blocks.... not going to happen.smile.gif
Dr_Mark is offline
Old 03-06-2013, 11:20 AM
Super Moderator
markrubin's Avatar
Liked: 2273
LOL
I tried monoblocks several years ago and had significant hum issues
My Outlaw is on the truck for delivery today: I am resting up getting ready to do some heavy lifting smile.gif
Old 03-06-2013, 11:51 AM
DHF
DHF's Avatar
iPad definitely has more "real estate" than the iPhone. I ahve no experience with Roomie - but on iRule - you can set up both an iPad and an iPhone. I am guessing a mini would be the same as the iPad...only smaller tongue.gif
iRule is really very customizable - and] if you have done any object oriented programming its pretty easy to pick up. I gotta give a hand to their user support - i get fast answers off their website - very very good support.
Attached are images from iPhone and iPad
DHF is offline
Old 03-06-2013, 12:08 PM
Troll
ufokillerz's Avatar
Liked: 47
LOL
wouldn't the humming issue be a problem with ground?
i've run many monoblocks at once, and never had a problem.
ufokillerz is offline
Old 03-06-2013, 12:23 PM
comfynumb's Avatar
Liked: 410
Hi, this is an app for iPhone/iPad?
comfynumb is offline
Old 03-06-2013, 12:28 PM
Point Source
beastaudio's Avatar
Liked: 2826
LOL
More than likely, the hum situation is still there, but the amps being used now are plugged in differently, or have lower gain, so the buzz/hum isn't as significant. I had pretty bad humm issues as well, but just looked at different ways to plug my amps in and all is well now smile.gif
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
Originally Posted by discodol View Post
Unfortunately this did not work for me.
Spent an hour on the phone with Comcast Paid Support, they set a static ip for the 8801 and opened ports on the router with no joy. Marantz Support says they do not have the capability to connect down to the 8801 so the only option at this point is to have the unit serviced. So back to my dealer it goes.
I hope the rest of the folks who cannot connect have better luck!
My dealer Sound Advice brought out a new AV8001 and it would not connect either. So they took the new unit next door and on my neighbor's network it had no trouble connecting and downloading the updated firmware which means my network is the issue.
I spent several hours on the phone with Comcast's fee based support group who really know their stuff. Unfortunately after connecting to my network and applying all their tricks and tweaks the Marantz unit would still not connect through my Comcast Arris TG852G Telephony/Modem/Wireless Router. The fix was to purchase my own wireless router and then have the Arris put in bridge mode so I could use my Lynksys EA6500. After having the Comcast Modem put in bridge mode I ran the Lynksys install software and within 10 minutes all my network devices including the AV8801 were connecting flawlessly with solid fast signals.
So the moral of the story is if you have a Comcast Telephony Wireless Modem Router combo don't waste you time if your Marantz won't connect on its own. Get your own router, put the Comcast piece in bridge mode and connect with ease.
David Ferebee
discodol is offline
Old 03-06-2013, 12:37 PM
comfynumb's Avatar
Liked: 410
Not sure if this helps. I have Comcast also, but I only use their modem and my own Netgear wifi router. I just upgraded routers to the newer WNDR4500 with good results.
Old 03-06-2013, 12:55 PM
Super Moderator
markrubin's Avatar
Liked: 2273
the Outlaw 7500 is in the house and temporally hooked up and working: I will give it some time to break in
this beast has all the weight up front behind the front panel: you can see two huge toroids from the top
speaker terminals are heavy duty
I am listening to it and already performed my 'stress test' which is operating at high volume with a known source (OPPO 105/ Dire Straits Brothers In Arms SACD via 7.1 analog) connected through Furman IT Reference 15i
so far so good...
I bought a Middle Atlantic RSH custom rack mount for it if I decide to keep it
Old 03-06-2013, 01:06 PM
Oppo Beta Group
RichB's Avatar
Quoted: 868 Post(s)
Liked: 565
W'ell try not to disturb you.
The Outlaw looks much better in person than it does on the web site.
- Rich
RichB is online now
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
