Marantz AV8801 Preamp/Processor Official Owner's thread - Page 141 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
Old 03-21-2013, 08:32 PM
Dave Vaughn's Avatar
Quoted: 895 Post(s)
Liked: 1346
Originally Posted by Bill222 View Post
What were you listening to? Blu-ray? SACD? How was the signal being sent across the HDMI wire? LPCM? Or Bitstream? My preference for a test for someone like you (someone how can hear the difference in "better imaging" - since I'm not sure what that sounds like. Seriously. I think I probably lost hearing at loud concerts in my youth... ) would be to try again on an Oppo-105 - and let the Oppo-105 do the decoding, so it's just sending multi-channel LPCM along the HDMI.
I want to ensure the wire is the only difference, and not a decoding setting. I have heard many differences between bitstream across HDMI and multi-channel LPCM across the very same HDMI - due to different decoding settings - and usually outright bugs - in various receivers.
Bill, it was done with a variety of concert Blu-ray discs with both players set to bitsream the audio. On one of the discs, I chose the PCM 5.1 track (Elton John concert) to eliminate the decoding from the equation and the Audioquest Carbon cable was the better sounding of the two.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
Old 03-21-2013, 08:40 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
PCM over HDMI is sent between video frames, that can cause additional jitter depending on the processor.
I have my Pronto programmed to switch between the HDMI, COAX, Oppo 7.1, and XLR outs.
They all sound different. Two are analog two a digital.
I'd love to know why. I use the 7.1 almost exclusively.
Perhaps others knew this, but I just discovered that the Bass setting LFE + Main sends bass to the sub in Direct and Pure Direct mode. This works on the HDMI, COAX, and XLR inputs. The analog 7.1 analog in's do not.
I will propose and LFE + Main setting to Oppo.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 03-21-2013, 09:05 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
I just placed an order today for my 8801 , I'm going to pair it with a D Sonic M2-2000-5
as for power cords I have settled on Shunyata Venom 3 & Diamondback
VRD Monoblocks Totaldac Twelve System Music Storage NAS SSD - Dedicated Router - (2) Paul Hynes SR-5 Linear PSU - Controlled by Ipad
Speakers :Joseph Perspective's Cables : Antipodes reference Speaker / IC's - Wywires Silver Juice II - Totaldac D1 USB
All Furutech GTX-D Gold Receptacles
a1usedcomp is offline
Old 03-21-2013, 09:10 PM
Geronimo.USMC's Avatar
Quoted: 133 Post(s)
Liked: 76
Originally Posted by Geronimo.USMC View Post
I will check this out when I get home. Did you update to the firmware released last night? Maybe the OP will update with the changelog for this firmware.
Just checked. I'm on the newest firmware. No problem here.
-HTPC/Gaming Rig: Silverstone CW02B, Core i7-5820K, ASUS X99-A, 16GB, EVGA GeForce GTX 1080 SC GAMING ACX 3.0 >Samsung 78JS9500
-Auzen HDMI XFi> 7.2 via Marantz AV8802A>Wyred4Sound monoblocks + Halo A51>Paradigm 100'sV5, ADP590'sV5, 690v5, 20v5's, + Dual SVS SB13 PLUS Subs
-40TBof Blu ray .iso's in a Synology DS1815+ controlled by a Dune Solo 4K
-Samsung UBD-K8500 4K UHD WCG HDR Player
Geronimo.USMC is offline
Old 03-21-2013, 09:11 PM
whoaru99's Avatar
Liked: 69
Have you tried anything like using a test tone through the player and simply measuring the voltage at a speaker terminal pair to see if they're all pushing the same level?
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 03-21-2013, 09:15 PM
whoaru99's Avatar
Liked: 69
Firmware updates....
IMO, never update firmware unless you first know what it does (or is supposed to do).
whoaru99 is offline
Old 03-21-2013, 10:37 PM
Bill222's Avatar
Thanks for checking.
Sigh... Now I should publish a complete list of settings so any interested party can do a true test. And I'm just too tired to do that tonight.
I noticed this problem from day one - I just never complained about it before. And it's remained consistent after all the firmware updates. I only see it on the web-interface. The web-interface always insists the Loudness Management is turned on - even though I definitely have it turned off.
Bill222 is offline
Old 03-21-2013, 10:43 PM
Bill222's Avatar
- Rich
Rich - you mentioned earlier that bass-management is NOT in effect over the 7.1 inputs - which makes perfect sense. But I believe some people have said that individual speaker trims would still be in effect over the 7.1 inputs. When I tried, individual speaker trims (such as - raising the center channel by 5 db) had no effect for sources played through the 7.1 inputs.
Have you (or has anyone) tried the manual speaker trims while using the 7.1 inputs (NOT the graphic equalizer, but the simple DB trim for each channel)? From my experiments, the 7.1 inputs completely ignored the manual speaker trim settings.
Bill222 is offline
Old 03-21-2013, 10:49 PM
Bill222's Avatar
- Rich
That makes sense. LFE+Main made more sense to me when someone explained *WHY* that option exists. It's intended for listening to stereo music - and using your system's sub(s) to support your stereo speakers. The mode was created to support sub-woofers when connected with RCA (or XLR) inputs instead of using speaker wire shared with the front speakers. (So maybe wiring your sub with speaker-wire shared with front speakers was the preferred method back then? I tried it once on a bookshelf-speaker system. But I blew the speakers during fireworks/explosions in a movie I was watching).
So the "LFE+Main" setting is for Stereo purists - not for movie listening. SO it makes perfect sense that it would work in both Direct and Pure Direct mode.
Bill222 is offline
Old 03-21-2013, 11:06 PM
Quoted: 133 Post(s)
Liked: 76
Did you try refreshing the page or even clearing your browser's cache?
Old 03-22-2013, 01:07 AM
audiofan1's Avatar
Quoted: 1651 Post(s)
Liked: 1669
- Rich
There is no bass from the sub in the LFE+main setting via the XLR inputs unless you use Auto as for Direct and Pure Direct the display does indicate if you have it set LFE+main but in actuality the sub is bypassed.
Also RichB you still find the 7.1 inputs better than the XLR for stereo from the 105 In my findings the XLR input offers the closest comparison to running the 105 direct to the amp and even more so when the 105 is set to output DSD the 7.1 for stereo ( using the dedicated stereo outs with the FR/FL option set in the 105) doesn't sound as refined and has less overall seperation of instruments and not as full sounding.
audiofan1 is offline
Old 03-22-2013, 01:10 AM
comfynumb's Avatar
Liked: 410
I'd like to make a suggestion for Comcast customers with seperate modems and routers. I recently purchased a new netgear gigabit wifi router as my old one was getting dated. While my son was online on his ps3 and I was streaming music and all our other devices were connected, his games started lagging. I suspected the dated modem and called Comcast about it, and they sent me a new one. To make a long story short, my speeds went from approx 17 down to nearly 25 down and all my slow connects on my AV gear and my sons ps3 lagging were gone. You might want to think about the age of your modem. The internet speeds increased over the 4 years I had mine, but it was never designed for 24 or 25 Mbps. Just a suggestion and everyone's experience might not be the same smile.gif
comfynumb is offline
Old 03-22-2013, 01:28 AM
audiofan1's Avatar
Liked: 1669
My speeds are 27mbps and I use the NG 4500 as well which modem did they send you?
Old 03-22-2013, 01:32 AM
comfynumb's Avatar
Liked: 410
I'll take a look when I get up in the morning and post the number. Both old and new are Arris modems. After I hooked up the new one it was a huge difference for me.
Old 03-22-2013, 01:36 AM
audiofan1's Avatar
Liked: 1669
I'll take a look when I get up in the morning and post the number. Both old and new are Arris modems. After the I hooked up the new one it was a huge difference for me.
Cool I have an Arris as well they updated my area a few years back and they said the modem needed replacing for there new setup as well as the HDDVR's.
Latters!
Old 03-22-2013, 03:49 AM
comfynumb's Avatar
Liked: 410
Latters!
I hear ya, maybe a new modem is in order. The old Arris model #TM602G/CT new Arris model #TM822G/CT. Now I want their newer DVR smile.gif
Old 03-22-2013, 05:41 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
LPCM over HDMI and COAX are digital but very different paths. HDMI must be buffered and re-clocked so the possibility exists.
I suppose I could ask my EE friends for assistance.
- Rich
RichB is online now
Old 03-22-2013, 07:53 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
From my testing, the 7.1 ins do not respond to trims nor the bass LFE + Main setting.
All other input do.
- Rich
RichB is online now
Old 03-22-2013, 07:55 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
With some subs, you can also send the Unbalanced (RCA) outs to the sub as well. My friend does this with his Martin Logan Grotto I sub. The sub has crossover and level settings to do the rest.
One thing, I would expect the LFE + Main is also in effect for movies too wink.gif
- Rich
RichB is online now
Old 03-22-2013, 08:03 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
I do not understand what you are saying.
I have the XLRs connected to the BDP-105 and I use the Analog select remote code that is programmed into my Pronto. When I do that, the LFE + Main and all other sound processing is available. That means the AV8801 is capable of digitizing the Balanced In.
I like both the XLR and 7.1 analog ins.
The XLR sounds brighter (with more high-end) and sometime more dynamic as a result.
The 7.1 fuller. Since the XLR provides much more processing opportunities and bass management they are also a great choice.
- Rich
RichB is online now
Old 03-22-2013, 09:19 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
Does anyone know if the AV8001 has ARC (Audio Rate Control) circuit?
- Alex
AlxG is offline
Old 03-22-2013, 09:26 AM
gurkey's Avatar
Quoted: 114 Post(s)
Liked: 89
... or ARC = Audio Return Channel (over HDMI) ?
gurkey is offline
Old 03-22-2013, 09:27 AM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
I have never seen any mention or indication that it does.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 03-22-2013, 09:29 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
- Rich
Rich,
You have an interesting sound observation of using XLR vs. 7.1 signal path. Since it's your own observation, therefore it's always right:)
In theory, I'd expect more dynamic response from pristine 7.1 analog path since the analog signal doesn't have to go though the extra ADC to DAC path. My receiver's 6.1 analog direct signal path give me much more dynamic response compared to CD input path which gets digitized.
- Alex
AlxG is offline
Old 03-22-2013, 09:35 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
Thanks Kal,
I was studying ARC (HDMI phase lock loop) circuit and find it very useful for clock recovery while minimizing jitter at bay. Do you feel AV8801 HDMI signal path is good enough for playing high res music, or do I have to rely on a much better Blu-Ray player via its analog path?
- Alex
AlxG is offline
Old 03-22-2013, 09:41 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
I was asking about Audio Rate Control. This Phase Lock Loop Frac N. synthesizer circuit idea came from digital radio world which help suppress ( minimize) transmission jitter components.
Please note, this is a vey complicated clock recovery circuit and can harm sound reproduction if it's not design properly.
- Alex
AlxG is offline
Old 03-22-2013, 10:09 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
Rich,
You also have an interesting expectation. Since it is your expectation, therefore it is always right smile.gif
Since the signal is manipulated in the XLR path, then anything is possible wink.gif
That said, I feel the 7.1 is the more pristine path so I use it.
However, many folks like to use their subs for 2 channel, in which case, the XLR's are the way to go.
- Rich
RichB is online now
Old 03-22-2013, 10:40 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
- Rich
Rich,
I don't like the sub in the loop when I listen to 2-channel music. In my opinion and my preference, I've always felt that bass and drums are better played back in their proper soundstage space without a sub. My speakers can easily go down to 25Hz based on my Near-Field and Far-Field measurements.
In my opinion, bi-amping is more important to me than bass management for 2-channel playback. My lower/bass section of the loudspeaker is measures at 2.3 Ohms from 60 Hz to around 150 Hz and almost look like a short-circuit with most amplifiers(:
- Alex
AlxG is offline
Old 03-22-2013, 10:53 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
- Rich
Rich,
Speaking about our 2-channel music priorities, how good is AV8801 (7.1-input) analog section compared to other dedicated 2-channel preamps?
My wife is objecting to addition equipment in our family room, so I'm looking for good multi-purpose pre-pro that I can live with for 2-channel playback...
- Alex
AlxG is offline
Old 03-22-2013, 10:58 AM
baranowski's Avatar
Quoted: 41 Post(s)
When connecting the oppo via the analog out to the av8801, you cannot utilize the room correction.... this this correct?
i ask because i am reading that some of you are using the room correction for movies and not for multi channel music.
if the room correction is used to make the sound better for the given "room" then wouldn't it ALSO benefit for multi channel music?
thanks,
Bill
baranowski is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
