Marantz AV8801 Preamp/Processor Official Owner's thread - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #4351 of 13490 Old 03-25-2013, 09:55 AM
comfynumb's Avatar
Liked: 410
Originally Posted by Darrel McBane View Post
I contacted Marantz support this morning about my firmware fail problem. There fix is to reset the network/processor with the following command. While unplugged press and hold on the front panel movie/music buttons while plugging in unit. This should reset the network and processor. Except on my unit of course. I still get a locked in standby mode condition. Now, I have to take to unit to a service repair place to resolve the problem. I suggested to the helpful assistant that Marantz allow users to download the firmware from their website to a usb device and update it that way. He said he would pass that along.
But they gave you no reason why it happened? Or why it happened to some and not others?
comfynumb is offline
post #4352 of 13490 Old 03-25-2013, 11:03 AM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
Just wondering how Airplay works (and sounds!) on the 8801. I have been using my Squeezebox Classic for streaming itunes - anybody compare this to Airplay in the 8801? One thing I'm trying to figure out: If I want to stream itunes from my PC to the AV8801 & use the Apple remote app on my Touch, what controls volume? Doesn't itunes have it's own volume? If so, is there a way to change it to "fixed" so I don't have both the itunes & 8801's volume controls active?
TL5 is online now
post #4353 of 13490 Old 03-25-2013, 01:16 PM
comfynumb's Avatar
Liked: 410
I can comment on AirPlay, it works and sounds great from both my iPhone and iPad. I never used squeezebox so I can't compare the two, but I can't imagine it would sound any better. There's a volume control right at the bottom of your device when in AirPlay mode.
post #4354 of 13490 Old 03-25-2013, 01:25 PM
Darrel McBane's Avatar
His only comment about the download problem was that their servers are heavily used and had caused some problems.
Now is Forever
Darrel McBane is offline
post #4355 of 13490 Old 03-25-2013, 01:32 PM
comfynumb's Avatar
Liked: 410
Damn, I guess I'll be waiting a couple of days after the release from now on. I hope the service works out for your 8801, good luck smile.gif
post #4356 of 13490 Old 03-25-2013, 02:50 PM
Point Source
beastaudio's Avatar
Quoted: 3516 Post(s)
Liked: 2834
I use it daily, and it works flawlessly. You are still going to have a seperate volume control inside airplay, but you should be able to adjust this to an appropriate level where your AVR's level will default to when selecting the airplay device. For instance, I have my airplay volume set at about halfway down, so if I turn on my AVR and then press play to have some tunes, it automatically changes the AVR to -47dB, and then I use the marantz app if I want to adjust it up or down from there. the -47dB is just a good average starting point smile.gif
beastaudio is online now
post #4357 of 13490 Old 03-25-2013, 03:18 PM
erhurd's Avatar
Location: Buckeye, Arizona (Phoenix); USA; Planet Earth
Quoted: 61 Post(s)
Liked: 52
That sounds like the smarter strategy...
Edwin R. Hurd
AVS Forums Lurker-In-Training!
My Tight-space A/V Setup
erhurd is offline
post #4358 of 13490 Old 03-25-2013, 03:50 PM
Quoted: 1394 Post(s)
Liked: 588
Yeah.....I'm going to have to have some assurance that I'm not going to brick my 8801 when I do a firmware update.
In any event, I didn't see anything in the change log that would apply to me.
JimP is online now
post #4359 of 13490 Old 03-25-2013, 04:57 PM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
Thanks for the info. So are you saying whatever the volume is set at it iTunes (in your example -47db) that's the starting point when you first activate airplay, and the volume on the Marantz takes it from there? I'm just trying to determine if there are in fact two volume controls active at one time - the one in the Marantz and the level control in iTunes. That's something I don't want - especially if the iTunes volume control is digital.
TL5 is online now
post #4360 of 13490 Old 03-25-2013, 06:33 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I hate to say it but that is a good gameplan. I have since received 3 or 4 emails from my website from others who have had their 8801s go into a coma from attempting this update. I am going with the "Only fools rush in where angels fear to tread" attitude for now on with updates for my 8801.
I wish the others a speedy recover for their 8801. Hang in there. At least they should be 100% covered under warranty (3 years)...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
post #4361 of 13490 Old 03-25-2013, 07:01 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Glad to say mine made the update without issue.
GetGray is offline
post #4362 of 13490 Old 03-25-2013, 07:02 PM
Dave Vaughn's Avatar
Quoted: 895 Post(s)
Liked: 1346
I was the first to update to this firmware when I was reviewing it. Thank God it was emailed to me!
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #4363 of 13490 Old 03-25-2013, 07:37 PM
Quoted: 895 Post(s)
Liked: 1346
I'm thinking about purchasing one of these (http://www.coolerguys.com/ccstandktc.html) to sit on top of the 8801. I had to move mine recently to a shelf that's a little less ventilated than before and I've noticed it's getting about 10 degrees warmer (108 degrees) than in its old spot. Anyone have experience with this stuff?
post #4364 of 13490 Old 03-25-2013, 07:55 PM
Stewy04's Avatar
Originally Posted by buckley44 View Post
Last night i turned on my Marantz to watch a movie and had a blank screen, so i thought maybe it was my blu ray player so i switched inputs and still had no screen,I had watched something 2 hrs prior so i know that i had not made any changes.By the way i have not done the latest upgrade as of yet,
eventually i had to unplug the Marantz and reboot and then everything was up and running again,strange but i'm glad everything seems to be fine for now, i'm a little scared to do the update today because tonight is out night to watch all of are shows with the wife eek.gif better play it safe and shoot for Monday during the day.
I have had a similar experience. Only I had a green screen not a blank one. I switch over between sources (first PS3 then Satelite then Internet radio and lastly to my iPod) and nothing changed. Just a green screen. I turned the unit off and then back on and all was good.
buckley44 likes this.
Stewy04 is offline
post #4365 of 13490 Old 03-25-2013, 08:13 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I've always used these: http://www.amazon.com/Antec-Profile-Component-Theater-Products/dp/B000QJ4ZE2/ref=sr_1_1?ie=UTF8&qid=1364263949&sr=8-1&keywords=antec+component+cooler
They're on sale too! Usually 20.00 more or so.
post #4366 of 13490 Old 03-25-2013, 08:58 PM
Bill222's Avatar
I don't like the noise level they're listing. I've bought fans from them before - great fans, great service. But that device shows a 20.4 dB level just to move 46CFM of air. When I tried fans with dBA ratings in the 20s, maybe even in the teens, they were too loud for my tastes. I used a do-it-yourself approach with brackets bought at my local hardware store and attached those fans to an open-air rack to move air across the heat-sinks of my amps. Since this open-air rack is in my living room with the TV, I'm very sensitive to any sound made by fans.
Years ago when I bought fans from them a single 120mm fan could move 33.5CFM of air at only 8.7 dBA. That fan was the Scythe S-FLEX SFF21D 120mm Case Fan. Unfortunately, it looks like that fan has been discontinued. I would look for a fan with similar specs (under 10 dbA, over 30 CFM of air movement) - and look at adding those fans to a cooling stand. They sell those ready-for-fans cooling stands too - http://www.coolerguys.com/ccstand.html
Bill222 is offline
post #4367 of 13490 Old 03-25-2013, 09:29 PM
Quoted: 895 Post(s)
Liked: 1346
Thanks Bill. I'm worried about noise as well.
post #4368 of 13490 Old 03-25-2013, 10:05 PM
Bill222's Avatar
You might try adding these fans to the ready-for-fans cooler case.
Noctua 120mm NF-S12B ULN 120mm Fan 700/500RPM - http://www.coolerguys.com/840556089810.html
At 700 rpm, they move 33.5 CFM and are only making 6.8 dBA of noise. That's the quietest I can find. I've never tried them personally, but the specs look good.
Here's a list of 120mm fans that helped me zero in on that particular fan. The list can be sorted by noise - just click on the "Noise (dBA)" column header. - http://www.quietpc.com/120mmfans
Bill222 is offline
post #4369 of 13490 Old 03-25-2013, 10:10 PM
Quoted: 895 Post(s)
Liked: 1346
Thanks Bill. I'll give it a look!
post #4370 of 13490 Old 03-25-2013, 10:55 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
We can do that!?! Sweet mother of pearl...I need to try this!
zuluwalker is offline
post #4371 of 13490 Old 03-25-2013, 11:11 PM
Woof Woof's Avatar
Quoted: 128 Post(s)
Liked: 79
From what I can tell using Audirvana Plus to Airplay, the Marantz like most AP devices are limited to 44.1kHz. AudirvanaPlus sends out using 24/44.1
AudirvanaPlus also sees that as a DAC that has a volume control. Adjusting the volume knob in A+ also adjusts the Marantz volume setting as seen on the front display.
Woof Woof is online now
post #4372 of 13490 Old 03-26-2013, 01:10 AM
h2the's Avatar
hello all,
need a little help please... where can i get a good deal on this processor? i live in los angeles.
thanks in advance
Xbox Live: h2tHe7
h2the is offline
post #4373 of 13490 Old 03-26-2013, 03:17 AM
pinoy ako's Avatar
Liked: 26
Does anyone paired this with new Marantz NA-11S1 network audio player?
Thanks a lot.
Anthem Statements | Kef Reference 205/2 | Kef LS50 | PSA Triple XS30SE | Panasonic AE8000 | Dalite 110" PJ Screen | CAPS V3 Zuma | Synology DS1512+ (15TB) | Cambridge Azur 651BD
pinoy ako is offline
post #4374 of 13490 Old 03-26-2013, 04:37 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
I have used those fans in PC's and they are very good.
Also, you can use a fan speed controller to adjust them.
If they can run at 5V you could power them off a USB port as well.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #4375 of 13490 Old 03-26-2013, 04:58 AM
comfynumb's Avatar
Liked: 410
- Rich
Rich I have two fans running, one blowing on the 8801 and one on my amp. (I noticed the back of the Sunfire hot to the touch) I've heard others say a fan blowing on rather than pulling air through AV equipment can heat up the boards. What are your thoughts on this?
post #4376 of 13490 Old 03-26-2013, 05:25 AM
gurkey's Avatar
Quoted: 114 Post(s)
Liked: 89
You should always follow the natural flow of hot air and don't work against it. This means, instead of blowing into it (against the natural flow) sucking out the air thus supporting that flow.
If you blow the hot air into the unit you are distributing the temperature rise even further into places where it didn't happen before.
gurkey is offline
post #4377 of 13490 Old 03-26-2013, 05:37 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
Wow, A Sunfire gets hot. I have never had more than warm, but mine was in an open credenza.
Also, I find it is less dusty to blow away from the equipment.
- Rich
RichB is online now
post #4378 of 13490 Old 03-26-2013, 05:52 AM
baranowski's Avatar
Quoted: 41 Post(s)
Ups tracking number states that my av8801 is "out for delivery" looks like i will be headed home and get the elite out and prep for the new processor!
baranowski is offline
post #4379 of 13490 Old 03-26-2013, 05:54 AM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
Im getting mine in the morning cant wait Congrats
VRD Monoblocks Totaldac Twelve System Music Storage NAS SSD - Dedicated Router - (2) Paul Hynes SR-5 Linear PSU - Controlled by Ipad
Speakers :Joseph Perspective's Cables : Antipodes reference Speaker / IC's - Wywires Silver Juice II - Totaldac D1 USB
All Furutech GTX-D Gold Receptacles
a1usedcomp is online now
post #4380 of 13490 Old 03-26-2013, 05:55 AM
buckley44's Avatar
Quoted: 56 Post(s)
Liked: 33
I bought a single one to sit on top of my amp and Marantz,cheap for both of them and they have the variable speed on them so i turn them down pretty low and they do move the air away from the equipment, if you have them on full blast they do have some noise to them as far as the blower itself. so like i said i leave my on low and it does the job and a very cheap alternative.
buckley44 is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
