Marantz AV8801 Preamp/Processor Official Owner's thread - Page 176 - AVS Forum | Home Theater Discussions And Reviews
 294Likes
post #5251 of 13537 Old 04-26-2013, 09:46 AM
Kevin C Brown's Avatar
Quoted: 12 Post(s)
Liked: 27
Originally Posted by jam88 View Post
The AV8801 has at least one HDMI handshaking issue that I've experienced that seems to be caused by the EDID negotiation. See my post recounting my experience although I don't think my workaround would be desirable in your situation even if it were to work.
I think that in your situation, you would be better served with a USB based firmware update. Please read this post by jdsmoothie on how you can obtain the firmware file and USB update procedure from him. Best of luck.
I wonder of that's what I'm seeing. But in my case, even with no source hooked up, I can't get anything from the 8801 to my plasma. I did try hooking up the BDP-95 to the 8801, and still no joy. But the 95 worked fine through the 7005. (But I send 1080i from the 95 too!)
Yeah, I'll try the USB update. Thanks. (Yeah, was waiting on the Outlaw, oh well ... wink.gif )
My dealer also suggested "borrowing" a cheap display (or PC monitor with an HDMI input) and trying that just to make sure the 8801's HDMI out worked at all.)
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #5252 of 13537 Old 04-26-2013, 10:08 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1264 Post(s)
Liked: 848
Originally Posted by Stewy04 View Post
I did not know that was even possible!
Any pdf can be saved to iBooks using the arrow ithingy.
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is offline
post #5253 of 13537 Old 04-26-2013, 11:17 AM
jam88's Avatar
I thought of that and forgot to mention that you hook up a PC monitor through HDMI to test it. You may want to open a support ticket with Marantz.
jam88 is offline
post #5254 of 13537 Old 04-26-2013, 11:49 AM
massprince's Avatar
8801and oppo 105 problems!
I have a Mac connected to oppo 105 via USB Dac and then oppo connected to B&K reference 70. Using same connection sequence to 8801, I am not getting any subwoofer output. I disabled audessey and used direct on assigned input setting with no success. I also don't want to use airplay, since reproduction on AirPlay sucks. Any suggestions to make subwoofer work
massprince is offline
post #5255 of 13537 Old 04-26-2013, 11:52 AM
massprince's Avatar
Oppo was connected to B&K via XLR cable and also using same connection to marantz
post #5256 of 13537 Old 04-26-2013, 11:57 AM
Quoted: 12 Post(s)
Liked: 27
I emailed Marantz this morning with the particulars. Will be interesting to see what they say. I also have another possible solution if I can't ever fix the 8801's HDMI output to my plasma. From the player:
a) HDMI 1 to the display for video
b) HDMI 2 to the 8801 for audio
I'm checking in the BDP-95 thread if this is doable. (I.e., are both outputs active at the same time?)
Still would need a monitor to set the 8801 up, but I could get something cheap/small for that and just use it when I need it.
post #5257 of 13537 Old 04-26-2013, 12:46 PM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
Kevin,
Not sure if you can feed AV8801 > Panasonic TV via composit cable to help you setup the AV8801 video configuration. Perhaps the HDMI signal path has not been configured yet.
- Alex
AlxG is offline
post #5258 of 13537 Old 04-26-2013, 12:49 PM
audiofan1's Avatar
Quoted: 1820 Post(s)
Liked: 1865
Yes both outputs are active ! I use this configuration with the 105 and 8801 (hdmi 1 to Tv and hdmi 2 to the 8801). And you don't need a monitor for the 8801's setup , just use the flip down panel as it displays all the 8801's functions, I even use it for Audyssey setup so as to not have any unnecessary noise from my display.
audiofan1 is online now
post #5259 of 13537 Old 04-26-2013, 02:27 PM
Quoted: 12 Post(s)
Liked: 27
Originally Posted by AlxG View Post
Kevin,
Not sure if you can feed AV8801 > Panasonic TV via composite cable to help you setup the AV8801 video configuration. Perhaps the HDMI signal path has not been configured yet.
Dang, I didn't even think it had one of those, but you're right. The 8801 does have a yellow RCA monitor output. So at least in that case, if I can't solve the HDMI problem, I wouldn't need to buy an additional little display to use HDMI when I wanted to do set up stuff.
Theoretically, I know I could use the front panel display smile.gif, but I think it would be easier to use that display after I've already become familiar with the regular display output.
The good thing is, if I can't get the problem addressed, this isn't necessarily a show stopper either. Luckily, I don't need the video processing/switching capability the 8801 has.
post #5260 of 13537 Old 04-26-2013, 07:30 PM
Mad Norseman's Avatar
Liked: 102
Sorry if this question has been asked before, but David Vaughn said in his wonderful Home Theater Magaine review on the Marantz AV8801:
"The video processing can be bypassed by source, so if you want the 1080p/24 signal from your Blu-ray player to be unprocessed but your cable/satellite to be scaled to 1080p, you can customize this in the setup menu".
That's exactly what I want to do - set up the Blu-ray source input to 'pass through' unscathed, while the CBL/Sat source is upconverted from 1080i to 1080p before it reaches my Panny - because I suspect the Marantz will do a better job of that upconversion(?).
But for the life of me, I just can't see how to set it up that way by reading (and re-reading, and re-reading...) the manual, or even just playing around in the menu!
It appears (to me) that its a 'global' setting that does not allow individual selection of how each source's input is treated...but David indicates otherwise.
I'm sure I'm missing something, so where can I find the correct instructions in the manual, or can someone here relate those steps to me please?
Thanks in advance!
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #5261 of 13537 Old 04-26-2013, 10:20 PM
jdsmoothie's Avatar
Quoted: 15006 Post(s)
Liked: 7233
You can set the "i/p Scaler" setting (p. 129 OM) to OFF.
jdsmoothie is offline
post #5262 of 13537 Old 04-27-2013, 02:41 AM
ohyeah32's Avatar
Quoted: 63 Post(s)
Liked: 36
I'm starting to warm up to the 8801 a bit more now. Last night I watched the 3D Blu-ray of Jurassic Park, and the 7.1 DTS-HD MA sounded phenomenal! The sounds were all around the room, and while very dynamic, the sound was easy on the ears.smile.gif
The immersive sound, combined with a gorgeous picture, made for a very impressive and memorable viewing and listening experience.
The more I am using the 8801 the more I'm enjoying it.
ohyeah32 is offline
post #5263 of 13537 Old 04-27-2013, 05:47 AM
comfynumb's Avatar
Liked: 411
You sound like I did when I first set my 8801 up and I think it's because I was used to the sound of my old pre/pro. Your right about the 8801 for movies it really makes them enjoyable and I haven't watched this many movies in a long time smile.gif glad to hesr your enjoying it.
comfynumb is offline
post #5264 of 13537 Old 04-27-2013, 07:04 AM
jmschnur's Avatar
Are the xlr and RCA outputs both live? I will want to use three or four different amps to implement 9.2 or 11.2. Two are XLR and the other two are RCA.
Both subs are XLR .
jmschnur is offline
post #5265 of 13537 Old 04-27-2013, 07:13 AM
krellcoda's Avatar
I've had issue getting video from the Oppo 95 to 8801 but after trying 3 different HDMI cables, I found one that works (hdmi 1.4). It seems like the 8801 is very finicky on the type of hdmi cable connecting to it.
krellcoda is offline
post #5266 of 13537 Old 04-27-2013, 07:22 AM
comfynumb's Avatar
Liked: 411
That's strange because I have 3 different HDMI cables going in and out of the 8801, including a $10 one I bought from Wallyworld and haven't had any connectivity or quality issues.
post #5267 of 13537 Old 04-27-2013, 08:01 AM
satfam's Avatar
Quoted: 44 Post(s)
Liked: 56
I use Monoprice cables and haven't had any problems.
H/T: Marantz 7702MK II, MM8077, MM7055, Triton 2s, SCXL, SL/SR-S50s, BL/BR-S50s, H/W-4 Sat3s, dual SB16 Ultras, Sony HW50ES, Dalite 110", Tivo PXL, PS-3, Apple TV, GIK Acoustics treatments
Gameroom: Denon AVR-X4300H, NHT S2,SC, 4 NHT ceiling speakers, 2 Velo SPL-1000R, Sony XBR65X850C, PS3, 4, Sony FMP-X10, Samsung K8500
satfam is offline
post #5268 of 13537 Old 04-27-2013, 08:43 AM
Dave Vaughn's Avatar
Quoted: 1054 Post(s)
Liked: 1528
Thanks in advance!
Yep.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #5269 of 13537 Old 04-27-2013, 09:05 AM
Liked: 102
Originally Posted by Dave Vaughn View Post
Yep.
Page 129 reads under ipscaler:
i/p Scaler:
Convert the input source resolution to the resolution set.
CBL/SAT - (set to "On"?)
Blu-ray - (set to "Off"?)
(Leave all others at the default setting?)
Analog : Use i/p scaler function for analog video signal:
Analog & HDMI : Use i/p scaler function for analog and HDMI video signal, (select THIS one?).
HDMI : Use i/p scaler function for HDMI video signal, (Or select THIS one?).
Off : Do not use i/p scaler function.
• “Analog & HDMI” can be set for input sources for which an HDMI input
connector is assigned.
• Which items can be set depend on the input source assigned to each
input connector.
I'm sure I just missed something the first time, but I'll try it again tonight...thanks so much for everyone's quick reply!
(I'll report back on my sucess, or failure! wink.gif)
post #5270 of 13537 Old 04-27-2013, 10:35 AM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
What HDMI are you using right now?
It would be nice or get a running list of reasonably priced HDMI cables.
- Alex
AlxG is offline
post #5271 of 13537 Old 04-27-2013, 01:55 PM
orangeblast's Avatar
Hello,
When it comes to the Oppo 103 acting as an external video processor, by using it's HDMI inputs, how would it compare to the video processing on the Marantz 8801 pre/pro? I like the idea of the Oppo doing some video processing, but if the Martanz 8801 has equal or superior video processing, then I may just go with the Sony S790 instead.
Thoughts?
orangeblast is offline
post #5272 of 13537 Old 04-27-2013, 02:55 PM
Quoted: 12 Post(s)
Liked: 27
I'm also using Monoprice HDMI cables. Ok, got one these yesterday for testing:
http://t.staples.com/skava/static/product.html?type=StaplesProduct&input=%7B%22url%22%3A%5B%22http%3A%2F%2Fwww.staples.com%2FLenovo-LI2321s-23-inch-Wide-LED-Monitor%2Fproduct_140303%3Ft%3Dyes%22%5D%7D&t=yes
But it doesn't work either ... But the AV7005 does. So my dealer does think it has a bad HDMI output.
I got the f/w from jdsmoothie (thanks! smile.gif ). But I can't get it to update. I can see the 8801 access the flashndrive, but never goes into the update procedure. Just the firmwares folder on the drive. Weird. So I still plan to try the composite output, and maybe try to update the f/w that way just to try.
My dealer is truly being very awesome about this whole thing. He has another unit ready to be sent to me on Mon.
post #5273 of 13537 Old 04-27-2013, 07:29 PM
nezff's Avatar
Quoted: 155 Post(s)
Liked: 75
I think I'm liking my purchase of this unit even more. Seeing too many issues with the other camp.
nezff is offline
post #5274 of 13537 Old 04-27-2013, 10:12 PM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
Installed Mogami 2549 XLR and 2930 Y-splitter cables and at first found them too revealing with thin midrange and lacking dynamics. Once I ran the AV8801 setup and specified XLR output paths, the magic has returned plus lots of top end clarity and air. One thing I've noticed is a relay click when I selected XLR instead of RCA signal path.
- Alex
AlxG is offline
post #5275 of 13537 Old 04-27-2013, 10:39 PM
WestCoastD's Avatar
Quoted: 285 Post(s)
Liked: 106
compared to a brand of XLR interconnects use previously on the AV8801?
WestCoastD is offline
post #5276 of 13537 Old 04-28-2013, 12:17 AM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
I never did this....specified xlr in the setup menu. It just worked. Does going through the setup menu do anything? I also heard the relay clicks....
mookie b is offline
post #5277 of 13537 Old 04-28-2013, 04:04 AM
dreyfusfabrini's Avatar
Greetings to all of you!
I currently own a Marantz AV7005 with an Anthem MCA50. I'm considering the possibility of selling the AV7005 in order to buy the AV8801 (and I'll certainly do it!). Do you think it's worthy selling the Anthem MCA50 as well, and get the Marantz amp, the MM8077?
I have 5 speakers, Monitor Audio GS60 as front, GSLCR in the center and GSFX as surrounds.
Dreyfus
dreyfusfabrini is offline
post #5278 of 13537 Old 04-28-2013, 04:35 AM
comfynumb's Avatar
Liked: 411
Dreyfus
Hi, personally I would never give up your Anthem amp, it has more power than the Marantz 8077 and by all accounts a great amp. Why don't you just add a 2 channel amp if you want more speakers?
dreyfusfabrini likes this.
post #5279 of 13537 Old 04-28-2013, 06:05 AM
avman09's Avatar
Dreyfus
If you think the Marantz looks nicer and that's important to you then it is worth it otherwise no, you will end up with a little bit less power and money for no other reasons.
avman09 is offline
post #5280 of 13537 Old 04-28-2013, 06:42 AM
jrhooper1963's Avatar
Quoted: 99 Post(s)
Liked: 38
Dreyfus
Don't do it !! The Anthem amp is a better amp .
jrhooper1963 is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
