Marantz AV8801 Preamp/Processor Official Owner's thread - Page 178 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #5311 of 13490 Old 04-29-2013, 12:29 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
Originally Posted by Mad Norseman View Post
Hi DMark1,
My experiance with the AV8801's HDMI switching has been good - its never taken more than about 2 seconds to lock onto any input source switch.
(But oddly, my old Yamaha RX-V1900 AVR was twice as fast! - Go figure).
Bottom line is though that its a relatively fast, and more importantly - it establishes a solid HDMI connection in every instance.
I have had good experiences as well, but with HDMI it takes two to tango.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #5312 of 13490 Old 04-29-2013, 12:57 PM
Point Source
beastaudio's Avatar
Quoted: 3510 Post(s)
Liked: 2831
Originally Posted by comfynumb View Post
Audyssey questions. I only ran it one time in my life and it was on the 8801. I believe it could not adjust the bass properly because of my poor room and just sent it all to my sub. It's very open and the front right speaker is not the same distance from the side wall as the left main. It is also placed near a hallway so there isn't much of a wall behind it. This can't be helped for now, so instead of crossing my mains in the 60-80Hz range like my other speakers it crossed them at 250Hz. They are Revel F52's so they are a pretty capable speaker. Has anyone else ran into this? Also it had my surround levels at -5 db, I like my music loud on occasions and they have equal power going to them as my fronts and center. So if I leave them at -5 db the circuit protection in them will go off or I'll bottom the woofers out. Does anyone else turn their surround levels down after Audyssey? I didn't really care for Audyssey after I ran it but now I do and really like it's equalizing abilities. Well I do after I readjusted the crossover setting for my fronts and the surround levels.
Listening to MultiCh stereo? Only a good idea when your surrounds are timbre matched and in most cases just as capable as your mains, which is very rarely the case. I always end up turning my surrounds up just a tad after audyssey to accentuate the surround effect. If you use Audyssey's dynamic EQ, then your surrounds are already boosted by default unless you are listening at reference (0.0).
beastaudio is online now
post #5313 of 13490 Old 04-29-2013, 01:01 PM
Point Source
beastaudio's Avatar
Liked: 2831
I have a quick one for you all, has anyone noticed any issues with streaming music via the "network" feature? I have my Itunes library running and the network feature/airplay is how I stream music to my system, but sometimes I feel like I am losing fidelity and extension doing it this way. Does anyone have a better method to hook a hard drive or laptop directly to your system and get better quality sound out of it? Just interested what others might be doing. Am I really even losing fidelity this way in the first place?
post #5314 of 13490 Old 04-29-2013, 01:06 PM
jrhooper1963's Avatar
Quoted: 56 Post(s)
Liked: 36
I am probably going to be upgrading to this processor. I currently have the AV7005 in my system, and have absolutely no complaints with it. I just can't stand to read anymore about the 8801. I probably should have picked one up in the first place. LOL
I am just wondering if the 8801 is similar to the 7005, as far as setting it up. I used the Outlaw Guide to the 7005. It was a wonderful alternative to the Marantz manual. I would hate to get this thing and solely be at the mercy of the Marantz manual. LOL Hopefully someone can chime in on this.
THANKS !!
jrhooper1963 is online now
post #5315 of 13490 Old 04-29-2013, 01:09 PM
comfynumb's Avatar
Liked: 410
Yeah I pretty much listen to all of my music in MultiCh stereo, it's just that my surrounds are no where near as capable as my mains and I have a bad habit of turning the volume up pretty far for brief periods.
comfynumb is offline
post #5316 of 13490 Old 04-29-2013, 01:20 PM
Point Source
beastaudio's Avatar
Liked: 2831
Have you given pLIIx music DTS:NEO music a shot? It still gives you a good "front stage" sound while creating ambient sounds around you! I like to crank it to but as we have discussed before, I am strictly 2ch listening for music. Just like a real concert...
post #5317 of 13490 Old 04-29-2013, 01:53 PM
audiofan1's Avatar
Quoted: 1651 Post(s)
Liked: 1669
Originally Posted by thrang View Post
Had a chance to demo the McIntosh MX-151 in my home for a week, and was unexpectedly very impressed, especially with Room Perfect. The 8801 is superb, and has benefits over the 151 in certain areas...but they are different animals.
Wow ! man that sounds like a golden opportunity and after checking out the spec's , it sounds like it was designed with Audiophiles in mind and I rather like the minimalist approach with no unnecessary duplicated functions. I look forward to your impressions once you've had time to put it through its paces!
audiofan1 is online now
post #5318 of 13490 Old 04-29-2013, 02:20 PM
comfynumb's Avatar
Liked: 410
Well I know you don't have those speakers and all those subs and not have a lead foot err lead hand biggrin.gif
I'm going to give that a good listen right now beast. And run Audyssey again when I get a chance that crossover settings was bewildering. Will it save my settings from a month ago also or does it wipe them out and start over?
post #5319 of 13490 Old 04-29-2013, 02:35 PM
Point Source
beastaudio's Avatar
Liked: 2831
You can always default back to what audyssey read the last time it swept and start your tweaking over again. Biggest thing to make sure if is that you set your XO points where you feel appropriate, and then make sure the distances that Aud reads all seem appropriate. It is nice to default back as sometimes I get to overzealous and just tap that button to return to "normal" and start over again smile.gif
EDIT:
I see you meant save your tweaks post audyssey now and go back them if you want. Unfortunately no, but a pen and paper and writing down the settings will get you right back if you go to messing around more. smile.gif
post #5320 of 13490 Old 04-29-2013, 02:46 PM
Selden Ball's Avatar
Quoted: 3070 Post(s)
Liked: 1501
You can save the 8801's internal settings to a PC and restore them later. In principle you could save the settings for a variety of calibrations and restore the ones you like the most. Of course, if you've changed the room's furnishings since the backup was saved, the results won't be exactly what you want.
Selden
Selden Ball is online now
post #5321 of 13490 Old 04-29-2013, 02:59 PM
Point Source
beastaudio's Avatar
Liked: 2831
Have you actually measured differences in your room after changing furnishings? Unless you are doing some serious remodelling, the difference is quite subtle, assuming the primary listening positions is not adjusted in the move....
post #5322 of 13490 Old 04-29-2013, 03:19 PM
comfynumb's Avatar
Liked: 410
EDIT:
I'm assuming Audyssey will come up with different settings each time you run it. So it doesn't store each run separately so you can back to it's previous settings? A pen and paper would work but there's no way to save the dynamic EQ settings. That's where I see the biggest differences with Audyssey.
post #5323 of 13490 Old 04-29-2013, 03:29 PM
comfynumb's Avatar
Liked: 410
You mean with a meter?
post #5324 of 13490 Old 04-29-2013, 03:31 PM
comfynumb's Avatar
Liked: 410
I can save all of Audyssey's settings that way?
post #5325 of 13490 Old 04-29-2013, 04:18 PM
jmschnur's Avatar
Before deciding on the 8801 or to wait for Integra's 80.5 I downloaded the manual. It seems rather hard to use. Is this the perception of those who have the unit now?
jmschnur is offline
post #5326 of 13490 Old 04-29-2013, 04:55 PM
comfynumb's Avatar
Liked: 410
My opinion is that's it's not that hard to use. I was used to my Sunfire pre/pro that didn't have the network capabilities, but I had this up and sounding decent in about an hour and a half, setting everything manually, and I'm a novice. There is a lot to it but if you run into snags the guys on here are great. There are a couple of guys on here coming from the Integra, maybe they'll chime in. I have zero regrets, it's an amazing pre/pro. Just do it biggrin.gif
post #5327 of 13490 Old 04-29-2013, 05:00 PM
Mad Norseman's Avatar
Liked: 101
That's very interesting, and prettty much the opposite of whay Audyssey XT32 did for my set up.
It set mt front L&R at full range, and each at -8db.
And set my surrounds at full range(!?), and -3db(!).
Then it set my center at a 40Hz crossover, and -4.5db.
What that did is make my surrounds very overpowering - I had to drop them to -5.0db with an 80Hz crossover to get a more balanced result.
Also boosted my fronts to -6.0 db, and a 40Hz crossover, (I might try 60Hz later...).
And boosted my center to -4.0db, and set the crossover at 80Hz.
All pretty much the reverse of your experiance.
My room is tall w/sloped ceiling, 19' x 26', w/few specific acoustic treatments and is open on one end, and above to the front half way up.
If I were you, I'd re-run it, make sure its dead-quiet, and then make manual adjustments (based upon what you KNOW about your speakers capabilities) ,until it sounds good to you.
So much bass sent to your subs is odd too, because with those Revels that shouldn't have happend. Maybe there was some 'noise pollution' while you ran it?
Lastly, I wouldn't fool around with the frequency adjustments Audyssey makes, as I think those are pretty accurate.
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #5328 of 13490 Old 04-29-2013, 05:06 PM
comfynumb's Avatar
Liked: 410
Hi, yeah you definitely had the opposite happen when you ran Audyssey. I'm almost afraid to rerun it and lose my settings. I can write the distances and crossovers etc down. But won't I lose those frequency settings and my dynamic EQ settings? Also I've heard some people say that they only run it from 3 mic positions, I wonder if this would work for me.
post #5329 of 13490 Old 04-29-2013, 05:18 PM
jdsmoothie's Avatar
Quoted: 12138 Post(s)
Liked: 5527
jdsmoothie is online now
post #5330 of 13490 Old 04-29-2013, 05:19 PM
Liked: 101
comfynumb typed:
"Hi, yeah you definitely had the opposite happen when you ran Audyssey. I'm almost afraid to rerun it and lose my settings. I can write the distances and crossovers etc down. But won't I lose those frequency settings and my dynamic EQ settings?"
Yes, but so what?
Just run it again, and you'll get all new settings anyway (some only very subtle differences, some - hopefully based on what you're describing - are more major and appropreate!).
Another approach would be to just go into the menu and reset everything to the factory defaults and start over from scratch.
Start with studying your speaker's specs and figure out where the crossovers SHOULD be.
For example, if Revel says they're good down to '30Hz, at -3db', then a good rule of thumb is to set the crossover for them at 20Hz to 30Hz ABOVE that (i.e. @ a 60Hz crossover).
That allows for a smooth roll off.
Re-run Audyssey XT32 & SubEQ (make sure your sub levels are at 75db +/- 1db or so) by using the built in level meter & mic.
Keep things VERY quiet, and then re-run the room correction software.
From you original experiance it should come up with something very different (and better).
Then 'tweak' your levels as you see fit.
Failing all of that, call Marantz's phone help (they're very helpful) and put the questions to them.
Good luck!
post #5331 of 13490 Old 04-29-2013, 05:22 PM
jdsmoothie's Avatar
Liked: 5527
EDIT:
post #5332 of 13490 Old 04-29-2013, 05:36 PM
comfynumb's Avatar
Liked: 410
Originally Posted by jdsmoothie View Post
That definitely works I just tried it. So if I run it again and don't like the settings the restore will put the prior settings back?
post #5333 of 13490 Old 04-29-2013, 05:41 PM
comfynumb's Avatar
Liked: 410
comfynumb typed:
Yes, but so what?
Good luck!
I guess my lack of Audyssey experience makes me second guess myself. I mean to me it sounds really good the way it is. But I will run it again, thanks for the help smile.gif
post #5334 of 13490 Old 04-29-2013, 05:44 PM
jdsmoothie's Avatar
Liked: 5527
post #5335 of 13490 Old 04-29-2013, 05:47 PM
Point Source
beastaudio's Avatar
Liked: 2831
EDIT:
It might. You can't go back to the previous Aud. settings unless you go with the PC method mentioned earlier after you run it again.
Yes. or Omnimic or REW if you want to really see what is going on. Still the best investment I have ever made for my theater.
EDIT:
Mentioned that earlier JD, it will restore your audyssey results but there is no way really to save your tweaks AFTER Aud. and save them proper that I know of.
A good plan for sure. Room gain will give you some additional gain down low to extend that f3, but choose to use it or not, the natural rolloff of the speaker is not a bad place to start, and bumping that up a few points is just going to preserve what you have and not ask more of the speaker than it should be doing, especially if Aud. is boosting below the f3 point...
post #5336 of 13490 Old 04-29-2013, 05:47 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
Originally Posted by erhurd View Post
Two thumbs up!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #5337 of 13490 Old 04-29-2013, 05:48 PM
comfynumb's Avatar
Liked: 410
That is comforting, and although I had it up and sounding decent in a short time the tweaks over a couple of months time took lots of patience. it is too bad that you can't save multiple Audyssey runs for comparison. Thanks for the tips again smile.gif
post #5338 of 13490 Old 04-29-2013, 05:58 PM
jdsmoothie's Avatar
Liked: 5527
Ah but you can ... you simply have to rename the file once saved to your PC. smile.gif
post #5339 of 13490 Old 04-29-2013, 06:05 PM
comfynumb's Avatar
Liked: 410
It looks like I need to look into this, that would be the way to go. Although I have no clue how it's done.
post #5340 of 13490 Old 04-29-2013, 06:10 PM
jdsmoothie's Avatar
Liked: 5527
Uh ... right click on the file and select "Rename" after first jotting down the original file name that the 8801 will recognize. smile.gif
Give it a name that describes something unique about the EQ ... eg. the date and some other tidbit to differentiate it from the other EQ file names. You would then have to rename it back to the original file name when reloading it back to the 8801.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
