Marantz AV8801 Preamp/Processor Official Owner's thread - Page 184 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
Old 05-08-2013, 06:11 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
Originally Posted by WestCoastD View Post
ah, I see, thanks. Looking closer, I guess you're using two sets of rails, obviously, to support front and rear portion of each shelve. You most likely are using plywood side panels which the metal rail supports are fastened to?
I don't understand the problems/issues and challenges with DirectTV and running through AV8801? (guess I missed the previous posts)
Yes, two sets of rails. And yes to the plywood and two by fours to support the heavy weight.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
Old 05-08-2013, 06:29 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
I have been A/B testing for a couple hours now. I am using a Darblet the difference is neglible. And I have went back from video conversion Off to 1080p out of the 8801. Now here's the kicker... When I change pic modes from off to Standard that is where the "pop" and "detail" seem to kick back in. Sharpness is strong no matter what with the Darblet but without it and the 8801 with pic mode Off there is a slight loss in sharpness and detail. I never saw that before and admit since the Superbowl we have not watched DirecTV downstairs. We are right now watching the Bulls and Heat play. I am wondering if the last firmware update did something? I will play some more...
Old 05-08-2013, 07:49 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
These are a couple of pics taken from my iphone 5. I am only trying to show the difference with Standard and Off pic modes from the 8801. Yes, screen shots are tough to make a case with anything and I only had a couple quick minutes between a commercial. Of course if I waited until the end of the third I could have had all night. Anyway the first pic is Standard and the second is Off...
Old 05-08-2013, 07:56 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
Actually I apologize. The differences are much more clearer (and cleaner) on my phone. eek.gif
Old 05-09-2013, 03:50 AM
Geronimo.USMC's Avatar
Quoted: 133 Post(s)
Liked: 76
The way I see it, on my setup, is that standard makes it brighter......
-HTPC/Gaming Rig: Silverstone CW02B, Core i7-5820K, ASUS X99-A, 16GB, EVGA GeForce GTX 1080 SC GAMING ACX 3.0 >Samsung 78JS9500
-Auzen HDMI XFi> 7.2 via Marantz AV8802A>Wyred4Sound monoblocks + Halo A51>Paradigm 100'sV5, ADP590'sV5, 690v5, 20v5's, + Dual SVS SB13 PLUS Subs
-40TBof Blu ray .iso's in a Synology DS1815+ controlled by a Dune Solo 4K
-Samsung UBD-K8500 4K UHD WCG HDR Player
Geronimo.USMC is offline
Old 05-09-2013, 06:16 AM
Quoted: 1393 Post(s)
Liked: 587
G,
I'm seeing the same thing on the 65VT50. Standard picture mode contrast is slightly higher than off but comes closer to bypassing the 8801 all together. Bypassing the 8801 seems to give a different balance to the picture. I'll have to study this closer....preferably before ordering more cables. smile.gif
JimP is offline
Old 05-09-2013, 06:35 AM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
I'll be setting up my 8801 this weekend - also bought a new Oppo BDP-103 player. What are the best video settings in the marantz to use with the Oppo? I'm confused regarding the Video Conversion and I/P scaler in the marantz - should they be disabled for use with the Oppo? I would like to use the OSD from the marantz - will disabling these not allow the OSD to work? . Are these settings per input or global?
THANKS for any help!!!
TL5 is online now
Old 05-09-2013, 09:46 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Originally Posted by RichB View Post
I like accurate picture and sound. There is plenty of POP in todays displays when in suitable environment.
I use the Mini and it works quite well, certainly better than DVDO edge I had.
- Rich
Agreed. A Lumagen should be a part of a serious theater. Being able to calibrate the display correctly, especially as, say, a bulb ages, is quite important.
And its not overpriced at all considering what it can do. A Lumagen plus Calman and a good Spectro meter can give you an almost hands off calibration to an objective standard.
Now, if you want to simply goose up the colors / mess with the image until it fits criteria that you enjoy, like over saturation, etc....no problem. Its just not accurate to what was intended.
hifiaudio2 is offline
Old 05-09-2013, 10:54 AM
Liked: 587
You have two HDMI output on your Oppo. You want to run the better of the two(usually HDMI 1) directly to your display. The other one goes to your Marantz.
This is intended to give you the cleanest picture signal possible.
JimP is offline
Old 05-09-2013, 11:09 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
Perfect. I am not a fan of sending the Blu ray image through anything before it hits the display. No detours does make the best possible image. Unless you are using a Darblet set around 40 (displays may vary)...
Old 05-09-2013, 11:10 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
S what's the verdict for others? Is anyone else's seeing slight image degradation going into the Marantz before their display?
Old 05-09-2013, 11:16 AM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
^^^^ Thanks. So the second HDMI cable from the Oppo to the marantz would carry just the audio?
TL5 is online now
Old 05-09-2013, 11:41 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
Yes, you woukd keep it on (the Oppo) split Audio and Video in its set up.
Old 05-09-2013, 11:56 AM
Liked: 587
Actually, what you do is set HDMI 1 on the Oppo to video only.
What you might want to play with is comparing your input from HDMI 1 to HDMI 2 that goes through the Marantz. Be sure that all picture settings on your display are the same.
JimP is offline
Old 05-09-2013, 12:46 PM
Oppo Beta Group
RichB's Avatar
Quoted: 869 Post(s)
Liked: 565
HDMI-1 uses the QDEO video processing chip and HDMI-2 MediaTek chip so they are not the same.
HDMI-1 is a bit softer so some users have found that HDMI-1 looks better with sharpness +1.
YMMV
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
Old 05-09-2013, 01:17 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
Old 05-09-2013, 01:29 PM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Some have noted a change in the sharpness settings on the Oppo's due to the official firmware release, as a test I bumped up from +1 to + 2 to see, but will have to test further to determine if this is indeed the case wink.gif
And keep in mind there is still video present when sending hdmi 2 to the 8801 for audio, when using the 103 or 105 in split av!
audiofan1 is offline
Old 05-09-2013, 06:41 PM
wcniedba's Avatar
New to forums so sorry if this is in wrong place!
There is a feature I am looking for and curious if the AV8801 has it. My condo is wired for Ethernet in all rooms. I would like to have pre-amp/processor/receiver that can send audio to other rooms via the Ethernet signal. I notice the AV8801 has Ethernet connections. I also notice that Marantz makes an item called Consolette that has Ethernet and I'm wondering if it could serve as a remote speaker in each room. I honestly don't care if the signals are different going to each room. My main goal is to the same music playing no matter where you go in the house.
I suppose I could simply connect Airport Expresses to the Ethernet in each room but then I'd just have to send my signals from a Mac/PC I'm guessing. I'd like to have whatever is going through my main receiver broadcast that signal throughout the house and utilize the existing Ethernet wiring in the house.
Thanks in advance for any insight and please let me know if I should move this post to another location!!!
Chris
wcniedba is offline
Old 05-09-2013, 06:55 PM
jdsmoothie's Avatar
Quoted: 12105 Post(s)
Liked: 5508
The ethernet jack is designed to be connected directly to a router or modem only.
jdsmoothie is offline
Old 05-09-2013, 06:56 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
Another update. I am concluding the image is definitely not as clean going through the 8801 at this time. I compared all of my previous recordings and the proof is in the pudding. I think either this past firmware or the one before it is the culprit. Either way I just re routed my DirecTV path. Crisp, clean back with my genie.
Old 05-09-2013, 08:42 PM
sjoGM's Avatar
Do you run hdmi on all connections?
sjoGM is offline
Old 05-09-2013, 09:05 PM
cofn42's Avatar
Quoted: 41 Post(s)
Liked: 51
OK, so I am having a slight issue today after the Audyssey calibration.
When I listen to the default Music mode (Stereo) I lose 100% of the signal to my sub, and it routes all bass information to the mains.
This appears to be only happening in the 2 channel stereo mode.
The calibration has left my mains as Large and crossed at 40hz (which is fine by me as they are DT BP2000TL with 12" woofers)
Only thing I could do to combat this was to set them to small manually for stereo mode, or change the sub settings to LFE+Main.
Is something wrong here? Am I missing something?
Marantz AV8801 / Rotel 2x RMB-1095 / RMB-1090 / Yamaha P7000S / Velodyne SMS-1 / DTech BP2000TL / DTech C/L/R 3000 / 4x - DTech BPVX/P Surrounds / DTech SM55 Heights / DTech SM65 Wides / SVS PB13 Ultra / 2x Buttkicker LFE / JVC DILA-X750 / HDFury Integral / Globalcache, iRule & Insteon.
Coffin Family Theater Build
cofn42 is offline
Old 05-09-2013, 09:11 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
stereo is just two channels. no channel for the sub. so you won't get sound to the sub from a stereo input unless you route bass from the left and right channels. While it's actually the receiver's logic, not Audyssey's (and they'd do it differently if they have control) it's common for folks to end up with a calibration that sets their left and right speakers as large, which is confusion-speak for "turn off bass management" so nothing goes to the sub unless you change (most here would say "correct") the settings to utilize the sub. Most would vote for setting speakers small and a crossover around 80 Hz, I think. At least I would.
JHAz is offline
Old 05-10-2013, 12:55 AM
ohyeah32's Avatar
Thanks for taking the time to verify this. Perhaps Marantz should be made aware of this, and see about fixing it in a future firmware update.
So as it stands, the general consensus is to go directly to the display when at all possible.
ohyeah32 is offline
Old 05-10-2013, 01:10 AM
MaDBeN's Avatar
Quoted: 49 Post(s)
Has anyone noticed any motion differences (fast action blur) with going direct to display or through the Marantz? I seem to be noticing it more now than when the Marantz was not in the system (could be a number of things as the room has undergone some changes recently) and am trying to trouble shoot the cause.
MaDBeN is online now
Old 05-10-2013, 04:30 AM
comfynumb's Avatar
Liked: 410
I was content going through the 8801, but now I'm wondering if my picture could be better. Are their any lip sync issues if I go directly from source to display?
comfynumb is offline
Old 05-10-2013, 08:02 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Both things you tried will work. Basically, when the mains are large, the system in stereo is assuming you don't need a sub, even thought this is 99% of the time not the case...You can leave them large if you want and set the LFE channel to LFE+Main and you will get bass from the subs too.
beastaudio is offline
Old 05-10-2013, 10:11 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 490
I would say the best for now is to go directly to the display. I was having HDMI handshaking issues and just decided to use the COAX off my DirecTV genie for sound. I haven't used it in years! I was shocked how good the sound was though and quite frankly I like it. As for lip sync mine was off just a little but I used the 8801's adjust feature and corrected it quickly. All channels are spot on.
Old 05-10-2013, 11:38 PM
Troll
ufokillerz's Avatar
Liked: 47
so i missed quite a few pages, but does anyone know if logitech remotes work properly yet?
ufokillerz is offline
Old 05-11-2013, 12:30 AM
ohyeah32's Avatar
Do an A/B comparison and see what you think. For Blu-ray, I have to go through the AV8801, because if I go separate video and audio with my current TV, the sound will go out of sync. I know that the 8801 has an audio delay adjustment feature that should work great, but I haven't tried it for 2D Blu-ray playback.
ohyeah32 is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
