Marantz AV8801 Preamp/Processor Official Owner's thread - Page 199 - AVS Forum | Home Theater Discussions And Reviews
 294Likes
post #5941 of 13537 Old 06-03-2013, 04:19 AM
avman09's Avatar
I think we are both on the same page here, just discussing two different ways of looking at specs smile.gif Even the AVR's are going to do quite well in stereo mode, but one you step to 2 channel amps, you start running into the same issues, their specs are going to be inflated in most cases for the "both channels driven" numbers as well. Most people look past it and buy the amps anyways, so why be honest right?
Agree, typically inflated, everything I quoted are in relative terms only, but don't forget I was also trying to response to the last question in his #3:
Originally Posted by Stewy04 View Post
3. I was told to listen in two channel, I was told that my L/R speakers can handle louder music . Is this true? is two channel better for loud?
You had already responded so I tried to supplement yours by adding that in 2 channel even the amps would give a little more. Actually I should not have bothered because that 10 to 20% more isn't going to help in practical terms. It is best he turns things down a notch to help save his speakers, amps and most importantly his hearing. Too bad, he said that wasn't an option for him. I hope our back and forth at least add some clarity to the responses he's getting for question#3.
avman09 is offline
post #5942 of 13537 Old 06-03-2013, 12:35 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1273 Post(s)
Liked: 873
Here is my current solution to the Marantz AV8801 getting up to 126 degress when mounted in my open credenza:
The GELID Solutions Slim 12 UV fan has been wired to the AV8801 rear USB output so it runs slower and is very quiet.
The temp is now 102 F max.
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is offline
post #5943 of 13537 Old 06-03-2013, 01:23 PM
comfynumb's Avatar
Liked: 411
- Rich
Hey Rich, do you the fan have blowing air onto the 8801?
comfynumb is offline
post #5944 of 13537 Old 06-03-2013, 01:28 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
It blows accross the top of the AV8801 and not directly into it so I expect that it will not cause an accumulation of dust.
- Rich
RichB is offline
post #5945 of 13537 Old 06-03-2013, 01:32 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
- Rich
My rear USB is not working , do I need to disable the front port ?
VRD Monoblocks Totaldac Twelve System Music Storage NAS SSD - Dedicated Router - (2) Paul Hynes SR-5 Linear PSU - Controlled by Ipad
Speakers :Joseph Perspective's Cables : Antipodes reference Speaker / IC's - Wywires Silver Juice II - Totaldac D1 USB
All Furutech GTX-D Gold Receptacles
a1usedcomp is offline
post #5946 of 13537 Old 06-03-2013, 01:44 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
Once I selected the USB, I had to select the rear USB port and then it worked.
Apparently, they are mutually exclusive.
- Rich
RichB is offline
post #5947 of 13537 Old 06-03-2013, 01:46 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
- Rich
I already got it , I guess that's what the manual is for . Did I miss something the fan always stays on ?
post #5948 of 13537 Old 06-03-2013, 01:47 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
My fan is only on when the AV8801 is powered on.
Does yours stay on?
- Rich
RichB is offline
post #5949 of 13537 Old 06-03-2013, 01:55 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
Does yours stay on?
- Rich
Yes
post #5950 of 13537 Old 06-03-2013, 01:58 PM
comfynumb's Avatar
Liked: 411
- Rich
Gotcha. I'm thinking about one that sits on top of the unit, but they look pretty ugly. But it needs something, definitely gets too warm.
post #5951 of 13537 Old 06-03-2013, 02:01 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
If you got the room how about one of these http://www.antec.com/soundscience/AVCooler.php
post #5952 of 13537 Old 06-03-2013, 02:05 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
It is ok if you are stacking, I have one.
I took it apart and cut away the mounts and inserted electrical tape to dampen vibration.
It still makes too much noise for my tastes.
You do not need to move much air to reduce the tempurature.
- Rich
RichB is offline
post #5953 of 13537 Old 06-03-2013, 02:07 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
I need to figure out why my USB port is powered with unit off , front and rear both are
post #5954 of 13537 Old 06-03-2013, 02:12 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
I believe that is by design, which is a good thing for a fan.
- Rich
RichB is offline
post #5955 of 13537 Old 06-03-2013, 02:34 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
- Rich
I meant my fan wont turn off with the unit , it doesn't matter if I pick the front or rear . But you said yours turns off
post #5956 of 13537 Old 06-03-2013, 02:35 PM
jdsmoothie's Avatar
Quoted: 15354 Post(s)
Liked: 7508
Do you have either HDMI Control/HDMI Pass Through set to ON or Network set to "Always ON"?
jdsmoothie is online now
post #5957 of 13537 Old 06-03-2013, 02:38 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
Network set to Always ON I know that for sure
post #5958 of 13537 Old 06-03-2013, 02:47 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
My network is not set to always on because I have switches in the neighborhood which should be better than a hub.
Try turning that off to see if it makes a difference.
If it does, that is a weird side-effect.
- Rich
RichB is offline
post #5959 of 13537 Old 06-03-2013, 03:03 PM
comfynumb's Avatar
Liked: 411
They are as nice as I've seen. I have 2 5/8" to the next shelf and this fan is approx 1 3/4" thick. That should leave me just enough room. In the one pic I see they have the component sitting on top of the fan, but I don't see how it would work, that fan looks like it blows out the sides of it. Thanks for the link.
post #5960 of 13537 Old 06-03-2013, 04:09 PM
Mad Norseman's Avatar
Liked: 102
- Rich
That looks like a good solution, but with the top of the AV8801 mostly covered from view (by the shelf above), you could have done what I did - and use two of these fans that sit on top at the rear of the unit and suck hot air up and out of the unit and blow it out the back:
http://www.coolerguys.com/codublfancoc.html
I can't see them unless I get down and look in since I have a few inches of clearance (like your set-up), and they're located near the rear of the AV8801 where the top vents are so they go un-noticed and are very quiet. I haven't measured the actual temperature, but it now stays cool to the touch...
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #5961 of 13537 Old 06-03-2013, 04:37 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
- Rich[/quot
The fan will not turn off if network is set to always on Thanks JD
post #5962 of 13537 Old 06-03-2013, 04:48 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
There is about 4 inches above the AV8801 so, unfortunately, you can see the top from any seat.
It does not take much so long at the air does not stagnate above the unit.
I have also ordered a white fan that I think may disappear into the wall.
I have found that white wires are better camouflaged.
- Rich
RichB is offline
post #5963 of 13537 Old 06-03-2013, 04:50 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
- Rich
Strange design choice.
If you have another network option, it saves a few watts to turn it off anyway wink.gif
- Rich
RichB is offline
post #5964 of 13537 Old 06-04-2013, 06:48 AM
beastaudio's Avatar
Quoted: 4152 Post(s)
Liked: 3514
Or possibly some of your other zones are accidentally on? When powering down the unit, I have to manually turn zone 2 off as well or parts of the unit will prevent it from completely going into standby.
beastaudio is offline
post #5965 of 13537 Old 06-04-2013, 01:40 PM
kamiraa's Avatar
Liked: 31
I saw some chatter about this throughout the thread. But what is the consciousness of the MM8077 vs. a Emotiva series amp.
Thanks all!
kamiraa is offline
post #5966 of 13537 Old 06-04-2013, 01:57 PM
leadliner's Avatar
Quoted: 39 Post(s)
the mm8077 runs hot. i need to get one of those coolerguys fan on mine it has shut down on me 3 times. i just put a glass shelf that came with my sunfire tg-3 between the 8801and 8077 seems to have helped. soundwise it sounds nice and smooth i have tinnitus so its better for me than emotiva. emotiva amps make you want to crank the piss out of it, it sounds so good.tongue.gif
leadliner is offline
post #5967 of 13537 Old 06-04-2013, 02:43 PM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 809
Originally Posted by Glenn Baumann View Post
"We all know that in a few years something knew will come out but it's doubtful it will be worthwhile upgrading for."
You don't think XT64, 8k and 22.4 would be worth upgrading for? tongue.gif. Come on, you know that they must come up with new and creative ways to separate us from our wallets! wink.gif....Glenn smile.gif
Yes 8K will be outstanding, Dolby ATMOS, DTS Multi Dimensional Sound (MDA) and 23.4 have my name on it !
wse is offline
post #5968 of 13537 Old 06-04-2013, 03:01 PM
cp1966's Avatar
I did the FW update, it said it would take about 45 minutes.
It downloaded the file pretty quick, but now the display on the front panel says "sub 38 minutes" and its been like that for close to an hour.....
Any thoughts?
cp1966 is offline
post #5969 of 13537 Old 06-04-2013, 03:24 PM
comfynumb's Avatar
Liked: 411
Hi, your 8801 has shut down 3 times? I don't and wouldn't stack anything on top of the 8801, it runs hot as it is, and I would think it would transfer too much heat to the amp. Not trying to tell you what to do. I have mine side by side with my Sunfire amp and have small floor fans on both, till I figure out which dedicated fans work best, they're are noisy and ugly but work for now.
post #5970 of 13537 Old 06-04-2013, 03:26 PM
comfynumb's Avatar
Liked: 411
Any thoughts?
Hi, how did you make out?
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
