Marantz AV8801 Preamp/Processor Official Owner's thread - Page 205 - AVS Forum | Home Theater Discussions And Reviews
 294Likes
post #6121 of 13537 Old 06-14-2013, 04:17 AM
comfynumb's Avatar
Liked: 411
Originally Posted by Franin View Post
I have nothing's coming out now
And you selected heights in the Marantz setup I'm assuming? I'm hearing if Audyssey is engaged it converts the audio to PCM as it cannot except DSD.
comfynumb is offline
post #6122 of 13537 Old 06-14-2013, 04:25 AM
Franin's Avatar
Quoted: 2401 Post(s)
Liked: 1508
Yeah I did nothings coming out know I'm any speakers
_________________________
Franin is offline
post #6123 of 13537 Old 06-14-2013, 04:37 AM
comfynumb's Avatar
Liked: 411
You assigned the proper input for your player under input assign, be it HMDI or however you have it connected? What about trying the radio on the 8801, I'd see if you have sound coming out of there, then you could eliminate it's the 8801. I'd go through the setup again. There's a lot of things it could be, and I know your competent, I've seen your posts before.
You'll get it.
post #6124 of 13537 Old 06-14-2013, 04:40 AM
Franin's Avatar
Liked: 1508
Ok I figured one bit its my DVDO DUO. I disconnected the hdmi cable from the duo and ran it in directly to the Marantz. But still the heights are not showing. How do you select pllz?
Franin is offline
post #6125 of 13537 Old 06-14-2013, 04:50 AM
comfynumb's Avatar
Liked: 411
On your Marantz remote hold down for a couple seconds either the red movie button or the green music button and the different audio modes will come up on your OSD. I never had heights so I'm not sure how they work, one of the guys that use them might be able to tell you more. I'm sure it's just a setting or mode.
post #6126 of 13537 Old 06-14-2013, 04:57 AM
Franin's Avatar
Liked: 1508
Franin is offline
post #6127 of 13537 Old 06-14-2013, 05:03 AM
comfynumb's Avatar
Liked: 411
post #6128 of 13537 Old 06-14-2013, 07:33 AM
Franin's Avatar
Liked: 1508
Does anyone know what is the refrence volume on the Marantz is? I also want to know if there is any Dvdo duo owners who are connecting there blu ray player to the Duo and running audio just to the Marantz? Im finding the Duo is incompatible in the audio side regarding the Marantz. Its only allowing 2 ch PCM to the Marantz.
Franin is offline
post #6129 of 13537 Old 06-14-2013, 07:44 AM
beastaudio's Avatar
Quoted: 4158 Post(s)
Liked: 3515
Mine seems to track pretty well with the speakers level matched at 75dB using the pink noise. After Aud runs, they usually are around 72dB and I bump them up to 75 dB.
beastaudio is offline
post #6130 of 13537 Old 06-14-2013, 07:46 AM
Franin's Avatar
Liked: 1508
So 75db on the volume control on the Marantz is the refrence level?
Franin is offline
post #6131 of 13537 Old 06-14-2013, 07:53 AM
beastaudio's Avatar
Liked: 3515
No no. Small suggestion, go into the Audio menu and change the volume readoff from absolute (0-100) to reference (-85dB to 0.0 or however it is labeled). That is how 9/10 guys on here are stating volume levels and is a good way to know how you are listening compared to others. The absolute scale is just what comes stock on the 8801. Once changed, setting the receiver at 0.0 would be "around" reference level. I have gotten in many a tiff with folks on here defining what "reference" is but as a general understanding, reference for movie watching is an average of around 85dB with 105dB peaks from your speakers, and 115dB peaks from your subs. Running Audyssey on the 8801 and then putting the unit at 0.0 usually equals this exact scenario, thus "reference" as most people understand it.
sjoGM likes this.
post #6132 of 13537 Old 06-14-2013, 07:53 AM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is online now
post #6133 of 13537 Old 06-14-2013, 07:56 AM
Franin's Avatar
Liked: 1508
Thanks for that Im doing audyssey at the moment( I haven't changed anything ) will I have to redo audyssey again if I change the volume read off?
Franin is offline
post #6134 of 13537 Old 06-14-2013, 08:00 AM
Franin's Avatar
Liked: 1508
Originally Posted by joerod View Post
Joe you have the Dvdo duo have you plugged in your players and gone out solely audio out to the Marantz?
Franin is offline
post #6135 of 13537 Old 06-14-2013, 08:02 AM
comfynumb's Avatar
Liked: 411
Doesn't Audyssey set reference at 0 and 105db at that volume? Or am I misinterpreting things?
post #6136 of 13537 Old 06-14-2013, 08:04 AM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
No. It's just telling the 8801 to display its volume level in a different way and has no effect on Audyssey's calibration.
Selden
Selden Ball is offline
post #6137 of 13537 Old 06-14-2013, 08:10 AM
Franin's Avatar
Liked: 1508
Does audyssey go to its own volume? When I was doing audyssey with the DENON it will always go to 0.0.
Franin is offline
post #6138 of 13537 Old 06-14-2013, 08:21 AM
beastaudio's Avatar
Liked: 3515
The audyssey blip test you should not touch the volume control. On the Denon it went to 0.0 which is what we are referring to by changing the volume readout. JoeRod appears to still use the same volume scale you currently have it set on, but like I said, 9/10 guys use the other option. It won't change any other settings on the 8801 by changing the volume readout.
Comfy, yes with the readout I use, and am suggesting, at 0.0 your speakers SHOULD be only doing 105dB peaks. The average at this level for dialogue is usually around 80-85dB depending on the material.
post #6139 of 13537 Old 06-14-2013, 08:24 AM
Franin's Avatar
Liked: 1508
Of course I will never touch the volume but I was curious to find out what level on the Marantz Audyssey sets it readings at.
Franin is offline
post #6140 of 13537 Old 06-14-2013, 08:25 AM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I do lately. I like sending DirecTV through it though because it makes life much easier adjusting. Blu ray just audio goes into the 8801. The 103's other HDMI out goes into my Darblet then the Sony 1000.
post #6141 of 13537 Old 06-14-2013, 08:27 AM
comfynumb's Avatar
Liked: 411
You are the man beast and I'm learning!
Also oops I sometimes listen above 0 to around +4 am I the only one? My Sunfire never clips and I only listen that loud for a song.
post #6142 of 13537 Old 06-14-2013, 08:33 AM
beastaudio's Avatar
Liked: 3515
Same as Denon. The pink noise tone after audyssey runs is a -25dBfs signal and the blip test is in fact at 0.0.
post #6143 of 13537 Old 06-14-2013, 08:34 AM
Franin's Avatar
Liked: 1508
With the audio for blu ray are you getting DTS HD Ma though the duo cause I was only getting PCM 2.0 and my players bitstream. When I removed the Duo out ofbthe gain everything was fine. Was I meant to set something in the duo?
Franin is offline
post #6144 of 13537 Old 06-14-2013, 08:36 AM
beastaudio's Avatar
Liked: 3515
Nope smile.gif I can't hang at +4 on a LOT of material and for movies that is way too loud for me. I never get above 0.0 and rarely enough even go that far.
But on Music? PSSHH I have knocked it up to +10 on a couple of tracks and it is borderline insane. My usual volume when I want to really rock the system is -10 to 0 for a little while. I can't handle that loud for extended sessions though still.
post #6145 of 13537 Old 06-14-2013, 08:47 AM
comfynumb's Avatar
Liked: 411
I didn't mention that I don't do movies above -8 or so and that's too loud during most action scenes. But it is fun to scare the crap out of unsuspecting people, mainly my gf biggrin.gif so yes only above 0 for music.
post #6146 of 13537 Old 06-14-2013, 09:16 AM
bwv1080's Avatar
Quoted: 41 Post(s)
Liked: 95
Originally Posted by audiofan1 View Post
I have the 8801 and 105 and I only use the 105 balanced outs to the 8801 for analog, all else for multi/ch I use hdmi and prefer it for many reasons the strongest of those being Audyssey for multi ch sacd sent to the 8801 via Bitstream from the 105 which I have set to DSD ( try it and hear why) As for the analog outs assign them to the "CD" input ( speaking xlr here) you are using the rca outs you can configure them on the Bluray input or any other you choose as you can set that particular input to digital or analog and from there use the movie mode button on the remote by holding it down to scroll through the modes until it says multi ch input.
The simple and best sounding way to me is as follows.
1.) Oppo 105 xlr or rca to the Cd input for stereo playback of cd's usb and 2/ch sacd I leave this one in Pure direct as the 8801 remembers the settings and all I need do is hit CD on the remote.
2.) Hdmi 2 from the 105 set to bitsream and DSD for the Audio settings while using the the split a/v mode to the 8801's bluray input, here you will still look for multi/ch on the display using the movie button as described above for DSD 5.1 tracks you can still select stereo or dpl II dts neo etc.. and also pure direct for multi ch. This will also cover your movies as the Dolby True HD or DTS Master HD logos light up . You can then use the hdmi 1 from the 105 direct to your display .
Thanks, but I am curious to hear the multi-channel analog outs.
DALI Epicon 2 speakers; SVS SB 13 Ultra subwoofer; PrimaLuna HP integrated amp; Esoteric K-03 SACD player; Oppo BDP 105 SACD/Blu-ray player; VPI Scout 1.1/Ortofon 2M Black; Audeze LCD-XC headphones
bwv1080 is offline
post #6147 of 13537 Old 06-14-2013, 09:31 AM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I don't send Blu ray (audio or video) through the Duo. Only TV and video game systems. I have an Oppo 103 so Audio goes straight to the 8801 and video straight to the projector (actually Darblet first).
post #6148 of 13537 Old 06-14-2013, 12:16 PM
audiofan1's Avatar
Quoted: 1885 Post(s)
Liked: 1958
Having come from an 95 with the full gravitas of the sabre dac's for multi/ch analog biggrin.gif trust me when I say set the 105 ( still reigns for 2/ch via xlr to the 8801) to bitstream for hdmi audio and sacd to DSD, get your audyssey right and about 300 hrs on both units and then let the 8801 show you why its the top dog pre/pro wink.gif
audiofan1 is online now
post #6149 of 13537 Old 06-14-2013, 12:36 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
Very happy with my 8801/105 combo a tad bright coming from a 4 yr old Sony 5400ES but I will give it time
VRD Monoblocks Totaldac Twelve System Music Storage NAS SSD - Dedicated Router - (2) Paul Hynes SR-5 Linear PSU - Controlled by Ipad
Speakers :Joseph Perspective's Cables : Antipodes reference Speaker / IC's - Wywires Silver Juice II - Totaldac D1 USB
All Furutech GTX-D Gold Receptacles
a1usedcomp is offline
post #6150 of 13537 Old 06-14-2013, 03:50 PM
bwv1080's Avatar
Quoted: 41 Post(s)
Liked: 95
Haha, I'll probably stay with the HDMI setup that I have: If nothing else, it is more wife-friendly since it requires far fewer cables! smile.gif
bwv1080 is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
