Marantz AV8801 Preamp/Processor Official Owner's thread - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #6301 of 13491 Old 06-19-2013, 09:37 PM
Waboman's Avatar
Quoted: 4604 Post(s)
Liked: 10775
Originally Posted by ohyeah32 View Post
So far I have been VERY happy with the 8801! I've had it for close to 3 months now and have not had a single issue with the 12v triggers.smile.gif
Muchas gracias, amigo.
That's good to know. Triggers are about as basic a feature as you can get. Glad to hear they're all firing.biggrin.gif Any other thoughts pros/cons you have on the 8801?
Waboman is online now
post #6302 of 13491 Old 06-19-2013, 11:49 PM
CIH USER
Franin's Avatar
Quoted: 2192 Post(s)
Liked: 1313
Wabo I don't see any Cons I'm very impressed with the unit. The pros is we get the full version of XT32, which made a big difference.
_________________________
Franin is offline
post #6303 of 13491 Old 06-19-2013, 11:50 PM
CIH USER
Franin's Avatar
Liked: 1313
Have a think about Wabo who knows you might end up getting one.
Franin is offline
post #6304 of 13491 Old 06-20-2013, 03:19 AM
ohyeah32's Avatar
Like Frank said, this is a fantastic pre/pro! I really haven't seen any negatives with this unit. It is quite a difference from the AVP, but mainly differences with the way the menus are. This one is very straight forward, and is actually easier to navigate through. There are some things that the AVP has that this one doesn't, like a separate menu for 2 channel. But on a positive note, this one does allow for separate sub levels for 2 channel listening like the AVP. So for movies it stays one way and for 2 channel you can have it set another.
The menu system on this one has less sub menus compared to the AVP. With the Denon one can literally get lost with all the sub menus it has. So in a way I see this as a plus, as it's so much easier to be up and running, and won't take the months of learning like the AVP required.
The 8801 doesn't allow channel levels to be adjusted on the fly like the AVP. So if you need to raise the center channel, you have to go into the menu. Thankfully this is something that is usually only required once and then left alone. So I haven't found it to be a major omission. Sound quality wise, this pre/pro delivers the goods with both movies and music.smile.gif And it's a great match for Martin Logans! The sound is neutral like the AVP, so it doesn't sound bright.
This was one of my primary concerns, being that this has no THX processing modes. On the AVP I always left THX Ultra 2 on for movies and HD satellite. But with Audyssey XT32 engaged along with dynamic EQ, this Marantz sounds sweet! Dynamic and powerful, yet easy on the ears.smile.gif
The fit and finish of this pre/pro is first rate also! And in no way has a cheap feel or look. And like the AVP, this one is also made in Japan.smile.gif
dlynch34 likes this.
ohyeah32 is offline
post #6305 of 13491 Old 06-20-2013, 03:35 AM
comfynumb's Avatar
Liked: 410
Hi, if you have an iPhone or iPad you can use the deremote app to adjust many settings, including Audyssey and channel levels on the fly, without opening up the main menu. I'm sure there is something for android also, just not the deremote.
comfynumb is offline
post #6306 of 13491 Old 06-20-2013, 06:13 AM
CIH USER
Franin's Avatar
Liked: 1313
That's a good App
Franin is offline
post #6307 of 13491 Old 06-20-2013, 06:22 AM
comfynumb's Avatar
Liked: 410
Originally Posted by Franin View Post
That's a good App
Yeah it is. I use it everyday and it's nice because you don't have to turn your panel on. Like many apps sometimes you have to close it and reopen it to get it to work, but basically no issues for me.
post #6308 of 13491 Old 06-20-2013, 06:41 AM
CIH USER
Franin's Avatar
Liked: 1313
How do you use airplay on the marantz?
Franin is offline
post #6309 of 13491 Old 06-20-2013, 06:57 AM
comfynumb's Avatar
Liked: 410
Lower right corner, this is a pic I found on the net.
On your idevice in your music there's an arrow, click on it and it should list the Marantz AV8801 and your device, just click on the 8801. It should also work in iTunes on your PC. Arrow is up the top left on iTunes.
post #6310 of 13491 Old 06-20-2013, 07:23 AM
jcas's Avatar
There seems to be some inconsistent performance when trying to use JRiver via dlna.
jcas is offline
post #6311 of 13491 Old 06-20-2013, 07:29 AM
Waboman's Avatar
Liked: 10775
Thanks, Franin. What I like to hear.
post #6312 of 13491 Old 06-20-2013, 07:37 AM
jcas's Avatar
Originally Posted by jmschnur View Post
JR River dlna or JR river from the computer?
Fairly new with the 8801 but JRiver from the computer appears to work well.
I am having some issues with the 8801 and overall network compatibility via the media server and using JRiver dlna.
jcas is offline
post #6313 of 13491 Old 06-20-2013, 07:41 AM
CIH USER
Franin's Avatar
Liked: 1313
That's awesome thank you.
Franin is offline
post #6314 of 13491 Old 06-20-2013, 07:47 AM
CIH USER
Franin's Avatar
Liked: 1313
I hope someone can answer this question and help me. I had to get rid of my Duo due to incompatibility with the Marantz but I need to purchase the Lumagen Mini. I dont want to purchase if it causes lip sync issues.
I need to go Components to Marantz to Lumagen Mini to JVC Projector.
Is anyone going this way
Franin is offline
post #6315 of 13491 Old 06-20-2013, 07:53 AM
comfynumb's Avatar
Liked: 410
post #6316 of 13491 Old 06-20-2013, 08:11 AM
Waboman's Avatar
Liked: 10775
If it's good enough to make the Franin & ohyeah cut, then it's like Marsellus Wallace sending The Wolf. That's all you had to say.biggrin.gif
I had heard the menu is much more streamlined. Keep in mind it's been a good 5 years since I've played with another pre/pro. I might be all thumbs for awhile.
I just assumed it had THX. Not that this is a deal breaker. Would have been a nice addition though.
Glad to hear it matches so well with our MLs. I appreciate the fact it's made in Japan and not China or Malaysia. Lots to think about, amigo.smile.gif
post #6317 of 13491 Old 06-20-2013, 09:01 AM
Point Source
beastaudio's Avatar
Quoted: 3539 Post(s)
Liked: 2839
THX is a fancy marketing gimmick for the most part. The fact is the "THX" people just put their stamp of approval on the unit, and then Onkyo can show it as "better" than other AVR and pre's. There quite honestly is nothing that makes it any better to begin with. You get a THX mode... which some people like, and it tells you the 80hz crossover is THX spec when you select it. Well, both of these things can still be accomplished without it in the first place.
beastaudio is offline
post #6318 of 13491 Old 06-20-2013, 09:07 AM
comfynumb's Avatar
Liked: 410
+1
post #6319 of 13491 Old 06-20-2013, 09:13 AM
Waboman's Avatar
Liked: 10775
Like I said. Not a deal breaker.
post #6320 of 13491 Old 06-20-2013, 10:12 AM
Dundas's Avatar
There are discrete IR remote codes available to adjust individual channel volume.
Dundas is online now
post #6321 of 13491 Old 06-20-2013, 01:34 PM
jam88's Avatar
In the new July issue of Stereophile, Kalman Rubinson writes another fine article where he discusses Oppo's recently added feature (in beta) to the BDP-103 and 105 that allows them to play downloaded DSD files through USB connected hard drives and SMB/CIFS network access.
He then writes about the DeRemote app that allows one to control the AV8801 from any iOS device like an iPad or iPhone. In that section he also gives his thoughts on the subject that I brought to the attention of this thread in this post. While I initially was disappointed to learn that the 8801 down-samples high-resolution PCM to 48kHz/24 bits, I've come to the same conclusion that Kal makes in that the MultEQ XT32 room correction benefits outweigh the marginal effects of the increase in resolution.
I've contacted both Audyssey and Marantz on this issue. Since I've been very busy lately, I have not followed up with their responses on this thread but I will try to do so by this weekend.
BTW, good work Kal!
jam88 is offline
post #6322 of 13491 Old 06-20-2013, 01:44 PM
audiofan1's Avatar
Quoted: 1651 Post(s)
Liked: 1672
BTW, good work Kal!
I've pondered on this lately and wonder if that's one of the reasons the "Bypass FR/FL" option exist as I use this option from time to time ( mostly) when playing multi ch sacd's .
audiofan1 is offline
post #6323 of 13491 Old 06-20-2013, 02:42 PM
Kal Rubinson's Avatar
Quoted: 682 Post(s)
Liked: 461
I hadn't thought of that.  I had thought the "Bypass FR/FL" option existed only for me as it lets me enjoy a pair of speakers in for review without doing a full run of Audyssey. biggrin.gif
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #6324 of 13491 Old 06-20-2013, 02:53 PM
audiofan1's Avatar
Liked: 1672
Now that would indeed make it a true reviewers pre/pro! you must dream of gear like this biggrin.gif
post #6325 of 13491 Old 06-20-2013, 06:28 PM
Quoted: 682 Post(s)
Liked: 461
It is one of the reasons I bought it.  Also I recently bought a 5.1channel analog preamp for my other system so that I could have more options.
Kal Rubinson
post #6326 of 13491 Old 06-20-2013, 07:37 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Whi
Which 5.1 preamp? Assume this is for your main system (B&W)?
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is online now
post #6327 of 13491 Old 06-20-2013, 07:44 PM
Quoted: 682 Post(s)
Liked: 461
Originally Posted by jima4a View Post
Whi
Audio Research MP1 for main system.
Kal Rubinson
post #6328 of 13491 Old 06-20-2013, 07:54 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Sweet! Did you consider the SP3 for this role? What is your source?
post #6329 of 13491 Old 06-20-2013, 08:34 PM
Quoted: 682 Post(s)
Liked: 461
No.  I needed multiple MCH inputs.  Multiple MCH sources including the 3xMytek setup.
Kal Rubinson
post #6330 of 13491 Old 06-20-2013, 09:06 PM
Waboman's Avatar
Liked: 10775
markrubin likes this.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
