Marantz AV8801 Preamp/Processor Official Owner's thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
Old 12-02-2012, 09:56 AM - Thread Starter
exm
exm's Avatar
Quoted: 117 Post(s)
Liked: 80
Interesting. On my AV7005 I always had Dynamic Volume on (not that I need it for any particular reason), and I just turned it off. So, does it really sounds better or is it placebo? smile.gif In general, do you guys recommend this on or off?
exm is offline
Old 12-02-2012, 09:59 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5501
OFF, unless you need it for late night listening and don't want to disturb others. Note however, that on the flipside it will also boost low dialogue as well.
jdsmoothie is offline
Old 12-02-2012, 04:04 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
interesting. I have been confused on whether Dynamic Volume would enhance, or boost, low dialog or not? I've have Dynamic Volume = OFF on my Denon AVR-2112CI. I think I will switch to ON now.
WestCoastD is offline
Old 12-02-2012, 05:17 PM
jdsmoothie's Avatar
Liked: 5501
Right ... the whole point is to adjust the volume to your desired level ... lowering the explosions and boosting the weak dialogue to meet that level depending on whether set to (light, medium, heavy).
Old 12-02-2012, 05:38 PM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 458
With Denon (XX11 and newer) and Marantz AVRs and pre/pros (X005 and newer) with Audyssey of any flavor, at the end of the AUTO SETUP procedure, give you the option of turning Dyn Volume OFF, otherwise it will default to ON (medium) as noted below.
The 8801 does not.  It turns on Dynamic EQ and Dynamic Volume by default and one has to return to the setup menu to defeat and/or modify them.  Of course, I had to do that anyway since, as usual, the prepro set all my speakers to LARGE.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 12-02-2012, 05:44 PM
jdsmoothie's Avatar
Liked: 5501
Really? I took that snippet directly from the Owner's manual. You sure about that Kal? Sciacca implied he saw that GUI page.
Old 12-02-2012, 05:51 PM
Bghead8che's Avatar
Originally Posted by Chucka View Post
I would also like to see a review of the Marantz AV8801 as compared to the Denon AVR-4520 and if is worth the difference in cost...
Chucka
So far I am failing to see what advantage the Marantz has over the Denon 4520, if any.
As I see it the the Denon has everthing the Marantz does plus the following:
Robust 9 channel amplifier
Denon Link HD
$500 less
I'd rather have the "free" amp and Denon link. The Marantaz does not seem to have any way to deal with the pronounced jitter found in HDMI singals.
What am I missing?
-Brian
Brian R. Smith
Bghead8che is offline
Old 12-02-2012, 06:01 PM
Quoted: 672 Post(s)
Liked: 458
I see that in the manual but I do not recall being offered that option when I did the Audyssey calibration.  I do recall that both DEQ and Dvol were activated and I did go into the Audyssey menu to defeat both.  I will probably get to doing another EQ in the future and pay more attention to this particular frame.
Kal Rubinson
Old 12-02-2012, 06:02 PM
wse
wse's Avatar
Quoted: 1965 Post(s)
Liked: 739
Denon Link HD
$500 less
What am I missing?
-Brian
You are paying for Marantz name
wse is online now
Old 12-02-2012, 06:04 PM
wse
wse's Avatar
Liked: 739
I know you have three 800Diamond in the front what amplification do you use? Also how far apart are the L/R channels, finally since you have tried both how does the 8801 compares to the SSP-800.
I would love Classe to have DTS NeoX but more importantly Audyssey MultiEQ32X
wse is online now
Old 12-02-2012, 06:09 PM
jdsmoothie's Avatar
Liked: 5501
Great. Thanks. Otherwise, if the next new owner can check as well?. smile.gif
Old 12-02-2012, 07:01 PM
Manchild's Avatar
Denon Link HD
$500 less
What am I missing?
-Brian
XLR outputs.
This is the same when comparing an Integra DHC-80.3 to an Onkyo TX-NR5009.
Manchild is offline
Old 12-02-2012, 07:07 PM
Quoted: 672 Post(s)
Liked: 458
Originally Posted by Manchild View Post
XLR outputs.
Another issue is weight.  I hefted the TX-NR5010 and my DHC-80.2 yesterday.  I am much happier manipulating the latter to install it onto an upper shelf of the rack and having the power amps hidden away as well as closer to their particular speakers.
Kal Rubinson
Old 12-02-2012, 07:29 PM
Manchild's Avatar
Agreed.
Manchild is offline
Old 12-02-2012, 08:44 PM
randman's Avatar
I'm curious how long it takes for the Marantz to switch input resolution. For example, I have a TiVo and would like to configure it to output the native format of the program being watched. However, channel surfing is a pain if you're switching to channels that have different output resolutions. My old Anthem D2 takes some time to process changes to input resolutions so I wound up configuring my TiVo to output a fixed resolution. Obviously, I would prefer to have the preamp processor do the upconversion but only if it can respond to resolution changes quickly.
randman is offline
Old 12-02-2012, 08:50 PM
Bghead8che's Avatar
XLR outputs.
OK. And what else....?
Brian R. Smith
Old 12-02-2012, 09:51 PM
Quoted: 1392 Post(s)
Liked: 587
Denon Link HD
$500 less
What am I missing?
-Brian
The 4520 uses op amps where the 8801 uses HDAM circuits.
Here's a read on the HDAM circuits http://www.dutchaudioclassics.nl/?strBrand=Various&strType=Highfidelity&strPage=Info
In theory, the 8801 should sound better. We'll have to see if it actually does.
JimP is online now
Old 12-02-2012, 10:57 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
The only thing I can find is copper shielding
does'nt the AV7701 feature copper shielding as well? And also torriodial power-supply (not the EI type found in AV7005)?
Old 12-03-2012, 12:15 AM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1664
Denon Link HD
$500 less
What am I missing?
-Brian
One's a receiver and one's a pre/amp processor, not that hard to understand:)
audiofan1 is online now
Old 12-03-2012, 04:34 AM
Theresa's Avatar
Liked: 51
But that is moot as the Denon has pre-outs so it is the equivalent of both a pre-pro and a receiver.
Theresa is offline
Old 12-03-2012, 07:07 AM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
Denon Link HD
$500 less
What am I missing?
-Brian
This was covered a page or 2 earlier. There are quite a few reasons including the DAC's. bigger power supply, HDAM, XLR's, etc. The Denon is the downscaled 8801.
Life is enjoyable with good quality
Dr_Mark is offline
Old 12-03-2012, 07:43 AM - Thread Starter
exm
exm's Avatar
Quoted: 117 Post(s)
Liked: 80
Exactly. The Marantz is build using better internal components and has the benefit of not having to share amplification with its power supply. If all of that results in better SQ is unclear yet.
exm is offline
Old 12-03-2012, 07:52 AM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
For a lot of people "good enough" is just that. If you would probably not hear the differance or care to pay for the upgrades, no reason to waste your money.
Dr_Mark is offline
Old 12-03-2012, 08:12 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
In general, the reasons for getting a pre/pro instead of a receiver have little or nothing to do with the quality of the sound. Unless something's broken, noise and distortion are far below audibility at this level of home audio equipment. There are plenty of other reasons, though, not least of which are the emotional ones. Each potential customer has to decide if they justify the expense. For some people they do, for others they do not.
Selden
Selden Ball is online now
Old 12-03-2012, 08:51 AM
Bill Mac's Avatar
Quoted: 1265 Post(s)
Liked: 1440
SB,
I agree 100% with your thoughts smile.gif. I used to think that a dedicated prepro was the better choice over using an AVR as a prepro. But after owning several prepros then going to the 4311 I notice no loss in SQ. I'm sitting here listening to JT's Hourglass MCH SACD and it sounds excellent (all subjective thoughts of course) smile.gif.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 12-03-2012, 11:36 AM
Theresa's Avatar
Liked: 51
Yes, I too have an emotional attachment to having separates but given the performance and price of the 4311 I am ignoring that emotional attachment. I won't be using any of its amps until I live someplace conducive to 7.1.
Theresa is offline
Old 12-03-2012, 12:56 PM
Theresa's Avatar
Liked: 51
You seem to be saying that even though a receiver may have a full set of pre-outs and has the same sound quality as a pre-pro you prefer a pre-pro. That's o.k., given a choice between a pre-pro and a receiver of the same price and quality I would choose the pre-pro too. But if I must pay a $1,000 more for a pre-pro with the same sound quality as a receiver I must choose the latter. I just ignore the presence of internal amplification.
Theresa is offline
Old 12-03-2012, 01:07 PM
bfreedma's Avatar
Liked: 51
Originally Posted by WestCoastD View Post
Personally I believe a dedicated pre-pro is the better choice ultimately. Although many current-generation AVR's (such as the Denon AVR-4311CI) yield pretty much equal enjoyment in regards to sound-quality and cool features (ie. streaming content, Audyssey Multi EQ XT32, etc.,...), are practical and save space.
However I prefer dedicated separate amplification, as opposed to an integrated pre-amp/processor/amp package. Separate, or dedicated, amplification provides a more "modular" configuration- the user has the ability to upgrade the pre-pro as necessary, while not having to physically change amplification. One could even swap their pre-pro out for a current-generation AVR, such as the Denon AVR-4311CI (which has pre-out's), and still use the same amplification (since many of the latest "cool" features are found in the latest AVR's). Also I can experiment with just about any type of speakers.
In my experiences, employing a high-quality separate amp yield's better performance. Currently I'm using a Denon AVR-2112CI receiver (90wpc) in my living room system (including Energy RC-Series speakers), very impressive performance from this unit considering it's amp specifications. However my theater room features an AV7005/Parasound A51 amplifier (250wpc) configuration, including Monitor Audio GS-Series speakers. Playing the same BluRay source ("Mr. Brooks"- Kevin Costner) on both systems, the dynamics were noticeably better from the dedicated configuration. Both systems employ Audyssey Multi EQ XT. Music listening experience is noticeably nicer as well (I listen to SACD's and DVD-A's, FLAC, etc.,...). Obviously I'm comparing different amp spec's and speakers, etc.,.....but still.
And different rooms. Kind of hard to draw any kind of conclusion given all of the variables involved.
bfreedma is offline
Old 12-03-2012, 01:19 PM
audiofan1's Avatar
Liked: 1664
Not moot at all! it has amps on board disabled or not, additional circuitry is additional circuitry . Why yes of course it can preform the task of driving an outboard amp and the question for many is how well? is it the same? A great debate for sure but the 8801 and other preamp/processors like it are not marketed at the receiver (all in one crowd) but at those who consider it an upgrade over the all in one solution. I would imagine the the additional money is hopefully spent on more attention to detail and better part selection and overall construction but that is debatable as well in regards to sonic merits (YMMV) . Those of you wanting this to be a Denon with out amps is an apples to oranges comparison, no matter how similar they may seem. This is a Marantz 8801 smile.gif
Old 12-03-2012, 01:21 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
Looks like a Denon 4520 with upgraded parts minus the amps. I do like the copper plating, always did like in Pioneer Elites. Not being in Marantz world, what benefit is HDAM?
This looks like a perfect fit for an excellent quality separates solution < the $7500 AVP! Looks like D&M finally got the latest version of Audyssey in there. It was about time wink.gif
I'm still married to Pioneer but I downloaded the manual & all support info...never hurts to keep up with what's out there.
Steve
ss9001 is online now
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
