Marantz AV8801 Preamp/Processor Official Owner's thread - Page 223 - AVS Forum | Home Theater Discussions And Reviews
 294Likes
post #6661 of 13537 Old 07-08-2013, 02:43 PM
Sonic icons's Avatar
Here is a more extensive quote, section header and several paragraphs from David Rich's article, which is primarily a review of the Anthem Room Correction (ARC) system, with some comparison to Audyssey MultEQ XT32. Note that the article is not specifically intended as a review of the Marantz AV8801 prepro, rather the Marantz was chosen for the comparison tests because it is a recent unit with MultEQ XT32.
Notes on High Resolution Signal Processing:
The Anthem D2 and AVM Pre/Pro products that have ARC will process an incoming signal at its native rate up to 96k samples/second. Robert Kozel verified this by using a 30kHz test signal sampled at 96k samples/sec on an Anthem D2. He did the same test with the new Marantz AV8801 Pre/Pro that has Audyssey MultEQ XT32 room correction. The AV8801 did not pass the 30kHz signal because it down-sampled the high resolution test tone to the standard resolution of 48k samples/sec. The Marantz AV8801 is $3,600 before the costs of having the unit upgraded by a Marantz certified Pro Installer using the Audyssey PC based tools and calibrated microphone. Sampling at 96k sample/sec requires twice the DSP resources for the real time filters used for room correction.
Here are graphs (all graphs shown below were produced by Robert Kozel) to illustrate that the Marantz Audyssey processing does not pass 30 kHz, which it otherwise would if digital down-sampling to 48 kHz were not occurring. The signals were 24/96, which is the maximum sampling rate that the Audyssey will accept.
First, an 18 kHz and 30 kHz set of test tones with Audyssey turned off. Note that both test tones are seen in the output.
Now, a graph with the same set of test tones, but with Audyssey turned on. Note that the 30 kHz signal is no longer there. That is because the signal has been downsampled to 48 kHz, and the maximum analog frequency that can be passed through to the output is 1/2 of that, which is 24 kHz.
http://www.hometheaterhifi.com/audio-calibration/audio-calibration-reviews/anthem-room-correction-arc-system-part-1/page-9-room-gain.html
So the main "point" of David Rich's comments about Audyssey XT32 on the Marantz AV8801 seems to be that a "high resolution" 96 kHz / 24-bit test signal is passed unaltered when Audyssey is off, but the same test signal is down-sampled to 48 kHz / 24-bit when Audyssey is turned on.
And I read the sentence "Sampling at 96k sample/sec requires twice the DSP resources for the real time filters used for room correction" as a proposed explanation for why the Marantz down-samples to 24 bit / 48 kHz when Audyssey is turned on. In other words, Marantz designed the AV8801 that way because more DSP resources (higher parts cost) would have been required to accept 24 bit / 96 kHz signals and also do the Audyssey processing of these signals without down-sampling.
(edited shortly after posting to clarify what the Secrets article is saying, in my understanding)
Sonic icons is offline
post #6662 of 13537 Old 07-08-2013, 02:53 PM
comfynumb's Avatar
Liked: 411
^^ Don't fool yourself the Marantz AV7005 made a lot of waves in the AV world. So with the dozens of AVR's and pre/pro's with Audyssey they just had an 8801 handy? I'm not saying this happened but if people think this kind of thing doesn't happen in AV land they are mistaken. In these companies minds it is ALL about the almighty buck. Think about it the 7005 bests a lot of gear worth twice as much and now the 8801 threatens the big boys. Coincidental? Maybe.
comfynumb is offline
post #6663 of 13537 Old 07-08-2013, 03:24 PM
slark's Avatar
Originally Posted by comfynumb View Post
^^ Think about it the 7005 bests a lot of gear worth twice as much and now the 8801 threatens the big boys. Coincidental? Maybe.
"There are no coincidences." -Anonymous.
Where is the 8801's wifi connection?
slark is offline
post #6664 of 13537 Old 07-08-2013, 03:24 PM
I believe that David Rich chose a Marantz AV8801 as the "Audyssey comparison unit" for his article on the Anthem Room Correction system because he wanted to test the most advanced version of Audyssey room correction, which is MultEQ XT32, not MultEQ XT or plain MultEQ. Further, he may have preferred to test an Audyssey prepro, not a receiver (for comparison to the Anthem prepros which are the main focus of the article).
post #6665 of 13537 Old 07-08-2013, 03:28 PM
comfynumb's Avatar
Liked: 411
No wifi it's Ethernet. Wifi is littered with dropped connectivity and that's probably why it wasn't used, IMO. Just ask me about my wifi printer, I'll keep it's brand name anonymous smile.gif
post #6666 of 13537 Old 07-08-2013, 03:34 PM
comfynumb's Avatar
Liked: 411
It is entirely possible this is the case. Or maybe he didn't choose it at all, maybe Anthem did. I'll make you one guarantee, Marantz has cut into the bottom line of more than one of the big boys wink.gif I'll back off the conspiracy theory now lol.
post #6667 of 13537 Old 07-08-2013, 03:53 PM
CruelInventions's Avatar
Quoted: 641 Post(s)
Liked: 787
I could understand why they would want to stay anonymous because you would have to be an idiot to truly believe it. tongue.gif
slark likes this.
The first principle is that you must not fool yourself and you are the easiest person to fool. ~ Richard P. Feynman
CruelInventions is offline
post #6668 of 13537 Old 07-08-2013, 03:58 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1272 Post(s)
Liked: 873
I have never read a review that compares the product under review to brand-x (or even brand M) tongue.gif
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #6669 of 13537 Old 07-08-2013, 04:01 PM
baranowski's Avatar
Quoted: 41 Post(s)
So what exactly does the down sampling do?????
are we talking audio or video or both?
are we talking that if one is playing a blu ray does the marantz down sample the signal even though it should just "pass through"?
are we only talking if the marantz is converting a dvd type signal it down samples it?
i am confused...
Bill
baranowski is offline
post #6670 of 13537 Old 07-08-2013, 04:05 PM
jmschnur's Avatar
Audio only. 96khz 48khz. There is quite a controversy about whether one can hear the difference between the two. The recording and mastering process seem to be much more important . AIX produces some very good . Hi res sound Blu Rays . they have several samplers if you are interested.
jmschnur is offline
post #6671 of 13537 Old 07-08-2013, 04:26 PM
comfynumb's Avatar
Liked: 411
I agree that the recording and mastering are more important. But I do have some SACD's and DVD-A's that sound amazing on the 8801, in fact better than any red book CD I have, so I'm not quite sure what to make of that article. I'm guilty of making too much out of this when it's not clear if this is normal when Audyssey is engaged. I suspect this is a normal for Audyssey and that their room correction benefits far out weigh high res. I have a hard time believing that Audyssey has been out for years and no one knew this eek.gif It would be interesting to see if one of the other "big boys" let high res pass through their room correction. Wouldn't that be a story if they didn't but don't expect those graphs posted any time soon wink.gif Plus the 8801 has been well reviewed so who really cares smile.gif
post #6672 of 13537 Old 07-08-2013, 05:20 PM
matthewa's Avatar
Quoted: 17 Post(s)
I find 24-bit seems to be more an improving factor over the sampling rate
matthewa is offline
post #6673 of 13537 Old 07-08-2013, 05:24 PM
avman09's Avatar
I agree that the recording and mastering are more important. But I do have some SACD's and DVD-A's that sound amazing on the 8801, in fact better than any red book CD's I have, so I'm not quite sure what to make of that article.
It goes both way, I have SACDs that sound better than some of my CDs but also have CDs that sound much better than some of my SACDs.
avman09 is offline
post #6674 of 13537 Old 07-08-2013, 06:55 PM
comfynumb's Avatar
Liked: 411
I agree smile.gif IYO what is your best sounding disc?
post #6675 of 13537 Old 07-08-2013, 07:08 PM
Kal Rubinson's Avatar
Quoted: 802 Post(s)
Liked: 567
Originally Posted by jh901 View Post
With respect to the downsampling, is it the case that L/R bypass will maintain the original resolution?
I also want to be sure that this downsampling only occurs when Audyssey is enabled. So, for example, is the resolution maintained when bass management is utilized?
Also, has it been determined that downsampling is performed on all Marantz prepros released in the past few years which use Audyssey. How about Denon? I'd assume so. I'm not sure which others use Audyssey.
Forgive me for covering this ground once again, but I'm coming in late and appreciate the time and advice.
Most of this is not known.  Someone would have to make an investigation to determine the answers.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #6676 of 13537 Old 07-08-2013, 08:01 PM
steady teddy's Avatar
Quoted: 112 Post(s)
Liked: 53
Apologies in advance if this has already been mentioned but I am logged in from a computer at work and am unable to use the search feature for this thread for some reason.
I skimmed through the PDF manual for the 8801 and I think I found the answer to one of my two questions but I would like confirmation on both.
1) Can the AV8801 output two independent HDMI sources simultaneously?
2) Can a different audio source be assigned to an HDMI video source? I mean can I listen to internet radio or a CD audio while watching video from HDMI? From what I've read in the manual, I am geussing the answer is a definitive NO.
Thanks in advance
Mains: Revel Salon2's powered by ATI AT6002
Center: Revel C208
Surrounds: Revel F208
SW: SVS PB 13 Ultra
Amp: Emotiva XPR5 (surrounds & center)
steady teddy is offline
post #6677 of 13537 Old 07-08-2013, 08:46 PM
jh901's Avatar
Quoted: 518 Post(s)
Liked: 186
Mastering quality is the primary factor (post-recording) and not the resolution. Ideally, the best mastering work for a given music album would be available in hi-res PCM and DSD (both trapped on an SACD and as a file for streaming). Of course, we don't live in that world. There are those who seek out the best digital mastering and I count myself among them. I believe that Kal prefers surround sound mixes for music, but I'll take a great stereo (or mono) mastering any day for playback on my reference system.
In any event, that's way off-topic. Check out the Analogue Productions CCR catalog SACDs for an example of great DSD. Then pick up Audio Fidelity Bob Dylan Greatest Hits Vol. 1 "gold" redbook CD. You will enjoy both. It's the mastering.
HT: Panasonic DMP-UB900 | JVC RS600 | 106" x 45" Stewart ST 100 | Marantz AV7005 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut B6; Focal CMS Sub
Stereo: Cary Audio 306 SACD Pro | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 | Focal Diablo Utopia III
Den: 60" Panasonic VT60
jh901 is offline
post #6678 of 13537 Old 07-08-2013, 08:54 PM
jh901's Avatar
Quoted: 518 Post(s)
Liked: 186
You enjoy the AV8801, but why is it necessary to "prove" that the AV8801 is the best pre-pro in any price range of all-time. Or perhaps "prove" that spending any more will only result in incremental improvements that are nearly inaudible?
Marantz does not design gear intended to be used by the most discerning, budget-free enthusiasts. There are too many compromises at this price point. Start removing the compromises and the price will go up and then we won't be able to afford it. Power supplies and analog output stages, at their best, are not cheap. This is very likely where the Cary Cinema 12, Classe, Bryston, etc will win in overall sound quality.
JimP likes this.
jh901 is offline
post #6679 of 13537 Old 07-08-2013, 09:26 PM
comfynumb's Avatar
Liked: 411
That's not my intention, I'm trying to find out if the reason high res isn't being passed is because of Audyssey or the 8801. If you've followed any of my posts (in the last 6 + months on this thread) you would have already known that I've conceded there's better jh. But I will "stick up" for my 8801 when the occasional nay sayer appears on this thread or give my highest recommendation when someone asks for an opinion or advice when I have the answer. If your looking to pick on someone for their posting style or you just couldn't resist the temptation to share your Marantz philosophy with me, I'm really not interested.
post #6680 of 13537 Old 07-08-2013, 11:28 PM
AlxG's Avatar
Quoted: 23 Post(s)
Liked: 25
In my opinion, our listening room geometry, speakers, equipment synergy and our musical response preference have far more impact on music reproduction than processors.
I've heard bad and good demos with Anthem, Classe and Anthem processors based the rest of the equipment synergy.
In my situation, 2-channel music AV8801 7.1 analog inputs sounds much better as compared to it's own digital inputs. I'm able to hear differences between various DAC's where I wasn't able to hear DAC's differences via D2V so called analog input.
comfynumb likes this.
- Alex
AlxG is offline
post #6681 of 13537 Old 07-09-2013, 12:33 AM
audiofan1's Avatar
Quoted: 1879 Post(s)
Liked: 1955
How sure are you about that in terms of SQ, non of the above will accept a native DSD signal! which alone is a no go at there price point and they are only 7.1 or 7.2 at best rolleyes.gif
audiofan1 is online now
post #6682 of 13537 Old 07-09-2013, 04:00 AM
avman09's Avatar
I agree it is very likely...but that I have the feeling that it would become very unlikely if those were priced lower than the 8801, or in a blind test, even just a simple single blind test.
avman09 is offline
post #6683 of 13537 Old 07-09-2013, 04:15 AM
jh901's Avatar
Quoted: 518 Post(s)
Liked: 186
Right. And in a blind test a 2013 Porsche 911 will drive like a Camry. Ok, ok. I know. We can easily measure the difference in that case. Look, if it makes Marantz owners feel better with the comfort of believing that hi-end engineers, who invest more time and money into various aspects of the component, are making fools out of their customers then so be it. Clearly, it's not enough to be satisfied with a purchase unless all other purchasing decisions, well the more expensive options that is, are "proven" to be a waste.
jh901 is offline
post #6684 of 13537 Old 07-09-2013, 04:52 AM
comfynumb's Avatar
Liked: 411
That's depends if the Camry is 11.2 or only 7.1 like the Porsche biggrin.gif
Read the thread some of us had pre/pro's worth twice as much plus and prefer the 8801, myself not included but my old pre was 3 grand 8 years ago so it wasn't a toy. Somehow you'll have to deal with this, I'm not sure how maybe go purchase a mega buck pre that's 7.1 or 7.2 and tell yourself it sounds as good as some that have wides and heights in a huge room running the 8801. These are tongue in cheek comments and I never claimed the 8801 was the best pre just a darn good one. Now back to more important things.
post #6685 of 13537 Old 07-09-2013, 05:50 AM
Quoted: 1704 Post(s)
Liked: 731
You're making a very large assumption that we're all delusional.
Most if not all of us understand and expect a prepro costing twice as much is going to sound better. Who in their right mind wouldn't expect that?
What the 8801 brings to the table is a very good sound without any operational issues at a price point that we are willing to spend.
wolfdog1959 likes this.
JimP is offline
post #6686 of 13537 Old 07-09-2013, 06:09 AM
Quoted: 802 Post(s)
Liked: 567
8801.  It is simply a matter of the processor having enough DSP to handle higher bitrates.
Kal Rubinson
post #6687 of 13537 Old 07-09-2013, 06:14 AM
comfynumb's Avatar
Liked: 411
Gotcha Kal. So there are some pre's or AVR's using XT32 that can process the higher bitrates?
post #6688 of 13537 Old 07-09-2013, 06:25 AM
comfynumb's Avatar
Liked: 411
Exactly Jim smile.gif I was under no illusion when I traded my old pre in that I had just purchased a product that was an end all game over pre. What I did get was a surprising versatile and great sounding piece of gear. I do not have the best of the best as far as all my gear goes but it isn't bad either smile.gif
post #6689 of 13537 Old 07-09-2013, 06:34 AM
Oppo Beta Group
RichB's Avatar
Liked: 873
There are some idiosyncracies in the 8801. Namely, changes to the sound when changing from even Pure Direct to Direct. Nevermind engaging signal processing.
I have not heard LPCM over HDMI that compares to the analog ins connected to the BDP-105.
Many Anthem users say that the D2V does, but I have never considered this product because it is so damned ugly. All thos silver buttons, what for? Zero WAF smile.gif
I would love Classe performance in a 3K product. From Secrets of Home Theater:
Classé gave me the following, more specific, details about the circuit design: "The DAC is a current output DAC, so there is an I/V converter followed by a reconstruction filter (TI OPA2134), then the volume control, then a buffer stage (National LM4562) followed by a gain stage (also LM 4562). The signal is differential thru the output and biased in Class A. The single-ended output just uses the non-inverting side of the LM4562. There are two DSPs and both are the TI TMS320DA710."
About 5 years ago, I modded an Azentech sound card with LM4562 OpAms and bigger Caps. It sounded fantastic. So, I am not sure this is really about cost since Marantz and many large Electonic manufacturers use Toroidal power supples and other top quality parts. DACs and ICs are relatively cheap. I really think processors have focues on feature count so they can get logos on the box.
It bugs me that changing the video settings changes the sound of the 8801. This is a needless design issue. The BDP-105 is equal parts a video and audio product and altering the video processing never affects the sound. The other problem is the heat.
The 8801 is a very good processor that I feel is better than my old Onkyo 5507.
However, if a processor comes out that, runs cooler, handles HDMI LPCM better, and has impecable analog audio handling, then I'll certainly take a look.
The more Processors that enter the market the better they will all get.
- Rich
RichB is online now
post #6690 of 13537 Old 07-09-2013, 06:52 AM
jh901's Avatar
Quoted: 518 Post(s)
Liked: 186
I'm with you on both points. Appreciated.
I only have a lowly AV7005, but you won't find me running around posting that 8801 owners are wasting money and that they can't "scientifically" justify their purchase.
Off-topic, but if Kal doesn't mind I'd be curious to know a few examples where a multi-channel mix of a 60s-70s rock album bests the stereo (or mono). I bring this up because I thought I recalled reading that he often doesn't find stereo engaging.
jh901 is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
