Marantz AV8801 Preamp/Processor Official Owner's thread - Page 261 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #7801 of 13494 Old 08-20-2013, 09:34 AM - Thread Starter
exm
exm's Avatar
Quoted: 122 Post(s)
Liked: 80
Originally Posted by kbrown425 View Post
Greetings.
Anyone using the AV8801 with the Logitec Harmony One remote? On the initial remote setup, the power on (activity) from this remote turns on all zones, but does not turn all zones off, thus leaving the AV8801 "on". When I programmed the "power on" setting of the Harmony remote by "Learning" the on command button from the Marantz remote, the Harmony One no longer turns on all zones, and only powers up the main zone (which is what I want.) However, the "activity" is not set properly when powering up the system (watch Blu-Ray, watch TV, etc.) and I have to press the activity button a second time once the AV8801 is on in order to set the AV8801 to the desired input. It powers up and defaults to the prior input from the previous session.
Not a big deal, but would prefer to press the "Activity" once and have everything come on per the activity selected. The wife gets confused and I have to remind her to press the activity on the Harmony twice to set the AV8801 to the proper input.
I have this combination and I don't exactly remember what I did, but if you turn the zones off on the Marantz, they should remain off. If I remember correctly smile.gif
exm is offline
post #7802 of 13494 Old 08-20-2013, 09:36 AM
comfynumb's Avatar
Liked: 410
Originally Posted by AlxG View Post
If the hottest point was measured at 140 degrees right at the chip's case, I would start worrying about it. When it's 115-120 degrees at the top of the AV8801 enclosure, it tells me that convection cooling principles are working as it should as long as the cool air is pulled in from the bottom of the enclosure.
Gotcha, I'm not saying it's cause for alarm, just warmer than most IMO. I have a habit of listening at pretty high levels and it gets warmer than my amp.
comfynumb is offline
post #7803 of 13494 Old 08-20-2013, 09:50 AM
Oppo Beta Group
RichB's Avatar
Quoted: 874 Post(s)
Liked: 575
Greetings.
Harmony's attempt to remember the state of you components during an activity.
If something does not receive the code, you have to go to the help or repeat the sequence.
There are up to five actions you can perform asside from those performed by the activity.
You can try adding your discrete ON commands these functions and they should always get set.
Harmony is almost a great remote.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #7804 of 13494 Old 08-20-2013, 10:00 AM
Mad Norseman's Avatar
Liked: 101
Originally Posted by Dave Vaughn View Post
Right over the middle of the HDMI ports is on the top of the unit is the hottest point.
My observations:
I've found that the warmest point (when looking at it from the front) is at the rear/left of the top of the AV8801's cabinet.
So I placed one of the two fans directly atop that.
Second warmest point is at the rear/middle point, so another fan went there.
The rear/right of the AV8801's cabinet only gets slightly warm, and the front half really doesn't get warm at all...
Scott-C likes this.
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #7805 of 13494 Old 08-20-2013, 12:49 PM
kbrown425's Avatar
You are correct. My issue is when using the Harmony remote. It wants to turn on all zones when you follow the standard programming (setup) but does not turn off each zone when powering off. I re-programmed the power-on (for the activities) by learning from the Marantz remote, but this doesn't set the specific activity until I press that activity a second time. It no longer turns on each zone, however, so that is good. I will play with the custom programming on the Harmony remote a bit more. See if I can program each "activity" a bit better when turning on the AV8801.
kbrown425 is offline
post #7806 of 13494 Old 08-20-2013, 12:58 PM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
I am getting ready to upgrade my turntable to a Pro-ject 2Xperience Classic http://www.project-audio.com/main.php?prod=xperiencec&cat=turntables&lang=en that will be connected to a Parasound JC3 phono preamp http://www.parasound.com/halo/jc3.php and then to the analog RCA stereo inputs of my 8801.
I have a pair of Cardas Clear Light Interconnects http://www.cardas.com/clear_light_ic.php that are long enough to go between the TT and the JC3. I have found a pair of Cardas Quadlink 5C http://www.cardas.com/quadlink_ic.php cables at a very reasonable price that I am thinking of using between the JC3 and the 8801.
Do you think stepping down from Clear Lights to the Quadlink cables for one of the legs going into the 8801 will be an acceptable compromise in SQ considering that it will save me about $500?
David Ferebee
discodol is offline
post #7807 of 13494 Old 08-20-2013, 01:09 PM
comfynumb's Avatar
Liked: 410
To be honest I'll bet in a blind test no one could tell which cable is which if you compare those two and a set of $30 generic cables. In every blind test I've seen they get the correct cable around 50% of the time, which means they're guessing. Any quality cable from a place like BJC is all you need. Why spend hundreds or thousands of dollars if you can't hear it? Some guys will tell you they can hear a difference but they'd fail the test too biggrin.gif
OzzieP likes this.
post #7808 of 13494 Old 08-20-2013, 01:10 PM
Homebrew101's Avatar
Quoted: 53 Post(s)
Liked: 63
don't overlook changing out the power cable of the 8801 too
Homebrew101 is offline
post #7809 of 13494 Old 08-20-2013, 01:15 PM
comfynumb's Avatar
Liked: 410
Oh stop it would make no difference if you put a pure gold cable on it. Yikes I fell for the cable debate bait again, I keep failing this test tongue.gif
post #7810 of 13494 Old 08-20-2013, 01:44 PM
audiofan1's Avatar
Quoted: 1651 Post(s)
Liked: 1672
Sucker! biggrin.gif well since you brought it up rolleyes.gif I guess I'll chime for a post and then I'm going home ( I always say this and it leads to just one more! I think I have a problem,wait ! does that mean I'm in cable denial or did I just take the first step eek.gifbiggrin.gif)
Ok here goes! who needs gold when silver or POCCC will do just fine on a power cable wink.gif
audiofan1 is offline
post #7811 of 13494 Old 08-20-2013, 02:01 PM
comfynumb's Avatar
Liked: 410
Yes and we all know it's silver and POCCC from our houses to the power company biggrin.gif
post #7812 of 13494 Old 08-20-2013, 02:26 PM
Quoted: 53 Post(s)
Liked: 63
:popcorn:
http://www.pstracks.com/pauls-posts/homemade-cables/11272/
http://www.pstracks.com/pauls-posts/the-prototype/11277/
http://www.pstracks.com/pauls-posts/lab-cable/11297/
post #7813 of 13494 Old 08-20-2013, 02:32 PM
comfynumb's Avatar
Liked: 410
I'm done with the cable debate. If you can hear the difference I believe you smile.gif
post #7814 of 13494 Old 08-20-2013, 02:34 PM
Waboman's Avatar
Quoted: 4608 Post(s)
Liked: 10786
The cable debate will degrade faster than a signal thru a Bose.
Waboman is offline
post #7815 of 13494 Old 08-20-2013, 02:43 PM
audiofan1's Avatar
Liked: 1672
post #7816 of 13494 Old 08-20-2013, 02:59 PM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
I appreciate the opinion of those who do not think cables make a difference; if anyone out there thinks otherwise I would like to hear your thoughts on my question.
David Ferebee
discodol is offline
post #7817 of 13494 Old 08-20-2013, 03:05 PM
Point Source
beastaudio's Avatar
Quoted: 3546 Post(s)
Liked: 2852
Please not in this thread...Good lord please!!!
beastaudio is offline
post #7818 of 13494 Old 08-20-2013, 03:16 PM
comfynumb's Avatar
Liked: 410
post #7819 of 13494 Old 08-20-2013, 08:37 PM
audiofan1's Avatar
Liked: 1672
Go with your plan as you'll be able to recoup your funds and move up, I say say give them a shot and hope the better ones filter down the benfits wink.gif
post #7820 of 13494 Old 08-20-2013, 09:13 PM
TheFactor's Avatar
Liked: 106
I'll bite :eek:I beleive interconnects make a difference to my ears I have no doubt . I swear by Analysis plus oval one if you don't need XLRs . I recently did a side by side comparison With a higher end Kimber Hero IC to the Oval one and noticed a fuller sound more bass . The kimbers sounded bright I listen to a lot of jazz and the instruments sounded harsh with the kimbers . With some recordings the kimbers sounded better with more detail but they were very picky . I felt the oval ones sounded better with more recordings . Long story short those were my choice after spending 4 days with both with my in house demo . I strongly beleive though it depends on your gear as far as what IC sounds best for you with your setup .
TheFactor is offline
post #7821 of 13494 Old 08-20-2013, 09:57 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 942
Just calibrate XT32 in 8801 today for the second time in three weeks.
On initial set up, I set LCR to large due to waiting for an S2. Well............................calibrated for the second time in three weeks and for the life of me, Audyssey wont let we switch back to small for LCR.
So.....................I went into manual setup and changed crossovers and LCR to small and bumped up sub 3db's. Am I good to go?
I've heard rumors changing anything post calibration ruins the XT32 calibration. Just checking before I blow a few 8" mid-woofers!! biggrin.gif
doublewing11 is offline
post #7822 of 13494 Old 08-21-2013, 04:02 AM
jdsmoothie's Avatar
Quoted: 12243 Post(s)
Liked: 5579
Changing the settings post Audyssey will not impact the actual "EQ" as it's the 8801 that makes those settings and not Audyssey, so then yes, you are good to go. Also note that without a sub in the setup, the FL/FR speakers will default to LARGE as that is where the lower frequencies and LFE would go.
jdsmoothie is online now
post #7823 of 13494 Old 08-21-2013, 04:12 AM
comfynumb's Avatar
Liked: 410
If you lowered your crossovers (raising them has no impact on Audyssey) from where Audyssey had set them everything below that xo point is not filtered by Audyssey, even if set to large I believe. Correct me if I'm wrong guys.
post #7824 of 13494 Old 08-21-2013, 04:59 AM
comfynumb's Avatar
Liked: 410
A big congrats to jdsmoothie! If you notice his new logo he's a member of the AVS Science sales team, and I can't think of anyone more qualified for this. Best of luck in your new venture JD.
jrhooper1963 likes this.
post #7825 of 13494 Old 08-21-2013, 08:12 AM
htdhvy's Avatar
Quoted: 28 Post(s)
Liked: 34
I recently bought a pair of Revel Salon 2’s and I am loving them. I have been listening to them in my bedroom with a Bel-Canto DAC3 directly driving a pair of Ref1000’s and music sounds amazing. I am looking to move these speakers into my main theater rig which is currently controlled by a Marantz AV8003 Processor. The AV8003 has been pretty good for a theater processor although I added the DAC3 to beef up the 2 channel music performance.
My usage is probably 65% music, 35% movies/games. The thing I care most about is stereo audio sound quality.
I’ve done a fair amount of reading and have landed on a few options.
1. Replace the combo of AV8003 and DAC3 with a Anthem D2v (my dealer is able to get me a rather aggressive price on the latest version). I am wondering here how the DACs in the D2v compare with the BC DAC3.
2. Replace the combo of the AV8003 and DAC3 with a Marantz AV8801. Here I am also wondering how the DACs in the AV8801 compare with the BC DAC3. I’m assuming that the D2v is better for 2 channel audio than the AV8801 but im not sure by how much. Also wondering if the AV8801 is a step-up from the AV8003 for stereo music.
3. Replace just the AV8003 with the AV8801 and keep the DAC3. There are a few advantages to having the DACs inside the processor (I can apply adjustments) but of course if the BC DAC3 sounds better than either the D2v or the AV8801 then this might be something to consider.
The D2v will probably cost me about $1500 more than what I can get the AV8801 for.
I have thought about keeping a dedicated two channel setup but it seems like a waste of space and id like to get the benefit of the Salon 2's for movies and the benefit (if possible) of the f113 for music.
If you’re wondering why not just keep the AV8003, it has a few limitations that are really bothersome. There is a bug which keeps it from designating the front speakers as “large” and having a separate subwoofer at the same time. I have a JL Fathom f113 that I want to use with the Salons. Additionally, for a second zone, you cannot use a digital source. I have speakers on my porch and can’t play the music from my apple tv out there. I’m hoping neither the D2v nor the AV8801 have these limitations, but if they do, please let me know.
Thanks in Advance!
Revel Ultima2 Salon2 [pair] || Revel Ultima2 Voice2 || Revel Ultima2 Gem2 [quad] || JL Audio Fathom f212 [pair]
Mark Levinson No 502 || Mark Levinson No 532 || Bel Canto REF1000M || Bel Canto REF1000 [pair] || Audiophilleo2 w/PurePower || Furman IT-Reference 20i || Samsung 65JS9500
HtdHvy's (ever-evolving) Audiophile Home Theater Rig
htdhvy is offline
post #7826 of 13494 Old 08-21-2013, 08:23 AM
comfynumb's Avatar
Liked: 410
Thanks in Advance!
The D2v is old news. Under featured and over priced. Your better off with the 8801 and there are guys coming from the D2v to the 8801 on this thread that will chime in I'm sure. There are also some Salon owners on here, I have the Revel F52's and can tell you the 8801 sounds incredible through them along with a Sunfire amp. Good luck with your choice smile.gif
post #7827 of 13494 Old 08-21-2013, 08:57 AM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
Keep your Dac for sure if you buy the 8801 , I run a separate Dac with my 8801 night and day . I also had 2 Anthems not worth the money
VRD Monoblocks Totaldac Twelve System Music Storage NAS SSD - Dedicated Router - (2) Paul Hynes SR-5 Linear PSU - Controlled by Ipad
Speakers :Joseph Perspective's Cables : Antipodes reference Speaker / IC's - Wywires Silver Juice II - Totaldac D1 USB
All Furutech GTX-D Gold Receptacles
a1usedcomp is online now
post #7828 of 13494 Old 08-21-2013, 09:03 AM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
I would sell my 8801 for 2000.00 if anyone is interested plus fee's and shipping smile.gif
post #7829 of 13494 Old 08-21-2013, 09:40 AM
Quoted: 229 Post(s)
Liked: 942
Thanks.....................
That's what I figured...............yet better check to be on the safe side. biggrin.gif
post #7830 of 13494 Old 08-21-2013, 09:54 AM
comfynumb's Avatar
Liked: 410
Your welcome, I only have about six months experience with Audyssey but this is what I'm reading.
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
