Marantz AV8801 Preamp/Processor Official Owner's thread - Page 265 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
Old 08-30-2013, 12:18 AM
TheFactor's Avatar
Liked: 106
Originally Posted by tombeck View Post
Yes, I also did that, it's the SBR channel. No matter what I do, whatever is attached to the SBR output doesn't output sound (at least nothing that could be used). I wanted to make sure I missed absolutely nothing before I returned the unit. Thanks! smile.gif
That's good and hope you have better luck with the new one so you can start enjoying your setup smile.gif
TheFactor is offline
Old 08-30-2013, 06:43 AM
ezrangel's Avatar
Quoted: 21 Post(s)
Friends, since I installed my 8801, I noticed a small delay on the audio. I tryed lip sync on and off and didnt help.
There´s an option for adicional audio delay but none for pushing audio forword, nor some "video delay" either. Anyone noticed that too?
I use an Oppo 95 and JVC RS4810. Video straight from oppo to the jvc.
Sorry for bad english...
ezrangel is offline
Old 08-30-2013, 07:35 AM
GerryWaz's Avatar
Quoted: 25 Post(s)
There´s an option for adicional audio delay but none for pushing audio forword, nor n"video delay" either. Anyone noticed that too?
I've got the Oppo 95 and the AV8801. Not seeing and hearing that. Only time lip sync is off has been once or twice with a bad, old movie on cable. Have never seen it with things so far from the Oppo (knock on wood). Think I have audio delay set to 0.
I'm also not sending video through the Marantz. Video goes from the Oppo to my Radiance XS via HDMI and then to the display.
GerryWaz is offline
Old 08-30-2013, 07:37 AM
matthewa's Avatar
Quoted: 17 Post(s)
I have an oppo bdp-83 and saw the same thing, when I turned off the ability for OSD of the marantz settings, ie volume displayed etc, that's seemed to solve it for me.
matthewa is offline
Old 08-30-2013, 08:45 AM
ezrangel's Avatar
Quoted: 21 Post(s)
I´ll try that! tks.
ezrangel is offline
Old 08-30-2013, 10:09 AM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
Finally getting around to setting-up my system (believe it or not). I'm planning to use dual monitor (HDMI) outputs- ie. employing (Epson 3020) projector and (Pioneer Elite Kuro PDP-4280HD plasma) flat-screen.
How are others here, using similiar configuration, configuring HDMI Monitor OUT's? Does it matter whether Monitor 1 or Monitor 2 go to projector or flat-screen? (I assume it does'nt matter, that they are equal)
Thanks........
WestCoastD is online now
Old 08-30-2013, 11:36 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 960 Post(s)
Liked: 2929
Thanks........
Greetings,
I have my 8801 connected to my JVC front projector and a 1080p flat panel and it's fine. You designate which HDMI out you want to go to which display and it doesn't matter. Refer to page 128 of the owner's manual for output settings.
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
Old 08-30-2013, 12:03 PM
NGiovas's Avatar
Liked: 43
Is there a list of the IP commands for the AV8801?  I would like to look into controlling my device viva IP.
thanks,
Nick
NGiovas is offline
Old 08-30-2013, 12:11 PM
Blu-ray Reviewer
Moderator
Quoted: 960 Post(s)
Liked: 2929
thanks,
Nick
Greetings,
Yes there are. Send Mark Ruben a PM....
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
Old 08-30-2013, 12:30 PM
Dundas's Avatar
thanks,
Nick
Marantz are very slow in updating their website with downloads for newer products but you can find most of what you need under downloads for the SR7007:
http://us.marantz.com/us/Products/Pages/ProductDetails.aspx?CatId=AVReceivers&SubCatId=0&ProductId=SR7007
Dundas is offline
Old 08-30-2013, 12:33 PM
Super Moderator
markrubin's Avatar
Quoted: 1040 Post(s)
Liked: 2292
I have the complete list for the newest Marantz units including 8801: there are a lot of new codes
PM me with your email if you want the info for IR and serial/ IP commands
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
Old 08-30-2013, 12:44 PM
NGiovas's Avatar
Liked: 43
Thanks Mark and Dundas.  That is a huge help.
Nick
NGiovas is offline
Old 08-30-2013, 02:53 PM
Kevin C Brown's Avatar
Liked: 27
I have an Oppo 95 direct to my Panasonic plasma, audio HDMI to the 8801, and no issues either.
I also have from my 95 to the 8801 to the display, because I wanted to test the difference, and I have video conversion off as well, so no OSD display.
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
Old 08-30-2013, 04:19 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
thanks Ralph, a great help.
Old 08-30-2013, 04:26 PM
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
It appears many 8801 users have "evolved" in their knowledge of Audyssey XT32 and how to apply the settings for the best sound reproduction.
I tend to set my system up for what sounds best with music and use those same settings for multi-channel/HT as well.
What are others here doing, post Audyssey, to tweak the Audyssey settings? ie, DEQ, Dynamic Volume, Audyssey Flat, Sub level increase, etc.
I'm mostly interested in music settings as I like my highs to be "sparkling" and not EQ'd excessively.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. Datasat RA7300, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 106" Carada BW screen, Oppo BDP-103.
knobstoneaudio.com
jdlynch is offline
Old 08-30-2013, 05:04 PM
audiofan1's Avatar
Quoted: 1651 Post(s)
Liked: 1672
Great minds think alike wink.gif I setup for music first as well and have found a friend indeed with Dynamic EQ on 0 for movies and 5 for music and at best a boost on the sub 3 db and when cutting loose +6 db biggrin.gif. The best Audyssey tweak I've found is getting the first position nailed down and by that i mean distance settings as this has the most profound effect on soundfield placement especially for mains and sub! coming from many hours of tweaking distance and level setting with the tape measurer and RS spl meter this knowledge has paid off. I find 10" from the rear of the seat to give the best in bubble and sub articulation and blending with the mains. The second would have to be the last two positions which I do just behind the MLP at about 15 " and 2ft apart , The result has been consistent after trying many a different position and well worth the time of exploration cool.gif
audiofan1 is offline
Old 08-30-2013, 07:59 PM
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Jeff-
I guess my mind is not as great as yours smile.gif Are you saying that you can adjust the Dynamic EQ setting? I thought it was either off or on.
Edit:
Nevermind; I forgot about the RLO adjustment
knobstoneaudio.com
jdlynch is offline
Old 08-30-2013, 08:09 PM
jdsmoothie's Avatar
Quoted: 12181 Post(s)
Liked: 5549
With Dyn EQ set to ON, you can adjust the "Reference Level Offset" setting (p. 124 OM) which is associated with Dynamic EQ and can be set as shown below ....
jdsmoothie is offline
Old 08-31-2013, 06:51 AM
comfynumb's Avatar
Liked: 410
I've always just left the RLO at "0" with DEQ engaged. My preferred genre is rock, that ranges from classic to some harder progressive rock. What are others setting the RLO to when it comes to music. I see the Marantz suggestions when it comes to movies and different genres of music but I'd like to hear your experiences.
comfynumb is offline
Old 08-31-2013, 10:43 AM
erhurd's Avatar
Location: Buckeye, Arizona (Phoenix); USA; Planet Earth
Quoted: 61 Post(s)
Liked: 52
Is this a global setting or can you make a different (custom) setting on a per input basis?
Edwin R. Hurd
AVS Forums Lurker-In-Training!
My Tight-space A/V Setup
erhurd is offline
Old 08-31-2013, 11:39 AM
jmschnur's Avatar
Per input .e.g. Blu ray set at 0; cable set at - 10. Cd set at off.
jmschnur is offline
Old 08-31-2013, 12:47 PM
erhurd's Avatar
Quoted: 61 Post(s)
Liked: 52
Thanks for the info, jmshnur; that's the answer I was hoping to see!
Edwin R. Hurd
erhurd is offline
Old 09-01-2013, 07:56 PM
treky11's Avatar
Quoted: 62 Post(s)
Liked: 111
Can anyone shoot me a PM where they bought their 8801 BELOW msrp?
Sony XBR75Z9D, Marantz 8802A/MM8077, Oppo UDP-203, XBox One S, Kef Reference 205/2, SVS SB16-Ultra
treky11 is offline
Old 09-02-2013, 07:36 AM
Point Source
beastaudio's Avatar
Quoted: 3539 Post(s)
Liked: 2839
Just PM Mike Garrett here on AVS. His name is AV Science Sales 5
beastaudio is offline
Old 09-02-2013, 11:34 AM
Selden Ball's Avatar
Quoted: 3086 Post(s)
Liked: 1509
Or jdsmoothie if you're on the East coast. Mike's on the West coast.
Selden
Selden Ball is offline
Old 09-03-2013, 02:40 PM
Bill Mac's Avatar
Quoted: 1269 Post(s)
Liked: 1446
I haven't kept up with this thread and it is now quite long. I'm wondering if any 8801 owners previously owned Onkyo/Integra prepros and what their thoughts are on the improvements that the 8801 offers. I have a friend with a 5508 and he is looking at the 8801. He is more into stereo and multichannel music than movies. He was thinking of adding a Parasound P5 preamp with HT Bypass but thought the 8801 was a possible option as well. I'd appreciate any thoughts on the 8801 compared to the Onkyo/Integra prepros smile.gif.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 09-03-2013, 02:54 PM
Dave Vaughn's Avatar
Quoted: 896 Post(s)
Liked: 1346
Bill,
I came from the Onkyo/Integra family of products and am glad I did. The audio upgrade is pretty noticeable, especially in the surround channels during multi-channel music and movies.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
Old 09-03-2013, 03:17 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
Bill,
I upgraded from an Onkyo PR-SC5507 but I have made so many changes since then, I cannot honestly say it was the AV8801 alone.
After upgrading to an AV8801 and a Parasound A51, there is a noticeable improvement. My system has never sounded better.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 09-03-2013, 03:26 PM
Bill Mac's Avatar
Liked: 1446
Dave and Rich,
Thanks for your thoughts smile.gif. My buddy has a very nice system with W4S mono block amps, Oppo 95 (modded by ModWright) and Salk speakers. So I think the 8801 would be a fine addition to those components. Maybe I should look at the 8801 as well smile.gif. I see many 8801 owners bought from AVS so I'll contact them for pricing.
Bill
Bill Mac is offline
Old 09-03-2013, 03:40 PM
jmschnur's Avatar
8801 from Integra 80.2. we listen to mainly stereo music . It is clearly better with the 8801.
jmschnur is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
