Marantz AV8801 Preamp/Processor Official Owner's thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #811 of 13503 Old 12-10-2012, 02:09 PM
misterSAX's Avatar
has someone compared A/B Marantz 7701/8801 ?
- musicality
- quality of decoding…
thank you ?
misterSAX is offline
post #812 of 13503 Old 12-10-2012, 08:23 PM
SeattleHTGuy's Avatar
Quoted: 13 Post(s)
Liked: 63
- musicality
thank you ?
I'd day not yet but if you are talking the primary improvement, look no further than a Denon 3311 vs a 4311. Same basic uptick and I will restate what has been said a million times. XT good
XT32 very much better. I too want ac reason to upgrade but really, when it's all said and done you want the 8801 if you desire XT32 and 11.2 plus in a blingy Pre format as opposed to amuch more comman man AVR.
SeattleHTGuy is offline
post #813 of 13503 Old 12-10-2012, 09:34 PM
Quoted: 1437 Post(s)
Liked: 599
- musicality
thank you ?
It's a bit early to say as they're just now starting to ship.
Some are speculating that there is only a difference in features while others argue that basic sound quality will improve with the difference in electronics.
Until more are installed it's mostly speculation.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
post #814 of 13503 Old 12-10-2012, 10:46 PM
misterSAX's Avatar
I've listened on a show in Paris that components are not the same
that they use also Curver inside the 8801???
11.2 is not my objective, find the best sounding processor is my search to replace my Meridian before Audionet and now EAD Signature 8 upgraded by Greg Noble. This one sounds as good in stereo as in multichannel, but with no HD preset, no video treatments (less important beacuase I use a DVDO processor).
So it's time for me to change.
The best of the new generation processors that I've listened is the SSP800 in my mind.
I'm not sure that an intenral acoustic treatment such as Audissey is a priority /necessity for me.
The day where I will search that, I will try to buy a Trinnov MC (for me the top of the top in this field).
A important budget. Yes.
Most of time internal parametric system doesn't work so well as expected (just my opinion).
thank your for your advices
post #815 of 13503 Old 12-10-2012, 11:28 PM
Quoted: 13 Post(s)
Liked: 63
Well then, I would wait on reviews, tests, and your own personal review experience. IMHO I don't expect much diiference between say the 4311 or 4520 to the new 8801. I see it as basically the same technology and signal path in a Pre amp package. Of couse, I haven't even heard it yet and await other capable people to discuss. I am just more in the "it's the XT32 stupid camp". Put another way, although Audyssey via the Pro kit is quite tweakable, you are either a room correction EQ fan or a path purist. The 8801 humbly said will not blow away any other exotic device if not for the utilization of its EQ capabilities. I do not believe that a 32 bit DAc is three times suckier than some futuristic 128 bit DAC....
post #816 of 13503 Old 12-10-2012, 11:49 PM
mankite's Avatar
Quoted: 76 Post(s)
Liked: 61
Even if this piece isn't any better sounding then the Integra pieces I'd rather own it as I've had problems with Integra/Onkyo gear before and always wanted a Matantz or Denon prepro that didn't break the bank and of course has XT32. That leaves the Marantz. smile.gif
Mankite
mankite is offline
post #817 of 13503 Old 12-10-2012, 11:59 PM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Originally Posted by Krobar View Post
Is there external volume control or are the additional 8 bits of the 32bit resolution being used as a neat way to control volume.
I assume volume control is done in the analog domain (under digital control) and not in the digital domain, that would be bad (loss of resolution) and at this price level i assume that is not done.
Daniel.
for men to evolve we have to upgrade
danielo is offline
post #818 of 13503 Old 12-11-2012, 03:01 PM
joerod's Avatar
Quoted: 654 Post(s)
Liked: 527
It's on!!!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
Martin Logan Stage X & Theos FS:
http://www.avsforum.com/forum/209-au...l#post51592513
joerod is online now
post #819 of 13503 Old 12-11-2012, 03:07 PM
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Originally Posted by joerod View Post
It's on!!!
Joe,that's a VERY expensive looking rack you have:D Look forward to the review.
mmarki is offline
post #820 of 13503 Old 12-11-2012, 03:08 PM
sfav's Avatar
Quoted: 23 Post(s)
I hope sound stage comparisons are not going to be made with stacked receivers, particularly on an amp. In addition that Parasound is going to bake the Denon.
sfav is offline
post #821 of 13503 Old 12-11-2012, 03:11 PM
randman's Avatar
The AV8801 manual actually recommends 12" all around it for ventilation. Seems a bit much if true.
randman is offline
post #822 of 13503 Old 12-11-2012, 03:43 PM
joerod's Avatar
Quoted: 654 Post(s)
Liked: 527
I was just doing this for effect. But you are wrong about the Parasound. It has an Antec Component Cooler on top not to mention an eight mini fan block on its back end. Been like that for a year now with numerous Receivers on top and never once and a single issue. And that is after many long football marathons and movie nights. I also have Antec Component Coolers on top whichever Receiver/pre-pro is running. smile.gif
post #823 of 13503 Old 12-11-2012, 03:45 PM
joerod's Avatar
Quoted: 654 Post(s)
Liked: 527
The entire backside of my rack is open to the back room of my basement. It is plenty cold back there so each component is well ventilated. Of course having those Antec Component Coolers help as well. I consider this belt and suspenders for ventilation protection.
post #824 of 13503 Old 12-11-2012, 03:58 PM
randman's Avatar
So it has really started shipping already? A couple of folks got it but didn't sound like the "general public" has gotten any yet... Would be nice if it's available in the next few days... Lots of folks probably have end of the year vacation days they'll be taking!
randman is offline
post #825 of 13503 Old 12-11-2012, 04:22 PM
sfav's Avatar
Quoted: 23 Post(s)
In many cases stacking preamps and processors closely with other components can impact sound quality quite a bit, particularly in the case of the sound stage and noise. I have have seen this in my rack before when experimenting with my Parasound JC2 Preamp, and other components.
sfav is offline
post #826 of 13503 Old 12-11-2012, 04:50 PM
Need4spdnb's Avatar
Joe,
Thanks for having me over today, theater looks great. Looking forward to your findings, I did mine but I am not Joerod, nobody cares. smile.gif
Theater design at Audio Video Interiors of Chicago, Inc.
Right across from the Oakbrook Center Mall.
Noah B.
Need4spdnb is offline
post #827 of 13503 Old 12-11-2012, 05:49 PM
joerod's Avatar
Quoted: 654 Post(s)
Liked: 527
Originally Posted by Need4spdnb View Post
Joe,
Hey, you are more than welcome anytime. It is going to be quite an adventure the next few days. Plugging and unplugging! smile.gif
post #828 of 13503 Old 12-11-2012, 06:32 PM
Kal Rubinson's Avatar
Quoted: 696 Post(s)
Liked: 476
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #829 of 13503 Old 12-11-2012, 06:42 PM
joerod's Avatar
Quoted: 654 Post(s)
Liked: 527
post #830 of 13503 Old 12-11-2012, 06:45 PM
joerod's Avatar
Quoted: 654 Post(s)
Liked: 527
Tough crowd here and I haven't even posted anything relevant yet. biggrin.gif
post #831 of 13503 Old 12-11-2012, 07:09 PM
Quoted: 696 Post(s)
Liked: 476
Just trying to be constructive.  The Zektor MAS7.1 does audio (RCA) and HDMI but for XLR switching I know only of 2channel solutions.
Kal Rubinson
post #832 of 13503 Old 12-11-2012, 07:22 PM
Woof Woof's Avatar
Quoted: 180 Post(s)
Liked: 95
There's this
http://www.emmlabs.com/html/audio/switchman3/switchman3.html#
But it might be overkill just to review a 3.5k AV pre/pro smile.gif
Woof Woof is online now
post #833 of 13503 Old 12-11-2012, 08:07 PM
Quoted: 696 Post(s)
Liked: 476
Originally Posted by Woof Woof View Post
There's this
Great.  I forgot about that and, now that I think of it, there are some others with mulitple 5.1 XLR inputs.
Kal Rubinson
post #834 of 13503 Old 12-12-2012, 12:39 AM
Woof Woof's Avatar
Quoted: 180 Post(s)
Liked: 95
Yeah.. I was looking around for a multichannel XLR solution a while back. Here's another:
http://www.electrocompaniet.no/products/classic/preamp/ec49.html
This isn't so much a switch like the EMM Labs but a proper multichannel XLR analog only preamp
post #835 of 13503 Old 12-12-2012, 04:52 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
It has been 13 hours and 40 minutes since joerod posted his pictures of the 4520 and 8801. Where the heck is the review???? wink.gif
Patience is a virtue I just don't possess!
I am so looking forward to reading this and truly appreciate the effort it takes.
PeterK is offline
post #836 of 13503 Old 12-12-2012, 05:42 AM
scratch17's Avatar
I spoke to my dealer yesterday. He expects delivery sometime shortly after 12/27 on the AV-8801. The MM-8807 will not arrive until late February He will 'lend' me an MM-7055 until my amp arrives. So I guess I will be able to judge SQ differences (if any) between the two amps.
Steven.
scratch17 is offline
post #837 of 13503 Old 12-12-2012, 05:46 AM
misterkit's Avatar
Joerod - comments on the 4520 as a pre/pro with your parasound (compared to the 8801 with parasound) would be much appreciated...thx
misterkit is offline
post #838 of 13503 Old 12-12-2012, 05:55 AM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
The first big batch has shipped. I was told to expect to pick mine up next week Tuesday. Looks like my Dealer has quite a few.. lost the special feeling.. biggrin.gif
Just wondering are your dealers taking your old pro/receiver in trade on a new pro/receiver too? Not a lot of dealers in Minneapolis do that anymore. At least I have a chance to compare the 7005 with the new 8801, before handing it over.
Life is enjoyable with good quality
Dr_Mark is offline
post #839 of 13503 Old 12-12-2012, 11:52 AM
Rosano's Avatar
Well just ordered mine. Maybe one of the first ones in Montreal or in Canada for that matter. Expected at the end of the month or very early Jan. Coming from a Lex MC12HD. Its gonna be a long Christmas lol !
Dr_Mark likes this.
Rosano is offline
post #840 of 13503 Old 12-12-2012, 12:24 PM
planetbrian777's Avatar
I too ordered one and my last pre/pro was a MC12B. I am trying the AV7701 with XLR connections, but I am getting noise out of all my speakers that is audible from 12 feet away. I sure do hope the 8801 will work better with my system. The MC12B was dead quiet because of the fully balanced XLR circuit I am sure.
planetbrian777 is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
