Marantz AV8801 Preamp/Processor Official Owner's thread - Page 295 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #8821 of 13490 Old 10-27-2013, 12:29 AM
Marantzsucks's Avatar
Was hopeful resetting microprocessor would work. No joy. Tried multiple times.
Marantzsucks is offline
post #8822 of 13490 Old 10-27-2013, 04:00 AM
audiofan1's Avatar
Quoted: 1651 Post(s)
Liked: 1669
Did you check the internet connection? try rebooting the main pc and the router with the 8801 shut down and then after powering back up check the internet connection to the 8801. I would try using another of the 4 jacks after this as well.
audiofan1 is offline
post #8823 of 13490 Old 10-27-2013, 04:09 AM
comfynumb's Avatar
Liked: 410
Originally Posted by billpiortp View Post
On the AV8801, is it OK to use the XLR outputs for front, center & surrounds and the RCA output for the sub? This won't cause a problem with the Audyssey calibration? The sub I am considering buying has no XLR input, but my B&K amp has them.hCWpp
Yes it's ok, my sub has no XLR either.
comfynumb is offline
post #8824 of 13490 Old 10-27-2013, 04:14 AM
comfynumb's Avatar
Liked: 410
Originally Posted by thecutter View Post
Is $2900 a decent price for a new AV8801 from an authorized dealer?
Yes it sounds like a decent price, but just for the heck of it I'd contact AVS and see what they want for one.
post #8825 of 13490 Old 10-27-2013, 04:16 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Audyssey won't care how they are connected, only how they sound in the room. But if you ever change from RCA to XLR or v-v it is wise to re-run the calibration as the output levels of XLR/RCA are likely to be different to each other.
kbarnes701 is offline
post #8826 of 13490 Old 10-27-2013, 05:44 AM
Super Moderator
markrubin's Avatar
Quoted: 1039 Post(s)
Liked: 2283
have you tried unplugging AC power for several minutes?
the failed download is not uncommon: if it fails it should still retain old firmware and operate...
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #8827 of 13490 Old 10-27-2013, 09:17 AM
thecutter's Avatar
Quoted: 142 Post(s)
Liked: 48
I just got and installed a Marantz SA-14s1 SACD player(retail $2499). I run it to my Integra 9.9. I also have a Oppo 105 via HDMI to the Integra. The Oppo/Integra combo appears more detailed. Sound is more localized.
The Marantz player seems good for redbook CD. The SACDs sound great! The music is integrated and softer.
I have a Marantz AV8801 on order. Will I loose the details in music with oppo to Marantz processor via HDMI? I listen to 80s alternative music with lots of synthesizer music. I don't want the sounds muted. Will the Marantz affect the sound and tone it down?
thecutter is offline
post #8828 of 13490 Old 10-27-2013, 09:34 AM
comfynumb's Avatar
Liked: 410
You'll have to try different combinations to see which one you like best. Is the Marantz player that much better than the Oppo 103 or 105 for CD's? What did you end up paying for it?
post #8829 of 13490 Old 10-27-2013, 09:38 AM
Thanx for the response guys but I tried rebooting and trying all jacks, does not work. Unplugged for several minutes does not work. I did however try resetting the microprocessor a few more times. Result, now the failed connection went away. However the bad news is the pre/pro does not/ will not try to reconnect anymore to complete update download and I can't go into the unit's setup. Clicking on any input result is only a two channel stereo, no sound, can't change any settings and nothing else works. She seems to be dead in the water.
post #8830 of 13490 Old 10-27-2013, 09:40 AM
I need some serious help guys. I got the 8801 about three weeks ago. The on screen menu started to flicker/blink on all inputs except for game and cable/sat. Checked all cables and restarted equipment with the same results. So I then go to update the firmware to see if this would resolve the issue. I started the download then was hands off. It never completed the download. Now i get connection failed 0E. Retry connection fails every time. i just had a flicker problem before now i can't even use my unit. Will call tech support on Monday. This sucks.
Equipment
Marantz 8801 pre/pro
Marantz 8807 amp
Yamaha MX-1 amp
B&W CM10
B&W CM Center 2
B&W CM Center x 2 FH
B&W CM1 x 4 SR and SRB
M&K MX-125 Sub
post #8831 of 13490 Old 10-27-2013, 09:40 AM
jdsmoothie's Avatar
Quoted: 12139 Post(s)
Liked: 5528
Originally Posted by labman1 View Post
I'm running a PS3 through the Bluray input and it will not show DTS MA. It shows DTS Neo X: Game. what do I have to do for it to show DTS MA? I'll check to see what I have the PS3 set on but I'm sure its bitstream.
Okay Guys Figured it out. Had to go back and reset after I connected to the 8801. Thanks anyway!rolleyes.gif
A good reminder for new buyers that the PS3/Blu Ray player connected to a TV will likely be set to pass STEREO audio only and must be reset while connected to the 8801 so it can detect the multi channel capability of the 8801, otherwise it will simply continue to pass STEREO audio and the 8801 will use a simulation mode to get to 5.1/7.1/9.1/11.1 (eg. DTS Neo:X). Also note on the PS3, if video issues are present, set the PS3 "Deep Color Output" to OFF.
jdsmoothie is offline
post #8832 of 13490 Old 10-27-2013, 09:45 AM
jdsmoothie's Avatar
Liked: 5528
Try doing a network reset by pressing/holding the MOVIE and MUSIC buttons on the front panel while powering on the unit.
post #8833 of 13490 Old 10-27-2013, 09:53 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
[8 -Ball]
Call around.
[/8 -Ball]
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #8834 of 13490 Old 10-27-2013, 09:57 AM
comfynumb's Avatar
Liked: 410
Originally Posted by RichB View Post
Call around.
- Rich
I wish I shopped a little more, but I think I paid for getting one of the first batch. Next time I will be a little more thorough wink.gif
post #8835 of 13490 Old 10-27-2013, 10:06 AM
Mad Norseman's Avatar
Liked: 101
Do you have a 'trade-in' to barter with?
If so, try these guys (authorized dealer):
http://hifiheaven.net/store/Products/Home-Theater-Electronics/Marantz-AV8801-AV-11.2-Channel-Preamplifier-processor
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #8836 of 13490 Old 10-27-2013, 10:13 AM
I haven't tried that yet. Well just tried it, same results. I'm all out of ideals.
post #8837 of 13490 Old 10-27-2013, 10:18 AM
comfynumb's Avatar
Liked: 410
If that doesn't work then the next step is to get ahold of Marantz, but I'd go for a replacement from your dealer if it was bad from the get go.
post #8838 of 13490 Old 10-27-2013, 01:07 PM
Point Source
beastaudio's Avatar
Quoted: 3516 Post(s)
Liked: 2834
Maybe check right here at AVS by private message to Jdsmoothie or av science sales 5 (aka Mike Garrett)
RayWK likes this.
beastaudio is online now
post #8839 of 13490 Old 10-28-2013, 07:44 AM
comfynumb's Avatar
Liked: 410
I know the only way to bypass the DAC in the 8801 is to use Direct or Pure Direct. This only holds true only for the analog inputs correct? If I use the HDMI inputs I'm using the 8801's DAC right?
post #8840 of 13490 Old 10-28-2013, 07:59 AM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Inevitably.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #8841 of 13490 Old 10-28-2013, 08:03 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
The only way to be certain to bypass the 8801 DACS is to use the 7.1 analog inputs.
Since the XLR inputs support LFE+MAIN the bass must be processed. I suppose that could be in parallel but the timing would be difficult.
If analog bass management was possible, then it would likely be supported for the 7.1 analog inputs, which it is not.
- Rich
RichB is online now
post #8842 of 13490 Old 10-28-2013, 08:08 AM
comfynumb's Avatar
Liked: 410
Originally Posted by Kal Rubinson View Post
Inevitably.
- Rich
Thanks guys I thought so and there is so much false information out there on this subject I wanted to be sure.
post #8843 of 13490 Old 10-28-2013, 12:17 PM
audiofan1's Avatar
Liked: 1669
- Rich
I still hear no bass from my sub nor does the power light come on , when using Pure direct via xlr using the cd input , direct may be a different story! tongue.gif
post #8844 of 13490 Old 10-28-2013, 12:25 PM
Selden Ball's Avatar
Quoted: 3074 Post(s)
Liked: 1501
Neither Direct nor Pure Direct will provide any subwoofer output on their own if there's no LFE channel provided in the source material. Unlike movies, very few multichannel music recordings include an LFE channel. All of their bass is included in their main audio tracks.
Having said that, if you're using digital inputs or stereo inputs (including the stereo XLR input), you can enable LFE+MAIN, which will copy (not remove) the low frequencies from the main channels to the subwoofer channel. That'll provide additional bass output. However, there will be interference in the frequency range where the subwoofer overlaps with the main speakers, resulting in what's known as "bloated bass".
goodkat likes this.
Selden
Selden Ball is online now
post #8845 of 13490 Old 10-28-2013, 12:41 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
I just verified that the XLR's work with LFE+Main on the CD input.
When I select the XLR inputs it really does not matter what input is assigned to, it still works.
LFE+MAIN engaged my subs in Pure, Direct, and Stereo mode.
The high-pass filter is set to 120hz.
All speakers are set to large.
If that does not work, contact tech support, your unit is defective.
- Rich
RichB is online now
post #8846 of 13490 Old 10-28-2013, 01:05 PM
audiofan1's Avatar
Liked: 1669
- Rich
Not defective at all, for one all video functions and display ( besides a flash of volume level and channels and it may even display the sub icon with the FR/FL but its not playing and your're not allowed to make any adjustments) while in Pure direct are disabled, can you increase the sub level? no you cant and the as for the High pass filter, it's meaningless! as it has nothing to do with stereo sources since there's no .1 channel. Now yes you can have sub with XLR in plain Auto or stereo regardless of input as I've verified as well but not I repeat not with Pure direct
In pure direct your not able to access the menu at all for any adjustments, so how are you doing so?
post #8847 of 13490 Old 10-28-2013, 01:18 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
  1. Exit Pure Direct Mode by pressing the Pure mode or button until the blue light is off (any mode will do).
  2. Enter the menu and Make changes.
  3. Enter Pure Direct mode by pressing the Pure button.
Changes that are made while not in Pure mode are still effective.
Also, If you are looking at the front panel channel display, it default to display the input signal.
You can change that to display the output which should show the sub active.
- Rich
RichB is online now
post #8848 of 13490 Old 10-28-2013, 01:23 PM
audiofan1's Avatar
Liked: 1669
- Rich
I owe you an apology Rich I increased the volume full tilt on the sub and it indeed came on wink.gif
post #8849 of 13490 Old 10-28-2013, 01:32 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
No problem.
We have been on this road a while, I am glad you got it working.
- Rich
RichB is online now
post #8850 of 13490 Old 10-28-2013, 01:33 PM
audiofan1's Avatar
Liked: 1669
No problem.
- Rich
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
