Marantz AV8801 Preamp/Processor Official Owner's thread - Page 302 - AVS Forum | Home Theater Discussions And Reviews
 288Likes
Old 11-08-2013, 05:46 PM
Norcuron's Avatar
Liked: 25
I have a volume question. I had an older CD playing through my PS3 today and I was able to turn it up to about 92 on the volume but it would not physically go higher even though in setup it shows to 98. I was kind of surprised that was absolute maximum volume. It's not like my amp is underpowering the system. It was very loud but still very clear. Any ideas? Thanks
Marantz AV 8801 Processor
Sunfire Signature Amp 400x7
Oppo DV971H DVD Player
PS3
PS4
Klipsch RF-7
Klispch RS-7
Klipsch RC-7
Sharp Aquos 80; 3D Quattron
Power Sound Audio Triax Subwoofer
Norcuron is offline
Old 11-08-2013, 05:54 PM
comfynumb's Avatar
Liked: 410
If your trim levels are high the Max volume number goes down. I think or at least they did on my previous pre/pro.
comfynumb is offline
Old 11-08-2013, 06:00 PM
Norcuron's Avatar
Liked: 25
Fronts: -6
Center -3.5
Surround -3.0
Sub -6.5 but I did increase it to -3.5 for a little more.
Seems weird everything is negative trim yet still that limit.
PS3
PS4
Klipsch RF-7
Klispch RS-7
Klipsch RC-7
Norcuron is offline
Old 11-08-2013, 06:13 PM
comfynumb's Avatar
Liked: 410
Fronts: -6
Center -3.5
Surround -3.0
You should use the relative volume scale, that way you would know 0 is reference. Just a thought. Under settings>volume there is a way to limit the volume, maybe your max is set at 92.
Old 11-08-2013, 06:36 PM
Norcuron's Avatar
Liked: 25
Thanks..I appreciate you trying to help. I tried the DB route too and it stopped at like 12 instead of 18. The max is set to no limit.
On a side note.....If all of my trims are set to a negative number for example:
Fronts: -6
Center -3.5
Surround -3.0
Is there a negative to increasing them all by 3DB so surrounds would be 0, fronts -3db and Center -.5? Sub I can take care of separately.
PS3
PS4
Klipsch RF-7
Klispch RS-7
Klipsch RC-7
Norcuron is offline
Old 11-08-2013, 06:56 PM
comfynumb's Avatar
Liked: 410
Fronts: -6
Center -3.5
Surround -3.0
If Audyssey set them you should leave them there at least for movies. I do turn my surrounds and center down a few db for music.
Old 11-08-2013, 10:51 PM
wse
wse's Avatar
Quoted: 1821 Post(s)
Liked: 703
Question is the Marantz a fully differential balanced design?
wse is online now
Old 11-08-2013, 11:25 PM
Quoted: 1238 Post(s)
Liked: 548
That was asked before and I believe the answer was that it wasn't.
JimP is online now
Old 11-09-2013, 12:22 AM
Roger Dressler's Avatar
Quoted: 1509 Post(s)
Liked: 705
Fronts: -6
Center -3.5
Surround -3.0
Manual page 44 states: >>The variable range differs according to the input signal and channel level setting.<< That means the channel gain trims can affect volume range, and so can the Source Level settings (p. 135). The thing is, you may find that no matter what you do, the overall max gain from source to output jacks remains a constant. OTOH, you may find that you can game the system to get more juice out of it. It depends on how the designers wrote the code -- did they pre-allocate certain ranges to certain functions, or is it a zero sum game. All three of these controls are talking to a single analog volume control stage, and that's why these things are not fully independent.
You can try some experiments. Change the source level setting for the CD input, say, 5 dB higher. Does the volume range go down another 5 dB or stay the same? If same, it ought to sound louder.
You can also try raising the gain trims by 3 dB idea. The only things that affects are the volume reading for a certain SPL, and since those numbers mean nothing, no need to worry. It will also shift DEQ to act 3 dB stronger, so you'd have to either like it, turn it off, or use RLO to compensate.
I wouldn't worry about secondary effects until you determine what's interacting with the volume range.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
Old 11-09-2013, 12:46 AM
Liked: 705
I have a question. Using the volume scale setting in the -79/+18 mode, I'd like to find out the actual SPL of a known test signal when the volume is set to 0 dB. Do you have one of the various test discs that have noise signals such as THX Optimizer, or Spears/Munsil, etc? If you have the AIX disc, set the volume to -10 for this test as their noise is recorded 10 dB louder.
Old 11-09-2013, 06:29 AM
thunderstorm77's Avatar
I'm considering the 8801. I don't doubt the sound quality. I will however be using this in a setup with several sources, and switching b/w TV and projector outputs. All HDMI. My issue is then: how good is the 8801 as a HDMI switch/matrix?
I will use it in an automated setup with iRule, and it needs to be very reliable as both my wife and kids will use it.
thunderstorm77 is offline
Old 11-09-2013, 08:29 AM
wse
wse's Avatar
Liked: 703
Originally Posted by JimP View PostThat was asked before and I believe the answer was that it wasn't.
Are any of them fully balanced?
wse is online now
Old 11-09-2013, 08:42 AM
comfynumb's Avatar
Liked: 410
I think fully balanced is a myth or for people that can afford a $15,000 pre/pro wink.gif Explain fully balanced?
Old 11-09-2013, 08:44 AM
Selden Ball's Avatar
Quoted: 2789 Post(s)
Liked: 1349
Supposedly some high-priced stereo preamps and amps are fully balanced.
Dont' forget that XLR connections are irrelevant in most home audio environments. The improvements they provide are primarily emotional ones. While they do provide more secure mechanical connections than many RCA connectors, their primary purpose is to reduce pickup of broadcast noise. This is very important in a live music presentation on a large stage where cables have to run long distances in an electrically noisy environment. Most homes are not like that.
Selden
Selden Ball is offline
Old 11-09-2013, 09:03 AM
wse
wse's Avatar
Liked: 703
Well if you use active studio monitors you need fully differential balanced
http://www.ti.com/lit/an/sloa054d/sloa054d.pdf
wse is online now
Old 11-09-2013, 09:34 AM
spentmuch's Avatar
"Dont' forget that XLR connections are irrelevant in most home audio environments. The improvements they provide are primarily emotional ones. While they do provide more secure mechanical connections than many RCA connectors, their primary purpose is to reduce pickup of broadcast noise. This is very important in a live music presentation on a large stage where cables have to run long distances in an electrically noisy environment. Most homes are not like that".
Couldn't agree more. And I'll add that your statement applies to most of the hype pitched by hind end cable manufacturers and retailers. I am particularly fond of the "hospital grade" AC power cords that are 3 feet long and sell for the big bucks. "Can't you hear the better imaging detail"? Never mind the fact that these pieces of wire are plugged into your electrical outlet that is fed from long runs of cheap wire. Relatively short runs of speaker wire? I'll admit I've fallen into the "emotional satisfaction" trap in years past too, buying gigantic, outrageously priced short runs of "biwire" speaker cable, all to the great satisfaction of the retailer who "just wanted me to get the best sound quality". Gotta love this hobby!
spentmuch is offline
Old 11-09-2013, 10:06 AM
Mad Norseman's Avatar
Liked: 101
The Emotiva XMC-1 to be available this January (or February?) will be a 'fully balanced' surround pre-pro.
Part of their product description reads:
"The XMC-1 is also a highly refined pure analog preamplifier, with a fully balanced audio path. Its analog performance easily meets the needs of the most demanding two-channel playback system".
Also a surround processor with Dirac Live™ room correction...
http://shop.emotiva.com/collections/processors/products/xmc1
$2,000.
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
Old 11-09-2013, 10:11 AM
comfynumb's Avatar
Liked: 410
I know and they all claim fully balanced. I'm assuming the Marantz isn't truly fully balance but would we know one if we heard it? I am not convinced and just like spentmuch said above there are many myths in high end audio and the higher up the ladder you go the bigger the claims are. One thing I'm sure of is the 8801 is one great sounding piece and it will stay in my setup for a long time. In 3 or 4 years maybe Atmos will make it to HT and I can do a dedicated 2.1 music room with the Marantz.
Old 11-09-2013, 11:30 AM
wse
wse's Avatar
Liked: 703
"The XMC-1 is also a highly refined pure analog preamplifier, with a fully balanced audio path. Its analog performance easily meets the needs of the most demanding two-channel playback system".Also a surround processor with Dirac Live™ room correction...http://shop.emotiva.com/collections/processors/products/xmc1
$2,000.
I will never buy EMOTIVA until they get rid of that smell!
wse is online now
Old 11-09-2013, 11:47 AM
SeattleHTGuy's Avatar
Liked: 48
I will receive the 8801 on Tuesday "WoooHooo!" Personally, I will use XLR cables to my amplifiers simply because of the infinitely more robust connections. My middle age plus ears could never hear a difference based on cables. I have, however, had equipment bend and break due to RCA connections. Emotive 1t Series XPA amplifiers are notorious for wimpy RCA connections. Go look at the back of the new Series 2 stuff to see they re-engineered the RCA connects. Too many returns due t the old connections breaking off the back board.
So, it's XLR's for me!!!
SeattleHTGuy is offline
Old 11-09-2013, 02:07 PM
Kris Deering's Avatar
Quoted: 1469 Post(s)
Liked: 2204
The 80.3 in 5.1 is fully balanced end to end. The Denon is fully balanced as are a few other high end models. The upcoming Emotiva design is too supposedly.
My Home Theater
Kris Deering is online now
Old 11-09-2013, 02:09 PM
Liked: 2204
I had the XSP-1 and currently have the XPR monos and XPA-2 second generation and not so much as a hint of any smell.
My Home Theater
Old 11-09-2013, 02:56 PM
Liked: 101
(Hmmm, I thought that 'Emo Dan' already took you to the woodshed over that comment?).
And I've never heard this from anyone but you, and it was a 'one-off' condition I understood from that thread, but suit yourself! cool.gif
Old 11-09-2013, 03:07 PM
Oppo Beta Group
RichB's Avatar
Quoted: 743 Post(s)
Liked: 501
Are any of the newer Denon's fully balanced?
- Rich
Oppo BDP-105D | Oppo HA-1 | Emotiva XMC-1 | Oppo PM-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 11-09-2013, 03:13 PM
Liked: 2204
The only Denon that is balanced is the AVP-1.
RichB likes this.
My Home Theater
Old 11-09-2013, 03:18 PM
whoaru99's Avatar
Liked: 68
If your speakers have balanced inputs then yes, it makes some sense to connect them to something with balanced outputs. However, that doesn't mean the pre/pro needs to be fully differential/balanced circuitry throughout.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 11-09-2013, 03:50 PM
wse
wse's Avatar
Liked: 703
wse is online now
Old 11-09-2013, 03:52 PM
wse
wse's Avatar
Liked: 703
Integra is fully balanced, good
wse is online now
Old 11-09-2013, 05:58 PM
Spiky's Avatar
Quoted: 150 Post(s)
Liked: 48
The XMC-1 is not fully balanced, Emo has stated that much. Is that the one you meant? They have discussed another model in the future, but I wouldn't worry about that until there's something even partially concrete.
Spiky is offline
Old 11-09-2013, 07:12 PM
Oppo Beta Group
RichB's Avatar
Quoted: 743 Post(s)
Liked: 501
From the Emotiva Site:
The XMC-1 is also a highly refined pure analog preamplifier, with a fully balanced audio path. Its analog performance easily meets the needs of the most demanding two-channel playback system.
- Rich
RichB is online now
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
