Marantz AV8801 Preamp/Processor Official Owner's thread - Page 328 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
post #9811 of 13500 Old 01-05-2014, 07:54 AM
comfynumb's Avatar
Liked: 410
Originally Posted by PaulForgey View Post
AirPlay is always 44.1 going out. Worse, Apple TV will up convert this to 48k (and there are plenty of ways to do sample rate conversion badly). While messy, I did get my 8801 to play 96k ALC files in their native form using a DLNA server set to never transcode. Fortunately, the 8801 knows how to deal with ALC and FLAC. Not as convenient as AirPlay, of course.
Airplay may always be 44.1 except when converted by the ATV, but there's no doubt it sounds better streamed from a PC over an iPhone or iPad. How are your high res files playing on your network with a HTPC or HD plugged into your router?
comfynumb is offline
post #9812 of 13500 Old 01-05-2014, 10:25 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Originally Posted by JimP View Post
What also happens often is that users want to use the standby button to turn on the 8801 when they should be using one of the input buttons such as "cab/sat", "DVD", etc.
I think i'll put a piece of tape over the standby button to prevent folks from messing with it including myself and try and have it turn off in an automated manner. Or just leave the thing on...
Blazar!
blazar is offline
post #9813 of 13500 Old 01-05-2014, 11:12 AM
jletourn's Avatar
Originally Posted by jdsmoothie View Post
When you cycle the power ..... also unplug the 8801 from the power for at least 10 minutes.
Thanks for your 10 minute miracle. Everything is back to normal after unplugging for 30 minutes or so. Thanks again!
jletourn is offline
post #9814 of 13500 Old 01-05-2014, 11:17 AM
jletourn's Avatar
I don't use the buttons on the unit, just the Universal Remote MX-900 which was configured by my installer. Does the Universal Remote operate the power correctly? (using the input instead of standby?)
jletourn is offline
post #9815 of 13500 Old 01-05-2014, 11:17 AM
jdsmoothie's Avatar
Quoted: 12252 Post(s)
Liked: 5583
A "soft reset" (ie. 10 minutes of no power) is like giving your AVR an aspirin ... it will often cure what ills the unit. smile.gif
jdsmoothie is online now
post #9816 of 13500 Old 01-05-2014, 11:57 AM
Quoted: 1394 Post(s)
Liked: 589
It depends on whether or not it was programmed correctly.
There's quite a few of us who had difficulty doing it.
You should have the 8801's original remote. Use it and see if its a prepros problem or a remote programming problem.
JimP is offline
post #9817 of 13500 Old 01-05-2014, 01:14 PM
GerryWaz's Avatar
Quoted: 26 Post(s)
I'm experiencing a very minor issue with the AV8801's input screens displaying on my TV. Not sure it it's a bug or something that I may not have set up right (probably the later biggrin.gif ).
I don't use the AV8801 for video as I have a Radiance VP for that (all videos go the Radiance and then to the display). So I'm running HDMI (from the AV8801's monitor1) to a HDMI input on my display (which does not support ARC), mainly for when I need to use Setup, watch HD radio info, or for Media Server selections via the Network input.
I was experimenting last week with the Network input and testing out the MediaMonkey media server (running on my main HP desktop) and also trying out the Plex Media Server on my Synology NAS (both were playing music just great, though I preferred MediaMonkey for its Playlist support).
However, I'd switch inputs on the AV8801 (say going from Network to Tuner or Setup and back) and I'd lose one or more of the appropriate screens from the AV8801 displaying on my TV. The pattern was never consistent for this happening.
So far, I've tried the following and they have not fixed the issue:
  • Re-pressing the desired input choice again with the remote or on the AV8801's front
  • Turning the unit on and off--might help at first but eventually after a few input changes, one or more of the AV8801's screens menus disappears from the display
  • Resetting the microprocessor
  • Unplugging the unit for 30 minutes or more - this worked great initially but after waiting a few minutes and re-testing, the problem came back
  • Trying other HDMI cables
If I press various inputs back and forth, eventually I can usually get a screen that I need to reappear. Then, sometimes after, all the screens may display fine with input changes for a short while.
I am on the latest firmware.
Again, not an earthshaking issue. More of a small inconvenience.
Any ideas what might be going on? A wrong setting somewhere?
GerryWaz is offline
post #9818 of 13500 Old 01-05-2014, 02:18 PM
PaulForgey's Avatar
Are you actually turning off the Airplay source by pressing and holding the "Enter" button on the Marantz remote (recommended) or are you simply setting the 8801 to Standby?
the problem happens when I do that before entering standby (press and hold enter or hitting stop on the transport control - both are the same AirPlay command). If I simply enter standby, the problem does NOT happen.
PaulForgey is offline
post #9819 of 13500 Old 01-05-2014, 03:33 PM
TKO1's Avatar
Liked: 65
Why would that be. Airplay is Apple Lossless regardless if it is on wifi or wired.
Cheers.
TKO1 is offline
post #9820 of 13500 Old 01-05-2014, 03:48 PM
comfynumb's Avatar
Liked: 410
Cheers.
I didn't mean wired I meant AirPlay sounds better if you use your laptop or PC rather than your iPhone or iPad. I've compared them myself and I'm assuming it's because a PC is just more powerful than a iPhone or iPad. I also read it somewhere but I'm having no luck finding it again.
post #9821 of 13500 Old 01-05-2014, 06:02 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Airplay device such as airport express is receiving and transmitting uncompressed audio which is basically wav/pcm. The device such as laptop or ipod is converting the apple lossless file before sending to airport express.
Blazar!
blazar is offline
post #9822 of 13500 Old 01-05-2014, 06:31 PM
etc6849's Avatar
Quoted: 168 Post(s)
Liked: 124
Maybe I'm missing something, but what's wrong with using the standby button on the front of unit or the one on the remote?
From the front, there's no other way to turn it on, besides flipping the door open and using the zone buttons which is a lot of work. Further, you can't select an input first without turning the unit on as the dial on the front doesn't work until the AV8801 is on. It is true that you can select the input to turn on the unit when using the remote, and even when using TCP which is nice.
At any rate, the unit works fine for me and I've used the front standby button many times. My home automation system I programmed (had to write the AV8801 driver from scratch) stays 100% in sync with the unit via the two-way tcp communications (I have network set to "always on"). I don't use the IR remote a lot, but it works also .
Premise, a FREE home automation program. Open-source Z-Wave Premise Module found here.
etc6849 is offline
post #9823 of 13500 Old 01-05-2014, 07:35 PM
Liked: 589
I was referring to the remote control.
JimP is offline
post #9824 of 13500 Old 01-05-2014, 08:32 PM
admranger's Avatar
Quoted: 14 Post(s)
Airplay via apple tv is NOT bitperfect and will upconvert music. Via airplay on an airport express i think it is bitperfect as long as no volume control is used (volume on itunes or music app is maxed out).
I am setting my marantz up after vacation when i get home tomorrow and this week i will put airplay in the marantz on my list of stuff to try.
It's possible that you are using pure direct with the CD player and audyssey "stereo" mode with equilization when you do airplay?
That's exactly what I'm doing. Same speakers, though the audyssey uses my dual 10" subs for the low end in addition to the front L & R speakers.
The audyssey should make it "better", right? It doesn't. Pure direct from the Oppo 95 just sounds much better. Not even close. It's not like I'm sending 256k songs via airplay. The files are in apple lossless format on the mac.
So I am missing something...
Marantz 8801 Marantz 7055 Merrill Thor Monobolcks Oppo 95 SystemDek IIX turntable ATC SCM 19 V2's (L&R) B&W LCR6 (center and heights) B&W in ceiling surround speakers Velodyne SPL-10 Subs (2) Sony xbr65x850a
admranger is offline
post #9825 of 13500 Old 01-05-2014, 09:16 PM
wse
wse's Avatar
Quoted: 2040 Post(s)
Liked: 748
I read the Yamaha CX-5000 sounds better than the Marantz any one had the opportunity to compare?
wse is offline
post #9826 of 13500 Old 01-05-2014, 09:23 PM
Dave Vaughn's Avatar
Quoted: 907 Post(s)
Liked: 1369
I had them both in my home at the same time and I wouldn't call that a fair statement. Both sound fantastic in their own rights but just slightly different (not in a bad way).
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #9827 of 13500 Old 01-05-2014, 09:39 PM
comfynumb's Avatar
Liked: 410
Dave, nice review of the Yamaha by the way. It sounds like a great pre/pro and I welcome the competition and hopefully we'll reap the benefits from it.
post #9828 of 13500 Old 01-05-2014, 09:59 PM
Waboman's Avatar
Quoted: 4614 Post(s)
Liked: 10797
Correct me if I'm wrong, but the Yamaha doesn't have subwoofer XLRs.
Waboman is offline
post #9829 of 13500 Old 01-05-2014, 11:36 PM
wse
wse's Avatar
Liked: 748
So which do you like best and why?
wse is offline
post #9830 of 13500 Old 01-05-2014, 11:37 PM
wse
wse's Avatar
Liked: 748
Yes
wse is offline
post #9831 of 13500 Old 01-06-2014, 12:47 AM
CIH USER
Franin's Avatar
Quoted: 2194 Post(s)
Liked: 1318
David, nice review of the Yamaha by the way. It sounds like a great pre/pro and I welcome the competition and hopefully we'll reap the benefits from it.
I must of missed the review, was it done through AVS?
_________________________
Franin is offline
post #9832 of 13500 Old 01-06-2014, 12:53 AM
comfynumb's Avatar
Liked: 410
http://www.soundandvision.com/content/yamaha-cx-a5000-surround-processor-and-mx-a5000-amplifier
post #9833 of 13500 Old 01-06-2014, 01:01 AM
CIH USER
Franin's Avatar
Liked: 1318
Thank you
Franin is offline
post #9834 of 13500 Old 01-06-2014, 03:34 AM
jjazdk's Avatar
Quoted: 34 Post(s)
Liked: 88
You are comparing apples to oranges, and have way too many variables that changes between the two setups.
Source: HTPC with JRiver
Pre: Focusrite Scarlett18i20 + 2 channel DAC
PA: April Music Stello S200 (GD1 >130Hz), 2x ICEpower 1000ASP (GD1 <130Hz), 2x ICEpower ASP1000 (Subs), Marantz MM8077 (Rear+Center+Back)
Spkr: GD1 (Front), GDA125 (2xRear+1xBack), GDA Center (Center)
Subs: 4 towers, a total of 28 x 10" 25W ScanSpeak
jjazdk is offline
post #9835 of 13500 Old 01-06-2014, 03:36 AM
TKO1's Avatar
Liked: 65
Please point me to the technical reference for this. FWIU Airplay downsamples to 16/44.1kHz (i.e. CD quality ALAC) for iOS devices while continuing to use ALAC format.
Cheers.
TKO1 is offline
post #9836 of 13500 Old 01-06-2014, 03:47 AM
Webmonkey's Avatar
Quoted: 52 Post(s)
Liked: 31
Hi Dave!
Something I felt was missing in the review was earlier comments here that the CX-A5000 had "higher output" than the AV8801. Does it play louder when used with your Parasounds than the AV8801??????
Was the AV8801 warmer and more musical sounding than the Yamaha????
Webmonkey is offline
post #9837 of 13500 Old 01-06-2014, 04:04 AM
audiofan1's Avatar
Quoted: 1651 Post(s)
Liked: 1672
audiofan1 is offline
post #9838 of 13500 Old 01-06-2014, 04:16 AM
comfynumb's Avatar
Liked: 410
Thank you
post #9839 of 13500 Old 01-06-2014, 06:19 AM
comfynumb's Avatar
Liked: 410
Cheers.
I wish there was a dedicated thread for AirPlay quality on AVS but there really isn't. For me the quality is not good enough to use all the time and I'm looking for an alternative to stream to my 8801, maybe Jriver.
post #9840 of 13500 Old 01-06-2014, 06:23 AM
CIH USER
Franin's Avatar
Liked: 1318
I wonder why they chose to go down that route.
Franin is offline
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
