Marantz AV8801 Preamp/Processor Official Owner's thread - Page 358 - AVS Forum | Home Theater Discussions And Reviews
 291Likes
Old 02-23-2014, 06:41 AM
jchong's Avatar
Liked: 32
Hi, can anybody tell me if the XLR outputs on the AV8801 are truly balanced or not?
jchong is offline
Old 02-23-2014, 08:11 AM
Waboman's Avatar
Quoted: 4581 Post(s)
Liked: 10686
Originally Posted by Franin View Post
Hey wabo man have you done the firmware upgrade yet ?
Yes sir. Just last night, as a matter of fact. Howabout you?
Waboman is online now
Old 02-23-2014, 08:38 AM
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
Not yet
_________________________
Franin is online now
Old 02-23-2014, 08:55 AM
JDOz's Avatar
Balanced at the XLR output but the signal path inside the av8801 is not fully balanced. Think that's what you mean.
JDOz is offline
Old 02-23-2014, 10:07 AM
Mad Norseman's Avatar
Liked: 101
Originally Posted by JimP View Post
I did the firmware update early today and thought the sound...didn't sound right. Unplugged power to the 8801 for a few minutes and after replugging it, it sound better but not as good as before the firmware update.
Probably just needs Audyssey to be rerun.
With that said, I don't see any improvements. If I had it to do over again, I'd not update the firmware.
An excellent 'rule of thumb' is: "NEVER run a firmware update if your component is already working the way you want it to!".
This is true for the AV8801, or any other piece of A/V gear IMO - just my two cents worth...rolleyes.gif
darthray likes this.
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
Old 02-23-2014, 01:13 PM
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Agreed, and,++1
This is why I have opted to not perform the update to my 8801.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. Datasat RA7300, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 106" Carada BW screen, Oppo BDP-103.
knobstoneaudio.com
jdlynch is offline
Old 02-23-2014, 01:24 PM
mvision7m's Avatar
Update completed this morning with no issues, changes in SQ or any prior set parameters. No problems.
mvision7m is offline
Old 02-23-2014, 02:02 PM
vince325's Avatar
Originally Posted by darthray View Post
Somehow, I thought the Home Theater EQ was only for Marantz AV8801 but finaly figure out my question and found some other stuff in the FAQ.
Here's my last setting before the movie for Sundays (can only watch a 2-3 hours movies, once a week due to work and family).
Anyone see something wrong with this or are OK with it?
Remember, small room with lots acoutics threatment and want to increase the high without killing the bass.
(click on my Avatar for some pictures at the bottom)
XT32 > Flat
MultEq >On
Home Theater EQ > Off
Dynamic EQ > On
Reference Level > 0 db
Dynamic Volume > Off
All speakers set to small > 80Hz
All comments are more than Welcome.
Ray
Ray I would have like a paper manual as well, but since one wasn't included I just went to the local copier and had them print it on 3 ring paper. I keep it in my AV cabinet so its close when ever I need to look a for reference. Vince
Thanks, Vince
Pioneer Kuro
Sony VPL-HW50
Marantz 8801
Oppo 103D
DirectV
XBOX 360
vince325 is offline
Old 02-23-2014, 03:22 PM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
Originally Posted by nixmikspop View Post
Any owners out there have problems with internet access? It was working fine the last time I used internet radio but today it kept telling me server connection failed when I tried it. I went to the network/diagnostics and it says Physical Connection OK Router Access OK but then says Internet Access Error. I reset my router, unplugged the CAT5e cable from bluray which I checked to make sure it was working properly, and plugged that into the Marantz and it still said the same thing. House internet is fine and I just can't figure this out..Any Ideas?? I did a search which didn't help. Thanks.
Has any of your internet hardware changed?
I had a connection problem when I first got my 8801 and I ended up having to get a different router than the one provided by Comcast.
Once I got my own router everything has been fine since.
Did you reset your modem or have your provider refresh your line?
Vary rarely is the 8801 the problem with internet connectivity.
David Ferebee
discodol is offline
Old 02-23-2014, 03:25 PM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
+1 Bet $15 I ever spent!! If you don't like 3 ring binders the copy places all have some plastic binder mechanism that makes a nice flat package.
David Ferebee
discodol is offline
Old 02-23-2014, 03:52 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Nice plug for Staples and copy centers everywhere. You should get a check for every schmuck who is going to do this, myself included. tongue.gif
Having a hard copy is just plain useful when doing adjustments, and beats even having it loaded to a tablet...as the tablet goes to sleep during long periods of doing nothing...like me pressing buttons and then unpressing them! eek.gif
zuluwalker is offline
Old 02-23-2014, 03:54 PM
Kal Rubinson's Avatar
Quoted: 677 Post(s)
Liked: 460
One possibility is an IP address conflict with another device on your internal network.  I am not expert but I have found this to be a problem at time with dynamically-assigned addresses.  You can reboot the entire network and that will go away but it will not prevent it from recurring.  If that is the issue, you might consider assigning a fixed IP address for the Marantz.   (I check IP addresses using FING on my iPad.)
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 02-23-2014, 04:36 PM
jchong's Avatar
Liked: 32
Yup that's what I wanted to know. Thanks.
jchong is offline
Old 02-23-2014, 04:37 PM
nixmikspop's Avatar
Thank you both very much. The funny thing is that it worked perfect at first then I rewired everything and now it won't work . I even checked the connection that went to my Blu-ray player first(which is working great)and then switched that wire to the Marantz with no luck. I did a soft reset on the Marantz and reset the modem with no luck. I have changed wires and reset the routers with no luck. I will try FING and see what happens. Thanks for the help.
nixmikspop is offline
Old 02-23-2014, 05:27 PM
Oppo Beta Group
RichB's Avatar
Quoted: 869 Post(s)
Liked: 565
Thanks for the Fing tip. It is a nice app.
I set my router to start a 100 and the rest are hard coded and I have no problems.
Another benefit is you can setup bookmarks to the Marantz (and others) configuration web pages.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
Old 02-23-2014, 05:38 PM
dlynch34's Avatar
Quoted: 252 Post(s)
Liked: 101
Yes, me too.  Think the topic came up before and I seemed to be in a very small minority.  Need to set my volume 10 dB higher than when I use my NAD M51 DAC.
Listening at -6 dB for music is "loudish but comfortable".  Think my ears should be starting to hurt a little at that setting.
I use XLR. Ran the Audyssey set up twice.
yes agree. I too am using xlr and have not listened to music since running audyssey. Not saying it sounds bad but just seems to require more juice if you will. Perhaps it is my emotiva mps-2. Thoughts to changing it out but up to now been happy with it.
Don
Marantz AV8802a,Parasound Halo A21, Emotiva XPA-1l x4,Emotiva MPS-2. Rhythmik DIY 15inch x2, Plus, Magnapan 3.7i, Magnepan CC5,Magnepan MC1,JVC RS400, DIY 125" 2:35 Elite Screen cinegray 3d .
dlynch34 is offline
Old 02-23-2014, 06:37 PM
AndyN's Avatar
Quoted: 23 Post(s)
I'm sure you all are doing this but do you make sure to change to music audyssey mode? especially is you use the same source for both music and movie. Just a thought. I love music on the 8801 vs. my 80.3. Warmer and less fatiguing. Just pleasant.
AndyN is online now
Old 02-23-2014, 07:02 PM
be83663's Avatar
My UPDATE Experience was Awesome!
My Sound Quality has just gotten More Natural and BETTER!
be83663 is offline
be83663's Avatar
be83663 is offline
Old 02-23-2014, 07:25 PM
vince325's Avatar
That great news and now I know I'm not imagining it.
Thanks, Vince
Pioneer Kuro
Sony VPL-HW50
Marantz 8801
Oppo 103D
DirectV
XBOX 360
vince325 is offline
Old 02-23-2014, 07:56 PM
JDOz's Avatar
Quick question re low volume in my set-up:  Actually, it's low even with Audyssey turned off, even in pure direct.  Still, Audyssey calibration sets all my speakers to negative trim.
If I manually raise all the trim levels by 6 dB, can you confirm that I will do no harm to Audyssey processing?
(adding 6 dB would give me trim range from -5.5 to +3.5)
JDOz is offline
Old 02-24-2014, 01:44 AM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Did the update while at lunch and not sure if I'm imagining it but my front and rear effects channels seem much more alive. I guess it could be all of them but I was watching the olympics speed skating and I was hearing the blades hit the ice all around me so cool. Any one else notice anything like this? Im running 9.2 CH just missing the front wides in my current setup.
Originally Posted by jdlynch View Post
Agreed, and,++1
You don't want to miss this one, trust me!
Natural indeed its quite breath taking in fact, its a major change in the mid and lower mid bass to great effect its far cleaner and much more defined and is a welcomed increase in weight and body! I always new these details where there and new there location in the sound filed, but they are much more pronounced due to this change . Better sound top to bottom wink.gif
I noticed this right away but wanted any chance of placebo or pseudo acoustical trickery out of the way and put it out of my mind and got on with the weekend. After watching a few movies "Escape Plan" and the first "Thor" during the beginning of EP" there was some brass playing and as I watched I thought to my self wow that's really nice to hear in a movie and sound that good! The rest of the movie delivered a great soundtrack. Now Thor I've seen but this was the first time I gave it high praise as the 8801 put on a very impressive show one upping itself and I'm not joking around here guys!
The rest of the weekend I did intentional investigation on this as this was to good to be true from a an update but I'm someone who listens to there 8801 everyday and I feel compelled to go out on a limb here and sum it up in short as to what the benefits in sound are here from the update! and need more confirmation from users! And no guys your not crazy.
Lower noise floor
Cleaner top end
greater texture from the midrange
tighter deeper bass
better overall tonality
audiofan1 is offline
Old 02-24-2014, 03:57 AM
comfynumb's Avatar
Liked: 410
Audiofan, is there any certain mode that sounds better to you? This holds true for music as well?
I haven't given my setup a good listen after the update, mainly because I've been sick.
comfynumb is offline
Old 02-24-2014, 04:07 AM
audiofan1's Avatar
Liked: 1666
Sorry to hear that hope you get better soon smile.gif Its across the board on every source I tried including the XLR input which may due to the fact it runs through the HDAM ?? I'm a bit stomped by it and will have to look over the update notes again as I can't believe the increase in Fidelity !
Old 02-24-2014, 04:30 AM
comfynumb's Avatar
Liked: 410
Wow that's great, and I know they don't always tell us every update in the actual update. They definitely try and sneak things through.
Old 02-24-2014, 05:00 AM
audiofan1's Avatar
Liked: 1666
^^^^ Yeah! it is this was announced as a major update and from looking at the changelog its some pretty extensive stuff and looks like they had to go deep into the architecture of the unit and may be the result, I'm planing on contacting them to see what info i can get on it, as you can tell its something very obvious to detect and there aren't any negatives here, all the things you love about the 8801 are still there but seriously better smile.gif
here's the changelog
6. 2/19/2014
1) Crestron update
2) Sirius XM API2.0
3) When DTS-HD MA 96k audio is streamed, there is noise or no output
4) Noise from DD+ stream from Netflix
5) WMA 11/12 files not playing
6) Noise from WAV file in NAS (Twonky Server 7) via remote app
7) MSLEFT and MSRIGHT of the AMX command
8) Noise between tracks of FLAC file
9) No communication with Buffalo LInkStation
10) No sound from SW in PURE DIRECT
11) Dialogue Enhancer set by Menu is not memorized
12) When connected Server shuts down in the Resume play of Last Sation of iRadio, the browsing of iRadio cannot be done
13) AMP ASSIGN 7.1 + Zone 2, unable to choose SB/FH/FW
Edited by exm - 2/20/14 at 9:38am
Old 02-24-2014, 05:15 AM
Quoted: 1393 Post(s)
Liked: 587
Regarding number 10) No sound from SW in Pure Direct
Isn't that what is to be expected since there is no audio processing being performed in Pure Direct? It all goes to your speakers?
JimP is offline
Old 02-24-2014, 05:21 AM
comfynumb's Avatar
Liked: 410
6. 2/19/2014
1) Crestron update
2) Sirius XM API2.0
I looked it over then other day and yeah it appears they dug pretty deep with this one.
I would appreciate if you would share what Marantz had to say.
audiofan1 likes this.
Old 02-24-2014, 05:31 AM
THX Mode's Avatar
Hi Folks,
I just updated yesterday. I'm finding that my DTS Neo X Cinema or Music doesnt show up as an option now until I put a DTS-MA disc into my Oppo 103?
When I just power on, I see PlIx + Audyssey H+W, where before I would default to DTS Neo X Cinema...?
THX Mode is offline
Old 02-24-2014, 06:10 AM
CIH USER
Franin's Avatar
Liked: 1311
Agreed, and,++1
Agree Im waiting for a couple of months before I do it, just in case...
Ken Kreisel Dxd 12012 Subwoofer , Marantz Av8801 , Receivers Amplifiers , Audyssey , Integra
